KBP4005 THRU KBP410
Reverse Voltage - 50 to 1000 Volts Forward Current - 4.0 Amperes
SINGLE BRIDGE RECTIFIERS
Features
KBP
Glass Passivated Chip Junction
Low forward voltage drop
High current capability
0.559(14.20)
0.543(13.80)
High surge current capability
0.043(1.1)
0.031(0.8)
The Plastic material-has UL flammability 94V-0
0.126(3.20)
0.118(3.00)
0.417(10.6)
0.402(10.2)
0.087(2.2)
0.071(1.8)
0.056(1.42)
0.048(1.22)
0.539(13.7)
0.500(12.7)
0.022(0.55)
0.012(0.3)
Mechanical Data
0.16(4.06)
0.14(3.56)
Case : JEDEC KBP Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.050 ounce, 1.52 grams
0.034(0.86)
0.030(0.76)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward output (With heatsink)
(Without heatsink)
rectified current at TC=100°C
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per birdge element at 4.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=125°C
I2t Rating for fusing (3ms≤t ≤8.3ms)
Typical Junction Capacitance per element (Note 2)
Typical Thermal Resistance (Note 2)
Operating junction temperature range
Storage temperature range
SYMBOLS
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
KBP4005
KBP401
KBP402
KBP404
KBP406
KBP408
KBP410
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
I(AV)
4.0
UNITS
V
V
V
A
IFSM
90
A
VF
1.1
V
IR
10
1
μA
mA
35
A2S
pF
I2t
Cj
50
RθJA
RθJC
RθJL
55
14
°C/W
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
Note:1. Mounted on glass epoxy PC board with 1.3mm 2 solder pad.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0V DC.
http://www.microdiode.com
Rev:2024A3
Page :1
KBP4005 THRU KBP410
Ratings And Characteristic Curves
Fig. 2 Maximum Non-repetitive Peak
Forward Surge Current
Fig. 1 Derating Curve for
Output Rectified Current
Peak Forward Surge
Current, Amperes
Average Forward Outp
ut Current, Amperes
120
4.0
60Hz Resistive of
Inductive Load
2.0
100
8.3ms
Single half-sine-Wave
[JEDEC Method]
90
60
30
1
100
Number of Cycles at 60HZ
150
o
Fig. 4 Typical Reverse
Characteristics
Case Temperature, C
10
Fig. 3 Typical Instantaneous
Forward Characteristics
Instantaneous Reverse
Current ,Amperes
Tc=100 C
100
40
10
4.0
1.0
0.1
TA=25 C
.01
60
80
100
120
140
Percent of Rated Peak Reverse Voltage, %
0.1
Tj=25 C
Pulse Width=300us
2% duty cycle
.01
0.6
0.7
0.8
0.9
1.0
1.1
Instantaneous
Forward Voltage,
Volts
Fig. 5 Typical Junction Capacitance
1.2
400
1.3
Capacitance, pF
Instantaneous Forward
Current, Amperes
100
10
Tj=25 C
f=1.0MHz
Ving =50mV p.p.
1
1.5
2
10
100
Reverse Voltage, Volts
The curve above is for reference only.
Rev:2024A3
Page :2
很抱歉,暂时无法提供与“KBP410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.88206
- 50+0.72398
- 100+0.71312
- 200+0.64489
- 500+0.50268
