B12WS THRU B120WS
Reverse Voltage 20 to 200Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SOD-323
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
High forward surge current capability
0.008(0.20)max.
Cathode bar
0.055(1.40)
0.016(0.40)
0.009(0.25)
0.047(1.20)
0.070 (1.80)
For use in low voltage, high frequency inverters, free
0.063 (1.40)
0.108 (2.75)
wheeling, and polarity protection applications
0.019 (0.475) ref.
Case : 6OD-323
Terminals : Solderable per MIL-STD-750,Method 2026
Weight : 0.0019 ounce, 0.00548 grams
0.10 (0.0031)
8°
0.0079 (0.20)
0° to
Mechanical Data
0.15 (0.0059)
0.016 (0.45)
0.008 (0.2 )
0.039 (1.0)
0.032 (0.8)
0.100 (2.55)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRMM
VRMS
VDC
B12WS
B14WS
B16WS
B18WS
B110WS
B112WS
B115WS
B120WS
B12S
B14S
B16S
B18S
110S
112S
115S
120S
28
40
60
42
60
80
56
80
100
70
100
120
84
120
150
105
150
200
140
200
UNITS
V
V
V
Maximum average forward rectified current
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
25
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=100℃
0.55
IR
Typical junction capacitance (NOTE 1)
Operating junction temperature range
CJ
TJ
Storage temperature range
TSTG
0.70
0.85
0.3
10
0.2
5
80
110
0.90
V
0.1
2
mA
pF
-55 to +125
-55 to +150
Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C.
http://www.microdiode.com
Rev:2024A2
Page :1
B12WS THRU B120WS
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current (uA)
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
10
4
10
3
TJ=100°C
10
2
TJ=25°C
101
10
150
80
100
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
500
TJ=25°C
10
1.0
Junction Capacitance (pF)
Instaneous Forward Current (A)
B12WS/B14WS
B16WS/B18WS
B110WS/B112WS
B115WS/B120WS
0.1
200
100
50
B12WS/B14WS
B16WS-B120WS
10
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2024A2
Page :2
B12WS THRU B120WS
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
E
F
B
A
W
P
D2
T
D1
C
W1
D
1.46
2.90
1.25
1.50
330.00
50.00
178.00
54.40
13.00
1.75
3.50
4.00
4.00
2.00
0.06
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
2.6
0.102
D
1.4
0.055
E
3.8
0.149
0.047
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“B110WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.13350
- 100+0.12460
- 300+0.11570
- 500+0.10680
- 2000+0.10235
- 5000+0.09968
- 国内价格
- 20+0.34930
- 100+0.20840
- 800+0.14580
- 3000+0.10420
- 6000+0.09900
- 30000+0.09170
