UAT26A03L05
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
UAT26A03L05 is surge rated diode arrays designed to protect high
speed data interfaces. It has been specifically designed to protect
sensitive components which is connected to data and transmission
lines from overvoltage caused by electrostatic discharge (ESD), electrical
fast transients (EFT), and lightning.
The unique design of the device incorporates one surge rated, and
four data lines. Low capacitance steering diodes and a TVS diode in
a single package. The low capacitance array configuration allows the
user to protect four high speed data or transmission lines.
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOT23-6L surface mount package
Protects four high-speed data lines and one power line
Array of surge rated, low capacitance diodes
Working voltage: 3.3V
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: B A03
6
5
4
1
2
3
Pin Configuration
Applications
USB power and data line protection
10/100/1000 Ethernet
Video line protection
I2C bus protection
HDMI interface protection
WAN/LAN equipment
ISDN S/T interface
Microcontroller input protection
Portable electronics
Maximum Ratings
Rating
Peak pulse current (tp=8/20μs waveform)
Symbol
Value
Unit
IPP
4
A
ESD voltage (Contact discharge)
±8
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:ESD-UAT26A03L05-001(A1)
TSTG ,TJ
1/5
kV
±15
-55~+150
http://brightking.pulseelectronics.com
UAT26A03L05
Electrical Characteristics (TJ=25℃)
Parameter
Symbol
Reverse stand-off voltage
Condition
Min.
Typ.
VRWM
Reverse breakdown voltage
Max.
Unit
3.3
V
VBR
IBR=1mA
4.5
V
Reverse leakage current
IR
VR=3.3V
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
8.5
V
VC
IPP=4A
15
V
Off state junction capacitance
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
0.5
pF
Applications Information
DVI connector
Tx0-
Rx0-
Tx0+
Rx0+
X
X
Tx1-
Rx1-
Tx1+
Rx1+
Tx2-
Rx2-
Tx2+
Rx2+
X
X
TCTC+
RCUAT26A03L05
RC+
DVI Data Line Protection
2/5
UAT26A03L05
ESD Protection Standards
IEC61000-4-2
Interfaces of consumer electronic equipment are widely specified according to the International Electrotechnical
Commission standard IEC61000-4-2. This standard is not targeted towards particular devices but towards general
equipment, systems and subsystems that may be involved in electrostatic discharge. consists of a 150pF capacitor
and a 330Ω series resistor representing the counterpart to the Device Under Test (DUT).
IPP
100%
330Ω
50MΩ to 100MΩ
v
high-voltage
generator
90%
DUT
150pF
10%
001aaf202
t
tr=0.7ns to 1ns
Test circuit according IEC61000-4-2
30ns
60ns
ESD surge according IEC61000-4-2
Human Body Model (HBM, MIL-883E method 3015.7)
The HBM standard simulates an ESD surge generated by human contact to electronic components.
IPP
1.5kΩ
10MΩ to 100MΩ
Ir
很抱歉,暂时无法提供与“UAT26A03L05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.50814
- 100+0.40446
- 300+0.35262
- 国内价格
- 1+0.33600
- 30+0.32400
- 100+0.31200
- 500+0.28800
- 1000+0.27600
- 2000+0.26880
- 国内价格
- 10+0.49680
- 100+0.39960
- 300+0.34560
- 3000+0.27000
- 国内价格
- 20+1.23880
- 100+0.73900
- 800+0.51730
- 3000+0.36950
- 6000+0.35100
- 30000+0.32510
- 国内价格
- 1+0.49830
- 200+0.32230
- 1500+0.27940
- 3000+0.24750
