Conductive Polymer Hybrid Capacitors
HBV
HBV Series
Features
‧105℃, 10,000 hours assured
‧Low ESR and High ripple current
‧RoHS Compliance
Marking color: Dark Green
Specifications
Items
Category Temperature Range
Capacitance Tolerance
Performance
-55℃ ~ +105℃
±20%
Leakage Current (at 20℃)
I = 0.01CV or 3 (μA) whichever is greater (after 2 minutes)
Where, C = rated capacitance in μF, V = rated DC working voltage in V
Tanδ (at 120Hz, 20℃)
See Standard Ratings
Shelf Life Test
Capacitance Change
Tanδ
ESR
Leakage Current
Resistance to Soldering Heat
(Please refer to page 25 for
reflowsoldering conditions)
Ripple Current and
Frequency Multipliers
Frequency (Hz)
120 ≦ f < 1k
1k ≦ f < 10k
10k ≦ f < 100k
100k ≦ f < 500k
Multiplier
0.1
0.3
0.6
1.0
Diagram of Dimensions
Lead Spacing and Diameter
B±0.2
φD±0.5
Within ±10% of initial value
Within specified value
A±0.2
P
C±0.2
Marking
φD = 6.3 mm
83
A5
56
25V
L
A
B
C
W
P ± 0.2
6.3
5.8 ± 0.3
6.6
6.6
7.2
0.5 ~ 0.8
2.0
6.3
7.7 ± 0.3
6.6
6.6
7.2
0.5 ~ 0.8
2.0
8
10.0 ± 0.5
8.3
8.3
9.0
0.7 ~ 1.1
3.1
8
12.0 ± 0.5
8.3
8.3
9.0
0.7 ~ 1.1
3.1
10
10.0 ± 0.5
10.3
10.3
11.0
0.7 ~ 1.3
4.7
10
12.5 ± 0.5
10.3
(*): For 6.3φ is 0.4 max.
10.3
11.0
0.7 ~ 1.3
4.7
W
0.3 max.
L
0.5 max.(*)
Unit: mm
φD
φD = 8 ~ 10 mm
Date code
Rated cap.
Rated voltage
& Series code
Negative
polarity
A5
HBV
270
35V
Date code
Series name
Rated cap.
Rated voltage
All product specifications in the catalog are subject to change without notice. (CAT. 2018E1)
83
Hybrid
Test Time
10,000 Hrs
Capacitance Change
Within ±30% of initial value
Tanδ
Less than 200% of specified value
ESR
Leakage Current
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated
ripple current for 10,000 hours at 105℃.
* After storage for 1,000 hours at 105 ± 2℃ with no voltage applied and then being stabilized at 20℃, capacitors shall meet the
limits specified in Endurance. (With voltage treatment)
Endurance
Negative
polarity
(at 120Hz, 20℃)
HBV
Dimension: φD×L(mm)
Ripple Current: mA/rms at 100k Hz, 105℃
Standard Ratings
Rated Volt.
(V)
Surge Voltage
(V)
16V (1C)
25V (1E)
35V (1V)
50V(1H)
Hybrid
63V(1J)
80V(1K)
18.4
28.8
40.3
57.5
72.5
92.0
Capacitance
(μF)
Size
φD×L(mm)
Tanδ
(120Hz, 20℃)
LC
(μA)
ESR
(mΩ/at 100kHz, 20℃ max.)
Rated R. C.
(mA/rms at 100k Hz, 105℃)
1,300
82
6.3 × 5.8
0.16
13.1
50
150
6.3 × 7.7
0.16
24
30
2,000
270
8 × 10
0.16
43.2
27
2,300
470
10 × 10
0.16
75.2
56
6.3 × 5.8
0.14
14
50
1,300
100
6.3 × 7.7
0.14
25
30
2,000
220
8 × 10
0.14
55
27
2,300
330
10 × 10
0.14
82.5
330
10 × 12.5
0.14
82.5
16
2,900
0.12
9.5
60
1,300
27
6.3 × 5.8
68
6.3 × 7.7
0.12
23.8
35
2,000
150
8 × 10
0.12
52.5
27
2,300
270
10 × 10
0.12
94.5
22
6.3 × 5.8
0.10
11
80
1,100
33
6.3 × 7.7
0.10
16.5
40
1,600
68
8 × 10
0.10
34
30
1,800
50
100
10 × 10
0.10
10
6.3 × 5.8
0.08
6.3
22
6.3 × 7.7
0.08
13.9
80
1,500
27
8 × 12
0.08
17
40
1,700
220μF
HBV
221
Series Name
Capacitance
2,000
1,000
33
8 × 10
0.08
20.8
40
1,700
56
10 × 10
0.08
35.3
30
1,800
22
8 × 10
0.08
17.6
45
1,550
33
10 × 10
0.08
26.4
36
1,700
Part Numbering System
HBV Series
28
120
±20%
M
Capacitance
Tolerance
25V
1E
Rated
Voltage
Carrier
Tape
TR
Package
Type
8φ×10L
Terminal
Type
0810
Case size
Pb-free and PET
coating case
Lead Wire and
Coating Type
Note: For more details, please refer to “Part Numbering System (SMD Type)” on page 15.
84
84
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Lelon:
HBV680M1HTR-0810 HBV330M1HTR-0608 HBV271M1VTR-1010 HBV331M1ETR-1010 HBV221M1ETR-0810
HBV220M1JTR-0608 HBV151M1VTR-0810 HBV100M1JTR-0606 HBV101M1HTR-1010 HBV330M1KTR-1010
HBV101M1ETR-0608 HBV680M1VTR-0608 HBV220M1HTR-0606
很抱歉,暂时无法提供与“HBV220M1HTR-0606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68869
- 50+1.33488
- 150+1.18325
- 1000+0.94444
- 2000+0.86440
- 5000+0.81629
- 国内价格
- 5+1.53233
- 50+1.21128
- 150+1.07369
