SMD Aluminum Electrolytic Capacitors
VEJ
Features
‧ 4 ~ 18φ, 105℃, 2,000 hours assured
‧ Designed for surface mounting on high density PC board
‧ RoHS Compliance
Marking color: Black
SPECIFICATIONS
Items
Category Temperature Range
Performance
6.3 ~ 100V
-55℃ ~ +105℃
160 ~ 450V
-40℃ ~ +105℃
(at 120Hz, 20℃)
±20%
Capacitance Tolerance
Rated voltage
Time
Case size
Leakage Current (at 20℃)
6.3 ~ 100V
after 2 minutes
160 ~ 450V
after 5 minutes
4 ~ 10φ
12.5 ~ 18φ
12.5 ~ 18φ
I = 0.01CV or 3µA,
I = 0.03CV or 4µA,
I = 0.04CV + 100µA
whichever is greater
Where, C = rated capacitance in µF
V = rated DC working voltage in V
Leakage Current
Dissipation Factor
(Tanδ at 120Hz, 20℃)
Rated Voltage 6.3
10
16
25
35
50
63
100 160 ~ 250 400 ~ 450
0.45 0.35 0.28 0.18 0.16 0.14 0.12 0.12
4 ~ 10φ
0.20
0.25
12.5 ~ 18φ 0.40 0.38 0.34 0.26 0.22 0.18 0.14 0.10
When the capacitance exceeds 1,000µF, 0.02 shall be added every 1,000µF increase.
Impedance ratio shall not exceed the values given in the table below.
Rated Voltage
6.3 10 16 25 35 50 63 100 160 ~ 250 400 ~ 450
Z(-25℃) φD<12.5 4
4
3
2
2
2
2
3
Impedance /Z(+20℃) φD≧12.5 5
4
3
2
2
2
2
2
3
6
Z(-55/-40℃ ) φD<12.5 12
Ratio
8
6
4
3
3
3
4
/Z(+20℃) φD≧12.5 10
8
6
4
3
3
3
3
6
10
Low Temperature
Characteristics (at 120Hz)
Test Time
2,000 Hrs
Within ±25% of initial value for φD ≦ 6.3mm;
Capacitance Change
Within ±20% of initial value for φD ≧ 8mm
Less than 300% of specified value for φD ≦ 6.3mm;
Dissipation Factor
Less than 200% of specified value for φD ≧ 8mm
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for
2,000 hours at 105℃.
Test time: 1,000 hours; other items are the same as those for the Endurance.
The rated voltage shall be applied to the capacitors before the measurements for 160 ~ 450V (Refer to JIS C 5101-4
4.1).
Endurance
Shelf Life Test
Freq. (Hz)
Cap. ( μF)
Under 1,000
1,000 < C ≦ 4,700
Ripple Current &
Frequency Multipliers
50
120
1k
10k up
0.80
0.85
1.00
1.00
1.25
1.15
1.40
1.25
DIAGRAM OF DIMENSIONS
Fig. 1
φD±0.5
Vent≧8φ×10L
LEAD SPACING AND DIAMETER
B± 0.2
W
L
0.3 Max
A±0.2
0.4 max
P
C±0.2
Fig. 2
φD±0.5
Vent
B±0.2
W
0.4 Max
L
A±0.2
1.0 Max
φD
4
5
6.3
6.3
8
10
10
10
12.5
12.5
16
18
L
5.7 ± 0.3
5.7 ± 0.3
5.7 ± 0.3
7.7 ± 0.3
10 ± 0.5
7.7 ± 0.3
10 ± 0.5
10.3 ± 0.5
13.5 ± 0.5
16 ± 0.5
16.5 ± 0.5
16.5 ± 0.5
A
4.3
5.3
6.6
6.6
8.4
10.4
10.4
10.4
13.0
13.0
17.0
19.0
B
4.3
5.3
6.6
6.6
8.4
10.4
10.4
10.4
13.0
13.0
17.0
19.0
C
5.1
6.1
7.4
7.4
9.2
11.2
11.2
11.2
15.0
15.0
19.0
21.0
Unit: mm
P ± 0.2 Fig. No.
W
0.5 ~ 0.8
1.0
1
0.5 ~ 0.8
1.5
1
0.5 ~ 0.8
2.0
1
0.5 ~ 0.8
2.0
1
0.7 ~ 1.1
3.1
1
0.7 ~ 1.1
4.7
1
0.7 ~ 1.1
4.7
1
0.7 ~ 1.1
4.7
1
1.1 ~ 1.4
4.4
2
1.1 ~ 1.4
4.4
2
1.1 ~ 1.4
6.4
2
1.1 ~ 1.4
6.4
2
P
C±0.2
2011 Verison
VEJ
MARKING
φD ≦ 6.3mm
Negative
polarity
φD = 8 ~ 10 mm
Date code
a1
10
16J
a1
VEJ
470
6.3V
Negative
polarity
Rated cap.
φD ≧ 12.5mm
Rated voltage
& Series code
Date code
Series name
a1
VEJ
2200
6.3V
Negative
polarity
Rated cap.
Rated voltage
Dimension: φD × L(mm)
Ripple Current: mA/rms at 120 Hz, 105°C
DIMENSION & PERMISSIBLE RIPPLE CURRENT
V. DC
6.3V (0J)
10V (1A)
63V (1J)
100V (2A)
R33
4×5.7
4
0.47
R47
4×5.7
5
4×5.7
1
010
4×5.7
8
4×5.7
8
2.2
2R2
4×5.7
12
4×5.7
12
3.3
3R3
4.7
4R7
10
100
22
220
4×5.7
22
4×5.7
33
330
5×5.7
34
47
470
5×5.7
100
101
220
221
330
331
mA
mA
mA
mA
φD×L
mA
5
φD×L
mA
3
4×5.7
14
5×5.7
17
4×5.7
17
4×5.7
17
5×5.7
6.3×5.7
22
32
4×5.7
4×5.7
5×5.7
27
6.3×5.7
32
6.3×5.7
22
5×5.7
30
5×5.7
30
6.3×5.7
44
6.3×5.7
38
6.3×7.7
58
8×10
100
5×5.7
34
5×5.7
34
6.3×5.7
46
6.3×5.7
46
6.3×7.7
65
8×10
140
10×10
150
38
5×5.7
38
6.3×5.7
48
6.3×5.7
48
6.3×7.7
80
6.3×7.7
70
8×10
170
12.5×13.5
250
6.3×5.7
69
6.3×5.7
69
6.3×5.7
69
240
8×10
210
10×10.3
310
12.5×13.5
380
120
6.3×7.7
120
6.3×7.7
120
100
270
270
8×10
6.3×7.7
6.3×7.7
8×10
10×7.7
8×10
270
10×10.3
330
12.5×13.5
470
16×16.5
450
8×10
290
8×10
10×7.7
290
290
8×10
290
10×10
370
12.5×13.5
490
16×16.5
650
18×16.5
590
320
320
410
10×10
380
10×10
380
12.5×13.5
520
12.5×16
550
16×16.5
700
12.5×13.5
550
12.5×16
550
16×16.5
800
18×16.5
990
18×16.5
1,050
8×10
290
470
471
8×10
320
1,000
102
10×10
410
8×10
10×7.7
10×10.3
2,200
222
12.5×13.5
680
12.5×13.5
680
16×16.5
900
16×16.5
900
3,300
332
12.5×16
850
16×16.5
950
16×16.5
950
18×16.5
1,150
4,700
472
16×16.5
1,000
16×16.5
1,000
18×16.5
1,225
6,800
682
18×16.5
1,290
18×16.5
1,290
V. DC
µF Contents
3.3
3R3
φD×L
50V (1H)
0.33
mA
φD×L
35V (1V)
R22
mA
φD×L
25V (1E)
0.22
Contents
φD×L
16V (1C)
φD×L
4×5.7
µF
φD×L
Date
code
Series
name
Rated
cap.
Rated
voltage
160V (2C)
φD×L
mA
200V (2D)
φD×L
mA
250V (2E)
400V (2G)
450V (2W)
φD×L
12.5×13.5
mA
60
φD×L
mA
φD×L
12.5×13.5
mA
40
4.7
4R7
12.5×13.5
65
12.5×13.5
45
12.5×13.5
45
10
100
12.5×13.5
80
12.5×13.5
70
12.5×13.5
50
12.5×16
75
22
220
12.5×16
110
12.5×13.5
105
16×16.5
85
16×16.5
85
33
330
18×16.5
100
18×16.5
100
47
100
12.5×13.5
95
12.5×16
120
16×16.5
180
470
16×16
240
16×16.5
220
16×16.5
220
101
16×16.5
250
18×16.5
280
18×16.5
260
2011 Version
很抱歉,暂时无法提供与“VEJ221M0JTR-0606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30562
- 100+0.28057
- 500+0.25551
- 1000+0.23046
- 2000+0.21376
- 4000+0.20875
