1SMA5916A
1SMA5916A
    DOWO(东沃电子)
    SMA(DO-214AC)
    耐压:4.3V 电流:5UA
1SMA5916A 数据手册
1SMA5913A - 1SMA5960A VZ : 3.3 - 200 Volts PD : 1.5 Watts SMA / DO-214AC Unit: inch ( mm ) .114 (2.90) .098 (2.50) FEATURES : .062 (1.60) .055 (1.40) * Complete Voltage Range 3.3 to 200 Volts * High peak reverse power dissipation * High reliability * Low leakage current * Pb / RoHS Free .181 (4.60) .157 (4.00) MECHANICAL DATA : * Case : SMA Molded plastic * Epoxy : UL94V-O rate flame retardant * Polarity : Color band denotes cathode end * Mounting position : Any * Weight : 0.060 gram (Approximately) .012 (.305) .096 (2.44) .078 (2.00) .006 (.152) .008(.203) .002(.051) .060 (1.52) .030 (0.76) .208 (5.28) .188 (4.80) MAXIMUM RATINGS Rating at 25C ambient temperature unless otherwise specified Rating DC Power Dissipation @ TL = 75 °C Symbol Value PD 1.5 W 20 mW/°C Measured zero lead length(1" square copper pad, FR-4 board) Unit Derate above 75 °C Thermal Resistance Junction to Lead RӨJL 50 °C/W DC Power Dissipation @ Ta = 25 °C PD 0.5 W 4.0 mW/°C Thermal Resistance Junction to Ambient RӨJA 250 °C/W Maximum Forward Voltage at IF = 200 mA VF 1.5 V TJ, TSTG - 65 to + 150 °C (FR-4 board) Derate above 25 °C Operating Junction and Storang Temperature Range PD, MAXIMUM DISSIPATION, (W) Fig. 1 POWER TEMPERATURE DERATING CURVE 1.5 1.2 0.9 TL 0.6 Ta 0.3 0 0 25 50 75 100 125 150 175 T, TEMPERATURE (°C) PAGE . 1 1SMA5913A - 1SMA5960A Rating at 25 C ambient temperature unless otherwise specified Nominal Zener Maximum Zener Voltage Impedance TYPE IZT ZZT @ IZT ZZK @ IZK VZ @ IZT (mA) (V) () () IZK (mA) 1SMA5913A 3.3 113.6 10 500 1.0 1SMA5914A 3.6 104.2 9.0 500 1.0 1SMA5915A 3.9 96.1 7.5 500 1SMA5916A 4.3 87.2 6.0 1SMA5917A 4.7 79.8 1SMA5918A 5.1 1SMA5919A Maximum Reverse Leakage Current I R @ VR (V) (A) Maximum DC Zener Current IZM (mA) 1.0 454 1.0 416 1.0 50 37.5 12.5 1.0 384 500 1.0 5.0 1.0 348 5.0 500 1.0 5.0 1.5 319 73.5 4.0 400 1.0 5.0 2.0 294 5.6 66.9 2.0 300 1.0 5.0 3.0 267 1SMA5920A 6.2 60.5 2.0 200 1.0 5.0 4.0 241 1SMA5921A 6.8 55.1 2.5 200 1.0 5.0 5.2 220 1SMA5922A 7.5 50.0 3.0 400 0.5 5.0 6.0 200 1SMA5923A 8.2 45.7 3.5 400 0.5 5.0 6.5 182 1SMA5924A 9.1 41.2 4.0 500 0.5 5.0 7.0 164 1SMA5925A 10 37.5 4.5 500 0.25 5.0 8.0 150 1SMA5926A 11 34.1 5.5 550 0.25 1.0 8.4 136 1SMA5927A 12 31.2 6.5 550 0.25 1.0 9.1 125 1SMA5928A 13 28.8 7.0 550 0.25 1.0 9.9 115 1SMA5929A 15 25.0 9.0 600 0.25 1.0 11.4 100 1SMA5930A 16 23.4 10 600 0.25 1.0 12.2 93 1SMA5931A 18 20.8 12 650 0.25 1.0 13.7 83 1SMA5932A 20 18.7 14 650 0.25 1.0 15.2 75 1SMA5933A 22 17.0 17.5 650 0.25 1.0 16.7 68 1SMA5934A 24 15.6 19 700 0.25 1.0 18.2 62 1SMA5935A 27 13.9 23 700 0.25 1.0 20.6 55 1SMA5936A 30 12.5 26 750 0.25 1.0 22.8 50 1SMA5937A 33 11.4 33 800 0.25 1.0 25.1 45 1SMA5938A 36 10.4 38 850 0.25 1.0 27.4 41 1SMA5939A 39 9.6 45 900 0.25 1.0 29.7 38 1SMA5940A 43 8.7 53 950 0.25 1.0 32.7 34 1SMA5941A 47 8.0 67 1000 0.25 1.0 35.8 31 1SMA5942A 51 7.3 70 1100 0.25 1.0 38.8 29 1SMA5943A 56 6.7 86 1300 0.25 1.0 42.6 26 1SMA5944A 62 6.0 100 1500 0.25 1.0 47.1 24 1SMA5945A 68 5.5 120 1700 0.25 1.0 51.7 22 1SMA5946A 75 5.0 140 2000 0.25 1.0 56.0 20 1SMA5947A 82 4.6 160 2500 0.25 1.0 62.2 18 1SMA5948A 91 4.1 200 3000 0.25 1.0 69.2 16 1SMA5949A 100 3.7 250 3100 0.25 1.0 76.0 15 1SMA5950A 110 3.4 300 4000 0.25 1.0 83.6 13 1SMA5951A 120 3.1 380 4500 0.25 1.0 91.2 12 1SMA5952A 130 2.9 450 5000 0.25 1.0 98.8 11 1SMA5953A 150 2.5 600 6000 0.25 1.0 114.0 10 1SMA5954A 160 2.3 700 6500 0.25 1.0 121.6 9.0 1SMA5955A 180 2.1 900 7000 0.25 1.0 136.8 8.0 1SMA5956A 200 1.9 1000 8000 0.25 1.0 152.0 7.0 1SMA5957A 220 1.7 1600 9000 0.25 1.0 167.0 6.0 1SMA5958A 240 1.55 1700 9000 0.25 1.0 182.0 5.5 1SMA5959A 250 1.5 1750 9000 0.25 1.0 189.5 5.3 1SMA5960A 270 1.4 1800 9000 0.25 1.0 205.0 5.0 Note : ( 1 ) Suffix " A " indicates ± 5.0% tolerance. PAGE . 2
1SMA5916A 价格&库存
很抱歉,暂时无法提供与“1SMA5916A”相匹配的价格&库存,您可以联系我们找货
