GBLC03C
Features
350 Watts Peak Pulse Power per Line (tp = 8/20μs)
Bidirectional Configuration
Protects One Power or I/O Port
ESD Protection > 40 kilovolts
Low Clamping Voltages
Ultra Low Capacitance: 1.0 pF Typical
IEC Compatibility (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5(Surge): 20A, 8/20μs
Mechanical Characteristics
Applications
Molded JEDEC SOD-323 package
Ethernet - 10/100/1000 Base T
Weight 10 milligrams (Approximate)
Cellular Phones
Flammability rating UL 94V-0
Handheld - Wireless Systems
8mm Tape and Reel Per EIA Standard 481
Personal Digital Assistant (PDA)
Device Marking: Marking Code
USB Interface
RoHS Compliant
PIN Configuration
BIDIRECTIONAL
Ver.: A1 2019-02-22 WA
0571-87006810
www.dowosemi.cn
1/4
GBLC03C
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp=8/20μs ) - See Figure 1
PPP
350
Watts
Operating Temperature
TJ
-55 to + 150
°C
TSTG
-55 to +150
°C
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
Electrical Characteristics
PART
NUMBER
(See Note 1
& Note 2)
GBLC03C
DEVICE
MARKING
3B
RATED
STAND-OFF
VOLTAGE
MINIMUM
BREAKDOWN
VOLTAGE
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
VWM(Volts)
@ 1mA
VBR(Volts)
@ IP = 1A
VC(Volts)
@8/20μs
VC @ IPP
3.3
4.0
7.0
19.0V @ 20.0A
MAXIMUM
LEAKAGE
CURRENT
@VWM
Id(μA)
1
TYPICAL
CAPACITANCE
@0V, 1 MHz
C(pF)
1
Note 1: Part numbers with an additional “B” suffix are bidirectional devices
Note 2: For Bidirectional Devices Only: Electrical characteristics apply in both directions.
0571-87006810
www.dowosemi.cn
2/4
GBLC03C
Typical Characteristics
0571-87006810
www.dowosemi.cn
3/4
GBLC03C
Outline Drawing – SOD323
PACKAGE OUTLINE
SOD-323
DIMENSIONS
SYMBOL
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
A
1.60
1.80
0.063
0.071
B
0.25
0.35
0.010
0.014
C
2.50
2.70
0.098
0.106
D
0.00
1.00
0.000
0.039
E
1.20
1.40
0.047
0.055
F
0.08
0.15
0.003
0.006
L
0.475 REF
0.019REF
L1
0.25
0.40
0.010
0.016
H
0.00
0.10
0.000
0.004
Notes
1. Controlling Dimensions in Millimeters.
2. Dimensions are exclusive of mold flash and metal burrs.
3B
LC
Marking Codes
Package Information
Qty:3k/Reel
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“GBLC03C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38157
- 100+0.29506
- 300+0.25175
- 3000+0.23156
- 6000+0.20553
- 9000+0.19257
- 国内价格
- 1+0.33880
- 200+0.21890
- 1500+0.19030
- 3000+0.16830
