GBLC05C
Features
800 Watts Peak Pulse Power per Line (tp = 8/20μs)
Unidirectional Configuration
Protects One Power or I/O Port
Low Clamping Voltages
Ultra Low Capacitance: 1.0 pF Typical
IEC Compatibility (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5(Lighting) 20A (8/20μs)
Mechanical Characteristics
Applications
Molded JEDEC SOD-323 package
Weight 10 milligrams (Approximate)
Ethernet - 10/100/1000 Base T
Cellular Phones
Flammability rating UL 94V-0
8mm Tape and Reel Per EIA Standard 481
Handheld - Wireless Systems
Personal Digital Assistant (PDA)
Device Marking: Marking Code
USB Interface
RoHS Compliant
PIN Configuration
2
1
UNIDIRECTIONAL
Ver.: A1 2019-03-22 WA
0571-87006810
www.dowosemi.cn
1/4
GBLC05C
Absolute Maximum Rating
Rating
Symbol
Value
Units
PPP
800
Watts
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Peak Pulse Power ( tp=8/20μs ) - See Figure 1
Operating Temperature
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
I
Parameter
IF
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
VC VBR VRWM
V
IR VF
IT
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
IPP
Electrical characteristics
PART
NUMBER
(See Note 1
& Note 2)
GBLC05C
RATED
STAND-OFF
VOLTAGE
MINIMUM
BREAKDOWN
VOLTAGE
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
MAXIMUM
LEAKAGE
CURRENT
TYPICAL
CAPACITANCE
V WM(Volts)
@ 1m A
V BR(Volts)
@ IPP = 1A
V C(Volts)
@8/20μs
VC @ IPP
@V WM
Id(μA)
@0V, 1 MHz
C(pF)
5.0
6.0
9.8
30V @ 20.0A
1
1
0571-87006810
www.dowosemi.cn
2/4
GBLC05C
Typical Characteristics
Figure 2: Power Derating Curve
10
Percent of Rated Power for Ipp
Ppp - Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
800W 8/20µs
Waveform
1
0.1
110
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ambient Temperature - TA (℃)
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
32
1.1
F=1MHz
0.9
24
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
1.0
16
0.8
0.7
0.6
0.5
0.4
0.3
8
0.2
0.1
10
15
Peak Pulse Current -Ipp(A)
Reverse Voltage -VR(V)
Figure 6: ESD Clamping( 8kV Contact per
IEC 61000-4-2)
Figure 5: Pulse Waveform
Tek Run : 5.00GS/s Sample
tr=8µs
110
Waveform
Paramters
tr=8µs
td=20µs
100
Percent Ipp
90
WE05S
C1 Max
19.0V
80
70
60
50
40
Half Value Ipp/2
30
td=20µs
10
R1
Ch1 500mV
Time (µs)
M 10.0ns Ch1
1.36V
0571-87006810
www.dowosemi.cn
3/4
GBLC05C
Outline Drawing – SOD-323
PACKAGE OUTLINE
C
A
SOD-323
DIMENSIONS
E
B
1
SYMBOL
2
D
F
H
L
L1
MOUNTING PAD
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
A
1.60
1.80
0.063
0.071
B
0.25
0.35
0.010
0.014
C
2.50
2.70
0.098
0.106
D
0.00
1.00
0.000
0.039
E
1.20
1.40
0.047
0.055
F
0.08
0.15
0.003
0.006
L
0.475 REF
0.019REF
L1
0.25
0.40
0.010
0.016
H
0.00
0.10
0.000
0.004
Notes
1. Controlling Dimensions in Millimeters.
2. Dimensions are exclusive of mold flash and metal burrs.
0.118”(3.00mm)
0.031”(0.80mm)
0.031”(0.80mm)
Marking Codes
Marking Code
05
LC
GBLC05C
Part Number
Package Information
Qty:3k/Reel
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“GBLC05C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37833
- 100+0.29798
- 300+0.25780
- 3000+0.23037
- 6000+0.20628
- 9000+0.19419
- 国内价格
- 1+0.35310
- 200+0.22770
- 1500+0.19800
- 3000+0.17490
