P4KE Series
Breakdown Voltage: 6.8 to 600 V
Peak Pulse Power: 400 W
Axial Lead
Transient Voltage Suppressors
Features
Glass passivated chip
400 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
DO-41
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-202, method
208 guranteed
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
1.000 [25.40]
MIN
DIA.
0.033 0.84
0.028 0.71
0.205 5.21
0.165 4.19
DIA.
0.117 2.97
0.090 2.29
1.000 [25.40]
MIN
Dimensions :
inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Value
Parameter
Symbol
(1)
PPP
400
Peak power dissipation with a 10/1000μs waveform
(1)
IPP
See Next Table
Peak pulse current with a 10/1000μs waveform
Power dissipation on infinite heatsink at TL = 75 °C
PD
1.0
Peak forward surge current, 8.3 ms single half sine-wave
IFSM
40
unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
VF
3.5/5.0
unidirectional only(3)
- 55 to +150
Operating junction and storage temperature range
TJ, TSTG
Unit
W
A
W
A
V
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“P4KE15CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39669
- 100+0.31893
- 300+0.28005
- 1000+0.25089
- 5000+0.20207
- 10000+0.19041
- 国内价格
- 10+0.36363
- 100+0.29235
- 1000+0.22998
- 2000+0.22653
- 5000+0.18523
