Low Voltage Detector
MD70XX SERIES
(NMOS/CMOS)
General Description
The MD70XX series is a set of three-terminal low power
voltage detectors implemented in CMOS technology. Each
voltage detector in the series detects a particular fixed
voltage ranging from 1.2V to 7V. The voltage detectors
consist of a high-precision and low power consumption
standard voltage source, a comparator, hysteresis circuit, and
an output driver. CMOS technology ensures low power
consumption. Although designed primarily as fixed voltage
detectors, these devices can be used with external
components to detect user specified threshold voltages
Features
Applications
·Low power consumption
·Low temperature coefficient
·Built-in high-stability reference source
·Open drain types:
NMOS: MD70XX
CMOS: 70XXC
·Built-in hysteresis characteristic
·TO-92 package
·SOT-89 package
·SOT-23-3/5 package
·SSOT-24 package
·Battery checkers
·Level selectors
·Power failure detectors
·Microcomputer reset
·Battery memory backup
·Non-volatile RAM signal storage protectors
· SSOT-24
packageRatings
Absolute
Maximum
Supply Voltage.................... ............. -0.3V to 18V
Output Voltage ..................VSS-0.3V to VDD+0.3V
Storage Temperature.......................-50℃to 125℃
Operating Temperature..............-40℃to 85℃
Output Current......................... 10mA
Power Consumption:
SOT89-3
500mW
TO-92
300mW
SOT23-/5
250mW
Note: These are stress ratings only. Stresses exceeding the range specified under _Absolute Maximum
Ratings_ may cause substantial damage to the device. Functional operation of this device at other
conditions beyond those listed in the specification is not implied and prolonged exposure to extreme
conditions may affect device reliability.
1
MD70XX SERIES
(NMOS/CMOS)
Selection Table
Part No.
Detectable
Voltage
Hysteresis
Width
Tolerance
MD7015
MD7019
MD7020
MD7021
MD7022
MD7023
MD7024
MD7027
MD7030
MD7033
MD7035
MD7036
MD7039
MD7042
MD7043
MD7044
MD7047
MD7050
1.5V
1.9V
2.0V
2.1V
2.2V
2.3V
2.4V
2.7V
3.0V
3.3V
3.5V
3.6V
3.9V
4.2V
4.3V
4.4V
4.7V
5.0V
0.075V
0.095V
0.100V
0.105V
0.110V
0.115V
0.120V
0.135V
0.150V
0.165V
0.175V
0.180V
0.195V
0.210V
0.215V
0.220V
0.235V
0.250V
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
±3%
MD7070
7.0V
0.350V
±3%
MD7025C
MD7027C
MD7030C
MD7033C
2.5V
2.7V
3.0V
3.3V
0.125V
0.135V
0.150V
0.165V
±3%
±3%
±3%
±3%
Marking
TO92/SOT89-3
SOT23-3/5
70XX
0XX
NMOS
Drain
output
70XXC
CMOS
output
70XXC
For example: The MD7044 is a 4.4V, NMOS open drain active low output
For semi-custom parts,selectable regulated voltage range is from 1.2V to 12V in 0.1V increment.
For semi-custom parts,selectable output type CMOS .
2
MD70XX SERIES
(NMOS/CMOS)
Block Diagram
N channel open drain output (normal open; active low)
CMOS output (normal high; active low)
3
MD70XX SERIES
(NMOS/CMOS)
Logical Characteristic(NMOS/CMOS TYPE)
(1) Solid Line ......VIN from Hi→Lo
(2) Dash Line ......VIN from Lo→Hi
Pin Assignment
TO-92L
SOT 89-3L
SOT 23-3L
NC
SOT23-5
NC
VDD
VOUT
VDD
GND
VOUT
VOUT VDD GND
4
GND
VOUT
VDD
GND
MD70XX SERIES
(NMOS/CMOS)
Electrical Characteristic
MD7015
Symbol
Parameter
Test Conditions
VDD
Conditions
VDET
VHYS
Hi→Lo Detectable Voltage
Hysteresis Width
IDD
VDD
IOL
△V DET
△T A
Operating Current
Operating Voltage
Output Sink Current
Temperature Coefficient
2.5
-1.4
No load
-VOUT=0.2V
0℃
很抱歉,暂时无法提供与“MD7030-SOT-23-3L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.32914
- 30+0.31779
- 100+0.29509
- 500+0.27239
- 1000+0.26104
