P25Q80L-UVH-IR
P25Q80L-UVH-IR
    PUYA(普冉)
    USON-8-EP(2x3)
    超低功耗,8 m位串行多I/O闪存
P25Q80L-UVH-IR 数据手册
P25Q80L Datasheet P25Q80L Ultra Low Power, 8M-bit Serial Multi I/O Flash Memory Datasheet Mar. 27, 2019 Performance Highlight  Wide Supply Range from 1.65 to 2.0V for Read, Erase and Program  Ultra Low Power consumption for Read, Erase and Program  X1, X2 and X4 Multi I/O Support  High reliability with 100K cycling and 20 Year-retention Puya Semiconductor (Shanghai) Co., Ltd Puya Semiconductor Page 1 of 68 P25Q80L Datasheet Contents 1 2 3 Overview ........................................................................................................................................................4 Description .....................................................................................................................................................5 Pin Definition .................................................................................................................................................6 3.1 Pin Configurations .............................................................................................................................6 3.2 Pin Descriptions .................................................................................................................................6 4 Block Diagram ...............................................................................................................................................7 5 Electrical Specifications .................................................................................................................................8 5.1 Absolute Maximum Ratings ...............................................................................................................8 5.2 DC Characteristics .............................................................................................................................9 5.3 AC Characteristics .......................................................................................................................... 10 5.4 AC Characteristics for Program and Erase ..................................................................................... 11 5.5 Operation Conditions ...................................................................................................................... 13 6 Data Protection ........................................................................................................................................... 15 7 Memory Address Mapping .......................................................................................................................... 17 8 Device Operation ........................................................................................................................................ 18 9 Hold Feature ............................................................................................................................................... 20 10 Commands ......................................................................................................................................... 21 10.1 Commands listing ........................................................................................................................... 21 10.2 Write Enable (WREN) ..................................................................................................................... 23 10.3 Write Disable (WRDI) ....................................................................................................................... 23 10.4 Write Enable for Volatile Status Register ....................................................................................... 24 10.5 Read Status Register (RDSR) .......................................................................................................... 24 10.6 Read Configure Register (RDCR) .................................................................................................... 26 10.7 Active Status Interrupt (ASI) ........................................................................................................... 27 10.8 Write Status Register (WRSR) ......................................................................................................... 27 10.9 Write Configure Register (WRCR) .................................................................................................... 28 10.10 Read Data Bytes (READ) ................................................................................................................. 29 10.11 Read Data Bytes at Higher Speed (FAST_READ) ............................................................................ 29 10.12 Dual Read Mode (DREAD) .............................................................................................................. 30 10.13 2 X IO Read Mode (2READ) ............................................................................................................ 31 10.14 2 X IO Read Performer Enhance Mode ............................................................................................ 31 10.15 Quad Read Mode (QREAD) ............................................................................................................. 33 10.16 4 X IO Read Mode (4READ) ............................................................................................................ 34 10.17 4 X IO Read Performance Enhance Mode ....................................................................................... 35 10.18 Burst Read....................................................................................................................................... 36 10.19 Page Erase (PE) .............................................................................................................................. 37 10.20 Sector Erase (SE) ............................................................................................................................ 37 10.21 Block Erase (BE32K) ....................................................................................................................... 38 10.22 Block Erase (BE).............................................................................................................................. 38 10.23 Chip Erase (CE)............................................................................................................................... 39 10.24 Page Program (PP).......................................................................................................................... 39 10.25 Dual Input Page Program (DPP) ...................................................................................................... 41 10.26 Quad Page Program (QPP) ............................................................................................................. 41 10.27 Erase Security Registers (ERSCUR) ................................................................................................ 42 10.28 Program Security Registers (PRSCUR) ........................................................................................... 43 10.29 Read Security Registers (RDSCUR) ................................................................................................ 44 10.30 Deep Power-down (DP) ................................................................................................................... 45 10.31 Release form Deep Power-Down (RDP), Read Electronic Signature (RES) ...................................... 45 10.32 Read Electronic Manufacturer ID & Device ID (REMS) ..................................................................... 46 10.33 Dual I/O Read Electronic Manufacturer ID & Device ID (DREMS) .................................................... 47 Puya Semiconductor Page 2 of 68 P25Q80L Datasheet 11 12 13 14 10.34 Quad I/O Read Electronic Manufacturer ID & Device ID (QREMS)................................................... 47 10.35 Read Identification (RDID)................................................................................................................ 48 10.36 Program/Erase Suspend/Resume .................................................................................................... 49 10.37 Erase Suspend to Program .............................................................................................................. 51 10.38 Program Resume and Erase Resume .............................................................................................. 51 10.39 No Operation (NOP) ........................................................................................................................ 51 10.40 Software Reset (RSTEN/RST) ......................................................................................................... 52 10.41 Read Unique ID (RUID) ................................................................................................................... 52 10.42 Read SFDP Mode (RDSFDP) .......................................................................................................... 53 Ordering Information........................................................................................................................... 58 Valid Part Numbers and Top Marking ................................................................................................. 59 Package Information........................................................................................................................... 60 13.1 8-Lead SOP(150mil) ....................................................................................................................... 60 13.2 8-Lead SOP(208mil) ....................................................................................................................... 61 13.3 8-Lead TSSOP ............................................................................................................................... 62 13.4 8-Land USON(3x2x0.55mm) .......................................................................................................... 63 13.5 8-Land USON(3x2x0.45mm) .......................................................................................................... 64 13.6 8-Land USON(3x4x0.55mm) .......................................................................................................... 65 13.7 8-Land WSON(6x5x0.75mm) ......................................................................................................... 66 Revision History.................................................................................................................................. 67 Puya Semiconductor Page 3 of 68 P25Q80L Datasheet 1 Overview General  Single 1.65V to 2.0V supply  Industrial Temperature Range -40C to 85C  Serial Peripheral Interface (SPI) Compatible: Mode 0 and Mode 3  Single, Dual and Quad IO mode  - 8M x 1 bit - 4M x 2 bits - 2M x 4 bits Flexible Architecture for Code and Data Storage - Uniform 256-byte Page Program - Uniform 256-byte Page Erase - Uniform 4K-byte Sector Erase - Uniform 32K/64K-byte Block Erase - Full Chip Erase  Hardware Controlled Locking of Protected Sectors by WP Pin  One Time Programmable (OTP) Security Register 3*512-Byte Security Registers With OTP Lock  128 bit unique ID for each device  Fast Program and Erase Speed - 2ms Page program time - 8ms Page erase time - 8ms 4K-byte sector erase time - 8ms 32K-byte block erase time - 8ms 64K-byte block erase time  JEDEC Standard Manufacturer and Device ID Read Methodology  Ultra Low Power Consumption   - 0.1uA Deep Power Down current - 9uA Standby current - 2.5mA Active Read current at 33MHz - 3.0mA Active Program or Erase current High Reliability - 100,000 Program / Erase Cycles - 20-year Data Retention Industry Standard Green Package Options - 8-pin SOP (150mil/208mil) - 8-land USON (3x2x0.55mm/3x2x0.45mm/3x4x0.55mm) - 8-land WSON (6x5x0.75mm) - 8-pin TSSOP - WLCSP - KGD for SiP Puya Semiconductor Page 4 of 68 P25Q80L Datasheet 2 Description The P25Q80L is a serial interface Flash memory device designed for use in a wide variety of high-volume consumer based applications in which program code is shadowed from Flash memory into embedded or external RAM for execution. The flexible erase architecture of the device, with its page erase granularity it is ideal for data storage as well, eliminating the need for additional data storage devices. The erase block sizes of the device have been optimized to meet the needs of today's code and data storage applications. By optimizing the size of the erase blocks, the memory space can be used much more efficiently. Because certain code modules and data storage segments must reside by themselves in their own erase regions, the wasted and unused memory space that occurs with large sectored and large block erase Flash memory devices can be greatly reduced. This increased memory space efficiency allows additional code routines and data storage segments to be added while still maintaining the same overall device density. The device also contains an additional 3*512-byte security registers with OTP lock (One-Time Programmable), can be used for purposes such as unique device serialization, system-level Electronic Serial Number (ESN) storage, locked key storage, etc. Specifically designed for use in many different systems, the device supports read, program, and erase operations with a wide supply voltage range of 1.65V to 2.0V. No separate voltage is required for programming and erasing. Puya Semiconductor Page 5 of 68 P25Q80L Datasheet 3 Pin Definition 3.1 Pin Configurations CS# 1 8 VCC SO 2 7 HOLD# WP# 3 6 SLCK 4 5 SI GND CS# 1 8 VCC SO 2 7 HOLD# WP# 3 6 SLCK 4 5 SI GND 8-PIN SOP (150mil/208mil) and TSSOP 8-Land USON (3x2mm//3x4mm/6x5mm) 3.2 Pin Descriptions No. Symbol 1 CS# 2 SO SIO1 3 WP# SIO2 4 GND - 5 SI SIO0 6 SCLK - 7 HOLD# SIO3 8 Vcc - Puya Semiconductor Extension Remarks Chip select Serial data output for 1 x I/O Serial data input and output for 4 x I/O read mode Write protection active low Serial data input and output for 4 x I/O read mode Ground of the device Serial data input for 1x I/O Serial data input and output for 4 x I/O read mode Serial interface clock input To pause the device without deselecting the device Serial data input and output for 4 x I/O read mode Power supply of the device Page 6 of 68 P25Q80L Datasheet 4 Block Diagram CS# High Voltage Generator Serial Bus Control Logic SCK Data buffer SI SO Control & Logic WP# Address Latch X -DECODER Interface Flash Memory Array HOLD# Serial MUX & I/O buffers Control and Protection logic VCC GND Puya Semiconductor Y-DECODER Page 7 of 68 P25Q80L Datasheet 5 Electrical Specifications 5.1 Absolute Maximum Ratings NOTICE: Stresses above those listed under “Absolute  Storage Temperature .......................-65°C to +150°C  Operation Temperature ....................-40°C to +85°C  Maximum Operation Voltage............. 2.5V  Voltage on Any Pin with Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at those or any other conditions above those indicated in the operational listings of this specification is not respect to Ground. ..........................-0.6V to + 2.5V  implied. Exposure to maximum rating conditions for DC Output Current ............................5.0 mA extended periods may affect device reliability. Table 5-1 Pin Capacitance [1] Symbol Parameter Max. Units Test Condition COUT Output Capacitance 8 pF VOUT=GND CIN Input Capacitance 6 pF VIN=GND Note: 1. Test Conditions: TA = 25°C, F = 1MHz, Vcc = 1.8V. Figure 5-1 Maximum Overshoot Waveform Maximum Negative Overshoot Waveform Maximum Positive Overshoot Waveform VCC+0.5V 20ns 0V VCC 20ns - 0.6V Figure 5-2 Input Test Waveforms and Measurement Level Input timing reference level 0.8VCC Output timing reference level 0.7VCC AC MeasurementLevel 0.5VCC 0.3VCC 0.2VCC Note:Input pulse rise and fall time ara < 5ns Figure 5-3 Output Loading DEVICE UNDER TEST 25K ohm VCC CL 25K ohm CL = 15/30pF Including jig capacitance Puya Semiconductor Page 8 of 68 P25Q80L Datasheet 5.2 DC Characteristics Table 5-2 DC parameters(Ta=-40°C to +85°C) Sym. Parameter IDPD Deep power down current ISB Standby current ICC1 Low power read current (03h) ICC2 Read current (0Bh) ICC3 ICC4 Conditions 1.65V to 2.0V Min. CS#=Vcc, all other inputs at 0V or Vcc CS#, HOLD#, WP#=VIH all inputs at CMOS levels Typ. Max. 0.1 0.6 9 Units uA uA f=1MHz; IOUT=0mA 1.0 2.0 mA f=33MHz; IOUT=0mA 1.0 2.0 mA f=50MHz; IOUT=0mA 1.5 2.5 mA f=85MHz; IOUT=0mA 2.0 3.0 mA Program current CS#=Vcc 2.0 4.0 mA Erase current CS#=Vcc 2.0 4.0 mA ILI Input load current All inputs at CMOS level 1.0 uA ILO Output leakage All inputs at CMOS level 1.0 uA VIL Input low voltage 0.2Vcc V VIH Input high voltage VOL Output low voltage IOL=100uA VOH Output high voltage IOH=-100uA 0.8Vcc V 0.2 Vcc-0.2 V V Note: 1. Typical values measured at 1.8V @ 25°C Puya Semiconductor Page 9 of 68 P25Q80L Datasheet 5.3 AC Characteristics Table 5-3 AC parameters(Ta=-40°C to +85°C) Symbol Alt. Parameter 1.65V~2.0V min. max. Unit D.C. 85 MHz Clock Frequency for the following instructions: FAST_READ, fSCLK fC RDSFDP, PP, SE, BE32K, BE, CE, DP, RES, WREN, WRDI, RDID, RDSR, WRSR(7) fRSCLK fR Clock Frequency for READ instructions 33 MHz fTSCLK fT Clock Frequency for 2READ,DREAD,QREAD instructions 85 MHz fQ Clock Frequency for 4READ instructions 70 MHz 85 MHz fQPP Clock Frequency for QPP (Quad page program) tCH(1) tCLH Clock High Time 5.5 ns tCL(1) tCLL Clock Low Time (fSCLK) 45% x (1fSCLK) 5.5 ns tCLCH(7) Clock Rise Time (peak to peak) 0.1 v/ns tCHCL(7) Clock Fall Time (peak to peak) 0.1 v/ns CS# Active Setup Time (relative to SCLK) 5 ns CS# Not Active Hold Time (relative to SCLK) 5 ns tSLCH tCSS tCHSL tDVCH tDSU Data In Setup Time 2 ns tCHDX tDH Data In Hold Time 3 ns tCHSH CS# Active Hold Time (relative to SCLK) 5 ns tSHCH CS# Not Active Setup Time (relative to SCLK) 5 ns CS# Deselect Time From Read to next Read 15 ns 30 ns tSHSL tCSH CS# Deselect Time From Write,Erase,Program to Read Status Register tSHQZ(7) tDIS tCLQV tV tCLQX tHO Output Disable Time 6 ns Clock Low to Output Valid Loading 30pF 7 ns 6 ns Clock Low to Output Valid Loading 15pF Output Hold Time 0 ns tHLCH HOLD# Active Setup Time (relative to SCLK) 5 ns tCHHH HOLD# Active Hold Time (relative to SCLK) 5 ns tHHCH HOLD# Not Active Setup Time (relative to SCLK) 5 ns tCHHL HOLD# Not Active Hold Time (relative to SCLK) 5 ns tHHQX tLZ HOLD# to Output Low-Z 6 ns tHLQZ tHZ HOLD# to Output High-Z 6 ns tWHSL(3) Write Protect Setup Time 20 tSHWL(3) Write Protect Hold Time 100 tDP ns ns CS# High to Deep Power-down Mode 3 us tRES1 CS# High To Standby Mode Without Electronic Signature Read 8 us tRES2 CS# High To Standby Mode With Electronic Signature Read tW Write Status Register Cycle Time Reset recovery time(for erase/program operation except tReady WRSR) Reset recovery time(for WRSR operation) Puya Semiconductor 8 30 12 8 us 12 ms us 8 ms Page 10 of 68 P25Q80L Datasheet 5.4 AC Characteristics for Program and Erase Table 5-4 AC parameters for program and erase(Ta=-40°C to +85°C) Sym. 1.65V to 2.0V Parameter Min. Typ. Max. Units TESL(6) Erase Suspend Latency 30 us TPSL(6) Program Suspend Latency 30 us TPRS(4) Latency between Program Resume and next Suspend 0.3 us TERS(5) Latency between Erase Resume and next Suspend 0.3 us tPP Page program time (up to 256 bytes) 2 3 ms tPE Page erase time 8 20 ms tSE Sector erase time 8 20 ms tBE1 Block erase time for 32K bytes 8 20 ms tBE2 Block erase time for 64K bytes 8 20 ms tCE Chip erase time 8 20 ms Note: 1. tCH + tCL must be greater than or equal to 1/ Frequency. 2. Typical values given for TA=25°C. Not 100% tested. 3. Only applicable as a constraint for a WRSR instruction. 4. Program operation may be interrupted as often as system request. The minimum timing of tPRS must be observed before issuing the next program suspend command. However, in order for an Program operation to make progress, tPRS ≥ 100us must be included in resume-to-suspend loop(s). Not 100% tested. 5. Erase operation may be interrupted as often as system request. The minimum timing of tERS must be observed before issuing the next erase suspend command. However, in order for an Erase operation to make progress, tERS ≥ 100us must be included in resume-to-suspend loop(s). Notes. Not 100% tested. 6. Latency time is required to complete Erase/Program Suspend operation. 7. The value guaranteed by characterization, not 100% tested in production. Figure 5-4 Serial Input Timing tSHSL CS# tCHSL tSLCH tCLH tCLL tCHSH tSHCH SCLK tDVCH tCHDX SI MSB SO High-Z Puya Semiconductor tCHCL tCLCH LSB Page 11 of 68 P25Q80L Datasheet Figure 5-5 Output Timing CS# tCLH SCLK tCLQV tCLQV tCLQX tSHQZ tCLL tCLQX tQLQH SO LSB tQHQL SI Least significant address bit (LIB) in Figure 5-6 Hold Timing CS# tCHHL SCLK tHLCH tHLQZ SO tCHHH tHHCH tHHQX HOLD# SI do not care during HOLD operation. Figure 5-7 WP Timing CS# tWHSL tSHWL WP# SCLK SI Write status register is allowed Puya Semiconductor Write status register is not allowed Page 12 of 68 P25Q80L Datasheet 5.5 Operation Conditions At Device Power-Up and Power-Down AC timing illustrated in "Figure AC Timing at Device Power-Up" and "Figure Power-Down Sequence" are for the supply voltages and the control signals at device power-up and power-down. If the timing in the figures is ignored, the device will not operate correctly. During power-up and power-down, CS# needs to follow the voltage applied on VCC to keep the device not to be selected. The CS# can be driven low when VCC reach Vcc(min.) and wait a period of tVSL. Figure 5-8 VCC AC Timing at Device Power-Up VCC(min) GND tVR tSHSL CS# tCHSL tSLCH tCHSH tSHCH SCLK tDVCH tCHCL tCHDX LSB MSB SI tCLCH High-Z SO Figure 5-9 Power-up Timing Vcc(max) Chip Selection is not allowed Vcc(min) tVSL Device is fully accessible VWI Time Puya Semiconductor Page 13 of 68 P25Q80L Datasheet Power Up/Down and Voltage Drop For Power-down to Power-up operation, the VCC of flash device must below VPWD for at least tPWD timing. Please check the table below for more detail. Figure 5-10 Power down-up Timing Vcc(max) Chip Selection is not allowed Vcc(min) tVSL VPWD(max) Device is fully accessible tPWD Time Symbol Parameter VPWD VCC voltage needed to below VPWD for ensuring initialization will occur tPWD tVSL tVR VWI The minimum duration for ensuring initialization will occur VCC(min.) to device operation VCC Rise Time Write Inhibit Voltage min 300 70 1 1.45 max unit 1 V 500000 1.55 us us us/V V Initial Delivery State The device is delivered with the memory array erased: all bits are set to 1 (each byte contains FFh). The Status Register contains 00h (all Status Register bits are 0). Puya Semiconductor Page 14 of 68 P25Q80L Datasheet 6 Data Protection During power transition, there may be some false system level signals which result in inadvertent erasure or programming. The device is designed to protect itself from these accidental write cycles. The state machine will be reset as standby mode automatically during power up. In addition, the control register architecture of the device constrains that the memory contents can only be changed after specific command sequences have completed successfully. In the following, there are several features to protect the system from the accidental write cycles during VCC power-up and power-down or from system noise. • Power-on reset: to avoid sudden power switch by system power supply transition, the power-on reset may protect the Flash. • Valid command length checking: The command length will be checked whether it is at byte base and completed on byte boundary. • Write Enable (WREN) command: WREN command is required to set the Write Enable Latch bit (WEL) before issuing other commands to change data. • Software Protection Mode: The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits define the section of the memory array that can be read but not change. • Hardware Protection Mode: WP# going low to protected the BP0~BP4bits and SRP0~1bits • Deep Power-Down Mode: By entering deep power down mode, the flash device is under protected from writing all commands except the Release form Deep Power-Down Mode command. Table 6-1. Protected Area Sizes P25Q80L Protected Area Sizes (CMP bit = 0) Status bit Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 15 0F0000H-0FFFFFH 64KB Upper 1/16 0 0 0 1 0 14 and 15 0E0000H-0FFFFFH 128KB Upper 1/8 0 0 0 1 1 12 to 15 0C0000H-0FFFFFH 256KB Upper 1/4 0 0 1 0 0 8 to 15 080000H-0FFFFFH 512KB Upper 1/2 0 1 0 0 1 0 000000H-00FFFFH 64KB Lower 1/16 0 1 0 1 0 0 and 1 000000H-01FFFFH 128KB Lower 1/8 0 1 0 1 1 0 to 3 000000H-03FFFFH 256KB Lower 1/4 0 1 1 0 0 0 to 7 000000H-07FFFFH 512KB Lower 1/2 0 x 1 0 1 0 to 15 000000H-0FFFFFH 1MB ALL x x 1 1 x 0 to 15 000000H-0FFFFFH 1MB ALL 1 0 0 0 1 15 0FF000H-0FFFFFH 4KB Upper 1/256 1 0 0 1 0 15 0FE000H-0FFFFFH 8KB Upper 1/128 1 0 0 1 1 15 0FC000H-0FFFFFH 16KB Upper 1/64 1 0 1 0 x 15 0F8000H- 0FFFFFH 32KB Upper 1/32 1 1 0 0 1 0 000000H-000FFFH 4KB Lower 1/256 1 1 0 1 0 0 000000H-001FFFH 8KB Lower 1/128 1 1 0 1 1 0 000000H-003FFFH 16KB Lower 1/64 1 1 1 0 x 0 000000H-007FFFH 32KB Lower 1/32 Puya Semiconductor Page 15 of 68 P25Q80L Datasheet P25Q80L Protected Area Sizes (CMP bit = 1) Status bit Memory Content BP4 BP3 BP2 BP1 BP0 Blocks Addresses Density Portion x x 0 0 0 0 to 15 000000H-0FFFFFH 1MB ALL 0 0 0 0 1 0 to 14 000000H-0EFFFFH 960KB Lower 15/16 0 0 0 1 0 0 to 13 000000H-0DFFFFH 896KB Lower 7/8 0 0 0 1 1 0 to 11 000000H-0BFFFFH 768KB Lower 3/4 0 0 1 0 0 0 to 7 000000H-07FFFFH 512KB Lower 1/2 0 1 0 0 1 1 to 15 010000H-0FFFFFH 960KB Upper 15/16 0 1 0 1 0 2 to 15 020000H-0FFFFFH 896KB Upper 7/8 0 1 0 1 1 4 to 15 040000H-0FFFFFH 768KB Upper 3/4 0 1 1 0 0 8 to 15 080000H-0FFFFFH 512KB Upper 1/2 0 x 1 0 1 NONE NONE NONE NONE x x 1 1 x NONE NONE NONE NONE 1 0 0 0 1 0 to 15 000000H-0FEFFFH 1020KB Lower 255/256 1 0 0 1 0 0 to 15 000000H-0FDFFFH 1016KB Lower 127/128 1 0 0 1 1 0 to 15 000000H-0FBFFFH 1008KB Lower 63/64 1 0 1 0 x 0 to 15 000000H-0F7FFFH 992KB Lower 31/32 1 1 0 0 1 0 to 15 001000-0FFFFFH 1020KB Upper 255/256 1 1 0 1 0 0 to 15 002000-0FFFFFH 1016KB Upper 127/128 1 1 0 1 1 0 to 15 004000-0FFFFFH 1008KB Upper 63/64 1 1 1 0 x 0 to 15 008000-0FFFFFH 992KB Upper 31/32 Note: 1. X=don’t care 2. If any erase or program command specifies a memory that contains protected data portion, this command will be ignored. Puya Semiconductor Page 16 of 68 P25Q80L Datasheet 7 Memory Address Mapping The memory array can be erased in three levels of granularity including a full chip erase. The size of the erase blocks is optimized for both code and data storage applications, allowing both code and data segments to reside in their own erase regions. P25Q80L Memory Organization Block64K …… …… Puya Semiconductor 1-0 0 …… 3-2 1 …… 5-4 2 29 - 28 14 31 - 30 15 Block32K Sector Address Range 255 0FF000H 0FFFFFH …… …… …… 240 0F0000H 0F0FFFH 239 0EF000H 0EFFFFH …… …… …… 224 0E0000H 0E0FFFH …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000H 02FFFFH …… …… …… 32 020000H 020FFFH 31 01F000H 01FFFFH …… …… …… 16 010000H 010FFFH 15 00F000H 00FFFFH …… …… …… 0 000000H 000FFFH Page 17 of 68 P25Q80L Datasheet 8 Device Operation Before a command is issued, status register should be checked to ensure device is ready for the intended operation. When incorrect command is inputted to this LSI, this LSI becomes standby mode and keeps the standby mode until next CS# falling edge. In standby mode, SO pin of this LSI should be High-Z. When correct command is inputted to this LSI, this LSI becomes active mode and keeps the active mode until next CS# rising edge. Input data is latched on the rising edge of Serial Clock (SCLK) and data shifts out on the falling edge of SCLK. The difference of serial peripheral interface mode 0 and mode 3 is shown as Figure 8-1. For the following instructions: RDID, RDSR, RDSR1, RDSCUR, READ, FAST_READ, DREAD, 2READ, 4READ, QREAD, RDSFDP, RES, REMS, DREMS, QREMS, the shifted-in instruction sequence is followed by a data-out sequence. After any bit of data being shifted out, the CS# can be high. For the following instructions: WREN, WRDI, WRSR, PE, SE, BE32K, BE, CE, PP, DPP, QPP, DP, ERSCUR, PRSCUR, SUSPEND, RESUME, RSTEN, RST, the CS# must go high exactly at the byte boundary; otherwise, the instruction will be rejected and not executed. During the progress of Write Status Register, Program, Erase operation, to access the memory array is neglected and not affect the current operation of Write Status Register, Program, Erase. Figure 8-1 Serial Peripheral Interface Modes Supported CPOL CPHA shift in (Serial mode 0) 0 0 SCLK (Serial mode 3) 1 1 SCLK SI SO shift out MSB MSB Note: CPOL indicates clock polarity of serial master, CPOL=1 for SCLK high while idle, CPOL=0 for SCLK low while not transmitting. CPHA indicates clock phase. The combination of CPOL bit and CPHA bit decides which serial mode is supported. Standard SPI The P25Q80L features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Dual SPI The P25Q80L supports Dual SPI operation when using the “Dual Output Fast Read” and “Dual I/O Fast Read”(3BHand BBH) commands. These commands allow data to be transferred to or from the device at two times the rate of the standard SPI. When using the Dual SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. Puya Semiconductor Page 18 of 68 P25Q80L Datasheet Quad SPI The P25Q80L supports Quad SPI operation when using the “Quad Output Fast Read”,” Quad I/O Fast Read”(6BH,EBH) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1, and WP# and HOLD# pins become IO2 andIO3. Quad SPI commands require the non-volatile Quad Enable bit(QE) in Status Register to be set. Puya Semiconductor Page 19 of 68 P25Q80L Datasheet 9 Hold Feature HOLD# pin signal goes low to hold any serial communications with the device. The HOLD feature will not stop the operation of write status register, programming, or erasing in progress. The operation of HOLD requires Chip Select(CS#) keeping low and starts on falling edge of HOLD# pin signal while Serial Clock (SCLK) signal is being low (if Serial Clock signal is not being low, HOLD operation will not start until Serial Clock signal being low). The HOLD condition ends on the rising edge of HOLD# pin signal while Serial Clock(SCLK) signal is being low( if Serial Clock signal is not being low, HOLD operation will not end until Serial Clock being low). Figure 9-1 Hold Condition Operation CS# SCLK HOLD# HOLD HOLD During the HOLD operation, the Serial Data Output (SO) is high impedance when Hold# pin goes low and will keep high impedance until Hold# pin goes high. The Serial Data Input (SI) is don't care if both Serial Clock (SCLK) and Hold# pin goes low and will keep the state until SCLK goes low and Hold# pin goes high. If Chip Select (CS#) drives high during HOLD operation, it will reset the internal logic of the device. To re-start communication with chip, the HOLD# must be at high and CS# must be at low. Note: The HOLD feature is disabled during Quad I/O mode. Puya Semiconductor Page 20 of 68 P25Q80L Datasheet 10 Commands 10.1 Commands listing Figure 10-1 Command set Abbr. Code ADR Bytes DMY Bytes Data Bytes Read Array (fast) FREAD 0Bh 3 1 1+ n bytes read out until CS# goes high Read Array (low power) READ 03h 3 0 1+ n bytes read out until CS# goes high Read Dual Output DREAD 3Bh 3 1 1+ n bytes read out by Dual output Read 2x I/O 2READ BBh 3 1 1+ n bytes read out by 2 x I/O Read Quad Output QREAD 6Bh 3 1 1+ n bytes read out by Quad output Read 4x I/O 4READ EBh 3 1 1+ n bytes read out by 4 x I/O Page Erase PE 81h 3 0 0 erase selected page Sector Erase (4K bytes) SE 20h 3 0 0 erase selected sector Block Erase (32K bytes) BE32 52h 3 0 0 erase selected 32K block Block Erase (64K bytes) BE64 D8h 3 0 0 erase selected 64K block CE 60h 0 0 0 erase whole chip C7h 0 0 0 erase whole chip Commands Function description Read Program and Erase Chip Erase Page Program PP 02h 3 0 1+ program selected page Dual-IN Page Program 2PP A2h 3 0 1+ program selected page by Dual input Quad page program QPP 32h 3 0 1+ quad input to program selected page Program/Erase Suspend PES 75h 0 0 0 suspend program/erase operation B0h 0 0 0 suspend program/erase operation 7Ah 0 0 0 continue program/erase operation 30h 0 0 0 continue program/erase operation Program/Erase Resume PER Protection Write Enable WREN 06h 0 0 0 sets the write enable latch bit Write Disable WRDI 04h 0 0 0 resets the write enable latch bit VWREN 50h 0 0 0 Write enable for volatile status register Erase Security Registers ERSCUR 44h 3 0 0 Erase security registers Program Security Registers PRSCUR 42h 3 0 1+ Program security registers Read Security Registers RDSCUR 48h 3 1 1+ Read value of security register RDSR 05h 0 0 1 read out status register RDSR2 35h 0 0 1 Read out status register-1 Read Configure Register RDCR 15h 0 0 1 Read out configure register Active Status Interrupt ASI 25h 0 1 0 Enable the active status interrupt Write Status Register WRSR 01h 0 0 2 Write data to status registers Write Configure Register WRCR 31h 0 0 1 Write data to configuration register Volatile SR Write Enable Security Status Register Read Status Register Puya Semiconductor Page 21 of 68 P25Q80L Datasheet Command set (Cont’d) Abbr. Code ADR Bytes DMY Bytes Data Bytes RSTEN 66h 0 0 0 Enable reset Reset RST 99h 0 0 0 Reset Read Manufacturer/device ID RDID 9Fh 0 0 1 to 3 Read Manufacture ID REMS 90h 3 Dual Read Manufacture ID DREMS 92h 3 1 1+ Quad Read Manufacture ID QREMS 94h 3 1 1+ DP B9h 0 0 0 enters deep power-down mode RDP/RES ABh 3 0 1 Read electronic ID data SBL 77h 0 0 0 Set burst length RDSFDP 5Ah Read SFDP parameter FFh Release from read enhanced Commands Function Other Commands Reset Enable Deep Power-down Release Deep Power-down/Read Electronic ID Set burst length Read SFDP Release read enhanced Read unique ID RUID 4Bh 1+ 4 1+ output JEDEC ID: 1-byte manufacturer ID & 2-byte device ID Read manufacturer ID/device ID data Dual output read manufacture/device ID Quad output read manufacture/device ID Read unique ID NOTE: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3,…..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. Fast Read Quad I/O Data IO0 = (x, x, x, x, D4, D0,…) IO1 = (x, x, x, x, D5, D1,…) IO2 = (x, x, x, x, D6, D2,…) IO3 = (x, x, x, x, D7, D3,…) 6. Security Registers Address: Security Register1: A23-A16=00H, A15-A9=0001000, A8-A0= Byte Address; Security Register2: A23-A16=00H, A15-A9=0010000, A8-A0= Byte Address; Security Register3: A23-A16=00H, A15-A9=0011000, A8-A0= Byte Address; Puya Semiconductor Page 22 of 68 P25Q80L Datasheet 10.2 Write Enable (WREN) The Write Enable (WREN) instruction is for setting Write Enable Latch (WEL) bit. For those instructions like PP,DPP,QPP, PE,SE, BE32K,BE, CE, and WRSR,ERSCUR, PRSCUR which are intended to change the device content, should be set every time after the WREN instruction setting the WEL bit. The sequence of issuing WREN instruction is: CS# goes low→ sending WREN instruction code→ CS# goes high. Figure 10-2 Write Enable (WREN) Sequence (Command 06) CS# SCLK 0 1 2 3 4 5 6 7 Command SI 06H High-Z SO 10.3 Write Disable (WRDI) The Write Disable (WRDI) instruction is for resetting Write Enable Latch (WEL) bit. The sequence of issuing WRDI instruction is: CS# goes low→ sending WRDI instruction code→ CS# goes high. The WEL bit is reset by following situations: - Power-up - Write Disable (WRDI) instruction completion - Write Status Register (WRSR) instruction completion - Page Program (PP) instruction completion - Dual Input Page Program (DPP) instruction completion - Quod Page Program (QPP) instruction completion - Page Erase (PE) instruction completion - Sector Erase (SE) instruction completion - Block Erase (BE32K,BE) instruction completion - Chip Erase (CE) instruction completion - Erase Security Register (ERSCUR) instruction completion - Program Security Register (PRSCUR) instruction completion - Reset (RST) instruction completion Figure 10-3 Write Disable (WRDI) Sequence (Command 04) CS# SCLK SI SO Puya Semiconductor 0 1 2 3 4 5 6 7 Command 04H High-Z Page 23 of 68 P25Q80L Datasheet 10.4 Write Enable for Volatile Status Register The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. The sequence of issuing Write Enable for Volatile Status Register instruction is: CS# goes low→ sending Write Enable for Volatile Status Register instruction code→ CS# goes high. Figure 10-4 Write Enable for Volatile Status Register Sequence (Command 50) CS# 0 1 2 3 4 5 6 7 SCLK Command(50H ) SI SO High-Z 10.5 Read Status Register (RDSR) The RDSR instruction is for reading Status Register Bits. The Read Status Register can be read at any time (even in program/erase/write status register condition). It is recommended to check the Write in Progress (WIP) bit before sending a new instruction when a program, erase, or write status register operation is in progress. For command code “05H”, the SO will output Status Register bits S7~S0. The command code “35H”, the SO will output Status Register bits S15~S8 The sequence of issuing RDSR instruction is: CS# goes low→ sending RDSR instruction code→ Status Register data out on SO. The SIO[3:1] are "don't care". Figure 10-5 Read Status Register (RDSR) Sequence (Command 05 or 35) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI 05Hor35H SO High-Z S7~S0 or S15~S8 out 7 6 MSB 5 4 3 2 1 S7~S0 or S15~S8 out 0 7 6 MSB 5 4 3 2 1 0 7 Status Register S15 SUS1 S14 CMP S13 LB3 S12 LB2 S11 LB1 S10 SUS2 S9 QE S8 SRP1 S7 SRP0 S6 BP4 S5 BP3 S4 BP2 S3 BP1 S2 BP0 S1 WEL S0 WIP Puya Semiconductor Page 24 of 68 P25Q80L Datasheet The definition of the status register bits is as below: WIP bit. The Write in Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register progress, when WIP bit sets 0, means the device is not in program/erase/write status register progress. WEL bit. The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write Status Register, Program or Erase command is accepted. BP4, BP3, BP2, BP1, BP0 bits. The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP4, BP3, BP2, BP1, BP0) bits are set to 1, the relevant memory area (as defined in Table “Protected Area Sizes”).becomes protected against Page Program (PP), Page Erase (PE), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP4, BP3, BP2, BP1, and BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed, only if the Block Protect (BP4, BP3, BP2, BP1and BP0) are set to “None protected”. SRP1, SRP0 bits. The Status Register Protect (SRP1 and SRP0) bits are non-volatile Read/Write bits in the status register. The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection SRP1 SRP0 WP# Status Register 0 0 x Software Protected 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 0 x 1 1 x Description The Status Register can be written to after a Write Enable command, WEL=1.(Default) WP#=0, the Status Register locked and can not be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Power Supply Status Register is protected and can not be written to Lock-Down(1) again until the next Power-Down, Power-Up cycle. One Time Program(2) Status Register is permanently protected and can not be written to. NOTE: 1. When SRP1, SRP0=(1, 0), a Power-Down, Power-Up cycle will change SRP1, SRP0 to (0, 0) state. 2. This feature is available on special order. Please contact PUYA for details. QE bit. The Quad Enable (QE) bit is a non-volatile Read/Write bit in the Status Register that allows Quad operation. When the QE bit is set to 0 (Default) the WP# pin and HOLD# pin are enable. When the QE pin is set to 1, the Quad IO2 and IO3 pins are enabled. (The QE bit should never be set to 1 during standard SPI or Dual SPI operation if the WP# or HOLD# pins are tied directly to the power supply or ground) LB3, LB2, LB1, bits. The LB3, LB2, LB1, bits are non-volatile One Time Program (OTP) bits in Status Register (S13-S11) that provide the write protect control and status to the Security Registers. The default state of LB3-LB1are0, the security registers are unlocked. The LB3-LB1bitscan be set to 1 individually using the Write Register instruction. The LB3-LB1bits are One Time Programmable, once its set to 1, the Security Registers will become read-only Puya Semiconductor Page 25 of 68 P25Q80L Datasheet permanently. CMP bit The CMP bit is a non-volatile Read/Write bit in the Status Register(S14). It is used in conjunction the BP4-BP0 bits to provide more flexibility for the array protection. Please see the table “Protected Area Size” for details. The default setting is CMP=0. SUS1, SUS2bit The SUS1 and SUS2bit are read only bit in the status register (S15and S10) that are set to 1 after executing an Program/Erase Suspend (75H or B0H) command (The Erase Suspend will set the SUS1 to 1,and the Program Suspend will set the SUS2 to 1). The SUS1 and SUS2 bit are cleared to 0 by Program/Erase Resume (7AH or 30H) command as well as a power-down, power-up cycle. 10.6 Read Configure Register (RDCR) The RDCR instruction is for reading Configure Register Bits. The Read Configure Register can be read at any time (even in program/erase/write status register condition). It is recommended to check the Write in Progress (WIP) bit before sending a new instruction when a program, erase, or write status register operation is in progress. The sequence of issuing RDCR instruction is: CS# goes low→ sending RDCR instruction code→ Configure Register data out on SO. The SIO[3:1] are "don't care". Figure 10-6 Read Status Register (RDCR) Sequence (Command 15) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI 15H High-Z SO Configure Register Out 7 6 MSB 5 4 3 2 1 Configure Register Out 0 7 6 MSB 5 4 3 2 1 0 7 Configure Register Bit7 DP Bit6 Reserved Bit5 Reserved Bit4 Reserved Bit3 Reserved Bit2 Reserved Bit1 Reserved Bit0 Reserved DP bit. The Dual Page (DP) bit is a non-volatile Read/Write bit in the Configure Register that allows Dual Page operation. When the DP bit is set to 0 (Default) the page size is 256bytes. When the DP pin is set to 1, the page size is 512bytes. This bit controls the page programming buffer address wrap point. Legacy SPI devices generally have used a 256 Byte page programming buffer and defined that if data is loaded into the buffer beyond the 255 Byte location, the address at which additional bytes are loaded would be wrapped to address zero of the buffer. The P25Q80L provides a 512 Byte page programming buffer that can increase programming performance. For legacy software compatibility, this configuration bit provides the option to continue the wrapping behavior at the 256 Byte boundary or to enable full use of the available 512 Byte buffer by not wrapping the load address at the 256 Byte boundary. When the DP pin is set to 1, the page erase instruction (81h) will erase the data of the chosen Dual Page to be "1". Puya Semiconductor Page 26 of 68 P25Q80L Datasheet 10.7 Active Status Interrupt (ASI) To simplify the readout of the WIP bit, the Active Status Interrupt command (25h) may be used. It is then not necessary to continuously read the status register, it is sufficient to monitor the value of the SO line. If the SO line is connected to an interrupt line on the host controller, the host controller may be in sleep mode until the SO line indicates that the device is ready for the next command. The WIP bit can be read at any time, including during an internally self-timed program or erase operation. To enable the Active Status Interrupt command, the CS pin must first be asserted and the opcode of 25h must be clocked into the device. For SPI Mode3, at least one dummy bit has to be clocked into the device after the last bit of the opcode has been clocked in. (In most cases, this is most easily done by sending a dummy byte to the device.) The value of the SI line after the opcode is clocked in is of no significance to the operation. For SPI Mode 0, this dummy bit (dummy byte) is not required. The value of WIP is then output on the SO line, and is continuously updated by the device for as long as the CS pin remains asserted. Additional clocks on the SCK pin are not required. If the WIP bit changes from 1 to 0 while the CS pin is asserted, the SO line will change from 1 to 0. (The WIP bit cannot change from 0 to 1 during an operation, so if the SO line already is 0, it will not change.) Deasserting the CS pin will terminate the Active Status Interrupt operation and put the SO pin into a high-impedance state. The CS pin can be deasserted at any time and does not require that a full byte of data be read. The sequence of issuing ASI instruction is: CS# goes low→ sending ASI instruction code→ WIP data out on SO Figure 10-7 Active Status Interrupt (ASI) Sequence (Command 25) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 SCLK Command SI SO 25H High - Z RDY/BSY High - Z 10.8 Write Status Register (WRSR) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on S15, S10, S1 and S0 of the Status Register. CS# must be driven high after the eighth or sixteen bit of the data byte has been latched in. If not, the Write Status Register (WRSR) command is not executed. If CS# is driven high after eighth bit of the data byte, the CMP and QE and SRP1 bits will be cleared to 0. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. Puya Semiconductor Page 27 of 68 P25Q80L Datasheet The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (BP4, BP3, BP2, BP1, and BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP1 and SRP0) bits in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. The sequence of issuing WRSR instruction is: CS# goes low→ sending WRSR instruction code→ Status Register data on SI→CS# goes high. The CS# must go high exactly at the 8 bits or 16 bits data boundary; otherwise, the instruction will be rejected and not executed. The self-timed Write Status Register cycle time (tW) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Write Status Register cycle is in progress. The WIP sets 1 during the tW timing, and sets 0 when Write Status Register Cycle is completed, and the Write Enable Latch (WEL) bit is reset. Figure 10-8 Write Status Register (WRSR) Sequence (Command 01) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI 01H Status Register in 7 MSB SO 6 5 4 3 2 1 0 15 14 13 12 11 10 9 8 High-Z 10.9 Write Configure Register (WRCR) The Write Configure Register (WRCR) command allows new values to be written to the Configure Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The sequence of issuing WRCR instruction is: CS# goes low→ sending WRCR instruction code→ Configure Register data on SI→CS# goes high. The CS# must go high exactly at the 8 bits data boundary; otherwise, the instruction will be rejected and not executed. The self-timed Write Status Register cycle time (tW) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Write Status Register cycle is in progress. The WIP sets 1 during the tW timing, and sets 0 when Write Configure Register Cycle is completed, and the Write Enable Latch (WEL) bit is reset. Puya Semiconductor Page 28 of 68 P25Q80L Datasheet Figure 10-9 Write Configure Register (WRCR) Sequence (Command 31) CS# 0 1 2 3 4 5 6 7 8 9 7 6 10 11 12 13 14 15 SCLK Command SI Configure Register in 31H 5 4 MSB 3 2 1 0 High - Z SO 10.10 Read Data Bytes (READ) The read instruction is for reading data out. The address is latched on rising edge of SCLK, and data shifts out on the falling edge of SCLK at a maximum frequency fR. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single READ instruction. The address counter rolls over to 0 when the highest address has been reached. The sequence of issuing READ instruction is: CS# goes low→ sending READ instruction code→ 3-byte address on SI→ data out on SO→ to end READ operation can use CS# to high at any time during data out. Figure 10-10 Read Data Bytes (READ) Sequence (Command 03) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI SO 03H High - Z 24 - bit address 23 22 21 3 2 1 0 Data Out1 MSB MSB 7 6 5 4 3 2 Data Out2 1 0 10.11 Read Data Bytes at Higher Speed (FAST_READ) The FAST_READ instruction is for quickly reading data out. The address is latched on rising edge of SCLK, and data of each bit shifts out on the falling edge of SCLK at a maximum frequency fC. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single FAST_READ instruction. The address counter rolls over to 0 when the highest address has been reached. The sequence of issuing FAST_READ instruction is: CS# goes low→ sending FAST_READ instruction code→3-byte address on SI→ 1-dummy byte address on SI→data out on SO→ to end FAST_READ operation can use CS# to high at any time during data out. While Program/Erase/Write Status Register cycle is in progress, FAST_READ instruction is rejected without any impact on the Program/Erase/Write Status Register current cycle. Puya Semiconductor Page 29 of 68 P25Q80L Datasheet Figure 10-11 Read at Higher Speed (FAST_READ) Sequence (Command 0B) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 0BH 23 22 21 3 2 1 0 High - Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK DummyByte SI 7 6 5 4 3 2 1 0 Data Out1 SO 7 6 MSB 5 4 3 Data Out2 2 1 0 7 6 MSB 5 10.12 Dual Read Mode (DREAD) The DREAD instruction enable double throughput of Serial NOR Flash in read mode. The address is latched on rising edge of SCLK, and data of every two bits (interleave on 2 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fT. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single DREAD instruction. The address counter rolls over to 0 when the highest address has been reached. Once writing DREAD instruction, the following data out will perform as 2-bit instead of previous 1-bit. The sequence of issuing DREAD instruction is: CS# goes low → sending DREAD instruction → 3-byte address on SI → 8-bit dummy cycle → data out interleave on SIO1 & SIO0 → to end DREAD operation can use CS# to high at any time during data out. While Program/Erase/Write Status Register cycle is in progress, DREAD instruction is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 10-12 Dual Read Mode Sequence (Command 3B) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI SO 24- bit address 3BH 23 22 21 3 2 1 0 High - Z CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Clocks SI SO Puya Semiconductor 6 4 2 0 6 4 2 0 6 Data Out1 Data Out2 7 5 3 1 7 5 3 1 MSB MSB 7 Page 30 of 68 P25Q80L Datasheet 10.13 2 X IO Read Mode (2READ) The 2READ instruction enables Double Transfer Rate of Serial NOR Flash in read mode. The address is latched on rising edge of SCLK, and data of every two bits (interleave on 2 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fT. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single 2READ instruction. The address counter rolls over to 0 when the highest address has been reached. Once writing 2READ instruction, the following address/dummy/data out will perform as 2-bit instead of previous 1-bit. The sequence of issuing 2READ instruction is: CS# goes low→ sending 2READ instruction→ 24-bit address interleave on SIO1 & SIO0→ 8-bit dummy cycle on SIO1 & SIO0→ data out interleave on SIO1 & SIO0→ to end 2READ operation can use CS# to high at any time during data out. While Program/Erase/Write Status Register cycle is in progress, 2READ instruction is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 10-13 2 X IO Read Mode Sequence (Command BB M5-4 ≠ (1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) BBH 6 SO(IO1) 7 4 2 0 6 5 3 1 7 A23-16 4 2 0 6 5 3 1 7 A15-8 4 2 0 6 5 3 1 7 A7-0 4 2 0 5 3 1 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Byte2 Byte3 Byte4 10.14 2 X IO Read Performer Enhance Mode “BBh” command supports 2 X IO Performance Enhance Mode which can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next 2 X IO Read command (after CS# is raised and then lowered) does not require the BBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first BBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal command. Puya Semiconductor Page 31 of 68 P25Q80L Datasheet Figure 10-14 2 X IO Read Performance Enhance Mode ( M5-4 = (1,0) ) CS# 0 1 2 3 4 5 6 7 8 9 6 10 11 12 13 14 15 16 17 18 19 20 21 22 23 4 2 0 6 5 3 1 7 SCLK Command SI(IO0) BBH SO(IO1) 7 A23-16 4 2 0 6 5 3 1 7 A15-8 4 2 0 6 5 3 1 7 4 2 0 5 3 1 M7-0 A7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCLK SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte1 Byte2 Byte3 Byte4 CS# 0 1 2 3 4 5 6 7 8 SI(IO0) 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 SO(IO1) 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK A23-16 A15-8 A7-0 M7-0 Byte1 Byte2 Note: 2 X IO Read Performance Enhance Mode, if M5-4 = 1, 0. If not using performance enhance recommend to set M5-4 ≠ 1, 0. Puya Semiconductor Page 32 of 68 P25Q80L Datasheet 10.15 Quad Read Mode (QREAD) The QREAD instruction enable quad throughput of Serial NOR Flash in read mode. A Quad Enable (QE) bit of status Register must be set to "1" before sending the QREAD instruction. The address is latched on rising edge of SCLK, and data of every four bits (interleave on 4 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fQ. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single QREAD instruction. The address counter rolls over to 0 when the highest address has been reached. Once writing QREAD instruction, the following data out will perform as 4-bit instead of previous 1-bit. The sequence of issuing QREAD instruction is: CS# goes low→ sending QREAD instruction → 3-byte address on SI → 8-bit dummy cycle → data out interleave on SIO3, SIO2, SIO1 & SIO0→ to end QREAD operation can use CS# to high at any time during data out. While Program/Erase/Write Status Register cycle is in progress, QREAD instruction is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 10-15 Quad Read Mode Sequence (Command 6B) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI(IO0) 24-Bit address 6BH 23 SO(IO1) High-Z WP#(IO2) High-Z HOLD#(IO3) High-Z 22 21 3 2 1 0 CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Clocks SI(IO0) 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 HOLD#(IO3) Byte1 Puya Semiconductor Byte2 Byte3 Byte4 Page 33 of 68 P25Q80L Datasheet 10.16 4 X IO Read Mode (4READ) The 4READ instruction enable quad throughput of Serial NOR Flash in read mode. A Quad Enable (QE) bit of status Register must be set to "1" before sending the 4READ instruction. The address is latched on rising edge of SCLK, and data of every four bits (interleave on 4 I/O pins) shift out on the falling edge of SCLK at a maximum frequency fQ. The first address byte can be at any location. The address is automatically increased to the next higher address after each byte data is shifted out, so the whole memory can be read out at a single 4READ instruction. The address counter rolls over to 0 when the highest address has been reached. Once writing 4READ instruction, the following address/dummy/data out will perform as 4-bit instead of previous 1-bit. The sequence of issuing 4READ instruction is: CS# goes low→ sending 4READ instruction→ 24-bit address interleave on SIO3, SIO2, SIO1 & SIO0→2+4 dummy cycles→data out interleave on SIO3, SIO2, SIO1 & SIO0 → to end 4READ operation can use CS# to high at any time during data out. Another sequence of issuing 4READ instruction especially useful in random access is: CS# goes low→sending 4READ instruction→3-bytes address interleave on SIO3, SIO2, SIO1 & SIO0 → “Continuous Read Mode” byte M[7:0]→ 4 dummy cycles →data out still CS# goes high → CS# goes low (reduce 4 Read instruction) →24-bit random access address. In the performance-enhancing mode, the “Continuous Read Mode” bits M[5:4] = (1,0) can make this mode continue and reduce the next 4READ instruction. Once M[5:4 ] ≠ (1,0) and afterwards CS# is raised and then lowered, the system then will escape from performance enhance mode and return to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal command While Program/Erase/Write Status Register cycle is in progress, 4READ instruction is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 10-16 4 X IO Read Mode Sequence (Command EB M5-4 ≠ (1,0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) EBH 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Note: 1. Hi-impedance is inhibited for the two clock cycles. 2. M[5-4] = (1,0) is inhibited. Puya Semiconductor Page 34 of 68 P25Q80L Datasheet 10.17 4 X IO Read Performance Enhance Mode “EBh” command supports 4 X IO Performance Enhance Mode which can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-byte address (A23-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next 4 X IO Read command (after CS# is raised and then lowered) does not require the EBH command code. If the “Continuous Read Mode” bits (M5-4) do not equal (1, 0), the next command requires the first EBH command code, thus returning to normal operation. A “Continuous Read Mode” Reset command can be used to reset (M5-4) before issuing normal command. Figure 10-17 4 x I/O Read Performance Enhance Mode Sequence ( M5-4 = (1,0) ) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) EBH 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 CS# 0 1 2 3 4 5 6 7 SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 8 9 10 11 12 13 14 15 SCLK A23-16 A15-8 A7-0 M7-0 Dummy Byte1 Byte2 Note: 1. 4 X IO Read Performance Enhance Mode, if M5-4 = 1, 0. If not using performance enhance recommend to set M5-4 ≠ 1, 0. Puya Semiconductor Page 35 of 68 P25Q80L Datasheet 10.18 Burst Read The Set Burst with Wrap command is used in conjunction with “4 X IO Read” command to access a fixed length of 8/16/32/64-byte section within a 256-byte page, in standard SPI mode. The Set Burst with Wrap command sequence: CS# goes low → Send Set Burst with Wrap command → Send 24 dummy bits→ Send 8 bits “Wrap bits” → CS# goes high. W6,W5 0,0 0,1 1,0 1,1 W4=0 Wrap Aroud Yes Yes Yes Yes W4=1 (default) Wrap Length 8-byte 16-byte 32-byte 64-byte Wrap Aroud No No No No Wrap Length N/A N/A N/A N/A If the W6-W4 bits are set by the Set Burst with Wrap command, all the following “4 X IO Read” command will use the W6-W4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap command should be issued to set W4=1. Figure 10-18 Burst Read (SBL) Sequence (Command 77) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK Command SI(IO0) 77H X X X X X X 4 X SO(IO1) X X X X X X 5 X WP#(IO2) X X X X X X 6 X HOLD#(IO3) X X X X X X X X W6-W4 Puya Semiconductor Page 36 of 68 P25Q80L Datasheet 10.19 Page Erase (PE) The Page Erase (PE) instruction is for erasing the data of the chosen Page to be "1". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Page Erase (PE). To perform a Page Erase with the standard page size (256 bytes), an opcode of 81h must be clocked into the device followed by three address bytes comprised of 2 page address bytes that specify the page in the main memory to be erased, and 1 dummy byte. The sequence of issuing PE instruction is: CS# goes low → sending PE instruction code→ 3-byte address on SI → CS# goes high. Figure 10-19 Page Erase Sequence (Command 81) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24-bit address 81H 23 22 MSB 2 1 0 10.20 Sector Erase (SE) The Sector Erase (SE) instruction is for erasing the data of the chosen sector to be "1". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Sector Erase (SE). Any address of the sector is a valid address for Sector Erase (SE) instruction. The CS# must go high exactly at the byte boundary (the latest eighth of address byte been latched-in); otherwise, the instruction will be rejected and not executed. Address bits [Am-A12] (Am is the most significant address) select the sector address. The sequence of issuing SE instruction is: CS# goes low → sending SE instruction code→ 3-byte address on SI → CS# goes high. The SIO[3:1] are don't care. Figure 10-20 Sector Erase (SE) Sequence (Command 20) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 20H 24-bit address 23 22 MSB 2 1 0 The self-timed Sector Erase Cycle time (tSE) is initiated as soon as Chip Select (CS#) goes high. The Write in progress (WIP) bit still can be check out during the Sector Erase cycle is in progress. The WIP sets 1 during the tSE timing, and sets 0 when Sector Erase Cycle is completed, and the Write Enable Latch (WEL) bit is reset. If the sector is protected by BP4, BP3, BP2, BP1, BP0 bits, the Sector Erase (SE) instruction will not be executed on the sector. Puya Semiconductor Page 37 of 68 P25Q80L Datasheet 10.21 Block Erase (BE32K) The Block Erase (BE32K) instruction is for erasing the data of the chosen block to be "1". The instruction is used for 32K-byte block erase operation. A Write Enable (WREN) instruction must be executed to set the Write Enable Latch (WEL) bit before sending the Block Erase (BE32K). Any address of the block is a valid address for Block Erase (BE32K) instruction. The CS# must go high exactly at the byte boundary (the least significant bit of address byte has been latched-in); otherwise, the instruction will be rejected and not executed. The sequence of issuing BE32K instruction is: CS# goes low → sending BE32K instruction code → 3-byte address on SI → CS# goes high. The SIO[3:1] are don't care. The self-timed Block Erase Cycle time (tBE32K) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked while the Block Erase cycle is in progress. The WIP sets during the tBE32K timing, and clears when Block Erase Cycle is completed, and the Write Enable Latch (WEL) bit is cleared. If the block is protected by BP4, BP3, BP2, BP1,BP0 bits, the array data will be protected (no change) and the WEL bit still be reset. Figure 10-21 Block Erase 32K(BE32K) Sequence (Command 52 ) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24-bit address 52H 23 22 MSB 2 1 0 10.22 Block Erase (BE) The Block Erase (BE) instruction is for erasing the data of the chosen block to be "1". The instruction is used for 64K-byte block erase operation. A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Block Erase (BE). Any address of the block is a valid address for Block Erase (BE) instruction. The CS# must go high exactly at the byte boundary (the latest eighth of address byte been latched-in); otherwise, the instruction will be rejected and not executed. The sequence of issuing BE instruction is: CS# goes low→ sending BE instruction code→ 3-byte address on SI→CS# goes high. The SIO[3:1] are "don't care". The self-timed Block Erase Cycle time (tBE) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Block Erase cycle is in progress. The WIP sets 1 during the tBE timing, and sets 0 when Block Erase Cycle is completed, and the Write Enable Latch (WEL) bit is reset. If the block is protected by BP4, BP3, BP2, BP1, BP0 bits, the Block Erase (BE) instruction will not be executed on the block. Figure 10-22 Block Erase (BE) Sequence (Command D8) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI Puya Semiconductor D8H 24-bit address 23 22 MSB 2 1 0 Page 38 of 68 P25Q80L Datasheet 10.23 Chip Erase (CE) The Chip Erase (CE) instruction is for erasing the data of the whole chip to be "1". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Chip Erase (CE). The CS# must go high exactly at the byte boundary (the latest eighth of address byte been latched-in); otherwise, the instruction will be rejected and not executed. The sequence of issuing CE instruction is: CS# goes low→ sending CE instruction code→ CS# goes high. The SIO[3:1] are "don't care". The self-timed Chip Erase Cycle time (tCE) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Chip Erase cycle is in progress. The WIP sets 1 during the tCE timing, and sets 0 when Chip Erase Cycle is completed, and the Write Enable Latch (WEL) bit is reset. If the chip is protected by BP4,BP3, BP2, BP1, BP0 bits, the Chip Erase (CE) instruction will not be executed. It will be only executed when all Block Protect(BP4, BP3, BP2, BP1, BP0) are set to “None protected”. Figure 10-23 Chip Erase (CE) Sequence (Command 60 or C7) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 60H or C7H 10.24 Page Program (PP) The Page Program (PP) instruction is for programming the memory to be "0". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Page Program (PP). The device programs only the last 256 data bytes sent to the device. If the entire 256 data bytes are going to be programmed, A7-A0 (The eight least significant address bits) should be set to 0. If the eight least significant address bits (A7-A0) are not all 0, all transmitted data going beyond the end of the current page are programmed from the start address of the same page (from the address A7-A0 are all 0). If more than 256 bytes are sent to the device, the data of the last 256-byte is programmed at the request page and previous data will be disregarded. If less than 256 bytes are sent to the device, the data is programmed at the requested address of the page. For the very best performance, programming should be done in full pages of 256 bytes aligned on 256 byte boundaries with each Page being programmed only once. Using the Page Program (PP) command to load an entire page, within the page boundary, will save overall programming time versus loading less than a page into the program buffer. It is possible to program from one byte up to a page size in each Page programming operation. Please refer to the P25Q serial flash application note for multiple byte program operation within one page. The sequence of issuing PP instruction is: CS# goes low→ sending PP instruction code→ 3-byte address on SI→ at least 1-byte on data on SI→ CS# goes high. The CS# must be kept low during the whole Page Program cycle; The CS# must go high exactly at the byte boundary (the latest eighth bit of data being latched in), otherwise the instruction will be rejected and will not be Puya Semiconductor Page 39 of 68 P25Q80L Datasheet executed. The self-timed Page Program Cycle time (tPP) is initiated as soon as Chip Select (CS#) goes high. The Write in Progress (WIP) bit still can be checked during the Page Program cycle is in progress. The WIP sets 1 during the tPP timing, and sets 0 when Page Program Cycle is completed, and the Write Enable Latch (WEL) bit is reset. If the page is protected by BP4, BP3, BP2, BP1, BP0 bits, the Page Program (PP) instruction will not be executed. The SIO[3:1] are "don't care". Figure 10-24 Page Program (PP) Sequence (Command 02) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 24- bit address 02H 23 22 21 3 Data Byte 1 2 1 0 7 MSB 6 5 4 3 2 1 0 MSB 2079 2077 2078 2075 2076 2073 2074 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2072 CS# 1 0 SCLK Data Byte 2 SI 7 6 MSB Puya Semiconductor 5 4 3 2 Data Byte 3 1 0 7 MSB 6 5 4 3 2 Data Byte 256 1 0 7 6 5 4 3 2 MSB Page 40 of 68 P25Q80L Datasheet 10.25 Dual Input Page Program (DPP) The Dual Input Page Program (DPP) instruction is similar to the standard Page Program command and can be used to program anywhere from a single byte of data up to 256 bytes of data into previously erased memory locations. The Dual-Input Page Program command allows two bits of data to be clocked into the device on every clock cycle rather than just one. A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit before sending the Dual Input Page Program (DPP). The Dual Input Page Programming takes two pins: SIO0, SIO1 as data input, which can improve programmer performance and the effectiveness of application. The other function descriptions are as same as standard page program. The sequence of issuing DPP instruction is: CS# goes low→ sending DPP instruction code→ 3-byte address on SI→at least 1-byte on data on SIO[1:0]→ CS# goes high. Figure 10-25 Page Program (DPP) Sequence (Command A2) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI(IO0) 24- bitaddress A2H 23 22 21 Byte1 3 2 1 0 Byte2 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 MSB SO(IO1) Byte5 SI(IO0) SO(IO1) Byte6 1055 1054 1052 Byte255 1053 1051 1050 48 49 50 51 52 53 54 55 1049 40 41 42 43 44 45 46 47 SCLK 1048 CS# Byte256 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 10.26 Quad Page Program (QPP) The Quad Page Program (QPP) instruction is for programming the memory to be "0". A Write Enable (WREN) instruction must execute to set the Write Enable Latch (WEL) bit and Quad Enable (QE) bit must be set to "1" before sending the Quad Page Program (QPP). The Quad Page Programming takes four pins: SIO0, SIO1, SIO2, and SIO3 as data input, which can improve programmer performance and the effectiveness of application. The QPP operation frequency supports as fast as fQPP. The other function descriptions are as same as standard page program. The sequence of issuing QPP instruction is: CS# goes low→ sending QPP instruction code→ 3-byte address on SIO0 → at least 1-byte on data on SIO[3:0]→CS# goes high. Puya Semiconductor Page 41 of 68 P25Q80L Datasheet Figure 10-26 Quad Page Program (QPP) Sequence (Command 32) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI(IO0) 24- bit address 32H 23 22 21 Byte1 Byte2 3 2 1 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MSB 543 542 540 541 539 538 536 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 537 CS# SCLK Byte11 Byte12 Byte253 Byte256 SI(IO0) 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 10.27 Erase Security Registers (ERSCUR) The product provides three512-byte Security Registers which can be erased and programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low → sending ERSCUR instruction CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. The Security Registers Lock Bit (LB3-1) in the Status Register can be used to OTP protect the security registers. Once the LB bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Puya Semiconductor Page 42 of 68 P25Q80L Datasheet Address A23-16 A15-12 A11-9 A8-0 Security Register #1 00H 0001 000 Don’t care Security Register #2 00H 0010 000 Don’t care Security Register #3 00H 0011 000 Don’t care Figure 10-27 Erase Security Registers (ERSCUR) Sequence (Command 44) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 44H 24 bit address 23 22 MSB 2 1 0 10.28 Program Security Registers (PRSCUR) The Program Security Registers command is similar to the Page Program command. It allows from 1 to 256/512 bytes Security Registers data to be programmed depend on DP bit set to “0 or 1”. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command sequence: CS# goes low → sending PRSCUR instruction As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. If the Security Registers Lock Bit (LB3-1) is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address A23-16 A15-12 A11-9 A8-0 Security Register #1 00H 0001 000 Byte Address Security Register #2 00H 0010 000 Byte Address Security Register #3 00H 0011 000 Byte Address Puya Semiconductor Page 43 of 68 P25Q80L Datasheet Figure 10-28 Program Security Registers (PRSCUR) Sequence (Command 42) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI 24- bit address 42H 23 22 21 3 Data Byte 1 2 1 0 7 MSB 6 5 4 3 2 1 0 MSB 2079 2077 2078 2075 2076 2074 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2073 2072 CS# 1 0 SCLK Data Byte 2 SI 7 6 5 4 3 Data Byte 3 2 1 0 7 6 MSB MSB 5 4 3 Data Byte 256 2 1 0 7 6 5 4 3 2 MSB 10.29 Read Security Registers (RDSCUR) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3-byte address (A23-A0) and a dummy byte, each bit being latched-in during the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, each bit being shifted out, at a Max frequency fC, during the falling edge of SCLK. The first byte addressed can be at any location. The address is automatically incremented to the next higher address after each byte of data is shifted out. Once the A8-A0 address reaches the last byte of the register (Byte 1FFH), it will reset to 000H, the command is completed by driving CS# high. The sequence of issuing RDSCUR instruction is : CS# goes low → sending RDSCUR instruction → sending 24 bit address → 8 bit dummy byte → Security Register data out on SO → CS# goes high. Address A23-16 A15-12 A11-9 A8-0 Security Register #1 00H 0001 000 Byte Address Security Register #2 00H 0010 000 Byte Address Security Register #3 00H 0011 000 Byte Address Figure 10-29 Read Security Registers (RDSCUR) Sequence (Command 48) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24- bitaddress 23 22 21 48H 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK DummyByte SI 7 6 5 4 3 2 1 0 Data Out1 SO Puya Semiconductor 7 6 MSB 5 4 3 Data Out2 2 1 0 7 6 MSB 5 Page 44 of 68 P25Q80L Datasheet 10.30 Deep Power-down (DP) The Deep Power-down (DP) instruction is for setting the device on the minimizing the power consumption (to entering the Deep Power-down mode), the standby current is reduced from ISB1 to ISB2). The Deep Power-down mode requires the Deep Power-down (DP) instruction to enter, during the Deep Power-down mode, the device is not active and all Write/Program/Erase instruction are ignored. When CS# goes high, it's only in standby mode not deep power-down mode. It's different from Standby mode. The sequence of issuing DP instruction is: CS# goes low→ sending DP instruction code→ CS# goes high. Once the DP instruction is set, all instruction will be ignored except the Release from Deep Power-down mode (RDP) and Read Electronic Signature (RES) instruction. (RES instruction to allow the ID been read out). When Power- down, the deep power-down mode automatically stops, and when power-up, the device automatically is in standby mode. For RDP instruction the CS# must go high exactly at the byte boundary (the latest eighth bit of instruction code been latched-in); otherwise, the instruction will not be executed. As soon as Chip Select (CS#) goes high, a delay of tDP is required before entering the Deep Power-down mode and reducing the current to ISB2. Figure 10-30 Deep Power-down (DP) Sequence (Command B9) CS# SCLK SI 0 1 2 3 4 5 Command 6 7 tDP Standby mode Deep power-down mode B9H 10.31 Release form Deep Power-Down (RDP), Read Electronic Signature (RES) The Release from Deep Power-down (RDP) instruction is terminated by driving Chip Select (CS#) High. When Chip Select (CS#) is driven high, the device is put in the Stand-by Power mode. If the device was not previously in the Deep Power-down mode, the transition to the Stand-by Power mode is immediate. If the device was previously in the Deep Power-down mode, though, the transition to the Stand-by Power mode is delayed by tRES2, and Chip Select (CS#) must remain High for at least tRES2(max). Once in the Stand-by Power mode, the device waits to be selected, so that it can receive, decode and execute instructions. RES instruction is for reading out the old style of 8-bit Electronic Signature, whose values are shown as table of ID Definitions. This is not the same as RDID instruction. It is not recommended to use for new design. For new design, please use RDID instruction. Even in Deep power-down mode, the RDP and RES are also allowed to be executed, only except the device is in progress of program/erase/write cycle; there's no effect on the current program/erase/ write cycle in progress. The RES instruction is ended by CS# goes high after the ID been read out at least once. The ID outputs repeatedly if continuously send the additional clock cycles on SCLK while CS# is at low. If the device was not previously in Deep Power-down mode, the device transition to standby mode is immediate. If the device was previously in Deep Power-down mode, there's a delay of tRES2 to transit to standby mode, and CS# must remain to high at least tRES2 (max). Once in the standby mode, the device waits to be selected, so it can be receive, decode, and execute instruction. The RDP instruction is for releasing from Deep Power-Down Mode. Puya Semiconductor Page 45 of 68 P25Q80L Datasheet Figure 10-31 Read Electronic Signature (RES) Sequence (Command AB) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 32 33 34 35 36 37 38 SCLK Command SI SO tRES2 3 Dummy Bytes 23 22 ABH 2 1 0 MSB High-Z Electronic Signature Out 7 6 5 MSB 4 3 2 1 0 Deep Power-down mode Standby Mode Figure 10-32 Release from Deep Power-down (RDP) Sequence (Command AB) CS# 0 1 2 3 4 5 6 tRES1 7 SCLK Command SI ABH Deep Power- down mode Stand-by mode 10.32 Read Electronic Manufacturer ID & Device ID (REMS) The REMS instruction returns both the JEDEC assigned manufacturer ID and the device ID. The Device ID values are listed in "Table ID Definitions". The REMS instruction is initiated by driving the CS# pin low and sending the instruction code "90h" followed by two dummy bytes and one address byte (A7~A0). After which the manufacturer ID for PUYA (85h) and the device ID are shifted out on the falling edge of SCLK with the most significant bit (MSB) first. If the address byte is 00h, the manufacturer ID will be output first, followed by the device ID. If the address byte is 01h, then the device ID will be output first, followed by the manufacturer ID. While CS# is low, the manufacturer and device IDs can be read continuously, alternating from one to the other. The instruction is completed by driving CS# high. Figure 10-33 Read Electronic Manufacturer & Device ID (REMS) Sequence (Command 90) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 90H 23 22 2 dummy byte and 1 address byte 21 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI Device ID Manufacturer ID SO 7 MSB Puya Semiconductor 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB Page 46 of 68 P25Q80L Datasheet 10.33 Dual I/O Read Electronic Manufacturer ID & Device ID (DREMS) The DREMS instruction is similar to the REMS command and returns the JEDEC assigned manufacturer ID which takes two pins: SIO0, SIO1 as address input and ID output I/O The instruction is initiated by driving the CS# pin low and shift the instruction code "92h" followed by two dummy bytes and one bytes address (A7~A0). After which, the Manufacturer ID for PUYA (85h) and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The instruction is completed by driving CS# high. Figure 10-34 DUAL I/O Read Electronic Manufacturer & Device ID (DREMS) Sequence (Command 92) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command SI(IO0) 92H SO(IO1) 6 4 2 0 6 4 2 0 6 7 5 3 1 7 5 3 1 7 Dummy byte 4 2 0 6 5 3 1 7 ADD byte Dummy byte 4 2 0 5 3 1 M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI(IO0) 6 SO(IO1) 7 4 2 0 6 5 3 1 7 MFRID 4 2 0 6 5 3 1 7 DeviceID 4 2 0 6 5 3 1 7 MFRID (Repeat) 4 2 0 6 5 3 1 7 DeviceID (Repeat) 4 2 0 6 5 3 1 7 MFRID (Repeat) 4 2 0 5 3 1 DeviceID (Repeat) 10.34 Quad I/O Read Electronic Manufacturer ID & Device ID (QREMS) The QREMS instruction is similar to the REMS command and returns the JEDEC assigned manufacturer ID which takes four pins: SIO0, SIO1,SIO2,SIO3 as address input and ID output I/O The instruction is initiated by driving the CS# pin low and shift the instruction code "94h" followed by two dummy bytes and one bytes address (A7~A0). After which, the Manufacturer ID for PUYA (85h) and the Device ID are shifted out on the falling edge of SCLK with most significant bit (MSB) first. If the one-byte address is initially set to 01h, then the device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The instruction is completed by driving CS# high. Puya Semiconductor Page 47 of 68 P25Q80L Datasheet Figure 10-35 QUAD I/O Read Electronic Manufacturer & Device ID (QREMS) Sequence (Command 94) CS# 0 SCLK 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Command SI(IO0) 94H 4 0 4 0 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 7 3 7 3 A23-16 A15-8 A7-0 M7-0 Dummy MFRID DID CS# 24 25 26 27 28 29 30 31 SCLK SI(IO0) 4 0 4 0 4 0 4 0 SO(IO1) 5 1 5 1 5 1 5 1 WP#(IO2) 6 2 6 2 6 2 6 2 HOLD#(IO3) 7 3 7 3 7 3 7 3 MFRID DID MFRID DID Repeat Repeat Repeat Repeat 10.35 Read Identification (RDID) The RDID instruction is for reading the manufacturer ID of 1-byte and followed by Device ID of 2-byte. The PUYA Manufacturer ID and Device ID are list as “as "Table . ID Definitionsi”. The sequence of issuing RDID instruction is: CS# goes low→ sending RDID instruction code → 24-bits ID data out on SO→ to end RDID operation can use CS# to high at any time during data out. While Program/Erase operation is in progress, it will not decode the RDID instruction, so there's no effect on the cycle of program/erase operation which is currently in progress. When CS# goes high, the device is at standby stage. Puya Semiconductor Page 48 of 68 P25Q80L Datasheet Figure 10-36 Read Identification (RDID) Sequence (Command 9F) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCLK SI 9FH SO 7 6 Manufacturer ID 5 4 3 2 1 0 MSB CS# 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 SCLK SI SO 7 Memory Type ID 6 5 4 3 2 1 MSB 0 7 6 Capacity ID 5 4 3 2 1 0 MSB Table ID Definitions P25Q80L RDID manufacturer ID command 85 memory type 60 RES electronic ID command 13 memory density 14 REMS manufacturer ID device ID command 85 13 10.36 Program/Erase Suspend/Resume The Suspend instruction interrupts a Page Program, Sector Erase, or Block Erase operation to allow access to the memory array. After the program or erase operation has entered the suspended state, the memory array can be read except for the page being programmed or the sector or block being erased. Readable Area of Memory While a Program or Erase Operation is Suspended Suspended Operation Readable Region of Memory Array Page Program All but the Page being programmed Page Erase All but the Page being erased Sector Erase(4KB) All but the 4KB Sector being erased Block Erase(32KB) All but the 32KB Block being erased Block Erase(64KB) All but the 64KB Block being erased When the Serial NOR Flash receives the Suspend instruction, there is a latency of tPSL or tESL before the Write Enable Latch (WEL) bit clears to “0” and the SUS2 or SUS1 sets to “1”, after which the device is ready to accept one of the commands listed in "Table Acceptable Commands During Program/Erase Suspend after tPSL/tESL" (e.g. FAST READ). Refer to " AC Characteristics" for tPSL and tESL timings. "Table Acceptable Commands During Suspend (tPSL/tESL not required)" lists the commands for which the tPSL and tESL latencies do not apply. For example, RDSR, RDSCUR, RSTEN, and RST can be issued at any time after the Suspend instruction. Puya Semiconductor Page 49 of 68 P25Q80L Datasheet Status Register bit 15 (SUS2) and bit 10 (SUS1) can be read to check the suspend status. The SUS2 (Program Suspend Bit) sets to “1” when a program operation is suspended. The SUS1 (Erase Suspend Bit) sets to “1” when an erase operation is suspended. The SUS2 or SUS1 clears to “0” when the program or erase operation is resumed. Acceptable Commands During Program/Erase Suspend after tPSL/tESL Command name Command Code Suspend Type Program Suspend Erase Suspend READ 03H • • FAST READ 0BH • • DREAD 3BH • • QREAD 6BH • • 2READ BBH • • 4READ EBH • • RDSFDP 5AH • • RDID 9FH • • REMS 90H • • DREMS 92H • • QREMS 94H • • RDSCUR 48H • • SBL 77H • • WREN 06H • RESUME 7AH OR 30H • • PP 02H • DPP A2H • QPP 32H • Acceptable Commands During Suspend(tPSL/tESL not required) Command name Command Code Suspend Type Program Suspend Erase Suspend WRDI 04H • • RDSR 05H • • RDSR2 35H • • ASI 25H • • RES ABH • • RSTEN 66H • • RST 99H • • NOP 00H • • Figure 10-37 Resume to Suspend Latency tPRS / tERS CS# Resume Command Suspend Command tPRS: Program Resume to another Suspend tERS: Erase Resume to another Suspend Puya Semiconductor Page 50 of 68 P25Q80L Datasheet 10.37 Erase Suspend to Program The “Erase Suspend to Program” feature allows Page Programming while an erase operation is suspended. Page Programming is permitted in any unprotected memory except within the sector of a suspended Sector Erase operation or within the block of a suspended Block Erase operation. The Write Enable (WREN) instruction must be issued before any Page Program instruction. A Page Program operation initiated within a suspended erase cannot itself be suspended and must be allowed to finish before the suspended erase can be resumed. The Status Register can be polled to determine the status of the Page Program operation. The WEL and WIP bits of the Status Register will remain “1” while the Page Program operation is in progress and will both clear to “0” when the Page Program operation completes. Figure 10-38 Suspend to Read/Program Latency tPSL / tESL CS# Suspend Command Read/Program command tPSL: Program latency tESL: Erase latency Notes: 1. Please note that Program only available after the Erase-Suspend operation 2. To check suspend ready information, please read status register bit15 (SUS2) and bit10(SUS1) 10.38 Program Resume and Erase Resume The Resume instruction resumes a suspended Page Program, Sector Erase, or Block Erase operation. Before issuing the Resume instruction to restart a suspended erase operation, make sure that there is no Page Program operation in progress. Immediately after the Serial NOR Flash receives the Resume instruction, the WEL and WIP bits are set to “1” and the SUS2 or SUS1 is cleared to “0”. The program or erase operation will continue until finished ("Resume to Read Latency") or until another Suspend instruction is received. A resume-to-suspend latency of tPRS or tERS must be observed before issuing another Suspend instruction ("Resume to Suspend Latency"). Figure 10-39 Resume to Read Latency tSE /tBE / tPP CS# Resume Command Read Command 10.39 No Operation (NOP) The "No Operation" command is only able to terminate the Reset Enable (RSTEN) command and will not affect any other command. The SIO[3:1] are don't care. Puya Semiconductor Page 51 of 68 P25Q80L Datasheet 10.40 Software Reset (RSTEN/RST) The Software Reset operation combines two instructions: Reset-Enable (RSTEN) command and Reset (RST) command. It returns the device to a standby mode. All the volatile bits and settings will be cleared then, which makes the device return to the default status as power on. To execute Reset command (RST), the Reset-Enable (RSTEN) command must be executed first to perform the Reset operation. If there is any other command to interrupt after the Reset-Enable command, the Reset-Enable will be invalid. The SIO[3:1] are "don't care". If the Reset command is executed during program or erase operation, the operation will be disabled, the data under processing could be damaged or lost. Figure 10-40 Software Reset Recovery CS# 66H 99H tReady Mode Stand-by Mode Figure 10-41 Reset Sequence CS# 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCLK SI Command Command 66H 99H SO High -Z 10.41 Read Unique ID (RUID) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each P25Qxx device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low → sending Read Unique ID command →Dummy Byte1 →Dummy Byte2 →Dummy Byte3 → Dummy Byte4 → 128bit Unique ID Out → CS# goes high. The command sequence is show below. Puya Semiconductor Page 52 of 68 P25Q80L Datasheet Figure 10-42 Read Unique ID (RUID) Sequence (Command 4B) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 3 bytes dummy 4BH High-Z SO CS# 164 165 166 32 33 34 35 36 37 38 39 40 41 42 43 SCLK DummyByte SI 128 bit unique serial number SO 3 127 126 125 124 MSB 2 1 0 10.42 Read SFDP Mode (RDSFDP) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. The sequence of issuing RDSFDP instruction is same as FAST_READ: CS# goes low→ send RDSFDP instruction (5Ah)→send 3 address bytes on SI pin→ send 1 dummy byte on SI pin→ read SFDP code on SO→ to end RDSFDP operation can use CS# to high at any time during data out. SFDP is a JEDEC Standard, JESD216B. Figure 10-43 Read Serial Flash Discoverable Parameter (RDSFDP) Sequence CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 5AH 23 22 21 3 2 1 0 High - Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK DummyByte SI 7 6 5 4 3 2 1 0 Data Out1 SO Puya Semiconductor 7 6 MSB 5 4 3 Data Out2 2 1 0 7 6 MSB 5 Page 53 of 68 P25Q80L Datasheet Figure 10-44 Serial Flash Discoverable Parameter (SFDP) Table Table Signature and Parameter Identification Data Values Description SFDP Signature Comment Fixed:50444653H Add(H) DW Add Data Data (Byte) (Bit) 00H 07:00 53H 53H 01H 15:08 46H 46H 02H 23:16 44H 44H 03H 31:24 50H 50H SFDP Minor Revision Number Start from 00H 04H 07:00 00H 00H SFDP Major Revision Number Start from 01H 05H 15:08 01H 01H Number of Parameters Headers Start from 00H 06H 23:16 01H 01H 07H 31:24 FFH FFH 08H 07:00 00H 00H Start from 0x00H 09H 15:08 00H 00H Start from 0x01H 0AH 23:16 01H 01H 0BH 31:24 09H 09H 0CH 07:00 30H 30H 0DH 15:08 00H 00H 0EH 23:16 00H 00H 0FH 31:24 FFH FFH 10H 07:00 85H 85H Start from 0x00H 11H 15:08 00H 00H Start from 0x01H 12H 23:16 01H 01H 13H 31:24 03H 03H Unused Contains 0xFFH and can never be changed ID number (JEDEC) 00H: It indicates a JEDEC specified header Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length (in double word) Parameter Table Pointer (PTP) How many DWORDs in the Parameter table First address of JEDEC Flash Parameter table Unused Contains 0xFFH and can never be changed ID Number It is indicates PUYA (PUYADevice Manufacturer ID) manufacturer ID Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length How many DWORDs in the (in double word) Parameter table Parameter Table Pointer (PTP) First address of PUYA Flash 14H 07:00 60H 60H Parameter table 15H 15:08 00H 00H 16H 23:16 00H 00H 17H 31:24 FFH FFH Unused Contains 0xFFH and can never be changed Puya Semiconductor Page 54 of 68 P25Q80L Datasheet Table Parameter Table (0): JEDEC Flash Parameter Tables Description Comment Add(H) (Byte) DW Add Data Data (Bit ) 00: Reserved; 01: 4KB erase; Block/Sector Erase Size 10: Reserved; 01:00 01b 02 1b 03 0b 11: not support 4KB erase Write Granularity Write Enable Instruction Requested for Writing to Volatile Status Registers 0: 1Byte, 1: 64Byte or larger 0: Nonvolatile status bit 1: Volatile status bit (BP status register bit) 30H E5H 0: Use 50H Opcode, Write Enable Opcode Select for Writing to Volatile Status Registers 1: Use 06H Opcode, Note: If target flash status register is 04 0b 07:05 111b 15:08 20H 16 1b 18:17 00b 19 0b Nonvolatile, then bits3 and 4 must be set to 00b. Unused Contains 111b and can never be changed 4KB Erase Opcode (1-1- 2) Fast Read 31H 0=Not support, 1=Support Address Bytes Number used in 00: 3Byte only, 01: 3 or 4Byte, addressing flash array 10: 4Byte only, 11: Reserved Double Transfer Rate (DTR) clocking 0=Not support, 1=Support 32H F1H (1-2- 2) Fast Read 0=Not support, 1=Support 20 1b (1-4- 4) Fast Read 0=Not support, 1=Support 21 1b (1-1- 4) Fast Read 0=Not support, 1=Support 22 1b 23 1b 33H 31:24 FFH 37H:34H 31:00 Unused Unused Flash Memory Density (1-4- 4) Fast Read Number of Wait states 0 0000b: Wait states (Dummy 04:00 Clocks) not support Mode Bits 000b:Mode Bits not support (1-4- 4) Fast Read Opcode (1-1- 4) Fast Read Number of Wait states 39H 0 0000b: Wait states (Dummy Clocks) not support 00100b 44H 07:05 010b 15:08 EBH 20:16 01000b 3AH (1-1- 4) Fast Read Number of Mode Bits (1-1- 4) Fast Read Opcode Puya Semiconductor 000b:Mode Bits not support 3BH FFH 007FFFFFH 38H (1-4- 4) Fast Read Number of 20H EBH 08H 23:21 000b 31:24 6BH 6BH Page 55 of 68 P25Q80L Datasheet Description Comment (1-1- 2) Fast Read Number of Wait 0 0000b: Wait states (Dummy states Clocks) not support Add(H) DW Add (Byte) (Bit) 04:00 Data 01000b 3CH (1-1- 2) Fast Read Number of Mode Bits 000b: Mode Bits not support (1-1- 2) Fast Read Opcode (1-2- 2) Fast Read Number of Wait states 3DH 0 0000b: Wait states (Dummy Clocks) not support 08H 07:05 000b 15:08 3BH 20:16 00000b 3EH (1-2- 2) Fast Read Number of Mode Bits 000b: Mode Bits not support (1-2- 2) Fast Read Opcode (2-2- 2) Fast Read 3FH 0=not support 1=support Unused 0=not support 1=support Unused 3BH 80H 23:21 100b 31:24 BBH 00 0b 03:01 111b 04 0b 07:05 111b 40H (4-4- 4) Fast Read Data BBH EEH Unused 43H:41H 31:08 0xFFH 0xFFH Unused 45H:44H 15:00 0xFFH 0xFFH 20:16 00000b 23:21 000b 47H 31:24 FFH FFH 49H:48H 15:00 0xFFH 0xFFH 20:16 00000b (2-2- 2) Fast Read Number of Wait states (2-2- 2) Fast Read Number of Mode Bits 0 0000b: Wait states (Dummy Clocks) not support 46H 000b: Mode Bits not support (2-2- 2) Fast Read Opcode Unused (4-4- 4) Fast Read Number of Wait 0 0000b: Wait states (Dummy states Clocks) not support (4-4- 4) Fast Read Number of Mode Bits Sector Type 1 Size Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector Type 1 erase Opcode Sector Type 2 Size Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector Type 2 erase Opcode Sector Type 3 Size Sector/block size=2^N bytes 0x00b: this sector type don’t exist Sector Type 3 erase Opcode Sector Type 4 Size Sector Type 4 erase Opcode Puya Semiconductor Sector/block size=2^N bytes 0x00b: this sector type don’t exist 00H 4AH 000b: Mode Bits not support (4-4- 4) Fast Read Opcode 00H 23:21 000b 4BH 31:24 FFH FFH 4CH 07:00 0CH 0CH 4DH 15:08 20H 20H 4EH 23:16 0FH 0FH 4FH 31:24 52H 52H 50H 07:00 10H 10H 51H 15:08 D8H D8H 52H 23:16 08H 08H 53H 31:24 81H 81H Page 56 of 68 P25Q80L Datasheet Table Parameter Table (1): PUYA Flash Parameter Tables Description Comment Add(H) DW Add (Byte) (Bit) 61H:60H 63H:62H Data Data 15:00 2000H 2000H 31:16 1650H 1650H 2000H=2.000V Vcc Supply Maximum Voltage 2700H=2.700V 3600H=3.600V 1650H=1.650V Vcc Supply Minimum Voltage 2250H=2.250V 2350H=2.350V 2700H=2.700V HW Reset# pin 0=not support 1=support 00 0b HW Hold# pin 0=not support 1=support 01 1b 0=not support 1=support 02 1b 0=not support 1=support 03 1b Deep Power Down Mode SW Reset SW Reset Opcode Should be issue Reset Enable(66H) before Reset cmd. 65H:64H 11:04 1001 1001b (99H) F99EH Program Suspend/Resume 0=not support 1=support 12 1b Erase Suspend/Resume 0=not support 1=support 13 1b 14 1b 15 1b 66H 23:16 77H 77H 67H 31:24 64H 64H 00 0b 01 0b 09:02 FFH 10 0b Unused Wrap Around Read mode 0=not support 1=support Wrap - Around Read mode Opcode 08H:support 8B wrap - around read Wrap - Around Read data length 16H:8B&16B 32H:8B&16B&32B 64H:8B&16B&32B&64B Individual block lock Individual block lock bit (Volatile/Nonvolatile) 0=not support 1=support 0=Volatile 1=Nonvolatile Individual block lock Opcode Individual blocklock Volatile protect bit default protect status 0=protect 1=unprotect CBFCH 6BH:68H Secured OTP 0=not support 1=support 11 1b Read Lock 0=not support 1=support 12 0b Permanent Lock 0=not support 1=support 13 0b Unused 15:14 11b Unused 31:16 FFFFH Puya Semiconductor FFFFH Page 57 of 68 P25Q80L Datasheet 11 Ordering Information P 25 Q 80 L A –SS H– I T Company Designator P = Puya Semiconductor Product Family 25 = SPI interface flash Product Serial Q = Q serial Memory Density 80 = 8 M bit Operation Voltage . L = 1.65V ~ 2.0V Generation A = A Version Default = blank Package Type SS = SOP8 150mil UX = USON8 3x2x0.55mm NX = USON8 3x4x0.55mm TS = TSSOP8 SU = SOP8 208mil UV = USON8 3x2x0.45mm WX = WSON8 6x5x0.75mm WF = WAFER Plating Technology H : RoHS Compliant, Halogen-free, Antimony- free Device Grade I = - 40 ~ 85C K = - 40 ~ 105C Packing Type T = TUBE R = TAPE & REEL Y = Tray W = WAFER Puya Semiconductor Page 58 of 68 P25Q80L Datasheet 12 Valid Part Numbers and Top Marking The following table provides the valid part numbers for the P25Q80L Flash Memory. Please contact PUYA for specific availability by density and package type. PUYA Flash memories use a 14-digit Product Number for ordering. Package Type SS SOP8 150mil SS SOP8 150mil SU SOP8 208mil SU SOP8 208mil TS TSSOP8 TS TSSOP8 UX USON8 3x2x0.55mm UV USON8 3x2x0.45mm WX WSON8 6x5mm Puya Semiconductor Product Number Density P25Q80L-SSH-IT 8M-bit P25Q80L-SSH-IR 8M-bit P25Q80L-SUH-IT 8M-bit P25Q80L-SUH-IR 8M-bit P25Q80L-TSH-IT 8M-bit P25Q80L-TSH-IR 8M-bit P25Q80L-UXH-IR 8M-bit P25Q80L-UVH-IR 8M-bit P25Q80L-WXH-IR 8M-bit Top Side Marking P25Q80L xxxxxxx P25Q80L xxxxxxx P25Q80L xxxxxxx P25Q80L xxxxxxx P25Q80L xxxxxxx P25Q80L xxxxxxx PQ80 xxxx PQ80 xxxx P25Q80L xxxxxxx Temp. Packing Type 85C Tube 85C Reel 85C Tube 85C Reel 85C Tube 85C Reel 85C Reel 85C Reel 85C Reel Page 59 of 68 P25Q80L Datasheet 13 Package Information 13.1 8-Lead SOP(150mil) h x45° A2 A b e C D 8 0.25mm GAUGE PLANE E1 E A1 k 1 L L1 Common Dimensions (Unit of Measure=millimeters) Symbol A Min Typ Max - - 1.750 A1 0.100 - 0.250 A2 1.250 - - b 0.280 - 0.480 c 0.170 - 0.230 D 4.800 4.900 5.000 E 5.800 6.000 6.200 E1 3.800 3.900 4.000 e - 1.270 - h 0.250 - 0.500 k 0° - 8° L 0.400 - 1.270 L1 - 1.040 - Note:1. Dimensions are not to scale TITLE DRAWING NO. REV SP-8 A 8-lead SOP Puya Semiconductor Page 60 of 68 P25Q80L Datasheet 13.2 8-Lead SOP(208mil) A2 A b C e D 8 0.25mm GAUGE PLANE E1 E A1 k 1 L Common Dimensions (Unit of Measure=millimeters) Symbol Min Typ Max A - - 2.150 0.250 A1 0.050 - A2 1.700 - 1.900 b 0.350 - 0.500 c 0.100 - 0.250 D 5.130 - 5.330 E 7.700 E1 5.180 e - 1.270 - k 0° - 8° L 0.500 - 0.850 8.100 5.380 Note:1. Dimensions are not to scale TITLE DRAWING NO. REV SP-8 A 8-lead SOP(208mil) Puya Semiconductor Page 61 of 68 P25Q80L Datasheet 13.3 8-Lead TSSOP D 8 5 C E E1 1 4 A A1 A2 b e CP α L L1 Common Dimensions (Unit of Measure=millimeters) Symbol A Min Typ Max - - 1.200 A1 0.050 - 0.150 A2 0.800 1.000 1.050 b 0.190 - 0.300 c 0.090 - 0.200 - 0.100 CP D e 2.900 - 3.000 0.650 3.100 - E 6.200 6.400 6.600 E1 4.300 4.400 4.500 L 0.450 0.600 0.750 L1 - α 0° 1.000 - 8° Note:1. Dimensions are not to scale TITLE 8-lead TSSOP Puya Semiconductor DRAWING NO. REV TS-8 A Page 62 of 68 P25Q80L Datasheet 13.4 8-Land USON(3x2x0.55mm) Puya Semiconductor Page 63 of 68 P25Q80L Datasheet 13.5 8-Land USON(3x2x0.45mm) D 0.1 C 0.08 C Pin1 corner 1 M C 8 SEATING PLANE E A2 C 8XL TOP VIEW M A SIDE VIEW PIN1 I.D. 8 A1 (A3) 1 8Xb K e e/2 5 0.1 C A B 4 EXPOSED DIE ATTACH PAD 0.1 C A B J Common Dimensions BOTTOM VIEW (Unit of Measure=millimeters) Symbol Min Typ Max A 0.350 0.400 0.450 A1 0.000 0.035 0.050 A2 - 0.250 - 0.152 REF A3 b 0.200 0.250 0.300 3.000 BSC D E 2.000 BSC 0.500BSC e L 0.400 0.450 J 0.100 0.200 0.300 K 1.500 1.600 1.700 0.500 Note:1. Dimensions are not to scale TITLE DRAWING NO. REV UX-8 A USON8 3X2X0.45 - 0.5 PITCH Puya Semiconductor Page 64 of 68 P25Q80L Datasheet 13.6 8-Land USON(3x4x0.55mm) Puya Semiconductor Page 65 of 68 P25Q80L Datasheet 13.7 8-Land WSON(6x5x0.75mm) Puya Semiconductor Page 66 of 68 P25Q80L Datasheet 14 Revision History Rev. Date V1.0 2017-05-30 Initial release Cyx V1.1 2017-10-30 P8 change operation temperature to 85C P9 change Idp max to 0.6uA P10 change 4Read fQ to 70MHz P65 add package type UV,NX P70 add USON 3x2x0.45 package P71 add USON 3x4x0.55 package Cyx V1.2 2017-11-23 P6 3.1 Corrected to SOP(150mil/208mil) Cyx V1.3 2018-01-04 P11 change Max erase time to 20ms P72 Correct WSON8 POD Cyx 2019-03-27 P11 update Note5 tERS>100us P39 PP command "For the very best performance, programming should be done in full pages of 256 bytes aligned on 256 byte boundaries with each Page being programmed only once. Using the Page Program (PP) command to load an entire page, within the page boundary, will save overall programming time versus loading less than a page into the program buffer. It is possible to program from one byte up to a page size in each Page programming operation. Please refer to the P25Q serial flash application note for multiple byte program operation within one page." P59 add valid Part Numbers Cyx V1.4 Puya Semiconductor Description Author Page 67 of 68 P25Q80L Datasheet Puya Semiconductor Co., Ltd. IMPORTANT NOTICE Puya Semiconductor reserves the right to make changes without further notice to any products or specifications herein. Puya Semiconductor does not assume any responsibility for use of any its products for any particular purpose, nor does Puya Semiconductor assume any liability arising out of the application or use of any its products or circuits. Puya Semiconductor does not convey any license under its patent rights or other rights nor the rights of others. Puya Semiconductor Page 68 of 68
P25Q80L-UVH-IR 价格&库存
很抱歉,暂时无法提供与“P25Q80L-UVH-IR”相匹配的价格&库存,您可以联系我们找货
P25Q80L-UVH-IR
    • 1+1.22840
    • 10+1.19880
    • 30+1.17915
    • 100+1.15938
    P25Q80L-UVH-IR
    • 1+0.82600
    • 30+0.79650
    • 100+0.76700
    • 500+0.70800
    • 1000+0.67850
    • 2000+0.66080
