SDCW3225L-2-601TF
SDCW3225L-2-601TF
    SUNLORD(顺络)
    SMD-4P,3.2x2.5mm
    共模滤波器 SMD-4P,3.2x2.5mm 600Ω@100MHz 1A 120mΩ
SDCW3225L-2-601TF 数据手册
Wire Wound Chip Common Mode Choke Coil – SDCW-S Series Operating Temp. : -40℃~+85℃ FEATURES  Prevention of common mode noise at high frequency 20Ω~1400Ω are optional for different noise level and signal frequency Excellent solderability ● ● APPLICATIONS USB2.0 of IEEE1394, PC, peripheral equipments, small digital AV equipments, etc. LVDS lines of Note PC, LCD Audio lines ● ● ● PRODUCT IDENTIFICATION SDCW 1608 S -2 -900 T F ① ② ③ ④ ⑤ ⑥ ⑦ ① ③ ② Type Winding Type Common Mode Choke Coil SDCW External Dimensions (L×W) (mm) 1210[0504] 1.2×1.0 1608[0603] 1.6×0.8 2520[1008] 2.5×2.0 3225[1210] 3.2×2.5 4532[1812] 4.5×3.2 ④ Number of Lines 2 Code S Standard L For larger current ⑦ ⑤ ⑥ Packing T Hazardous Substance Free Products F Impedance Example Nominal Value 900 90Ω Tape & Reel SHAPE AND DIMENSIONS Recommended Land Pattern Unit: mm Series SDCW1210 A 1.2±0.2 B 1.0±0.2 C 0.8±0.1 D Max. 0.10 E Typ. 0.36 F Typ. 0.33 a Typ. 0.50 b Typ. 1.55 c Typ. 1.00 d Typ. 0.30 SDCW1608 1.6±0.1 0.8±0.1 1.1±0.1 0.10 0.25 0.33 0.73 1.89 0.85 0.25 SDCW2520 2.5±0.2 2.0±0.2 1.2±0.2 0.20 0.60 0.45 1.20 3.20 2.00 0.60 SDCW3225 3.2±0.2 2.5±0.2 1.8±0.2 0.30 0.80 0.60 2.20 4.00 2.50 0.90 SDCW4532 4.5±0.2 3.2±0.2 2.8±0.2 0.50 1.10 0.80 2.70 5.10 3.20 1.00 Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SDCW1210S TYPE Part Number Units Symbol SDCW1210S-2-200TF SDCW1210S-2-350TF SDCW1210S-2-600TF SDCW1210S-2-900TF SDCW1210S-2-161TF SDCW1210S-2-201TF SDCW1210S-2-361TF Common Mode Impedance @100MHz Ω Z 20±25% 35±25% 60±25% 90±25% 160±25% 200±25% 360±25% Max. DC Resistance Ω DCR 0.15 0.18 0.30 0.30 0.40 0.40 0.55 Max. Rated Current mA Ir 500 430 400 400 260 250 250 Common Mode Impedance @100MHz Ω Z 25±25% 60±25% 90±25% 140±25% 220±25% Max. DC Resistance Ω DCR 0.10 0.20 0.25 0.25 0.25 Max. Rated Current mA Ir 500 350 300 300 300 Common Mode Impedance @100MHz Ω Z 300±25% 450±25% 600±25% 1000±25% Max. DC Resistance Ω DCR 0.25 0.30 0.38 0.50 Max. Rated Current mA Ir 400 350 330 240 Common Mode Impedance @100MHz Ω Z 80±25% 160±25% 270±25% 1000±25% 600±25% Max. DC Resistance Ω DCR 0.12 0.15 0.25 0.35 0.12 Max. Rated Current mA Ir 640 480 450 350 1000 Common Mode Impedance @100MHz Ω Z 330±25% 600±25% 800±25% Max. DC Resistance Ω DCR 0.11 0.12 0.16 Max. Rated Current mA Ir 1100 1000 900 Rated Voltage Volts V DC 20 20 20 20 20 20 20 Min. Insulation Resistance MΩ IR 10 10 10 10 10 10 10 SDCW1608S TYPE Part Number Units Symbol SDCW1608S-2-250TF SDCW1608S-2-600TF SDCW1608S-2-900TF SDCW1608S-2-141TF SDCW1608S-2-221TF Rated Voltage Volts V DC 20 20 20 20 20 Min. Insulation Resistance MΩ IR 10 10 10 10 10 SDCW2520S TYPE Part Number Units Symbol SDCW2520S-2-301TF SDCW2520S-2-451TF SDCW2520S-2-601TF SDCW2520S-2-102TF Rated Voltage Volts V DC 50 50 50 50 Min. Insulation Resistance MΩ IR 10 10 10 10 SDCW3225S TYPE Part Number Units Symbol SDCW3225S-2-800TF SDCW3225S-2-161TF SDCW3225S-2-271TF SDCW3225S-2-102TF SDCW3225L-2-601TF Rated Voltage Volts V DC 50 50 50 50 50 Min. Insulation Resistance MΩ IR 10 10 10 10 10 SDCW4532S TYPE Part Number Units Symbol SDCW4532S-2-331TF SDCW4532S-2-601TF SDCW4532S-2-801TF Sunlord Rated Voltage Volts V DC 50 50 50 Specifications subject to change without notice. Please check our website for latest information. Min. Insulation Resistance MΩ IR 10 10 10 Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SDCW4532S TYPE Part Number Units Symbol SDCW4532S-2-102TF SDCW4532S-2-142TF Common Mode Impedance @100MHz Ω Z 1000±25% 1400±25% Max. DC Resistance Ω DCR 0.18 0.20 Max. Rated Current mA Ir 800 700 Rated Voltage Volts V DC 50 50 Min. Insulation Resistance MΩ IR 10 10 ※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency SDCW1210S TYPE Frequency(MHz) SDCW2520S TYPE Frequency(MHz) SDCW1608S TYPE Frequency(MHz) SDCW3225S TYPE Frequency(MHz) SDCW4532S TYPE Frequency(MHz) Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SDCW3225L-2-601TF 价格&库存
很抱歉,暂时无法提供与“SDCW3225L-2-601TF”相匹配的价格&库存,您可以联系我们找货
SDCW3225L-2-601TF
  • 5+1.47480
  • 50+1.22129
  • 600+0.97699
  • 1200+0.96234
  • 3000+0.91664
库存:3004
SDCW3225L-2-601TF
  • 5+1.62100
  • 50+1.33570
  • 150+1.21500
  • 500+1.06610
  • 3000+1.00010
  • 6000+0.96060
库存:10977
SDCW3225L-2-601TF
    • 5+1.62530
    • 50+1.34591
    • 150+1.22616
    • 500+1.07669
    • 3000+1.01018
    • 6000+0.97031
    库存:8925
    SDCW3225L-2-601TF
    • 1+1.50700
    • 100+1.19900
    • 750+1.07250
    • 1500+1.01200
    • 3000+0.95920
    库存:8936
