STI8837
Low Voltage H-Bridge Motor Drive
FEATURES
GENERAL DESCRIPTION
Support the input voltage range: motor
power: 1.8 ~ 12 V, control power supply: 1.8
~ 5.5 V
LDMOSRdson (HS+LS) 280mΩ
Ultra low power sleep mode
Maximum 1.8 A current output capacity
Built-in UVLO Protection
Built-inOver Temperature Protection
Built-in Short Circuit Protection
Built-in Over Current Protection
Built-in Charge Pump
DFN8L 2*2 package
STI8837 is a low voltage DC motor driver IC ,
Internal integration 280m (HS+LS) H bridge
NMOS switch, which can support the
1.8~12V input voltage range, The maximum
current capacity of up to 1.8A, support for
ultra low power sleep mode; built-in UVLO,
Thermal Shutdown, OCP protection circuit
can be used in camera, toys and consumer
products
APPLICATIONS
Cameras
Toys
Consumer Products
TYPICAL APPILCATION
Figure 1. Basic Application Circuit
TMI and SUNTO are the brands of TOLL microelectronic
STI8837 V1.1 2016.11
www.toll-semi.com
www.suntosemi.com
1
STI8837
ABSOLUTE MAXIMUM RATINGS
Parameter
Value
Unit
VM Voltage Range
-0.3~12
V
VCC,IN1,IN2,nSLEEP Voltages Range
-0.3~6
V
VSET/VOUT Voltage Range
-0.3~Vin+0.3
V
Storage Temperature Range
-50~150
°C
Junction Temperature
-40~150
°C
Package Thermal Resistance
10
°C/W
PACKAGE/ORDER INFORMATION
VM
1
OUT1
2
OUT2
3
GND
4
GND
(EPAD)
8
2
VCC
7
EN
6
IN1
5
IN2
DFN8L 2*2
Top Mark: S8837YY XXX (S8837: Device Code,YY XXX: Inside Code)
www.toll-semi.com
2
Part Number
Package
Top mark
Quantity/ Reel
STI8837
DFN8L 2*2
S8837YY XXX
3000
www.suntosemi.com
STI8837
PIN FUNCTIONS
Pin
Name
Function
1
VM
2
OUT1
Motor Driver output 1
3
OUT2
Motor Driver output 2
4
GND
Ground pin
5
IN2
PWM input2
6
IN1
PWM input1
7
EN
8
VCC
Power Supply for Driver
Connect a 0.1u bypass ceramic capacitor to GND
Chip Enable Input
1:Enable, 2:Sleep Mode
Power Supply for Logic Input
ESD RATING
Items
Description
Value
Unit
VESD
Human Body Model for all pins
±2000
V
JEDEC specification JS-001
RECOMMENDED OPERATING CONDITIONS
Items
Description
Voltage Range
VM
1.8
12
V
TA
Operating Temperature Range
-40
85
°C
Min
www.toll-semi.com
Max
Unit
www.suntosemi.com
3
STI8837
ELECTRICAL CHARACTERISTICS (Note 3)
( VIN=12V , TA = 25°C, unless otherwise noted.)
Parameter
Symbol
VM Voltage Range
VVM
Conditions
Min
1.8
VM=5V VCC=3V
VM Supply Current
IVM
No PWM
VM=5V VCC=3V
50kHz PWM
VCC Voltage Surge
VVCC
No PWM
IVCC
VM=5V VCC=3V
50kHz PWM
VM=5V VCC=3V
Sleep Mode
Input Logic Low Voltage
VIL
Input Logic High Voltage
VIL
Input logic Hysteresis
VHYS
Input Logic Low Current
IIL
Input Logic High Current
IIH
Input Pull Down Resistor
RIN
Output Switch
On-Resistance
Output Switch Leakage
Current
RON
ILEAK
Max
Unit
12
V
67
uA
0.43
mA
1.8
VM=5V VCC=3V
VCC Supply Current
Typ
5.5
105
uA
0.28
mA
5
nA
0.25x
0.4x
VCC
VCC
V
0.5x
0.6x
VCC
VCC
0.1x
-5
Iload=800mA
V
V
VCC
VM=5V VCC=3V
V
5
uA
50
uA
100
KΩ
285
mΩ
-200
200
nA
VCC UVLO Voltage
VUVLO
1.7
V
UVLO Hysteresis
VUVLO_HY
100
mV
IOCP
2.2
A
Over Current Retry Time
TOCP_RT
1
mS
Thermal Shutdown Threshold
TSDN
160
www.toll-semi.com
4
www.suntosemi.com
STI8837
Thermal Shutdown Hysteresis
TSDN_HY
Output Enable time
T1
180
nS
Output Disable time
T2
70
nS
T3
140
nS
T4
160
nS
Output rise time
T5
60
nS
Output fall time
T6
nS
Delay Time
IN1 low to OUT2 high
IN2 low to OUT1 high
Delay Time
IN2 high to OUT1 low
IN1 high to OUT2 low
FUNCTIONAL BLOCK DIAGRAM
Charge
Pump
VCC
VM
EN
UVLO
HSD
GDRV
OUT1
SCP
LSD
GDRV
IN1
Logic
SCP
IN2
VM
HSD
GDRV
Thermal
Shutdown
OUT2
LSD
GDRV
OSC
GND
Figure 2. STI8837 Block Diagram
www.toll-semi.com
www.suntosemi.com
5
STI8837
INPUT OUTPUT LOGIC
T1
T4
T2
T3
EN
IN1
IN2
OUT1
OUT2
Function
X
X
Z
Z
Coast
1
Z
Z
Coast
1
1
H
L
Forward
1
L
H
Reverse
1
1
1
L
L
Break
www.toll-semi.com
6
www.suntosemi.com
STI8837
PACKAGE INFORMATION
DFN8L 2*2
Note:
1) All dimensions are in millimeters.
2) Package length does not include mold flash, protrusion or gate burr.
3) Package width does not include inter lead flash or protrusion.
4) Lead popularity (bottom of leads after forming) shall be 0.10 millimeters max.
5) Pin 1 is lower left pin when reading top mark from left to right.
www.toll-semi.com
www.suntosemi.com
7
很抱歉,暂时无法提供与“TMI8837”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.08050
- 10+1.59600
- 30+1.39650
- 100+1.14000
- 国内价格
- 1+2.36520
- 10+1.81440
- 30+1.58760
- 100+1.29600
- 500+1.16640
- 1000+1.08000
- 国内价格
- 1+0.57530
- 200+0.37070
- 1500+0.32230
- 3000+0.28600
