Techcode®
DATASHEET
40V, 800MA, 1.2MHz synchronous Buck Converter
TD1469
TD8325
General Description
Features
TD1469 is a 800mA synchronous buck converter with
integrated power MOSFETs. The TD1469 design with a
current-mode control scheme, can convert wide input
voltage of 7V to 40V to the output voltage adjustable from
0.8V to 90%VIN to provide excellent output voltage
regulation.
The TD1469 equipped with Power-on-reset, soft start and
whole protections (under-voltage, over temperature and
current-limit) into a single package.
This device, available SOT-23-6 provides a very compact
system solution of external components and PCB area.
Wide Input Voltage from 7V to 40V
800mA Output Current
High Efficiency over 85% from Load Current 50mA
to 100mA @ VOUT>=5V
Low EMI Converter
Adjustable Output Voltage from 0.8V to 90%VIN
Integrated High/Low Side MOSFET
1.2M Switching Frequency
Stable with Low ESR Capacitors
Power-On-Reset Detection
Over-Temperature Protection
Current-Limit Protection
Enable/Shutdown Function
Available in SOT-23-6 packages
Lead Free and Green Devices Available (RoHS
compliant).
Applications
Smart Electronic equipments
Output current(mA)
Pin Configurations
Package Types
SOT23-6
June 30, 2020.
(Top view)
Techcode Semiconductor Limited
1
www.techcodesemi.com
Techcode®
DATASHEET
TD1469
TD8325
Pin Description
Pin Number
Pin Name
1
BS
2
GDN
Description
High-Side Gate Drive Boost Input. BS supplies the voltage to drive the high-side N-channel
MOSFET. At least 10nF capacitor should be connected from SW to BS to supply the high side
switch.
Signal and power ground.
3
FB
Output feedback Input. The TD1469 senses the feedback voltage via FB and regulates the
voltage at 0.8V. Connecting FB with a resistor-divider from the converter’s output sets the
output voltage from 0.8V to 90%VIN.
4
EN
Enable Input. EN is a digital input that turns the regulator on or off. EN threshold is 1.1V with
0.2V hysteresis. Pull up with 1MΩ resistor for automatic startup.
5
VIN
Power Input. VIN supplies the power (7V to 40V) to the control circuitry, gate drivers and
step-down converter switches. Connecting a ceramic bypass capacitor and a suitably large
capacitor between VIN and GND eliminates switching noise and voltage ripple on the input to
the IC.
6
SW
Power Switching Output. It is the Drain of the N-Channel power MOSFET to supply power to
the output LC filter.
Ordering Information
TD1469
Circuit Type
Packing:
Blank:Tube
R: Tape and Reel
Package
T:SOT23-6
June 30, 2020.
2
Techcode®
DATASHEET
TD1469
TD8325
Function Block
Figure1 Function Block Diagram of TD1469
June 30, 2020.
3
Techcode®
DATASHEET
TD1469
TD8325
Absolute Maximum Ratings (Note1)
Symbol
Parameter
Rating
Unit
VIN
VIN Supply Voltage(VIN to Gnd)
-0.3 ~ 43
V
VSW
SW to GND Voltage
-0.3 to VIN+0.3
V
VBS
BS to GND Voltage
VSW - 0.3 ~ VSW +6
V
All Other Pins
PD
Power Dissipation
TJ
Junction Temperature
TSTG
Storage Temperature
TSDR
-0.3 ~ 6
V
Internally Limited
ºC
150
ºC
-65 ~ 150
Maximum Lead Soldering Temperature (10 Seconds)
W
ºC
260
Note1: Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only and functional
operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect device reliability.
Thermal Characteristics
Symbol
θJA
Parameter
Junction-to-Ambient Resistance in free air
(Note 2)
SOT-23-6
Typical Value
Unit
250
°C/W
Note 2: θJA is measured with the component mounted on a high effective thermal conductivity test board in free air.
Recommended Operation Conditions (Note3)
Symbol
Parameter
Range
VIN
VIN Supply Voltage
VOUT
Converter Output Voltage
VFB ~ VIN*90%
Operating Junction Temp
-40 ~ 125
7 ~ 40
Unit
V
V
o
C
Note 3: Refer to the typical application circuit
June 30, 2020.
4
Techcode®
DATASHEET
TD1469
TD8325
Electrical Characteristics
Unless otherwise specified, these specifications apply over VIN=12V, VEN=3V and TA = 25ºC.
Symbol
Parameter
Test Conditions
Min
Typ
0.792
0.812
0.832
V
0.1
µA
High Side MOSFET Resistance
0.9
Ω
Low Side MOSFET Resistance
0.4
Ω
1
µA
1
A
0.96
1.2
1.44
MHZ
VFB
Feedback Voltage
10V ≤ VIN ≤ 60V
IFB
Feedback Current
VFB = 0.85V
RDS(ON)
ISW_LKG
Switch Leakage
VEN=0V,VSW=0V
Max
Unit
ILIM
Current Limit
fSW
Oscillator Frequency
VFB=0.6V
fSW_F
Foldback Frequency
VFB=0V
125
KHZ
DMAX
Maximum Duty Cycle
VFB=0.6V
90
TON
Minimum ON-Time
100
ns
VUVLO_R
Under-Voltage Lockout
Threshold, Rising
6
V
VUVLO_F
Threshold, Falling
5.5
V
VUVLO_HYS
Threshold,Hysteresis
0.5
V
Soft Start Time
1
ms
VEN_R
EN Threshold, Rising
1.1
V
VEN_F
EN Threshold, Falling
0.9
V
EN Threshold, Hysteresis
200
mv
VEN=2V
3.1
µA
VEN=0V
0.1
µA
tSS
VEN_HYS
IEN
EN Input Current
IS
Supply Current (Shutdown)
VEN=0V
0.1
1
µA
IQ
Supply Current (Quiescent)
VEN=2V,VFB=1V
0.73
0.85
mA
TSD
Thermal Shutdown
165
o
o
TSD_HYS
Thermal Shutdown Hysteresis
June 30, 2020.
5
C
C
Techcode®
DATASHEET
TD1469
TD8325
Typical Application Circuit
U1
5
VIN
C1
10uF
VIN
BST
SW
R3
1M
1
C3
0.1uF
6
L1
22uH
5V
VOUT
TD1469
C2
22uF
EN
FB
3
R2
8.2K
2
4
GND
R1
43K
June 30, 2020.
6
Techcode®
DATASHEET
TD1469
TD8325
Application Information
Main Control Loop
The TD1469 is a constant frequency, synchronous rectifier
and current-mode switching regulator. In normal operation,
the internal upper power MOSFET is turned on each cycle.
The peak inductor current at which ICMP turn off the upper
MOSFET is controlled by the voltage on the COMP node,
which is the output of the error amplifier(EAMP). An
external resistive divider connected between Vout and
ground allows the EAMP to receive an output feedback
voltage VFB at FB pin. When the load current increases, it
causes a slightly decrease in VFB relative to the 0.8V
reference, which in turn causes the COMP voltage to
increase until the average inductor current matches the new
load current.
Setting Output Voltage
The regulated output voltage is determined by:
R
VOUT = 0.8 × (1 + )
R
VIN Power-On-Reset (POR)
The TD1469 keep monitoring the voltage on VIN pin to
prevent wrong logic operations which may occur when VIN
voltage is not high enough for the internal control circuitry
to operate. The VIN POR has a rising threshold of 6V (typical)
with 0.5V of hysteresis.
After the VIN voltages exceed its respective POR thresholds,
the IC starts a start-up process and then ramps up the
output voltage to the setting of output voltage. Connect a
RC network from EN to GND to set a turn-on delay that can
be used to sequence the output voltages of multiple
devices.
Over-Current-Protection and Hiccup
The TD1469 has a cycle-by-cycle over-current limit when the
inductor current peak value exceeds the set current limit
threshold. Meanwhile, the output voltage drops until FB is
below the Under-Voltage (UV) threshold below the
reference. Once UV is triggered, the TD1469 enters hiccup
mode to periodically restart the part. This protection mode
is especially useful when the output is dead-shorted to
ground. The average short circuit current is greatly reduced
to alleviate thermal issues and to protect the regulator. The
TD1469 exits the hiccup mode once the over-current
condition is removed.
Enable/Shutdown
Driving EN to ground places the TD1469 in shutdown. When
in shutdown, the internal power MOSFETes turn off, all
internal circuitry shuts down and the quiescent supply
current of VlN reduces to
很抱歉,暂时无法提供与“TD1469”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.00760
- 200+0.77550
- 1500+0.67320
- 3000+0.62700
