UM3304QA
UM3304QA
    UNION(英联)
    UQFN-12(1.7x2)
    转换器/电平移位器 双向 20Mbps 1.2V~3.6VCCA 1.65V~5.5VCCB
UM3304QA 数据手册
UM3304 4-Bit Bidirectional Voltage-Level Translator with Auto Direction Sensing and ±4kV ESD Protection UM3304 CSP12 1.9×1.4 UM3304QS QFN14 3.5×3.5 UM3304QT QFN16 2.6×1.8 UM3304QA QFN12 1.7×2.0 UM3304UE TSSOP14 General Description UM3304/UM3304QS/UM3304QT/UM3304QA/UM3304UE is quad channel level translator with auto direction sensing and ±4kV ESD protection. This 4-channel non-inverting translator uses two separate configurable power-supply rails. The A port is designed to track VCCA. VCCA accepts any supply voltage from 1.2V to 3.6V. The B port is designed to track VCCB. VCCB accepts any supply voltage from 1.65V to 5.5V. This allows for universal low-voltage bidirectional translation between any of the 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, and 5V voltage nodes. VCCA should not exceed VCCB. Both I/O ports are auto-sensing; thus, no direction pin is required, making it ideal for data transfer between low-voltage ASICs/PLDs and higher voltage systems. The UM3304/UM3304QS/UM3304QT/UM3304QA/UM3304UE operates at a guaranteed data rate of 20Mbps over the entire specified operating voltage range. Within specific voltage domains, higher data rates are up to 100Mbps. When the output-enable (OE) input is low, all outputs are placed in the high-impedance state. The UM3304/UM3304QS/UM3304QT/UM3304QA/UM3304UE is designed so that the OE input circuit is tracked to VCCA. The UM3304 is a quad level translator available in 1.90mm×1.40mm CSP12 bump package while the UM3304QS is packaged in a 3.50mm×3.50mm QFN14 package, the UM3304QT is packaged in a 2.60mm×1.80mm QFN16 package, the UM3304QA is packaged in 1.70mm×2.00mm QFN12 package and the UM3304UE is packaged in TSSOP14 package. Applications Features          Low-Voltage ASIC Level Translation Cell-Phone Cradles Portable POS Systems Portable Communication Devices Low-Cost Serial Interfaces Cell-Phones GPS Telecommunications Equipment      1.2V to 3.6V on A Port and 1.65V to 5.5V on B Port (VCCA≤VCCB) VCC Isolation Feature – If Either VCC Input is at GND, All Outputs are in the High-Impedance State OE Input Circuit Referenced to VCCA Low Power Consumption Latch-Up Performance Exceeds 100mA ±4kV ESD Protection on B Ports ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 1/18 UM3304 Pin Configurations Top View (Top View) M: Month Code UM3304 CSP12 1.9×1.4 (Top View) XX: Week Code UM3304QS QFN14 3.5×3.5 (Top View) XX: Week Code UM3304QT QFN16 2.6×1.8 (Top View) M: Month Code UM3304QA QFN12 1.7×2.0 ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 2/18 UM3304 (Top View) XX: Week Code UM3304UE TSSOP14 Ball Mapping for UM3304 Transparent Top View Pin Description Pin Name Function VCCA A1 A2 A3 A4 NC GND A-Port Supply Voltage. 1.2V≤VCCA≤3.6V and VCCA≤VCCB Input/Output 1. Referenced to VCCA Input/Output 2. Referenced to VCCA Input/Output 3. Referenced to VCCA Input/Output 4. Referenced to VCCA Not Connected. (Except for UM3304) Ground 3-State Output Enable. Pull OE low to place all outputs in 3-state mode. Referenced to VCCA Not Connected. (Except for UM3304) Input/Output 4. Referenced to VCCB Input/Output 3. Referenced to VCCB Input/Output 2. Referenced to VCCB Input/Output 1. Referenced to VCCB B-Port Supply Voltage. 1.65V≤VCCB≤5.5V Not Connected. (Only for UM3304QT) Ground. (Only for UM3304QT) OE NC B4 B3 B2 B1 VCCB NC GND ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 3/18 UM3304 Ordering Information Part Number Packaging Type Marking Code UM3304 CSP12 1.9×1.4 YAAB UM3304QS QFN14 3.5×3.5 UM3304QS UM3304QT QFN16 2.6×1.8 3304 UM3304QA QFN12 1.7×2.0 APA UM3304UE TSSOP14 UM3304UE Shipping Qty 3000pcs/7Inch Tape & Reel 3000pcs/13Inch Tape & Reel 3000pcs/7Inch Tape & Reel 3000pcs/7Inch Tape & Reel 3000pcs/13Inch Tape & Reel Absolute Maximum Ratings (Note 1) Over operating free-air temperature range (unless otherwise noted) Symbol VCCA VCCB VI Parameter Supply Voltage Range Supply Voltage Range Input Voltage Range A ports B ports Value -0.5 to +4.5 -0.5 to +6.5 -0.5 to +4.5 -0.5 to +6.5 Unit V V V Voltage Range Applied to Any A ports -0.5 to +4.5 Output in the High-Impedance or V B ports -0.5 to +6.5 Power-Off State Voltage Range Applied to Any A ports -0.5 to (VCCA+0.5) VO Output in the High or Low State V B ports -0.5 to (VCCB+0.5) (Note 2) IIK Input Clamp Current VI0.020 0.022 0.024 A1 0.00 - 0.05 0.000 - 0.002 A3 0.15REF 0.006REF b 0.15 0.20 0.25 0.006 0.008 0.010 D 1.75 1.80 1.85 0.069 0.071 0.073 E 2.55 2.60 2.65 0.100 0.102 0.104 e L 0.40BSC 0.30 0.40 0.016BSC 0.50 0.012 0.016 0.020 Land Pattern NOTES: 1. Compound dimension: 2.60×1.80 ; 2. Unit: mm; 3.General tolerance ±0.05mm unless specified; 4. The layout is just for reference. otherwise Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 15/18 UM3304 UM3304QA QFN12 1.7×2.0 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A >0.50 0.55 0.60 >0.020 0.022 0.024 A1 0.00 - 0.05 0.000 - 0.002 A3 0.15REF 0.006REF b 0.15 0.20 0.25 0.006 0.008 0.010 D 1.75 1.80 1.85 0.069 0.071 0.073 E 2.55 2.60 2.65 0.100 0.102 0.104 e L 0.40BSC 0.30 0.40 0.016BSC 0.50 0.012 0.016 0.020 Land Pattern NOTES: 1. Compound dimension: 1.7×2.0 ; 2. Unit: mm; 3.General tolerance ±0.05mm unless specified; 4. The layout is just for reference. otherwise Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 16/18 UM3304 UM3304UE: TSSOP14 Outline Drawing DIMENSIONS Symbol D Pin #1 ID e c b Top View End View θ2 0.10 Min Typ Max Min Typ Max - - 1.20 - - 0.047 A1 0.05 - 0.15 0.002 - 0.006 A2 0.90 1.00 1.05 0.035 0.039 0.041 A3 0.34 0.44 0.54 0.013 0.017 0.021 b 0.20 - 0.28 0.008 - 0.011 c 0.10 - 0.19 0.004 - 0.007 D 4.86 4.96 5.06 0.191 0.195 0.199 E 4.30 4.40 4.50 0.169 0.173 0.177 E1 6.20 6.40 6.60 0.244 0.252 0.260 0.75 0.018 e θ1 L1 θ3 INCHES A L L Side View MILLIMETERS 0.65BSC 0.45 0.60 0.026BSC 0.024 L1 1.00REF 0.039REF L2 0.25BSC 0.010BSC 0.030 θ1 0° - 8° 0° - 8° θ2 10° 12° 14° 10° 12° 14° θ3 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 4.96×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 17/18 UM3304 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com ________________________________________________________________________ http://www.union-ic.com Rev.20 Mar.2021 18/18
UM3304QA 价格&库存
很抱歉,暂时无法提供与“UM3304QA”相匹配的价格&库存,您可以联系我们找货
UM3304QA
  • 1+2.07351
  • 30+2.00201
  • 100+1.85901
  • 500+1.71600
  • 1000+1.64450
