T5MG16000324
T5MG16000324
    YJX(雅晶鑫)
    SMD5032_2P
    无源晶振 16MHz 50Ω 20pF ±30ppm -40℃~+85℃ SMD5032_2P
T5MG16000324 数据手册
序號Serial No. 2022-04-22-03 TAE雅晶 致TO: 日期Date: 2022-04-22 华秋 産品ITEM: 石英晶体谐振器 型號TYPE: T-5032-2PIN-GLASS 標稱頻率NOMINAL FREQUENCY: 16MHz/±30ppm/20pF/50Ω 請收到我們的規格書後,簽字回傳。 Please confirm you received this specification,sign and fax it to us. 接收確認RECEIVING CONFIRMATION 日期DATA 接收RECEIVED 浙江雅晶電子有限公司 浙江省台州市椒江区枫南东路757号 NO.757 Fengnan East Road, Jiaojiang District,Taizhou,Zhejiang,China 电话/Tel:0086-576-89025257,89025258,89020588 传真/Fax:0086-576-89025228 Post Code:318000 URL:www.taecn.com Email: market@taecn.com 擬制Prepared by: 应金会 批准Confirmed by: 王琴飞 taecl@mail.tzptt.zj.cn ABEL ELECTRON SURFACE MOUNTABLE CRYSTAL UNITS(SMD Package) 表面贴装石英晶體諧振器 浙江雅晶電子有限公司 T-5032-2PIN-GLASS RoHS Compliant Standard Features 特性 Nominal Frequency 标称频率:MHz Suited for portable devices with low current consumption 適合於低功耗的便攜設備 For a clock source in electronic equipments 適用於电子設備的時鐘源 Item Model T-5032-2PIN-GLASS Frequency Range 标称频率 16MHz Frequency Tolerance 調整頻差 ±30ppm Max ±30ppm Max –40~+85℃ –40~+85℃ 50Ω Max 20pF 7.0pF Max 100μw Max ±3ppm/year Max 500Mohm/Min Freq. Tol. Over Temp. 溫度頻差 Operating Temp. Range 工作溫度範圍 Storage Temp. Range 保存溫度範圍 Series Resistance 諧振電阻 Load Capacitance 負載電容 Shunt Capacitance 靜態電容 Drive Level 激勵電平 Aging 老化率 Insulation Resistance 絕緣阻抗 OUTLINE DIMENSIONS (unit:mm) http://www.taecn.com Conditions at 25℃ –40~+85℃ DC100V±15V ABEL ELECTRON 可靠性Reliability(Mechanical and Environmental Endurance) 序号 项目 NO ITEM 1 2 3 4 5 6 7 跌落 Drop 振动 Vibration 热冲击 Thermal shock 浙江雅晶电子有限公司 条件 CONDITIONS 合格标准 BASIS OF VERDICT 100cm高处自由跌落到3cm厚硬木板上,3次 △FL≤±5ppm High:100cm;Thickness:3cm;3 times △RS≤5Ωor±15% (whichever is larger) 频率 Frequency: 10~2000Hz;加速度幅度 Acceleration: 100 m/s2 振 △FL≤±5ppm △RS≤5Ωor±15% 动方向 Direction: X, Y, Z (Whichever is Larger) 振动时间 Duration: 每个方向30分钟 30 min/direction. 循环次数 Times: 12次 -55℃~+125℃,1000个循环 最大转换时间:5分钟;停留时间:5分钟 △FL≤±10ppm -55℃~+125℃,For 1000 cycles Maximum conversion time: 5 minutes;Remain time:5 minutes △RS≤5Ωor±20% (Whichever is Larger) 湿热 温度:85℃;湿度:85%;时间:1000小时 △FL≤±10ppm Humidity Temp:85℃;Humidity:85%;Times:1000h △RS≤5Ωor±20% (Whichever is Larger) 低温 Cold resistance 温度:-40℃;时间:1000小时 △FL≤±10ppm Temp:-40℃;Times:1000h 高温:65℃(10小时,含升温),低温:25℃(2小时,含降 温),湿度90%,循环10次,每循环24小时 High-Temperature: 65℃±2℃ (10 hours, including 湿度抗性 heating), Humidity resistance Low-Temperature: 25℃±2℃ (2 hours, including cooling), Humidity: 90%, for 10 cycles (24 hours/cycle) 峰值 Peak: 100g's 持续时间 Duration: 6ms 波形 Waveform: 半正弦波 Half-sine 机械冲击 变化速度 Velocity Change: 12.3 ft / sec Mechanical shock 振动方向 Direction: +X, -X, +Y, -Y, +Z, -Z 每个方向各3次 3 times/direction △RS≤5Ωor±20% (Whichever is Larger) △FL≤±10ppm △RS≤5Ωor±20% (Whichever is Larger) △FL≤±5ppm △RS≤5Ωor±15% (Whichever is Larger) ABEL ELECTRON 可靠性Reliability(Mechanical and Environmental Endurance) 序号 项目 NO ITEM 条件 CONDITIONS 浙江雅晶电子有限公司 合格标准 BASIS OF VERDICT △FL≤±5ppm 8 回流焊 Reflow △RS≤5Ωor±15% (Whichever is Larger) No Rusty 9 引脚拉力(SMD型) Pin pull 按照要求分别提供1.8kg的切向推力(60秒)以及1.8kg的垂直拉 力(60秒) In 电极不断裂 accordance with the requirements,offering 1.8kg tangential thrust (60 seconds), and 1.8kg vertical pull No Rupture Observed (60 seconds)respectively. 10 老化 温度:85℃;时间:1000小时 △FL≤±10ppm Aging Temp:85℃;Times:1000h △RS≤5Ωor±10% (Whichever is Larger) 可焊性 solderability 温度:235℃±5℃;时间:2秒 Temperature: 235℃±5℃; Time: 2sec 浸锡率≥95% Solder Coverage≥95% 11 备注 可靠性项目中的4、5、6、10,需在试验结束后24±2小时进行测试。 T-5032編帶規格TAPE AND REEL SPECIFICATION ABEL ELECTRON 浙江雅晶電子有限公司 1.編帶規格符合美國電子工業協會EIA-481-B電子元件編帶標準Tape and Reel form conform to EIA-481-B 2.每盤的晶體元件數量爲1000只。The quantity of crystal units per reel shall be 1000PCS. 3.在包裝盒及載帶盤的表面貼上標簽,注明必需的資訊A "LABEL" on which necessary information is clearly written is on the surface of packing box and the reel. 載帶尺寸圖CARRIER TAPE DIMENSIONS 載帶盤尺寸圖REEL DIMENSIONS http://www.taecn.com T-5032编带规格TAPE AND REEL SPECIFICATION 浙江雅晶电子有限公司 ■编带方式(TAPING METHOD) 轮 Reel 压封带 Cover 载带 tape MARKING MARKIN G MARKIN G MARKING Unreeling Direction 拉伸方向 Empty Pockets Unreeling Direction Empty Pockets T-5032编带规格TAPE AND REEL SPECIFICATION ■包装(PACKAGE) 1.自封袋(Bag) 浙江雅晶电子有限公司 30min 1000只=1 轮 1000pcs=1 Reel Desiccant 2.内包装(Inside package) 1 轮=1 盒 1 Reel=1 box 3.外包装(outside Package ) 10 盒=1 箱 10 box=1 carton 干燥剂
T5MG16000324 价格&库存
很抱歉,暂时无法提供与“T5MG16000324”相匹配的价格&库存,您可以联系我们找货
T5MG16000324
  • 5+0.97680
  • 50+0.91080
  • 200+0.84480
  • 1000+0.77880
  • 2500+0.74580
  • 5000+0.71280
库存:1000
