XMP-10V
XMP-10V
    JST
    P=2.5mm
    胶壳 间距P=2.50mm 10Pin(1x10)
XMP-10V 数据手册
XM CONNECTOR 2.5mm pitch/Crimp style wire-to-wire connectors Specifications ––––––––––––––––––– The retainer provides added protection against non-insertion or disconnection. • Inner-housing lock • Secondary retainers • Housing lance • Mountable on a variety of panels • Contacts smoothly insert into the housings without colliding with internal obstacles • Current rating: 3A AC, DC max. • Voltage rating: 250V AC, DC max. • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #28 to #20 0.08 to 0.50mm2 • Applicable panel thickness: 0.5 to 1.8mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards––––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Panel Layout and Assembly layout (18 circuits) 15.5 7.9 (2 to 12 circuits) 24.4 24.4 +0.1 A 0 +0.1 B±0.05 Circuits Receptacle housing +0.1 0 B±0.05 Panel hole dimensions (mm) General tolerance A +0.1 0 B±0.05 2 XMR-02V 9.3 12.6 3 XMR-03V 10.3 13.6 4 XMR-04V 12.8 16.1 5 XMR-05V 15.3 18.6 6 XMR-06V 17.8 21.1 7 XMR-07V 20.3 23.6 8 XMR-08V 22.8 26.1 9 XMR-09V 25.3 28.6 10 XMR-10V 27.8 31.1 11 XMR-11V 30.3 33.6 12 XMR-12V 32.8 36.1 18 XMR-18V 25.3 28.6 Note: 1. Punch holes in the panel according to the sketch and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 15.8 11.6±0.05 +0.1 0 8.2 5.5±0.05 A  0 Applicable panel thickness (mm) 0.5∼1.8 XM CONNECTOR Contact Pin contact Socket contact 6.5 1.9 1.9 12.5 2.9 2.5 1.3 3.1 2.9 1.3 2.3 2.4 6.3 0.8 0.8 Applicable wire Model No. Q´ty / reel Pin contact Socket contact mm2 AWG # Insulation O.D. (mm) Pin contact Socket contact SXM-001T-P0.6 SXA-001T-P0.6 0.08∼0.33 28∼22 0.8∼1.9 7,000 8,000 *SXM-01T-P0.6 SXA-01T-P0.6 0.22∼0.50 24∼20 1.5∼1.9 7,000 8,000 SXA-001T-P0.6L 0.13∼0.33 26∼22 1.3∼1.9 − 8,000 − Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for special products. 2. *Marked product is not UL/CSA approved. Contact Crimping machine Crimp applicator SXM-001T-P0.6 AP-K2N SXM-01T-P0.6 Applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA/M-01-06 APLMK SXA/M01-06 *MKS-SC SC/SXA/M-01-06 APLSC SXA/M01-06 Note: *Strip-crimp applicator Contact Crimping machine Crimp applicator SXA-001T-P0.6 SXA-01T-P0.6 AP-K2N SXA-001T-P0.6L Applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA/M-01-06 APLMK SXA/M01-06 *MKS-SC SC/SXA/M-01-06 APLSC SXA/M01-06 MKS-L MK/SXA-001-06L APLMK SXA001-06L *MKS-SC SC/SXA-001-06L APLSC SXA001-06L Contact position location numbers Contact position numbers are stamped Retainer Retainer Receptacle housing 1 2 3 4 5 6 7 8 9 10 11 12 Plug housing 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 12 11 10 9 8 7 6 5 4 3 2 1 9 8 7 6 5 4 3 2 1 18 17 16 15 14 13 12 11 10 2 XM CONNECTOR Receptacle housing (for Pin contact) (2 to 12 circuits) Circuits Model No. 2 XMR-02V XMR-03V XMR-04V XMR-05V XMR-06V XMR-07V XMR-08V XMR-09V XMR-10V XMR-11V XMR-12V XMR-18V A 2.5 B 3 4 5 6 7 10.8 8 20.2 7.9 9 10 (18 circuits) 11 12 A 10.8 15.5 20.2 Q´ty / bag 2.5 8.9 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 500 20.0 24.9 500 22.5 27.4 500 25.0 29.9 500 27.5 32.4 500 20.0 24.9 500 Material 2.5 B 18 Dimensions (mm) A B PA 66, UL94V-0 RoHS compliance Note: Receptacle housings without panel lock device are also available for 2, 3, 4, 6, 7, 8 and 9 circuits. Plug housing (for Socket contact) (2 to 12 circuits) Circuits Model No. 2 XMP-02V XMP-03V XMP-04V XMP-05V XMP-06V XMP-07V XMP-08V XMP-09V XMP-10V XMP-11V XMP-12V XMP-18V 3 2.5 A B 4 5 6 11.5 12.0 7 6.3 7.7 8 9 (18 circuits) 10 11 12 Q´ty / bag 2.5 8.8 1,000 5.0 9.8 1,000 7.5 12.3 1,000 10.0 14.8 500 12.5 17.3 500 15.0 19.8 500 17.5 22.3 500 20.0 24.8 500 22.5 27.3 500 25.0 29.8 500 27.5 32.3 500 20.0 24.8 500 A B 18 Dimensions (mm) A B 2.5 Material PA 66, UL94V-0 11.5 12.0 RoHS compliance 13.7 14.6 Retainer Circuits 2 3 4 5 6 A 7 8 2.5 9・18 10 11 2.5 7.8 0.95 12 Model No. XMS-02V XMS-03V XMS-04V XMS-05V XMS-06V XMS-07V XMS-08V XMS-09V XMS-10V XMS-11V XMS-12V Dimensions A (mm) Q´ty / bag 2.5 1,000 5.0 1,000 7.5 1,000 10.0 1,000 12.5 1,000 15.0 1,000 17.5 1,000 20.0 1,000 22.5 1,000 25.0 1,000 27.5 1,000 Material Glass-filled PA 66, UL94V-0 RoHS compliance Note: Commonly used for 9-circuit and 18-circuit housings. 3
XMP-10V
1. 物料型号:文档列出了多种XM系列连接器的型号,例如XMR-02V至XMR-12V和XMR-18V,以及XMP-02V至XMP-12V和XMP-18V,还有XMS-02V至XMS-12V。
2. 器件简介:XM CONNECTOR是一种2.5mm间距的端子,用于线对线连接,具有保持器以防止未插入或断开。
3. 引脚分配:文档提供了不同电路数的插座和插头外壳的尺寸和数量,例如2至12路和18路。
4. 参数特性: - 电流额定值:最大3A AC/DC。 - 电压额定值:最大250V AC/DC。 - 温度范围:-25°C至+85°C。 - 接触电阻:初始值10mΩ最大,环境测试后20mΩ最大。 - 绝缘电阻:最小500MΩ。 - 耐电压:1,500V AC/分钟。
5. 功能详解:文档描述了连接器的插入和固定机制,包括内壳锁定和次级保持器。
6. 应用信息:连接器适用于多种面板,并且可以平滑地插入外壳而不会与内部障碍物碰撞。
7. 封装信息:提供了插座外壳、插头外壳和保持器的尺寸、材料和RoHS合规性信息。材料包括磷青铜镀锡(回流处理)、PA 66, UL94V-0和含玻璃纤维的PA 66, UL94V-0。
XMP-10V 价格&库存
很抱歉,暂时无法提供与“XMP-10V”相匹配的价格&库存,您可以联系我们找货
XMP-10V
    • 500+0.71500
    库存:81000
    XMP-10V
    • 334+2.55548334+0.32746
    • 500+2.46308500+0.31563
    • 1000+1.796151000+0.23016
    库存:2167
    XMP-10V
      库存:4000
      XMP-10V
        库存:8480
        XMP-10V
          • 10+0.73644
          • 100+0.68668
          • 500+0.63692
          • 2000+0.58716
          • 5000+0.55233
          • 10000+0.53740
          库存:1980
          XMP-10V
            • 500+0.47153
            • 3000+0.45954
            • 10000+0.44756
            XMP-10V
              • 1+1.935201+0.24798
              • 300+1.44931300+0.18572
              • 500+1.34878500+0.17284
              • 1000+1.256631000+0.16103
              • 4000+1.206364000+0.15459
              • 5000+1.197985000+0.15351
              • 10000+1.1979810000+0.15351
              库存:2167
