SMAJ Series
Working Voltage: 5.0 to 440 V
Peak Pulse Power: 400 W
Surface Mount
Transient Voltage Suppressors
Features
Glass passivated chip
400 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
SMA/ DO-214AC
0.064 1.63
0.049 1.23
0.109 2.76
0.099 2.51
0.179 4.55
0.162 4.10
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
0.012 0.30
0.006 0.15
0.089 2.26
0.077 1.96
0.206 5.22
0.192 [4.87]
0.06 1.51
0.03 0.75
0.008 0.20
0.001 0.02
Dimensions : inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000μs waveform(1)
Peak pulse current with a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
unidirectional only(3)
Operating junction and storage temperature range
Value
Symbol
PPP
400
IPP
See Next Table
PD
1.0
Unit
W
A
W
IFSM
40
A
VF
3.5/5.0
V
TJ, TSTG
- 55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“SMAJ58CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.19691
- 100+0.19396
- 1000+0.13118
- 2000+0.12921
- 5000+0.11138
- 国内价格
- 20+0.21482
- 200+0.16870
- 600+0.14310
- 5000+0.12150
- 10000+0.10822
- 20000+0.10098
- 国内价格
- 1+0.50380
- 500+0.16830
- 2500+0.11220
- 5000+0.09163
