SMCJ Series
Working Voltage: 5.0 to 440 V
Peak Pulse Power: 1500 W
Surface Mount
Transient Voltage Suppressors
Features
SMC/ DO-214AB
Glass passivated chip
1500 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
IEC-61000-4-2 ESD 15kV(Air), 8kV
(Contact)
Mechanical Data
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
(1)
Peak power dissipation with a 10/1000μs waveform
Peak pulse current with a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 100 A for
unidirectional only(3)
Operating junction and storage temperature range
Typical thermal resistance, Junction to Ambient
Typical thermal resistance, junction to lead
Value
Symbol
PPP
1500
IPP
See Next Table
PD
6.5
Unit
W
A
W
IFSM
200
A
VF
3.5/5.0
V
TJ, TSTG
Rθ JA
Rθ JL
- 55 to +150
75
15
°C
°C/ W
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“SMCJ30A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68002
- 50+0.55301
- 600+0.44188
- 1200+0.43525
- 3000+0.38191
- 国内价格
- 5+0.74942
- 50+0.60945
- 150+0.53946
- 500+0.48698
- 3000+0.42088
- 6000+0.39993
- 国内价格
- 1+0.65230
- 200+0.42130
- 1500+0.36630
- 3000+0.32450
