BZT52C2V4S THRU BZT52C43S
Silicon Planar Zener Diodes
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
FEATURES
Total power dissipation: Max. 200mW.
Wide zener reverse voltage range 2.4V to 43V.
Ideally suited for automated assembly processes
2
1
Top View
MECHANICAL DATA
Simplified outline SOD-323 and symbol
Case: SOD-323
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight: 5.48mg / 0.00019oz
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation (NOTE 1)
PD
200
mW
Forward Voltage at I F = 10 mA(NOTE 2)
VF
0.9
V
RθJA
625
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
Transient Thermal Impedance( °C /W)
Fig.1 Power Derating Curve
Power Dissipation P D ( W )
250
200
150
100
50
50
75
100
125
150
175
T a ,Case Temperature (°C)
www.tw-gmc.com
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
t, Pulse Duration(sec)
1
100
Characteristics at Ta = 25°C
(NOTE 2)
Type
Marking
(NOTE 3)
V ZT(@ I ZT)
Min(V)
Nom(V)
Maximum
Reverse
Current
Maximum Zener
Impedance
Zener Voltage Range
(NOTE 2)
Typical
Temperature
Coefficient
@I ZTC mV/℃
Test
Current
I ZTC
I ZT
Z ZT(@ I ZT) Z ZK(@ I ZK)
I ZK
IR
VR
Max(V)
(mA)
(Ω)
mA
μA
V
MIN
MAX
mA
BZT52C2V4S
WX
2.2
2.4
2.6
5
100
600
1
50
1
-3.5
BZT52C2V7S
W1
2.5
2.7
2.9
5
100
600
1
-3.5
BZT52C3V0S
W2
2.8
3
3.2
5
95
600
1
10
1
-3.5
BZT52C3V3S
W3
3.1
3.3
3.5
5
95
600
1
5
1
-3.5
BZT52C3V6S
W4
3.4
3.6
3.8
5
90
600
1
5
1
-3.5
BZT52C3V9S
W5
3.7
3.9
4.1
5
90
600
1
3
1
-3.5
BZT52C4V3S
W6
4
4.3
4.6
5
90
600
1
3
1
-3.5
BZT52C4V7S
W7
4.4
4.7
5
5
80
500
1
3
2
-3.5
0.2
5
BZT52C5V1S
W8
4.8
5.1
5.4
5
60
480
1
2
2
-2.7
1.2
5
BZT52C5V6S
W9
5.2
5.6
6
5
40
400
1
1
2
-2
2.5
5
BZT52C6V2S
WA
5.8
6.2
6.6
5
10
150
1
3
4
0.4
3.7
5
BZT52C6V8S
WB
6.4
6.8
7.2
5
15
80
1
2
4
1.2
4.5
5
BZT52C7V5S
WC
7
7.5
7.9
5
15
80
1
1
5
2.5
5.3
5
BZT52C8V2S
WD
7.7
8.2
8.7
5
15
80
1
0.7
5
3.2
6.2
5
BZT52C9V1S
WE
8.5
9.1
9.6
5
15
100
1
0.5
6
3.8
7
5
BZT52C10S
WF
9.4
10
10.6
5
1
0.2
7
4.5
8
5
BZT52C11S
WG
10.4
11
11.6
5
1
0.1
8
5.4
9
5
12.7
5
25
150
1
0.1
8
6
10
5
170
8
BZT52C12S
WH
11.4
12
BZT52C13S
WI
12.4
13
14.1
5
30
1
0.1
BZT52C15S
WJ
13.8
15
15.6
5
30
200
1
0.1 10.5
BZT52C16S
WK
15.3
16
17.1
5
40
200
1
0.1
BZT52C18S
WL
16.8
18
19.1
5
45
225
1
BZT52C20S
WM
18.8
5
55
225
1
0.1
BZT52C22S
WN
20.8
22
23.3
5
55
250
1
0.1 15.4
BZT52C24S
WO
22.8
24
25.6
5
70
250
1
0.1 16.8
BZT52C27S
WP
25.1
27
28.9
2
80
300
0.5
0.1 18.9
BZT52C30S
WQ
28
30
32
2
80
300
0.5
0.1
BZT52C33S
WR
31
33
35
2
80
325
0.5
0.1 23.1
7
11
5
9.2
13
5
11.2
10.4
14
5
0.1 12.6
12.4
16
5
14.4
18
5
16.4
18.4
22
5
21.4
25.3
2
24.4
29.4
2
27.4
33.4
2
30.4
37.4
2
33.4
41.2
2
10
12
5
14
21
BZT52C36S
WS
34
36
38
2
90
350
0.5
0.1 25.2
BZT52C39S
WT
37
39
41
2
130
350
0.5
0.1 27.3
BZT52C43S
WU
40
43
46
2
100
700
1
NOTE:
0.1
1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2 .
2. Short duration test pulse used to minimize self-heating effect.
3. f = 1kHz.
www.tw-gmc.com
1
2
32
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.tw-gmc.com
1
3
8
很抱歉,暂时无法提供与“BZT52C10S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09029
- 500+0.07234
- 3000+0.05531
- 6000+0.04935
- 24000+0.04423
- 51000+0.04145
- 国内价格
- 50+0.08276
- 600+0.06631
- 1200+0.06532
- 3000+0.05070
