ESD5Z7V0
Transient Voltage Suppressors for ESD Protection
Applications
PINNING
DESCRIPTION
z
Cellular phones
1
Cathode
z
Portable devices
2
Anode
z
Digital cameras
z
Power supplies
PIN
Features
2
1
Top View
Simplified outline SOD-523 and symbol
z
Small Body Outline Dimensions
z
Low Body Height
z
Stand−off Voltage: 7V
z
Peak Power up to 200 Watts @ 8 x 20 _s Pulse
z
Low Leakage
z
Response Time is Typically < 1 ns
z
ESD Rating of Class 3 (> 16 kV) per Human
Body Model
z
IEC61000−4−2 Level 4 ESD Protection
z
IEC61000−4−4 Level 4 EFT Protection
z
We declare that the material of product
z
S- Prefix for Automotive and Other Applications
Requiring Unique Site and Control Change
Requirements; AEC-Q101 Qualified and PPAP Capable.
compliance with RoHS req uirements.
Absolute Ratings (Tamb=25°C )
Symbol
Parameter
Value
Units
PPP
Peak Pulse Power (tp = 8/20μs)
200
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-55 to +150
°C
Top
Operating Temperature Range
-40 to +125
°C
Tj
Maximum junction temperature
150
°C
±15
±8
KV
40
A
16
KV
IEC61000-4-2 (ESD)
air discharge
contact discharge
IEC61000-4-4 (EFT)
ESD Voltage
www.tw-gmc.com
Per Human Body Model
1
ESD5Z7V0
Electrical Parameter
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
Working Peak Reverse Voltage
IR
Maximum Reverse Leakage Current @ VRWM
IT
Test Current
VBR
Breakdown Voltage @ IT
IF
Forward Current
VF
Forward Voltage @ IF
Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified.VF = 0.9V at IF = 10mA
Device
ESD5Z7V0
Device
Marking
ZH
IR(uA)
VBR (V)@ IT
VC (V)
VC (V)
VRWM
(V)
@ VRWM
(Note 1)
Max
Max
Min
mA
Typ
Max
7.0
1.0
7.5
1.0
13.5
22.7
IT
@ IPP=5 A* @ Max IPP* (A)*
*Surge current waveform per Figure 1.
1. VBR is measured with a pluse test current IT at an ambient temperature of 25℃.
www.tw-gmc.com
1
2
IPP
PPK
C
(W)*
(pF)
Max
Max
Typ
8.8
200
65
ESD5Z7V0
SOD-523
D
−X−
NOTES:
1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994.
2. CONTROLLING DIMENSION: MILLIMETERS.
3. MAXIMUM LEAD THICKNESS INCLUDES LEAD FINISH.
MINIMUM LEAD THICKNESS IS THE MINIMUM THICKNESS OF
BASE MATERIAL.
4. DIMENSIONS D AND E DO NOT INCLUDE MOLD FLASH, PROTRUSIONS, OR GATE BURRS.
−Y−
E
1
2X b
0.08
M
2
MILLIMETERS
X Y
TOP VIEW
A
c
RECOMMENDED
SOLDERING FOOTPRINT*
PACKAGE
OUTLINE
www.tw-gmc.com
NOM
A
0.50
0.60
0.70
b
0.25
0.30
0.35
1.80
2X
0.40
1
3
MAX
c
0.07
0.14
0.20
D
1.10
1.20
1.30
E
0.70
0.80
0.90
HE
1.50
1.60
1.70
0.15
0.20
L2
SIDE VIEW
0.48
MIN
L
HE
2X
DIM
0.30 REF
0.25
很抱歉,暂时无法提供与“ESD5Z7V0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.10150
- 200+0.09450
- 600+0.08750
- 3000+0.08050
- 国内价格
- 20+0.12790
- 200+0.11810
- 600+0.10820
- 3000+0.09840
