S9014
S9014
    TWGMC(迪嘉)
    SOT-23
    三极管 NPN Ic=100mA Vceo=45V hfe=200~450 P=200mW SOT23
S9014 数据手册
S9014 S9014 TRANSISTOR (NPN) FEATURES Complementary to S9015 SOT-23 1.BASE 2.EMITTER 3.COLLECTOR MARKING: J6 MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter value units VCBO Collector-Base Voltage 50 V VCEO Collector-Emitter Voltage 45 V VEBO Emitter-Base Voltage 5 V IC Collector Current-Continuous 0.1 A PC Collector Power Dissipation 0.2 W TJ Junction Temperature 150 ℃ TSTG Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Symbol Test Collector-base breakdown voltage V(BR)CBO IC= 100µA, IE=0 50 V Collector-emitter breakdown voltage V(BR)CEO IC= 0.1mA, IB=0 45 V Emitter-base breakdown voltage V(BR)EBO IE=100µA, IC=0 5 V Parameter conditions MIN TYP MAX UNIT Collector cut-off current ICBO VCB=50V, IE=0 0.1 µA Collector cut-off current ICEO VCE=35V, IB=0 0.1 µA Emitter cut-off current IEBO VEB= 3V, IC=0 0.1 µA DC current gain hFE VCE=5V, IC= 1mA 200 450 Collector-emitter saturation voltage VCE(sat) IC=100 mA, IB= 5mA 0.3 V Base-emitter saturation voltage VBE(sat) IC=100 mA, 1 V Transition frequency www.tw-gmc.com fT VCE= 5V, f=30MHz 1 B= 5mA IC= 10mA 150 MHz S9014 Typical Characteristics Static Characteristic IC 16uA 14uA 4 12uA 10uA 8uA 2 IC Ta=25℃ 6uA 100 4uA 0 IB=2uA 0 2 6 COLLECTOR-EMITTER VOLTAGE VCEsat VCE 8 1 (V) 10 COLLECTOR CURRENT —— IC VBEsat 2 BASE-EMITTER SATURATION VOLTAGE VBEsat (V) 0.1 COMMON EMITTER VCE= 5V 10 0.1 (V) 1 COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat — — Ta=100℃ DC CURRENT GAIN COLLECTOR CURRENT COMMON EMITTER Ta=25℃ 20uA 18uA 6 hFE 1000 hFE (mA) 8 Ta=100℃ Ta=25℃ 1 —— IC 100 (mA) IC Ta=25℃ Ta=100℃ β=20 β=20 0.01 0.1 1 10 COLLECTOR CURRENT IC —— VBE fT 1000 100 (mA) —— IC Ta=25℃ 1 COMMON EMITTER VCE= 5V 0.6 0.3 0.9 1.2 100 10 COMMON EMITTER VCE=5V Ta=25℃ 1 0.1 1 100 —— Cob/ Cib VCB/ VEB COLLECTOR POWER DISSIPATION PC (mW) C Cib Cob 1 0.1 0.1 www.tw-gmc.com 10 1 REVERSE VOLTAGE VR PC 250 f=1MHz IE=0/IC=0 Ta=25 ℃ 10 10 COLLECTOR CURRENT BASE-EMMITER VOLTAGE VBE (V) (pF) IC (MHz) fT Ta=100℃ 10 0.1 0.0 CAPACITANCE 10 COLLECTOR CURRENT TRANSITION FREQUENCY IC COLLECTOR CURRENT 1 (mA) (mA) 100 IC 0.1 0.1 100 Ta 150 100 50 0 25 50 75 AMBIENT TEMPERATURE 2 100 (mA) 200 0 20 (V) —— IC 125 100 Ta (℃ ) 150 S9014 PACKAGE OUTLINE Plastic surface mounted package; 3 leads www.tw-gmc.com SOT-23 3
S9014 价格&库存
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
S9014
    • 100+0.06318
    • 1000+0.05152
    • 3000+0.03899
    • 9000+0.03510
    • 51000+0.03165
    • 99000+0.02981
    库存:72627
    S9014
    • 50+0.05792
    • 600+0.04722
    • 1200+0.04651
    • 3000+0.03574
    库存:2109
    S9014
    • 1+0.17270
    • 200+0.05753
    • 1500+0.03597
    • 3000+0.02860
    库存:2898
