VUP101M1VTR-0607K
VUP101M1VTR-0607K
    LELON(立隆电子)
    SMD,D6.3xL7.7mm
    贴片铝电解电容 SMD,D6.3xL7.7mm 100µF ±20% 35V 2000Hrs@125℃
VUP101M1VTR-0607K 数据手册
SMD Aluminum Electrolytic Capacitors VUP VUP Series Features ‧6.3φ ~ 10φ, 125℃, 2,000 ~ 3,000 hours assured ‧Low impedance capacitors ‧Chip type high temperature range, for +125℃ use ‧For automobile modules and other high temperature applications ‧RoHS compliance Marking color: Black Specifications Items Category Temperature Range Capacitance Tolerance Leakage Current (at 20℃) Tanδ (at 120 Hz, 20℃) Low Temperature Characteristics (at 120 Hz) Performance -40℃ ~ +125℃ ±20% I = 0.01CV or 3(µA) whichever is greater (after 2 minutes) Where, C = rated capacitance in µF, V = rated DC working voltage in V Rated Voltage Tanδ (max) 10 0.30 (at 120 Hz, 20℃) 16 0.23 25 0.18 35 0.16 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 10 16 25 35 Impedance Z(-40℃)/Z(+20℃) 12 8 6 4 Ratio 2,000 Hrs for φD = 6.3 mm 3,000 Hrs for φD ≧ 8 mm Capacitance Change Within ±30% of initial value Tanδ Less than 300% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 ~ 3,000 hours at 125℃. Test Time Endurance Shelf Life Test Ripple Current and Frequency Multipliers Test Time 1,000 Hrs Capacitance Change Within ±30% of initial value Tanδ Less than 300% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Frequency (Hz) Multiplier 50 0.35 120 0.50 300 0.64 1k 0.83 10k up 1.0 Diagram of Dimensions Lead Spacing and Diameter L A B C W P ± 0.2 6.3 7.7 ± 0.3 6.6 6.6 7.2 0.5 ~ 0.8 2.0 8 10 ± 0.5 8.3 8.3 9.0 0.7 ~ 1.1 3.1 10 10 ± 0.5 10.3 10.3 11.0 0.7 ~ 1.3 4.7 Marking φD = 6.3 mm 126 Unit: mm φD φD = 8 ~ 10 mm All product specifications in the catalog are subject to change without notice. (Cat. 2022E2) SMD Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: mA/rms at 100k Hz, 125℃ Impedance: Ω/ at 100k Hz, 20℃ Dimension and Permissible Ripple Current Rated Volt. (VDC) 10V (1A) φD×L 16V (1C) mA φD×L Imp. 25V (1E) mA φD×L 35V (1V) Imp. mA 330 6.3×7.7 0.5 197 47 470 6.3×7.7 8×10 0.5 0.2 197 270 100 101 8×10 0.2 270 220 221 8×10 0.2 10×10 0.15 500 330 331 8×10 10×10 0.2 0.15 470 471 10×10 0.15 6.3×7.7 8×10 0.5 0.2 197 270 270 8×10 0.2 270 270 500 10×10 0.15 500 500 10×10 0.15 500 Imp. mA φD×L 33 Cap. (µF) Contents Imp. VUP 6.3×7.7 8×10 8×10 10×10 0.5 0.2 0.2 0.15 197 270 270 500 10×10 0.15 500 Part Numbering System VUP series 100µF ±20% 16V Carrier Tape 6.3φ×7.7L VUP 101 M 1C TR - 0607 Series name Capacitance Capacitance Tolerance Rated Voltage Package Type Terminal Type Case Size Pb-free and Coated Case Lead Wire and Case Type Note: For more details, please refer to “Part Numbering System (SMD Type)” on page 15. All product specifications in the catalog are subject to change without notice. (Cat. 2022E2) 127
VUP101M1VTR-0607K 价格&库存
很抱歉,暂时无法提供与“VUP101M1VTR-0607K”相匹配的价格&库存,您可以联系我们找货
VUP101M1VTR-0607K
  • 5+0.90781
  • 20+0.82771
  • 100+0.74761
  • 500+0.66751
  • 1000+0.63012
  • 2000+0.60342
