RL16-500
RL16-500
    RUILON(瑞隆源)
    PTC_D10.7X3MM_TM
    PTC自恢复保险丝 PTC_D10.7X3MM_TM 16V 5A
RL16-500 数据手册
Positive Thermal Coefficient (PTC) RL16 Series Description Positive Thermal Coefficient devices(PTC),provide over-current protection for electrical and electronic devices. They function using conducting strips of metal imbedded inside polymers. Under normal conditions, the devices resistance is near zero, but over-current conditions will heat the PTC and expand the polymer, increasing the impedance. When current returns to normal, the components cool down, returning to their original shape and very low levels of resistance. Applications l Over-current and over-temperature protection of Features automotive electronics l I(hold): 0.3~15A l Hard disk drives l 16V Operating voltages l Point-of-sale (POS) equipment l Radial leaded devices. l PCMCIA cards l Over-current protection l Power over Ethernet (POE) l Very high voltage surge capabilities. l HDMI 1.4 Source protection l Available in lead-free version. l Computers & peripherals l Fast time–to–trip l Industrial control l RoHS compliant, Lead- Free and Halogen-Free l Security systems Part Number Code R L LOGO X X X - Voltage rating(VDC) X X X Hold current Environmental Specifications Test Conditions Resistance change Passive aging +85℃,1000hrs ±8% typical Humidity aging +85℃,85%R.H.1000hrs ±8% typical Thermal shock +125℃ to -55℃,10times ±12% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2020-05-12 Page:1 Positive Thermal Coefficient (PTC) RL16 Series Electrical Characteristic Ihold (A) IT (A) Vmax (V) RL16-030 0.3 0.6 RL16-050 0.5 RL16-075 Model Maximum Time to Trip Imax (A) Pd typ (W) Current(A) Time(S) 16 1.5 1 40 1.0 16 2.5 1.1 0.75 1.5 16 3.75 RL16-090 0.9 1.8 16 RL16-100 1.0 2.0 RL16-110 1.1 RL16-135 Resistance(Ω) Rimin R1max 0.3 0.3 1.3 40 0.4 0.2 0.65 4.8 40 0.3 0.1 0.28 4.5 1.2 40 0.6 0.09 0.25 16 5.0 5.0 40 1.0 0.07 0.25 2.2 16 5.5 2.3 40 0.7 0.08 0.24 1.35 2.7 16 6.75 4.5 40 0.8 0.04 0.25 RL16-160 1.6 3.2 16 8 9 40 0.9 0.03 0.2 RL16-200 2 4 16 10 9 40 0.9 0.018 0.09 RL16-300 3 6 16 15 2 40 2.3 0.02 0.11 RL16-400 4 8 16 20 3.5 40 2.4 0.02 0.08 RL16-500 5 10 16 25 3.6 40 2.6 0.014 0.044 RL16-600 6 12 16 30 5.8 40 2.8 0.009 0.031 RL16-700 7 14 16 35 8 40 3.0 0.006 0.022 RL16-800 8 16 16 40 9 40 3.0 0.005 0.021 RL16-900 9 18 16 45 12 40 3.3 0.004 0.018 RL16-1000 10 20 16 50 12.5 40 3.6 0.003 0.015 RL16-1100 11 22 16 55 13.5 40 3.7 0.003 0.013 RL16-1200 12 24 16 60 16 40 4.2 0.002 0.012 RL16-1300 13 26 16 65 18 40 4.6 0.002 0.012 RL16-1400 14 28 16 70 20 40 4.6 0.002 0.011 RL16-1500 15 30 16 75 18 40 4.6 0.002 0.0075 IH=Hold current: maximum current at which the device will not trip at 25℃ still air. IT=Trip current: minimum current at which the device will nalways at 25℃ still air. V max=Maximum voltage device can withstand without damage at rated current. Imax=Maximum fault current device can withstand tithout damage at rated voltage. T trip=Maximum time to trip(s) at assigned current. Pd=Typical power dissipation: typical amount of power dissipated by the decice when in state air environment. Ri min=Minimum device resistance at 25℃ prior to tripping. R1 max=Maximum device resistance is measured one hour post reflow. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2020-05-12 Page:2 Positive Thermal Coefficient (PTC) RL16 Series Solder reflow conditions 300 Wave Soldering 5s max. 250 Soldering Time:≤3sec. Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 Manual soldering Temperature℃ Soldering Temperature:260℃~270℃ Soldering 245℃-260 200 Pre-heating 150 100℃-130℃ 100 Soldering Temperature:250℃~280℃ 50 Soldering Time:≤3sec. 0 Cooling 0 50 100 Soldering Position: Resettable fuse wire and the bottom ≥ 6mm。 150 200 250 Time(s) Environmental temperature and IH,IT 300 250 200 150 100 IT 50 IH 0 -30 -20 -10 0 10 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. 20 30 40 50 Revised: 2020-05-12 60 70 80 85 Page:3 Positive Thermal Coefficient (PTC) RL16 Series Product Dimensions Marking Marking fig.1 Marking fig.2 fig.3 Dimensions(mm) Type Number Dimensions(in) Shape A(max) B(max) C(typ) D(max) LeadΦ (typ) A(max) B(max) C(typ) D(max) LeadΦ (typ) Fig RL16-030 4.5 9.0 5.1 3.1 0.5 0.177 0.354 0.201 0.122 0.02 1 RL16-050 5.5 12.0 5.1 3.0 0.5 0.224 0.217 0.201 0.118 0.02 1 RL16-075 6.9 11.4 5.1 3.0 0.5 0.272 0.449 0.201 0.118 0.02 1 RL16-090 7.4 13.5 5.1 3.0 0.5 0.291 0.531 0.201 0.118 0.02 1 RL16-100 7.4 12.2 5.1 3.0 0.5 0.291 0.480 0.201 0.118 0.02 1 RL16-110 7.4 14.2 5.1 3.0 0.6 0.291 0.559 0.201 0.118 0.024 1 RL16-135 8.9 13.5 5.1 3.0 0.6 0.350 0.531 0.201 0.118 0.024 3 RL16-160 8.9 16.7 5.1 3.0 0.6 0.350 0.657 0.201 0.118 0.024 1 RL16-200 8.9 14.8 5.1 3.0 0.6 0.350 0.583 0.201 0.118 0.024 3 RL16-300 9.0 12.0 5.1 3.0 0.8 0.354 0.472 0.201 0.118 0.031 2 RL16-400 10.0 13.0 5.1 3.0 0.8 0.394 0.512 0.201 0.118 0.031 2 RL16-500 10.7 17.5 5.1 3.0 0.8 0.421 0.689 0.201 0.118 0.031 2 RL16-600 13.5 17.5 5.1 3.0 0.8 0.531 0.689 0.201 0.118 0.031 2 RL16-700 13.5 23.0 5.1 3.0 0.8 0.531 0.906 0.201 0.118 0.031 2 RL16-800 13.5 23.0 5.1 3.0 0.8 0.531 0.906 0.201 0.118 0.031 2 RL16-900 15.0 24.0 5.1 3.0 0.8 0.591 0.945 0.201 0.118 0.031 2 RL16-1000 18.0 26.0 5.1 3.0 0.8 0.709 1.024 0.201 0.118 0.031 2 RL16-1100 18.2 26.0 5.1 3.0 0.8 0.717 1.024 0.201 0.118 0.031 2 RL16-1200 22.5 28.0 5.1 3.5 0.8 0.886 1.102 0.201 0.138 0.031 2 RL16-1300 26.5 30.0 10.2 3.0 0.8 1.043 1.181 0.402 0.118 0.031 2 RL16-1400 28.6 30.0 10.2 3.5 0.8 1.126 1.181 0.402 0.138 0.031 2 RL16-1500 28.6 31.5 10.2 3.0 0.8 1.043 1.122 0.402 0.118 0.031 2 Packaging Part Number Quantity RL16-030~RL16-1000 500pcs/bag RL16-1100~RL16-1200 250pcs/bag RL16-1300~RL16-1500 200pcs/bag Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2020-05-12 Page:4
