RTL8382M-VB-CG
RTL8382M-VB-CG
    REALTEK(瑞昱)
    LQFP-216-EP(24x24)
    多层管理10*10/100/1000M端口交换机控制器
RTL8382M-VB-CG 数据手册
RTL8380M-VB-CG MULTI-LAYER MANAGED 10*10/100/1000M-PORT SWITCH CONTROLLER RTL8382M-VB-CG MULTI-LAYER MANAGED 28*10/100/1000M-PORT SWITCH CONTROLLER DATASHEET (CONFIDENTIAL: Development Partners Only) Rev. 1.2 30 January 2016 Track ID: Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com RTL8380M-VB/RTL8382M-VB Datasheet COPYRIGHT ©2016 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document ‘as is’, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document provides detailed user guidelines to achieve the best performance when implementing the Realtek Ethernet Switch Controllers. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. REVISION HISTORY Revision 1.0 1.1 1.2 Release Date 2014/01/20 2016/1/8 2016/6/30 10/100/1000M Switch Controllers Summary First release. Remove the support for 10M-EEE and I2C master for EEPROM. Separate unmanaged series RTL8382L. ii Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Table of Contents 1. GENERAL DESCRIPTION .............................................................................................................................................. 1 2. FEATURES ......................................................................................................................................................................... 3 3. SYSTEM APPLICATIONS ............................................................................................................................................... 4 3.1. 3.2. 3.3. 3.4. 4. BLOCK DIAGRAMS ......................................................................................................................................................... 8 4.1. 4.2. 5. RTL8380M-VB: MANAGED 8*1000M UTP+2*1000BASE-X SWITCH ....................................................................... 4 RTL8382M-VB: MANAGED 28*1000M SWITCH VIA RTL8218B PHY ...................................................................... 5 RTL8382M-VB: MANAGED 20*1000M UTP+4*1000M COMBO SWITCH ................................................................. 6 RTL8382M-VB: MANAGED 24*1000M UTP+2*1000BASE-X SWITCH ..................................................................... 7 RTL8380M-VB BLOCK DIAGRAM .............................................................................................................................. 8 RTL8382M-VB BLOCK DIAGRAM .............................................................................................................................. 9 PIN ASSIGNMENTS AND DESCRIPTION (RTL8380M-VB) ................................................................................... 10 5.1. PIN ASSIGNMENTS FIGURE (RTL8380M-VB) ........................................................................................................... 10 5.2. PACKAGE IDENTIFICATION ......................................................................................................................................... 10 5.3. PIN ASSIGNMENTS TABLE CODES (RTL8380M-VB) ................................................................................................. 11 5.4. PIN ASSIGNMENTS TABLE (RTL8380M-VB) ............................................................................................................. 11 5.5. PIN DESCRIPTIONS (RTL8380M-VB) ........................................................................................................................ 16 5.5.1. 1000M Ethernet PHY MDI Interface Pins ............................................................................................................ 16 5.5.2. SGMII Interface Pins............................................................................................................................................ 18 5.5.3. 1000Base-X/100Base-FX Interface Pins .............................................................................................................. 18 5.5.4. DDR1/2 SDRAM Interface Pins ........................................................................................................................... 19 5.5.5. DDR3 SDRAM Interface Pins .............................................................................................................................. 20 5.5.6. Master Mode SPI Flash Interface Pins ................................................................................................................ 20 5.5.7. UART Interface Pins............................................................................................................................................. 21 5.5.8. LED Interface Pins ............................................................................................................................................... 21 5.5.9. GPIO Interface Pins ............................................................................................................................................. 21 5.5.10. EJTAG Interface Pins ...................................................................................................................................... 21 5.5.11. Configuration Strapping Pins .......................................................................................................................... 22 5.5.12. Miscellaneous Interface Pins ........................................................................................................................... 23 5.5.13. Power and Ground Pins .................................................................................................................................. 24 6. PIN ASSIGNMENTS AND DESCRIPTION (RTL8382M-VB) ................................................................................... 25 6.1. PIN ASSIGNMENTS FIGURE (RTL8382M-VB) ........................................................................................................... 25 6.2. PACKAGE IDENTIFICATION ......................................................................................................................................... 25 6.3. PIN ASSIGNMENTS TABLE CODES (RTL8382M-VB) ................................................................................................. 26 6.4. PIN ASSIGNMENTS TABLE (RTL8382M-VB) ............................................................................................................. 26 6.5. PIN DESCRIPTIONS (RTL8382M-VB) ........................................................................................................................ 44 6.5.1. 1000M Ethernet PHY MDI Interface Pins ............................................................................................................ 44 6.5.2. SGMII Interface Pins ............................................................................................................................................ 46 6.5.3. QSGMII Interface Pins ......................................................................................................................................... 46 6.5.4. 1000Base-X/100Base-FX Interface Pins .............................................................................................................. 47 6.5.5. DDR1/2 SDRAM Interface Pins ........................................................................................................................... 47 6.5.6. DDR3 SDRAM Interface Pins .............................................................................................................................. 48 6.5.7. Master Mode SPI Flash Interface Pins ................................................................................................................ 48 6.5.8. UART Interface Pins............................................................................................................................................. 49 6.5.9. LED Interface Pins ............................................................................................................................................... 49 6.5.10. GPIO Interface Pins ........................................................................................................................................ 49 6.5.11. EJTAG Interface Pins ...................................................................................................................................... 49 6.5.12. Configuration Strapping Pins .......................................................................................................................... 50 6.5.13. Miscellaneous Interface Pins ........................................................................................................................... 51 10/100/1000M Switch Controllers iii Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.14. 7. Power and Ground Pins .................................................................................................................................. 52 SWITCH FUNCTION DESCRIPTION ......................................................................................................................... 52 7.1. HARDWARE RESET AND SOFTWARE RESET................................................................................................................ 52 7.1.1. Hardware Reset .................................................................................................................................................... 52 7.1.2. Software Reset ...................................................................................................................................................... 52 7.2. CRYSTAL.................................................................................................................................................................... 53 7.3. IEEE 802.3AZ ENERGY EFFICIENT ETHERNET (EEE) ................................................................................................ 53 7.4. LAYER 2 LEARNING AND FORWARDING ..................................................................................................................... 53 7.4.1. Forwarding ........................................................................................................................................................... 53 7.4.2. Learning ............................................................................................................................................................... 53 7.4.3. DA/SA Block ......................................................................................................................................................... 54 7.5. PORT ISOLATION ........................................................................................................................................................ 54 7.6. IEEE 802.3X FLOW CONTROL ................................................................................................................................... 56 7.7. HALF DUPLEX BACKPRESSURE .................................................................................................................................. 57 7.7.1. Collision-Based Backpressure (Jam Mode) ......................................................................................................... 57 7.7.2. Carrier-Based Backpressure (I.e., Defer Mode) .................................................................................................. 57 7.8. LAYER 2 MULTICAST AND IP MULTICAST ................................................................................................................. 57 7.9. IEEE 802.1D/1W/1S (STP/RSTP/MSTP) ................................................................................................................... 58 7.10. IEEE 802.1P AND IEEE 802.1Q (VLAN) .................................................................................................................. 59 7.11. IEEE 802.1X (NETWORK ACCESS CONTROL) ............................................................................................................ 60 7.12. RESERVED MULTICAST ADDRESS HANDLING ............................................................................................................ 61 7.13. LAYER 2 TRAFFIC SUPPRESSION (STORM CONTROL) ................................................................................................. 62 7.14. PIE (PACKET INSPECTION ENGINE) ............................................................................................................................ 62 7.14.1. Ingress ACL ..................................................................................................................................................... 62 7.15. INPUT BANDWIDTH CONTROL AND ACL TRAFFIC METER ......................................................................................... 63 7.15.1. Input Bandwidth Control ................................................................................................................................. 63 7.15.2. ACL Traffic Meter............................................................................................................................................ 63 7.16. IEEE 802.3AD LINK AGGREGATION PROTOCOL ........................................................................................................ 63 7.17. IEEE 802.1AD VLAN STACKING............................................................................................................................... 64 7.18. QUALITY OF SERVICE (QOS) ...................................................................................................................................... 65 7.19. PACKET SCHEDULING (WRR AND WFQ) .................................................................................................................. 66 7.20. PACKET DROP ALGORITHM (TD) ............................................................................................................................... 67 7.21. EGRESS PACKET REMARKING .................................................................................................................................... 67 7.22. INGRESS AND EGRESS PORT MIRROR ......................................................................................................................... 67 7.22.1. Remote Mirror (RSPAN) .................................................................................................................................. 68 7.23. MANAGEMENT INFORMATION BASE (MIB) ............................................................................................................... 69 7.24. NIC AND CPU TAG FORWARDING ............................................................................................................................. 69 7.25. INDIRECT TABLE ACCESS........................................................................................................................................... 70 7.26. EXTERNAL PHY REGISTER ACCESS ........................................................................................................................... 70 7.27. SWITCH INTERRUPT INDICATION ................................................................................................................................ 70 8. CPU FUNCTION DESCRIPTION ................................................................................................................................. 71 8.1. 8.2. 8.3. 9. MIPS-4KEC............................................................................................................................................................... 71 SPI FLASH.................................................................................................................................................................. 71 SDRAM INTERFACE CONFIGURATION....................................................................................................................... 71 INTERFACE DESCRIPTIONS ...................................................................................................................................... 72 9.1. 9.2. 9.3. 9.4. 9.5. 9.6. 9.7. QSGMII .................................................................................................................................................................... 72 SGMII ....................................................................................................................................................................... 72 DDR1 SDRAM ......................................................................................................................................................... 73 DDR2 SDRAM ......................................................................................................................................................... 74 DDR3 SDRAM ......................................................................................................................................................... 75 SPI FLASH INTERFACE ............................................................................................................................................... 75 UART ........................................................................................................................................................................ 76 10/100/1000M Switch Controllers iv Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.8. 9.9. 9.10. 9.11. 10. EJTAG ...................................................................................................................................................................... 76 I2C SLAVE INTERFACE ............................................................................................................................................... 77 SPI SLAVE INTERFACE ............................................................................................................................................... 78 SERIAL LED............................................................................................................................................................... 79 ELECTRICAL AC/DC CHARACTERISTICS ............................................................................................................. 81 10.1. ABSOLUTE MAXIMUM RATINGS ................................................................................................................................ 81 10.2. OPERATING RANGE .................................................................................................................................................... 81 10.3. DC CHARACTERISTICS ............................................................................................................................................... 81 10.4. AC CHARACTERISTICS ............................................................................................................................................... 82 10.4.1. QSGMII Differential Transmitter Characteristics ........................................................................................... 82 10.4.2. QSGMII Differential Receiver Characteristics................................................................................................ 82 10.4.3. SGMII Differential Transmitter Characteristics.............................................................................................. 84 10.4.4. SGMII Differential Receiver Characteristics .................................................................................................. 85 10.4.5. 1000Base-X/100Base-FX Differential Transmitter Characteristics ................................................................ 86 10.4.6. 1000Base-X/100Base-FX Differential Receiver Characteristics ..................................................................... 87 10.4.7. DDR2 Characteristics ..................................................................................................................................... 88 10.4.8. DDR3 Characteristics ..................................................................................................................................... 89 10.4.9. SPI Interface Characteristics........................................................................................................................... 90 10.4.10. SMI (MDC/MDIO) Interface Characteristics .................................................................................................. 91 10.4.11. Serial Mode LED ............................................................................................................................................. 91 11. PACKAGE INFORMATION .......................................................................................................................................... 92 11.1. 12. LQFP216-E-PAD (24*24MM) ................................................................................................................................... 92 ORDERING INFORMATION ........................................................................................................................................ 94 10/100/1000M Switch Controllers v Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet List of Tables TABLE 1. PIN ASSIGNMENTS TABLE (RTL8380M-VB) ............................................................................................................... 11 TABLE 2. 1000M ETHERNET PHY MDI INTERFACE PINS ............................................................................................................ 16 TABLE 3. SGMII INTERFACE PINS ............................................................................................................................................... 18 TABLE 4. 1000BASE-X/100BASE-FX INTERFACE PINS ............................................................................................................... 18 TABLE 5. DDR1/2 SDRAM INTERFACE PINS .............................................................................................................................. 19 TABLE 6. DDR3 SDRAM INTERFACE PINS ................................................................................................................................. 20 TABLE 7. MASTER MODE SPI FLASH INTERFACE PINS ................................................................................................................ 20 TABLE 8. UART INTERFACE PINS ............................................................................................................................................... 21 TABLE 9. LED INTERFACE PINS .................................................................................................................................................. 21 TABLE 10. GPIO INTERFACE PINS ................................................................................................................................................ 21 TABLE 11. EJTAG INTERFACE PINS.............................................................................................................................................. 21 TABLE 12. CONFIGURATION STRAPPING PINS ............................................................................................................................... 22 TABLE 13. MISCELLANEOUS INTERFACE PINS............................................................................................................................... 23 TABLE 14. POWER AND GROUND PINS .......................................................................................................................................... 24 TABLE 15. PIN ASSIGNMENTS TABLE (RTL8382M-VB) .............................................................................................................. 26 TABLE 16. 1000M ETHERNET PHY MDI INTERFACE PINS ........................................................................................................... 44 TABLE 17. SGMII INTERFACE PINS .............................................................................................................................................. 46 TABLE 18. QSGMII INTERFACE PINS ............................................................................................................................................ 46 TABLE 19. 1000BASE-X/100BASE-FX INTERFACE PINS ............................................................................................................... 47 TABLE 20. DDR1/2 SDRAM INTERFACE PINS ............................................................................................................................. 47 TABLE 21. DDR3 SDRAM INTERFACE PINS ................................................................................................................................ 48 TABLE 22. MASTER MODE SPI FLASH INTERFACE PINS ............................................................................................................... 48 TABLE 23. UART INTERFACE PINS ............................................................................................................................................... 49 TABLE 24. LED INTERFACE PINS .................................................................................................................................................. 49 TABLE 25. GPIO INTERFACE PINS ................................................................................................................................................ 49 TABLE 26. EJTAG INTERFACE PINS.............................................................................................................................................. 49 TABLE 27. CONFIGURATION STRAPPING PINS ............................................................................................................................... 50 TABLE 28. MISCELLANEOUS INTERFACE PINS............................................................................................................................... 51 TABLE 29. POWER AND GROUND PINS .......................................................................................................................................... 52 TABLE 30. SPANNING TREE AND RAPID SPANNING TREE ACTION ................................................................................................ 59 TABLE 31. FORWARDING OF HOST N ............................................................................................................................................. 61 TABLE 32. RESERVED MULTICAST ADDRESS DEFAULT ACTIONS ................................................................................................. 61 TABLE 33. UART CONTROL INTERFACE PINS ............................................................................................................................... 76 TABLE 34. EJTAG INTERFACE PINS.............................................................................................................................................. 76 TABLE 35. SPI SLAVE INTERFACE ................................................................................................................................................. 78 TABLE 36. ABSOLUTE MAXIMUM RATINGS .................................................................................................................................. 81 TABLE 37. RECOMMENDED OPERATING RANGE ........................................................................................................................... 81 TABLE 38. DC CHARACTERISTICS (IO POWER =3.3V) .................................................................................................................. 81 TABLE 39. QSGMII DIFFERENTIAL TRANSMITTER CHARACTERISTICS ......................................................................................... 82 TABLE 40. QSGMII DIFFERENTIAL RECEIVER CHARACTERISTICS ............................................................................................... 82 TABLE 41. SGMII DIFFERENTIAL TRANSMITTER CHARACTERISTICS............................................................................................ 84 TABLE 42. SGMII DIFFERENTIAL RECEIVER CHARACTERISTICS .................................................................................................. 85 TABLE 43. 1000BASE-X/100BASE-FX DIFFERENTIAL TRANSMITTER CHARACTERISTICS ............................................................ 86 TABLE 44. 1000BASE-X/100BASE-FX DIFFERENTIAL RECEIVER CHARACTERISTICS ................................................................... 87 TABLE 45. DDR2 SDRAM TIMING CHARACTERISTICS ................................................................................................................ 88 TABLE 46. DDR3 SDRAM TIMING CHARACTERISTICS ................................................................................................................ 89 TABLE 47. SPI INTERFACE TIMING CHARACTERISTICS ................................................................................................................. 90 TABLE 48. SMI (MDC/MDIO) TIMING CHARACTERISTICS .......................................................................................................... 91 TABLE 49. SERIAL MODE LED AC TIMING .................................................................................................................................. 91 TABLE 50. ORDERING INFORMATION ............................................................................................................................................ 94 10/100/1000M Switch Controllers vi Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10/100/1000M Switch Controllers vii Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet List of Figures FIGURE 1. MANAGED 8*1000M UTP+2*1000BASE-X SWITCH .................................................................................................... 4 FIGURE 2. MANAGED 28*1000M SWITCH VIA RTL8218B PHY ................................................................................................... 5 FIGURE 3. MANAGED 20*1000M UTP+4*1000M COMBO SWITCH .............................................................................................. 6 FIGURE 4. MANAGED 24*1000M UTP+2*1000BASE-X SWITCH .................................................................................................. 7 FIGURE 5. RTL8380M-VB BLOCK DIAGRAM ............................................................................................................................... 8 FIGURE 6. RTL8382M-VB BLOCK DIAGRAM ............................................................................................................................... 9 FIGURE 7. PIN ASSIGNMENTS (RTL8380M-VB) ......................................................................................................................... 10 FIGURE 8. PIN ASSIGNMENTS (RTL8382M-VB) ......................................................................................................................... 25 FIGURE 9. DA/SA BLOCK ............................................................................................................................................................. 54 FIGURE 10. PORT ISOLATION EXAMPLE ........................................................................................................................................ 55 FIGURE 11. TX PAUSE FRAME FORMAT ........................................................................................................................................ 56 FIGURE 12. FLOW CONTROL STATE MACHINE .............................................................................................................................. 56 FIGURE 13. SIGNAL TIMING FOR COLLISION-BASED BACKPRESSURE ........................................................................................... 57 FIGURE 14. SPANNING TREE AND RAPID SPANNING TREE PORT STATES ...................................................................................... 58 FIGURE 15. IEEE 802.1AD FRAME FORMAT.................................................................................................................................. 64 FIGURE 16. PRIORITY SELECTION TABLE WEIGHT RULES EXAMPLE ............................................................................................ 65 FIGURE 17. PER-PORT QUEUE MANAGEMENT .............................................................................................................................. 66 FIGURE 18. RSPAN ENCAPSULATION ........................................................................................................................................... 68 FIGURE 19. RSPAN ILLUSTRATION .............................................................................................................................................. 68 FIGURE 20. NIC ARCHITECTURE ................................................................................................................................................... 69 FIGURE 21. QSGMII INTERCONNECTION ...................................................................................................................................... 72 FIGURE 22. SGMII SIGNAL ........................................................................................................................................................... 72 FIGURE 23. DDR1 SDRAM CONFIGURATION .............................................................................................................................. 73 FIGURE 24. DDR2 SDRAM CONFIGURATION .............................................................................................................................. 74 FIGURE 25. DDR3 SDRAM CONFIGURATION .............................................................................................................................. 75 FIGURE 26. SPI FLASH CONFIGURATION ....................................................................................................................................... 75 FIGURE 27. EJTAG USING A 5-PIN JTAG INTERFACE TO ACCESS DATA BLOCK.......................................................................... 76 FIGURE 28. I2C SLAVE INTERFACE ACCESS DATA SEQUENCE ...................................................................................................... 77 FIGURE 29. SERIAL LED CONNECTION ......................................................................................................................................... 79 FIGURE 30. QSGMII DIFFERENTIAL TRANSMITTER EYE DIAGRAM .............................................................................................. 82 FIGURE 31. QSGMII DIFFERENTIAL RECEIVER EYE DIAGRAM .................................................................................................... 83 FIGURE 32. SGMII DIFFERENTIAL TRANSMITTER EYE DIAGRAM ................................................................................................. 84 FIGURE 33. SGMII DIFFERENTIAL RECEIVER EYE DIAGRAM ....................................................................................................... 85 FIGURE 34. 1000BASE-X/100BASE-FX DIFFERENTIAL TRANSMITTER EYE DIAGRAM ................................................................. 86 FIGURE 35. 1000BASE-X/100BASE-FX DIFFERENTIAL RECEIVER EYE DIAGRAM ........................................................................ 87 FIGURE 36. DDR2 TIMING CHARACTERISTICS .............................................................................................................................. 88 FIGURE 37. DDR3 TIMING CHARACTERISTICS .............................................................................................................................. 89 FIGURE 38. SPI INTERFACE TIMING .............................................................................................................................................. 90 FIGURE 39. SMI (MDC/MDIO) TIMING ....................................................................................................................................... 91 FIGURE 40. SERIAL MODE LED AC TIMING PARAMETERS ........................................................................................................... 91 10/100/1000M Switch Controllers viii Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 1. General Description The RTL8380M-VB-CG and RTL8382M-VB-CG are new generation Gigabit switches supporting Energy Efficient Ethernet (EEE). The RTL8380M-VB is an 10-port 10/100/1000M switch controller, and the RTL8382M-VB is a 28-port 10/100/1000M switch controller. Both of them have an 8-port 10/100/1000M Ethernet PHY embedded. The RTL8380M-VB/RTL8382M-VB are provided via a 55nm CMOS process in an LQFP-216 E-PAD package. The Memory interface of the RTL8380M-VB/RTL8382M-VB supports DDR1/DDR2/DDR3 and SPI Flash. The following table lists the main differences between the RTL8380M-VB/RTL8382MVB: Features Port Capacity Management Mode DDR1/2/3 SPI Flash EEPROM Config. Internal CPU RTL8380M-VB 8G*UTP + 2*1000Base-X Managed Mode Only Yes Yes Yes Yes RTL8382M-VB 24G*UTP + 4GCombo Managed Mode Only Yes Yes Yes Yes The RTL8380M-VB supports two-pairs of SGMII/1000Base-X. The RTL8382M-VB support four pairs of serially connected QSGMII interface ports to connect to two Octal Gigabit PHYs (RTL8218B). The RTL8382M-VB also supports one serially connected QSGMII interface port to connect to 1 Quad Gigabit PHY (RTL8214FC). The RTL8380M-VB/RTL8382M-VB have an embedded 500MHz MIPS-4KEc CPU that supports a 32MByte (max.) SPI flash and DDR1/DDR2/DDR3 memory interface. Two 16C550 compatible UARTs are integrated for low speed serial data, and one E-JTAG is supported for on-chip debugging. There are 8K entries in the 4-way hash L2 table for MAC address learning and searching. The RTL8380M-VB/RTL8382M-VB supports two hash algorithms. An independent 512-entry Multicast table supports Layer 2 and IP multicast functions. The RTL8380M-VB/RTL8382M-VB has a 4K-entry VLAN table for 802.1Q port-based, protocol-andport-based, 802.1Q-based, IP-subnet-based, and ACL Rules-based VLAN operation to separate logical connectivity from physical connectivity. Support is provided for IVL (Independent VLAN Learning), SVL (Shared VLAN Learning), and IVL/SVL (both Independent and Shared VLAN Learning) for flexible network topology architecture. The RTL8380M-VB/RTL8382M-VB supports a 1.5K-entry Access Control List (ACL) that parses various protocol packet types and performs configurable actions, e.g., Permit/Drop, redirect, and traffic policing. The RTL8380M-VB/RTL8382M-VB supports per-port ingress/egress bandwidth control and per-queue egress bandwidth control. It has 8 physical queues in each port. The RTL8380M-VB/RTL8382M-VB provides three types of packet scheduling; SP (Strict Priority), WFQ (Weighted Fair Queuing), and WRR (Weighted Round Robin). Each queue provides a leaky-bucket to shape the incoming traffic into the average rate behavior. 10/100/1000M Switch Controllers 1 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Port-based 802.1X and MAC-based 802.1X authentication prevent unauthorized users from accessing internal servers. The RTL8380M-VB/RTL8382M-VB supports port isolation to enhance port security. The RTL8380M-VB/RTL8382M-VB also supports a 4-set port mirror configuration to mirror ingress and egress traffic. For network management purposes, complete MIB counter support reflects the switch status in real time. Support is provided for link aggregation to increase link redundancy, and increase linear bandwidth. The RTL8380M-VB/RTL8382M-VB adopts advanced technologies such as Realtek Cable Test (RTCT), Automatic loop detection and prevention (RLPP/RLDP), Attack Prevention, and MAC Address Learning Constraints. 10/100/1000M Switch Controllers 2 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 2.  Features  Hardware Interface      RTL8380M-VB  10-port Gigabit wire speed forwarding capability  Supports 8-port 10/100/1000M Ethernet PHY  Supports two pairs of SGMII/1000Base-X RTL8382M-VB  RTL8382M-VB provides 28-port Gigabit wire speed forwarding capability  Supports 8-port 10/100/1000M Ethernet PHY  Support 4-pairs of QSGMII to connect to external 8-port 10/100/1000M Ethernet PHYs  RTL8382M-VB supports an extra 1 pair of QSGMII or 2 pairs of SGMII/1000Base-X DRAM and Flash Interface  Support one 8-bit 128MByte DDR1/DDR2 or one 8-bit 256MByte DDR3 for internal CPU  Support one 32MByte SPI flash interface Embedded MIPS-4KEc with MMU  MIPS32 instruction set and 5-stage pipeline  500MHz CPU clock rate  16KByte I-Cache and 16KByte DCache  Built-in 128KByte SRAM  32 Translation Look-aside Buffer (TLB) entries  Two UART interfaces to control the internal CPU via a Command Line Interface (CLI)  L2 VLAN Function     I2C and slave SPI interface for external master interface to access internal registers Supports IVL, SVL, and IVL/SVL Supports IEEE 802.1Q VLAN  4K-entry VLAN Table  Port-based VLAN  Port-and-protocol-based VLAN  ACL-based VLAN  Supports up to 64 spanning tree instances for MSTP (IEEE 802.1s), RSTP, and STP Supports flexible Q-in-Q and VLAN Tag function L2 MAC Function  4.1 Mbit SRAM Packet Buffer  Packet length of 10000Bytes  8K-entry L2 MAC table with 4-way hashing algorithm  Independent 512-entry L2/IP Multicast table for multicast function  2-hash algorithm selection for L2 table searching/learning  Aging timer range from 0.2s to 1600000s  Supports IGMPv1/2/3 and MLDv1/2 snooping  Supports Reserved Multicast Addresses processing  Limited learned L2 MAC entry on each port and each VLAN Supports EJTAG interface 10/100/1000M Switch Controllers 3 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet  L2 Miscellaneous Functions  Supports broadcast, multicast, unknownmulticast, and unknown-unicast packet suppression control  Software supports IEEE 802.1x,        Supports Port Mirroring  Supports 4-sets of port mirrors  Flow-based mirror function  RSPAN function for remote mirroring Supports Link Aggregation (IEEE 802.3ad) for 8 groups of link aggregators with up to 8 ports per-group  Supports multiple actions  Supports L3 Unicast Routing, 512 next hop MAC Support QoS Functions  8 physical queues per port  Strict Priority (SP) and Weighted Fair Queue (WFQ), Weighted Round Robin (WRR) packet scheduling  QoS remarking for 802.1p and DSCP (includes IPv4/IPv6)  Supports average packet rate control leaky-bucket per queue, in 16Kbps steps up to 1Gbps maximum  Ingress port bandwidth control, in 16Kbps steps up to 1Gbps maximum  Egress port bandwidth control, in 16Kbps steps up to 1Gbps maximum Port isolation function to enhance port security Attack Prevention  Land attack  Blat attack  TCP control flag attack  Ping attack  Packet length attack Supports Automatic loop detection and isolation (RLPP/RLDP) Access Control List (ACL) Function  1.5K-entry ACL table  L2/L3/L4 format (e.g., DMAC, SMAC, and Ether-Type)  EAV, 1588v2  Cable Diagnostics (RTCT)  IEEE 802.3az Energy Efficient Ethernet (EEE)  MIB Functions  Ethernet-like MIB (RFC 3635)  IPv6 Parsing  Interface Group MIB (RFC 2863)  Per-flow traffic policing  RMON (RFC 2819)  16-entry VID range checking  Bridge MIB (RFC 1493)  8-entry IPv4 or 2-entry IPv6 range checking  Bridge MIB Extension (RFC 2674)  256 leaky-buckets for flow traffic policing; in 16Kbps steps up to 1Gbps maximum  256 log counters to enhance MIB count functionality 10/100/1000M Switch Controllers  Others  55nm CMOS process  3.3V/1.1V dual power input  LQFP216 E-PAD package 3 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 3. 3.1. System Applications RTL8380M-VB: Managed 8*1000M UTP+2*1000Base-X Switch DDR1/DDR2/DDR3 Flash 8*1000M+2*1000Base-X Switch with Embedded CPU 1000Base-X 1000Base-X 8*1000Base-T RTL8380M (8*1000M+2*1000Base-X Switch) LQFP216-EPAD LED Interface Figure 1. Managed 8*1000M UTP+2*1000Base-X Switch 10/100/1000M Switch Controllers 4 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 3.2. RTL8382M-VB: Managed 28*1000M Switch via RTL8218B PHY DDR1/DDR2/DDR3* Flash Managed 28*1000M port Switch QSGMII QSGMII Copper /fiber auto-det 4*1000Base-x RTL8214FC 4*1000Base-T QSGMII RTL8218B 8*1000Base-T LED Interface 8*1000Base-T RTL8218B 8*1000Base-T QSGMII QSGMII RTL8382M (28*1000M Switch) LQFP216-EPAD Figure 2. Managed 28*1000M Switch via RTL8218B PHY 10/100/1000M Switch Controllers 5 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 3.3. RTL8382M-VB: Managed 20*1000M UTP+4*1000M Combo Switch DDR1/DDR2/DDR3* Flash Managed 24*1000M port Switch QSGMII QSGMII Copper /fiber auto-det 4*1000Base-x 4*1000Base-T LED Interface RTL8218FB 4*1000Base-T 8*1000Base-T RTL8218B 8*1000Base-T QSGMII QSGMII RTL8382M (24*1000M Switch) LQFP216-EPAD Figure 3. Managed 20*1000M UTP+4*1000M Combo Switch 10/100/1000M Switch Controllers 6 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 3.4. RTL8382M-VB: Managed 24*1000M UTP+2*1000Base-X Switch DDR1/DDR2/DDR3* Managed 24*1000M+2*1000Base-X Switch Flash 1000Base-X 1000Base-X QSGMII QSGMII RTL8218B 8*1000Base-T LED Interface 8*1000Base-T RTL8218B 8*1000Base-T QSGMII QSGMII RTL8382M (24*1000M+2*1000Base-X Switch) LQFP216-EPAD Figure 4. Managed 24*1000M UTP+2*1000Base-X Switch 10/100/1000M Switch Controllers 7 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 4. Block Diagrams 4.1. RTL8380M-VB Block Diagram Scan or Serial LED GPIO DDR1/DDR2/ SPI Flash/ DDR3 I2C EEPROM UART0 UART1 EJTAG MIPS-4KEc 32bits@500M Hz LED Controller GPIO Controller SGMII/ 1000Base-X/ 100Base-FX SGMII/ 1000Base-X/ 100Base-FX Serdes0 Serdes1 GMAC8 GMAC9 Memory Controller 2*UART Controller 128KB SRAM EEPROM /I2C/SPI Register Controller Interrupt Controller GMAC10 and NIC Packet Buffer (4.1 Mbit SRAM) Flow Control Traffic Classification L2 and Forwarding Table 802.3ad Qos Manager Storm Control VLAN Table Scheduler(SP/WRR/WFQ) EEE 802.1x and STP ACL Table VLAN Tag/Untag Attack Prevention Input Bandwidth Control Q-in-Q Table Output Bandwidth Control MAC 0 MAC 1 MAC 2 MAC 3 MAC 4 MAC 5 MAC 6 MAC 7 PHY0~7 (Gigabit) 8*GE Figure 5. RTL8380M-VB Block Diagram 10/100/1000M Switch Controllers 8 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 4.2. RTL8382M-VB Block Diagram Scan or Serial LED QSGMII/ SGMII/1000Base-X DDR1/DDR2/ SPI Flash/ /100Base-FX DDR3 I2C EEPROM GPIO UART0 UART1 EJTAG MIPS-4KEc 32bits@500M Hz LED Controller GPIO Controller Serdes4 Serdes5 Memory Controller 2*UART Controller 128KB SRAM EEPROM /I2C/SPI Register Controller Interrupt Controller SGMII/ 1000Base-X/ 100Base-FX MUX GMAC24 GMAC25 GMAC28 and NIC MUX GMAC26 GMAC27 Packet Buffer (4.1 Mbit SRAM) Flow Control Traffic Classification L2 and Forwarding Table 802.3ad Qos Manager Storm Control VLAN Table Scheduler(SP/WRR/WFQ) EEE 802.1x and STP ACL Table VLAN Tag/Untag Attack Prevetion Input Bandwidth Control Q-in-Q Table Output Bandwidth Control MAC 0-3 MAC 4-7 Serdes 0 Serdes 1 2*QSGMII MAC 8 MAC 9 MAC 10 MAC 12 MAC 11 MAC 13 MAC 14 MAC 15 PHY8~15 (Gigabit) 8*GE MAC 16-19 MAC 20-23 Serdes 2 Serdes 3 2*QSGMII Figure 6. RTL8382M-VB Block Diagram 10/100/1000M Switch Controllers 9 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5. Pin Assignments Figure (RTL8380M-VB) 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 MVDDH DDR12_WE#/DDR3_WE# DVDDL DDR12_RAS#/DDR3_CAS# DDR12_CAS#/DDR3_RAS# DDR12_A11/DDR3_A10/LED_MODE[0] DDR12_A13/DDR3_A11/LED_MODE[1] DDR3_A14/SPI_ADDR_SEL DDR12_A8/DDR3_A1/SDS_PDOWN_EN DDR12_A6/DDR3_A8/SEL_XTAL_CLK DDR12_A4/DDR3_A6/PWRBLINK[1] DDR12_A2/DDR3_A4/PWRBLINK[0] DDR12_A0/DDR3_A12/DIS_EEE DDR12_CS#/DDR3_BA1 DDR12_ODT/DDR3_CKE DDR12_D5/DDR3_D5 DDR12_D2/DDR3_D7 DDR12_D0/DDR3_D1 DDR12_D7/DDR3_D3 VREF DDR12_DQS/DDR3_DM DDR12_CLK/DDR3_CLK DDR12_CLK#/DDR3_CLK# DVDDL DDR3_DQS# DDR12_DM/DDR3_DQS DDR12_D6/DDR3_D0 DDR12_D1/DDR3_D4 DDR12_D3/DDR3_D2 DDR12_D4/DDR3_D6 MVDDH DVDDH SPI_CLK SPI_SO/SIO1 SPI_SI/SIO0 SPI_CS#0 DVDDL UART0_RX UART0_TX/REG_IF_SEL LED_DAT LED_CLK MDIO MDC SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO/DIS_PHYAUTO_UP SSPI_CS# DVDDH RESET# GPIO0 GPIO1 GPIO2 GPIO3 DVDDL 5.1. Pin Assignments and Description (RTL8380M-VB) 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 RTL8380M LLLLLLL GXXXV TAIWAN 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 DVDDL AVDDL_PLL XI XO AVDDH_PLL SVDDL S1RXP S1RXN S1TXP S1TXN SVDDL S0RXN S0RXP S0TXN S0TXP SVDDL CKOUT0 SVDDH TEST3 TEST2 RESERVED RESERVED SVDDL TEST1 TEST0 RESERVED RESERVED SVDDL RESERVED DVDDL AVDDH P7MDIDN P7MDIDP P7MDICN P7MDICP AVDDL P7MDIBN P7MDIBP P7MDIAN P7MDIAP AVDDH P6MDIDN P6MDIDP P6MDICN P6MDICP AVDDL P6MDIBN P6MDIBP P6MDIAN P6MDIAP ATESTCK1 PLLVDDL P5MDIDN P5MDIDP P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN AVDDH AGND MDIREF AVDDL RTT1 RTT2 AVDDH DVDDL DVDDH JTAG_TCK JTAG_TMS JTAG_TDO/EEPROMTYPE JTAG_TDI JTAG_TRST# DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 MVDDH DDR3_BA2/DDR12_CKE DDR3_A9/DDR12_BA1 DDR3_A13/DDR12_A1/CPU_SLEEP DDR3_A2/DDR12_A12/DRAM_INI_EN DDR3_RST# DDR3_A7/DDR12_A9/MEM_TYPE[1] DDRR3_A5/DDR12_A7/MEM_TYPE[0] DDR3_A0/DDR12_A5/CLK_M_EE[1] DDR3_A3/DDR12_A3/CLK_M_EE[0] DDR3_BA0/DDR12_A10/EN_DECRYPT DDR3_CS#/DDR2_BA2 DDR3_ODT/DDR12_BA0 DDR3_ZQ# MVDDH DVDDL VX RESERVED SVDDL RESERVED RESERVED TEST4 TEST5 SVDDH RESERVED RESERVED TEST6 TEST7 SVDDL DVDDL AVDDH P0MDIAP P0MDIAN P0MDIBP P0MDIBN AVDDL P0MDICP P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP P1MDIAN P1MDIBP P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN Figure 7. Pin Assignments (RTL8380M-VB) 5.2. Package Identification Green package is indicated by a ‘G’ in ‘GXXXX’ (Figure 7). The version number is shown in the location marked ‘V’. 10/100/1000M Switch Controllers 10 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.3. Pin Assignments Table Codes (RTL8380M-VB) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value = 75KΩ) (Typical Value = 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value = 75KΩ) 5.4. OPU: Output Pin With Pull-Up Resistor; OPD: Output Pin With Pull-Down Resistor; (Typical Value = 75KΩ) Pin Assignments Table (RTL8380M-VB) Name P2MDIBP Table 1. Pin Assignments Table (RTL8380M-VB) Pin No. Type Name 1 AI/O AVDDH Pin No. 19 Type AP P2MDIBN AVDDL 2 3 AI/O AP AGND MDIREF 20 21 AG AO P2MDICP P2MDICN 4 5 AI/O AI/O AVDDL RTT1 22 23 AP AI/O P2MDIDP 6 AI/O RTT2 24 AI/O P2MDIDN AVDDH 7 8 AI/O AP AVDDH DVDDL 25 26 AP DP P3MDIAP P3MDIAN 9 10 AI/O AI/O DVDDH JTAG_TCK 27 28 DP I/OPU P3MDIBP 11 AI/O JTAG_TMS 29 I/OPU P3MDIBN AVDDL 12 13 AI/O AP JTAG_TDO/EEPROMTYPE JTAG_TDI 30 31 I/OPD I/OPD AVDDH P3MDICP 14 15 AP AI/O JTAG_TRST# DVDDL 32 33 I/OPU DP P3MDICN P3MDIDP 16 17 AI/O AI/O DVDDL DVDDH 34 35 DP DP P3MDIDN 18 AI/O AVDDH 36 AP 10/100/1000M Switch Controllers 11 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name P4MDIAP Pin No. 37 Type AI/O Name AVDDH Pin No. 78 Type AP P4MDIAN 38 AI/O DVDDL 79 DP P4MDIBP P4MDIBN 39 40 AI/O AI/O RESERVED SVDDL 80 81 AP AVDDH AVDDL 41 42 AP AP RESERVED RESERVED 82 83 - P4MDICP P4MDICN 43 44 AI/O AI/O TEST0 TEST1 84 85 - P4MDIDP 45 AI/O SVDDL 86 AP P4MDIDN AVDDH 46 47 AI/O AP RESERVED RESERVED 87 88 - P5MDIAP P5MDIAN 48 49 AI/O AI/O TEST2 TEST3 89 90 - P5MDIBP 50 AI/O SVDDH 91 AP P5MDIBN AVDDL 51 52 AI/O AP CKOUT0 SVDDL 92 93 AO AP P5MDICP P5MDICN 53 54 AI/O AI/O S0TXP S0TXN 94 95 AO AO P5MDIDP P5MDIDN 55 56 AI/O AI/O S0RXP S0RXN 96 97 AI AI PLLVDDL 57 AP SVDDL 98 AP ATESTCK1 P6MDIAP 58 59 AO AI/O S1TXN S1TXP 99 100 AO AO P6MDIAN P6MDIBP 60 61 AI/O AI/O S1RXN S1RXP 101 102 AI AI P6MDIBN 62 AI/O SVDDL 103 AP AVDDL P6MDICP 63 64 AP AI/O AVDDH_PLL XO 104 105 AP AO P6MDICN P6MDIDP 65 66 AI/O AI/O XI AVDDL_PLL 106 107 AI AP P6MDIDN AVDDH 67 68 AI/O AP DVDDL DVDDL 108 109 P P P7MDIAP 69 AI/O GPIO3 110 I/OPD P7MDIAN P7MDIBP 70 71 AI/O AI/O GPIO2 111 I/OPD P7MDIBN AVDDL 72 73 AI/O AP GPIO1 GPIO0 112 113 RESET# 114 I/OPD I/OPD AI P7MDICP 74 AI/O P7MDICN P7MDIDP 75 76 AI/O AI/O DVDDH SSPI_CS# 115 116 P IPU I/OPD 77 AI/O SSPI_SO/ DIS_PHYAUTO_UP SSPI_SI/I2C_DAT 117 P7MDIDN 118 I/OPU 10/100/1000M Switch Controllers 13 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name SSPI_CLK/I2C_CLK Pin No. 119 Type I/OPU MDC 120 MDIO LED_CLK 121 122 OPU I/OPU LED_DAT UART0_TX/REG_IF_SEL 123 124 OPU I/OPU I/OPD UART0_RX DVDDL 125 126 IPD P SPI_CS#0 127 IPU SPI_SI/SIO0 SPI_SO/SIO1 128 129 I/OPD I/OPD SPI_CLK DVDDH 130 131 OPD P MVDDH 132 P DDR12_D4/DDR3_D6 DDR12_D3/DDR3_D2 133 134 I/O I/O DDR12_D1/DDR3_D4 DDR12_D6/DDR3_D0 135 136 I/O I/O DDR12_DM/DDR3_DQS DDR3_DQS# 137 138 I/O I/O DVDDL 139 P DDR12_CLK#/DDR3_CLK# DDR12_CLK/DDR3_CLK 140 141 O O DDR12_DQS/DDR3_DM VREF 142 143 I/O P DDR12_D7/DDR3_D3 144 I/O DDR12_D0/DDR3_D1 DDR12_D2/DDR3_D7 145 146 I/O I/O DDR12_D5/DDR3_D5 DDR2_ODT/DDR3_CKE 147 148 I/O O DDR12_CS#/DDR3_BA1 DDR12_A0/DDR3_A12/ DIS_EEE DDR12_A2/DDR3_A4/ PWRBLINK[0] DDR12_A4/DDR3_A6/ PWRBLINK[1] DDR12_A6/DDR3_A8/ SEL_XTAL_CLK DDR12_A8/DDR3_A1/ SDS_PDOWN_EN DDR3_A14/SPI_ADDR_SEL 149 150 O I/O 151 I/O 152 153 10/100/1000M Switch Controllers Name DDR12_A13/DDR3_A11/ LED/MODE[1] DDR12_A11/DDR3_A10/ LED/MODE[0] DDR12_CAS#/DDR3_RAS# Pin No. 156 Type I/O 157 I/O 158 O DDR12_RAS#/DDR3_CAS# 159 O DVDDL DDR12_WE#/DDR3_WE# 160 161 P O MVDDH MVDDH 162 163 P P DDR12_CKE/DDR3_BA2 DDR12_BA1/DDR3_A9 164 165 O O DDR12_A1/DDR3_A13/ CPU_SLEEP DDR12_A12/DDR3_A2/ DRAM_INI_EN DDR3_RST# 166 I/O 167 I/O 168 O DDR12_A9/DDR3_A7/ MEM_TYPE[1] DDR12_A7/DDR3_A5/ MEM_TYPE[0] DDR12_A5/DDR3_A0/ CLK_M_EE[1] DDR12_A3/DDR3_A3/ CLK_M_EE[0] DDR12_A10/DDR3_BA0/ EN_DECRYPT DDR2_BA2/DDR3_CS# 169 I/O 170 I/O 171 I/O 172 I/O 173 I/O 174 O DDR12_BA0/DDR3_ODT DDR3_ZQ# 175 176 O O MVDDH DVDDL 177 178 P P VX 179 A RESERVED SVDDL 180 181 AO AP RESERVED RESERVED 182 183 AO AO I/O TEST4 TEST5 184 185 - I/O SVDDH 186 AP 154 I/O RESERVED RESERVED 187 188 AO AO 155 I/O TEST6 TEST7 189 190 - 14 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name SVDDL Pin No. 191 Type AP Name P1MDIAN Pin No. 205 Type AI/O DVDDL 192 P P1MDIBP 206 AI/O AVDDH P0MDIAP 193 194 AP AI/O P1MDIBN AVDDL 207 208 AI/O AP P0MDIAN P0MDIBP 195 196 AI/O AI/O P1MDICP P1MDICN 209 210 AI/O AI/O P0MDIBN AVDDL 197 198 AI/O AP P1MDIDP P1MDIDN 211 212 AI/O AI/O P0MDICP 199 AI/O PLLVDDL 213 AP P0MDICN P0MDIDP 200 201 AI/O AI/O ATESTCK0 P2MDIAP 214 215 AO AI/O P0MDIDN AVDDH 202 203 AI/O AP P2MDIAN DGND 216 EPAD AI/O G P1MDIAP 204 AI/O 10/100/1000M Switch Controllers 15 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5. Pin Descriptions (RTL8380M-VB) 5.5.1. 1000M Ethernet PHY MDI Interface Pins Table 2. 1000M Ethernet PHY MDI Interface Pins Type Description Port 0 Media Dependent Interface A~D. AI/O For 1000Base-T operation, differential data from the media is transmitted and AI/O received on all four pairs. For 100Base-Tx and 10Base-T operation, only AI/O MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. AI/O Pin Name P0MDIAP Pin No. 194 P0MDIAN 195 P0MDIBP 196 P0MDIBN 197 P0MDICP 199 AI/O P0MDICN 200 AI/O P0MDIDP 201 AI/O P0MDIDN 202 AI/O P1MDIAP 204 AI/O P1MDIAN 205 AI/O P1MDIBP 206 AI/O P1MDIBN 207 AI/O P1MDICP 209 AI/O P1MDICN 210 AI/O P1MDIDP 211 AI/O P1MDIDN 212 AI/O P2MDIAP 215 AI/O P2MDIAN 216 AI/O P2MDIBP 1 AI/O P2MDIBN 2 AI/O P2MDICP 4 AI/O P2MDICN 5 AI/O P2MDIDP 6 AI/O P2MDIDN 7 AI/O P3MDIAP 9 AI/O P3MDIAN 10 AI/O P3MDIBP 11 AI/O P3MDIBN 12 AI/O P3MDICP 15 AI/O P3MDICN 16 AI/O P3MDIDP 17 AI/O P3MDIDN 18 AI/O 10/100/1000M Switch Controllers Each of the differential pairs has an internal 100 ohm termination resistor. Port 1 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 2 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 16 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name P4MDIAP Pin No. 37 Type AI/O P4MDIAN 38 AI/O P4MDIBP 39 AI/O P4MDIBN 40 AI/O P4MDICP 43 AI/O P4MDICN 44 AI/O P4MDIDP 45 AI/O P4MDIDN 46 AI/O P5MDIAP 48 AI/O P5MDIAN 49 AI/O P5MDIBP 50 AI/O P5MDIBN 51 AI/O P5MDICP 53 AI/O P5MDICN 54 AI/O P5MDIDP 55 AI/O P5MDIDN 56 AI/O P6MDIAP 59 AI/O P6MDIAN 60 AI/O P6MDIBP 61 AI/O P6MDIBN 62 AI/O P6MDICP 64 AI/O P6MDICN 65 AI/O P6MDIDP 66 AI/O P6MDIDN 67 AI/O P7MDIAP 69 AI/O P7MDIAN 70 AI/O P7MDIBP 71 AI/O P7MDIBN 72 AI/O P7MDICP 74 AI/O P7MDICN 75 AI/O P7MDIDP 76 AI/O P7MDIDN 77 AI/O 10/100/1000M Switch Controllers Description Port 4 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 5 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 6 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 7 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 17 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5.2. SGMII Interface Pins Pin Name S0RXP Pin No. 96 Type AI S0RXN 97 AI S0TXP 94 AO S0TXN 95 AO S1RXP 102 AI S1RXN 101 AI S1TXP 100 AO S1TXN 99 AO 5.5.3. Table 3. SGMII Interface Pins Description SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Pins Table 4. 1000Base-X/100Base-FX Interface Pins Type Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. AI Pin Name S0RXP Pin No. 96 S0RXN 97 AI S0TXP 94 AO S0TXN 95 AO S1RXP 102 AI S1RXN 101 AI S1TXP 100 AO S1TXN 99 AO 10/100/1000M Switch Controllers 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. 18 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5.4. DDR1/2 SDRAM Interface Pins Table 5. DDR1/2 SDRAM Interface Pins Pin Name DDR12_D[7:0] Type I/O DDR2_BA[2] DDR12_BA[1:0] DDR12_WE# DDR12_CKE DDR12_RAS# DDR12_CAS# DDR12_CS#0 DDR2_ODT DDR12_DQS DDR12_CLK Pin No. 144, 136, 147, 133, 134, 146, 135, 145 156, 167, 157, 173, 169, 154, 170, 153, 171, 152, 172, 151, 166, 150 174 165, 175 161 164 159 158 149 148 142 141 DDR12_CLK# 140 DDR12_A[13:0] 10/100/1000M Switch Controllers Drive (mA) Description 8 DDR SDRAM Data Bus. I/O 8 DDR SDRAM Address Select. O O O O O O O O I/O O 8 8 8 8 8 8 8 8 8 8 O 8 DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Write Enable. DDR SDRAM Clock Enable. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Chip Select 0. DDR SDRAM On-Die Termination. DDR SDRAM Data Strobe. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. 19 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5.5. DDR3 SDRAM Interface Pins Table 6. DDR3 SDRAM Interface Pins Pin Name DDR3_D[7:0] DDR3_A[14] DDR3_A[13:10] DDR3_A[9] DDR3_A[8:0] DDR3_DQS# DDR3_DQS DDR3_CLK# DDR3_CLK DDR3_DM DDR3_CKE DDR3_BA[2:1] DDR3_BA[0] DDR3_RAS# DDR3_CAS# DDR3_WE# DDR3_RST# DDR3_CS# DDR3_ODT DDR3_ZQ# 5.5.6. Pin No. 146, 133, 147, 135, 144, 134, 145, 136 155 166, 150,156, 157 165 153, 169, 152, 170, 151, 172, 167, 154, 171 138 137 140 141 142 148 164, 149 173 158 159 161 168 174 175 176 Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. O I/O O I/O 8 8 8 8 DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. I/O I/O O O I/O O O I/O O O O O O O O 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 DDR SDRAM Data Strobe. DDR SDRAM Data Strobe. DDR SDRAM Clock. DDR SDRAM Clock. DDR SDRAM Data Mask. DDR SDRAM Clock Enable. DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Write Enable. DDR SDRAM Reset. DDR SDRAM Chip Select. DDR SDRAM On-Die Termination. DDR SDRAM External Reference Ball for Output Drive Calibration. This ball is tied to an external 240 Ohm resistor, which is tied to GND. Master Mode SPI Flash Interface Pins Pin Name SPI_CLK SPI_SO/SIO1 Pin No. 130 129 SPI_SI/SIO0 128 SPI_CS#0 127 Table 7. Master Mode SPI Flash Interface Pins Type Drive (mA) Description OPD 12 Serial Clock Output Pin. I/OPD 12 In Serial Mode: This is a flash chip output pin In Dual Mode: This is a flash chip bi-directional pin Note: This is MSB first. I/OPD 12 In Serial Mode: This is a flash chip input pin In Dual Mode: This is a flash chip bi-directional pin Note: This is LSB first. O 12 Chip Select Output Pin. Slave Transmit Enable and active low. 10/100/1000M Switch Controllers 20 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5.7. UART Interface Pins Pin Name UART0_RX Pin No. 125 Type IPD UART0_TX UART1_RX UART1_TX 124 116 117 I/OPD IPU I/OPD 5.5.8. 4 4 4 UART0 Interface Transmit Data. UART1 Interface Receive Data. UART1 Interface Transmit Data. LED Interface Pins Pin Name LED_CLK Pin No. 122 Type OPU LED_DAT 123 I/OPU 5.5.9. Table 8. UART Interface Pins Drive (mA) Description 4 UART0 Interface Receive Data. Table 9. LED Interface Pins Drive (mA) Description 12 (1) In Serial LED Mode Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. (2) In SMI-like LED Mode Reference output clock for I2C-like interface. 12 (1) In Serial LED Mode Serial bit stream of link status information. (2) In I2C-like LED Mode The data written to the LED IC. GPIO Interface Pins Table 10. GPIO Interface Pins Type Drive (mA) Description This pin default set as system LED. I/OPD 4 Can be configured as General Purpose Input/Output Pin. Pin Name Pin No. GPIO0 113 GPIO[3:1] 110, 111, 112 I/OPD 4 General Purpose Input/Output Pins. GPO10 30 I/OPD 4 General Purpose Output Pins. GPIO11 31 I/OPD 4 General Purpose Input/Output Pins. GPIO[14:12] 32,28,29 I/OPU 4 General Purpose Input/Output Pins. 5.5.10. EJTAG Interface Pins Pin Name JTAG_TMS JTAG_TCK JTAG_TRST# JTAG_TDI JTAG_TDO Pin No. 29 28 32 31 30 Type I/OPU I/OPU I/OPU I/OPD I/OPD 10/100/1000M Switch Controllers Table 11. EJTAG Interface Pins Drive (mA) Description 4 JTAG Test Mode Select. 4 JTAG Test Clock Input. 4 JTAG Test Reset. 4 JTAG Test Data Input. 4 JTAG Test Data Output. 21 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 5.5.11. Configuration Strapping Pins Pin Name EEPROMTYPE Pin No. 30 DIS_PHYAUTO_UP 117 REG_IF_SEL 124 DIS_EEE 150 PWRBLINK[1:0] 152, 151 SEL_XTAL_CLK 153 SDS_PDOWN_EN 154 SPI_ADDR_SEL 155 LED_MODE[1:0] 156, 157 CPU_SLEEP 166 DRAM_INI_EN 167 MEM_TYPE[1:0] 169, 170 10/100/1000M Switch Controllers Table 12. Configuration Strapping Pins Default Description 0b0 Select EEPROM Address Byte Size. 0b0: 1-byte 0b1: 2-byte 0b0 Disable ASIC Auto Power Up PHY. 0b0: Enable ASIC auto power up PHY 0b1: Disable ASIC auto power up PHY 0b0 Select Switch Core Register Access Interface. 0b0: I2C 0b1: SPI slave 0b0 Disable 1000M EEE and 100M EEE Function. 0b0: Enable 0b1: Disable 0b00 Select LED Power On Blinking Timer. 0b00: Disable 0b01: 800ms 0b10: 1.6s 0b11:3.2s 0b0 Select XTAL Input is 25M or 125M. 0b0: 25M 0b1:125M Note: This option is only for sync Ethernet. 0b0 Enable SerDes Power Down Mode. 0b0: SerDes 0/1 operate in normal mode 0b1: SerDes0/1 operate in power down mode 0b0 Select Address Mode for SPI Flash. 0b0: 3-byte address 0b1: 4-byte address 0b0 Select LED Mode. 0b00: Serial LED mode 0b01: Scan Single mode 0b10: Scan Bicolor mode 0b11: Disable LED 0b0 Enable CPU Function. 0b0: CPU is always under reset state 0b1: CPU is enabled 0b0 Enable DRAM Initialization Procedure. 0b0: Enable DRAM Initialization procedure 0b1: Bypass DRAM Initialization procedure 0b00 Select Memory Type for SOC. 0b00: Select SPI flash + DDR-3 0b01: Select SPI flash + DDR-2 0b10: Select SPI flash + DDR-1 0b11: Select EEPROM 22 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name CLK_M_EE[1:0] EN_DECRYPT Pin No. 171, 172 173 Default Description 0b00 When MEM_TYPE Select is SPI Flash: This Strapping Pin Selects the Initial Clock for The Memory Controller. For DDR2: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 100MHz 0b11: Reserved for test; For DDR3: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 125MHz 0b11: Reserved for test; Note: The initial value for this strapping pin must be set as recommended in the reference design guide. 0b0 When MEM_TYPE Select is EEPROM: CLK_M_EE[0] is used to select SOC EEPROM address byte size. 0b0: 1-byte address 0b1: 2-byte address Enable or Disable Decrypt for Flash. 0b0: Disable decrypt 0b1: Enable decrypt 5.5.12. Miscellaneous Interface Pins Pin Name MDC MDIO SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO SSPI_CS# RESET# XI XO MDIREF RTT1 RTT2 VX CKOUT0 ATESTCK[1:0] RESERVED Table 13. Miscellaneous Interface Pins Type Drive (mA) Description OPU 12 MII Management Interface Clock Pin. I/OPU 12 MII Management Interface Data Pin. I/OPU 4 SPI Serial Clock Input (Slave Mode). I2C Interface Clock Input (Slave Mode). I2C Interface Clock Output (Master Mode). 118 I/OPU 4 SPI Serial Data Input (Slave Mode). I2C Interface Bi-Directional data (Slave Mode). 117 I/OPD 4 SPI Serial Data Output (Slave Mode). 116 IUP 4 SPI Serial Chip Select (Slave Mode). 114 AI System Pin Reset Input (Low Active). To complete the reset function, this pin must be asserted for at least 10ms. It must be pulled up for normal operation. 106 AI 25MHz Crystal Clock Input and Feedback Pin. 105 AO 25MHz Crystal Clock Output Pin. 21 AO MDI Bias Resistor. Adjust the reference current for all PHYs. This pin must connect to AGND via a 2.49k ohm resistor. 23 AI/O Reserved for Internal Use (Must be Left Floating). 24 AI/O Reserved for Internal Use (Must be Left Floating). 179 A Low Voltage Power Control Resistor. 92 AO 8 25MHz Clock Output. 58, 214 AO Reserved for Internal Use (Must be Left Floating). 82, 83, 87, 88, Reserved pins (Must be Left Floating). 180, 182, 183, 187, 188 Pin No. 120 121 119 10/100/1000M Switch Controllers 23 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name TEST[7:0] Pin No. 84, 85, 89, 90, 184, 185, 189, 190 Type - Drive (mA) Description Reserved for Testing. 5.5.13. Power and Ground Pins Pin Name AVDDL PLLVDDL AVDDH DVDDL DVDDH SVDDL AVDDL_PLL SVDDH AVDDH_PLL MVDDH VREF AGND DGND Table 14. Power and Ground Pins Pin No. Type Description 3, 13, 22, 42, 52, 63, AP Analog Low Voltage Power. 73, 198, 208 57, 213 AP Analog PLL Low Voltage Power. 8, 14, 19, 25, 36, 41, AP Analog High Voltage Power. 47, 68, 78, 193, 203 26, 33, 34, 79, 108, P Digital Low Voltage Power. 109, 126, 139, 160, 178, 192 27, 35, 115, 131 P Digital High Voltage Power. 81, 86, 93, 98, 103, AP SerDes Low Voltage Power. 181, 191 107 AP PLL Low Voltage Power. 91, 186 AP SerDes High Voltage Power. 104 AP PLL High Voltage Power. 132, 162, 163,177 P SDRAM High Voltage Power. 143 P SSTL Reference Voltage (MVDDH/2). 20 AG Analog Ground. E-PAD G Digital Ground. 10/100/1000M Switch Controllers 24 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6. Pin Assignments Figure (RTL8382M-VB) 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 MVDDH DDR12_WE#/DDR3_WE# DVDDL DDR12_RAS#/DDR3_CAS# DDR12_CAS#/DDR3_RAS# DDR12_A11/DDR3_A10/LED_MODE[0] DDR12_A13/DDR3_A11/LED_MODE[1] DDR3_A14/SPI_ADDR_SEL DDR12_A8/DDR3_A1/SDS_PDOWN_EN DDR12_A6/DDR3_A8/SEL_XTAL_CLK DDR12_A4/DDR3_A6/PWRBLINK[1] DDR12_A2/DDR3_A4/PWRBLINK[0] DDR12_A0/DDR3_A12/DIS_EEE DDR12_CS#/DDR3_BA1 DDR2_ODT/DDR3_CKE DDR12_D5/DDR3_D5 DDR12_D2/DDR3_D7 DDR12_D0/DDR3_D1 DDR12_D7/DDR3_D3 VREF DDR12_DQS/DDR3_DM DDR12_CLK/DDR3_CLK DDR12_CLK#/DDR3_CLK# DVDDL DDR3_DQS# DDR12_DM/DDR3_DQS DDR12_D6/DDR3_D0 DDR12_D1/DDR3_D4 DDR12_D3/DDR3_D2 DDR12_D4/DDR3_D6 MVDDH DVDDH SPI_CLK SPI_SO/SIO1 SPI_SI/SIO0 SPI_CS#0 DVDDL UART0_RX UART0_TX/REG_IF_SEL LED_DAT LED_CLK MDIO MDC SSPI_CLK/I2C_CLK SSPI_SI/I2C_DAT SSPI_SO/DIS_PHYAUTO_UP SSPI_CS# DVDDH RESET# GPIO0 GPIO1 GPIO2 GPIO3 DVDDL 6.1. Pin Assignments and Description (RTL8382M-VB) 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 RTL8382M LLLLLLL GXXXV TAIWAN 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 DVDDL AVDDL_PLL XI XO AVDDH_PLL SVDDL S5RXP S5RXN S5TXP S5TXN SVDDL S4RXN S4RXP S4TXN S4TXP SVDDL CKOUT4 SVDDH S3RXP S3RXN S3TXP S3TXN SVDDL S2RXN S2RXP S2TXN S2TXP SVDDL CKOUT2 DVDDL AVDDH P7MDIDN P7MDIDP P7MDICN P7MDICP AVDDL P7MDIBN P7MDIBP P7MDIAN P7MDIAP AVDDH P6MDIDN P6MDIDP P6MDICN P6MDICP AVDDL P6MDIBN P6MDIBP P6MDIAN P6MDIAP ATESTCK1 PLLVDDL P5MDIDN P5MDIDP P2MDIBP P2MDIBN AVDDL P2MDICP P2MDICN P2MDIDP P2MDIDN AVDDH P3MDIAP P3MDIAN P3MDIBP P3MDIBN AVDDL AVDDH P3MDICP P3MDICN P3MDIDP P3MDIDN AVDDH AGND MDIREF AVDDL RTT1 RTT2 AVDDH DVDDL DVDDH JTAG_TCK JTAG_TMS JTAG_TDO/EEPROMTYPE JTAG_TDI JTAG_TRST# DVDDL DVDDL DVDDH AVDDH P4MDIAP P4MDIAN P4MDIBP P4MDIBN AVDDH AVDDL P4MDICP P4MDICN P4MDIDP P4MDIDN AVDDH P5MDIAP P5MDIAN P5MDIBP P5MDIBN AVDDL P5MDICP P5MDICN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 MVDDH DDR12_CKE/DDR3_BA2 DDR12_BA1/DDR3_A9 DDR12_A1/DDR3_A13/CPU_SLEEP DDR12_A12/DDR3_A2/DRAM_INI_EN DDR3_RST# DDR12_A9/DDR3_A7/MEM_TYPE[1] DDR12_A7/DDR3_A5/MEM_TYPE[0] DDR12_A5/DDR3_A0/CLK_M_EE[1] DDR12_A3/DDR3_A3/CLK_M_EE[0] DDR12_A10/DDR3_BA0/EN_DECRYPT DDR2_BA2/DDR3_CS# DDR12_BA0/DDR3_ODT DDR3_ZQ# MVDDH DVDDL VX CKOUT0 SVDDL S0TXP S0TXN S0RXP S0RXN SVDDH S1TXN S1TXP S1RXN S1RXP SVDDL DVDDL AVDDH P0MDIAP P0MDIAN P0MDIBP P0MDIBN AVDDL P0MDICP P0MDICN P0MDIDP P0MDIDN AVDDH P1MDIAP P1MDIAN P1MDIBP P1MDIBN AVDDL P1MDICP P1MDICN P1MDIDP P1MDIDN PLLVDDL ATESTCK0 P2MDIAP P2MDIAN Figure 8. Pin Assignments (RTL8382M-VB) 6.2. Package Identification Green package is indicated by a ‘G’ in ‘GXXXX’ (Figure 8). The version number is shown in the location marked ‘v’. 10/100/1000M Switch Controllers 25 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.3. Pin Assignments Table Codes (RTL8382M-VB) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value = 75KΩ) (Typical Value = 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value = 75KΩ) 6.4. OPU: Output Pin With Pull-Up Resistor; OPD: Output Pin With Pull-Down Resistor; (Typical Value = 75KΩ) Pin Assignments Table (RTL8382M-VB) Name P2MDIBP Table 15. Pin Assignments Table (RTL8382M-VB) Pin No. Type Name 1 AI/O AVDDH Pin No. 19 Type AP P2MDIBN AVDDL 2 3 AI/O AP AGND MDIREF 20 21 AG AO P2MDICP P2MDICN 4 5 AI/O AI/O AVDDL RTT1 22 23 AP AI/O P2MDIDP 6 AI/O RTT2 24 AI/O P2MDIDN AVDDH 7 8 AI/O AP AVDDH DVDDL 25 26 AP DP P3MDIAP P3MDIAN 9 10 AI/O AI/O DVDDH JTAG_TCK 27 28 DP I/OPU P3MDIBP 11 AI/O JTAG_TMS 29 I/OPU P3MDIBN AVDDL 12 13 AI/O AP JTAG_TDO/EEPROMTYPE JTAG_TDI 30 31 I/OPD I/OPD AVDDH P3MDICP 14 15 AP AI/O JTAG_TRST# DVDDL 32 33 I/OPU DP P3MDICN P3MDIDP 16 17 AI/O AI/O DVDDL DVDDH 34 35 DP DP P3MDIDN 18 AI/O AVDDH 36 AP 10/100/1000M Switch Controllers 26 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name P4MDIAP Pin No. 37 Type AI/O Name AVDDH Pin No. 78 Type AP P4MDIAN 38 AI/O DVDDL 79 DP P4MDIBP P4MDIBN 39 40 AI/O AI/O CKOUT2 SVDDL 80 81 AO AP AVDDH AVDDL 41 42 AP AP S2TXP S2TXN 82 83 AO AO P4MDICP P4MDICN 43 44 AI/O AI/O S2RXP S2RXN 84 85 AI AI P4MDIDP 45 AI/O SVDDL 86 AP P4MDIDN AVDDH 46 47 AI/O AP S3TXN S3TXP 87 88 AO AO P5MDIAP P5MDIAN 48 49 AI/O AI/O S3RXN S3RXP 89 90 AI AI P5MDIBP 50 AI/O SVDDH 91 AP P5MDIBN AVDDL 51 52 AI/O AP CKOUT4 SVDDL 92 93 AO AP P5MDICP P5MDICN 53 54 AI/O AI/O S4TXP S4TXN 94 95 AO AO P5MDIDP P5MDIDN 55 56 AI/O AI/O S4RXP S4RXN 96 97 AI AI PLLVDDL 57 AP SVDDL 98 AP ATESTCK1 P6MDIAP 58 59 AO AI/O S5TXN S5TXP 99 100 AO AO P6MDIAN P6MDIBP 60 61 AI/O AI/O S5RXN S5RXP 101 102 AI AI P6MDIBN 62 AI/O SVDDL 103 AP AVDDL P6MDICP 63 64 AP AI/O AVDDH_PLL XO 104 105 AP AO P6MDICN P6MDIDP 65 66 AI/O AI/O XI AVDDL_PLL 106 107 AI AP P6MDIDN AVDDH 67 68 AI/O AP DVDDL DVDDL 108 109 P P P7MDIAP 69 AI/O GPIO3 110 I/OPD P7MDIAN P7MDIBP 70 71 AI/O AI/O GPIO2 111 I/OPD P7MDIBN AVDDL 72 73 AI/O AP GPIO1 GPIO0 112 113 RESET# 114 I/OPD I/OPD AI P7MDICP 74 AI/O P7MDICN P7MDIDP 75 76 AI/O AI/O DVDDH SSPI_CS# 115 116 P IPU I/OPD 77 AI/O SSPI_SO/ DIS_PHYAUTO_UP SSPI_SI/I2C_DAT 117 P7MDIDN 118 I/OPU 10/100/1000M Switch Controllers 27 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name SSPI_CLK/I2C_CLK Pin No. 119 Type I/OPU MDC 120 MDIO LED_CLK 121 122 OPU I/OPU LED_DAT UART0_TX/REG_IF_SEL 123 124 OPU I/OPU I/OPD UART0_RX DVDDL 125 126 IPD P SPI_CS#0 127 O SPI_SI/SIO0 SPI_SO/SIO1 128 129 I/OPD I/OPD SPI_CLK DVDDH 130 131 OPD P MVDDH 132 P DDR12_D4/DDR3_D6 DDR12_D3/DDR3_D2 133 134 I/O I/O DDR12_D1/DDR3_D4 DDR12_D6/DDR3_D0 135 136 I/O I/O DDR12_DM/DDR3_DQS DDR3_DQS# 137 138 I/O I/O DVDDL 139 P DDR12_CLK#/DDR3_CLK# DDR12_CLK/DDR3_CLK 140 141 O O DDR12_DQS/DDR3_DM VREF 142 143 I/O P DDR12_D7/DDR3_D3 144 I/O DDR12_D0/DDR3_D1 DDR12_D2/DDR3_D7 145 146 I/O I/O DDR12_D5/DDR3_D5 DDR2_ODT/DDR3_CKE 147 148 I/O O DDR12_CS#/DDR3_BA1 DDR12_A0/DDR3_A12/ DIS_EEE DDR12_A2/DDR3_A4/ PWRBLINK[0] DDR12_A4/DDR3_A6/ PWRBLINK[1] DDR12_A6/DDR3_A8/ SEL_XTAL_CLK DDR12_A8/DDR3_A1/ SDS_PDOWN_EN DDR3_A14/SPI_ADDR_SEL 149 150 O I/O 151 I/O 152 153 10/100/1000M Switch Controllers Name DDR12_A13/DDR3_A11/ LED/MODE[1] DDR12_A11/DDR3_A10/ LED/MODE[0] DDR12_CAS#/DDR3_RAS# Pin No. 156 Type I/O 157 I/O 158 O DDR12_RAS#/DDR3_CAS# 159 O DVDDL DDR12_WE#/DDR3_WE# 160 161 P O MVDDH MVDDH 162 163 P P DDR12_CKE/DDR3_BA2 DDR12_BA1/DDR3_A9 164 165 O O DDR12_A1/DDR3_A13/ CPU_SLEEP DDR12_A12/DDR3_A2/ DRAM_INI_EN DDR3_RST# 166 I/O 167 I/O 168 O DDR12_A9/DDR3_A7/ MEM_TYPE[1] DDR12_A7/DDR3_A5/ MEM_TYPE[0] DDR12_A5/DDR3_A0/ CLK_M_EE[1] DDR12_A3/DDR3_A3/ CLK_M_EE[0] DDR12_A10/DDR3_BA0/ EN_DECRYPT DDR2_BA2/DDR3_CS# 169 I/O 170 I/O 171 I/O 172 I/O 173 I/O 174 O DDR12_BA0/DDR3_ODT DDR3_ZQ# 175 176 O - MVDDH DVDDL 177 178 P P VX 179 A CKOUT0 SVDDL 180 181 AO AP S0TXP S0TXN 182 183 AO AO I/O S0RXP S0RXN 184 185 AI AI I/O SVDDH 186 AP 154 I/O S1TXN S1TXP 187 188 AO AO 155 I/O S1RXN S1RXP 189 190 AI AI 28 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Name SVDDL Pin No. 191 Type AP Name P1MDIAN Pin No. 205 Type AI/O DVDDL 192 P P1MDIBP 206 AI/O AVDDH P0MDIAP 193 194 AP AI/O P1MDIBN AVDDL 207 208 AI/O AP P0MDIAN P0MDIBP 195 196 AI/O AI/O P1MDICP P1MDICN 209 210 AI/O AI/O P0MDIBN AVDDL 197 198 AI/O AP P1MDIDP P1MDIDN 211 212 AI/O AI/O P0MDICP 199 AI/O PLLVDDL 213 AP P0MDICN P0MDIDP 200 201 AI/O AI/O ATESTCK0 P2MDIAP 214 215 AO AI/O P0MDIDN AVDDH 202 203 AI/O AP P2MDIAN DGND 216 EPAD AI/O G P1MDIAP 204 AI/O 10/100/1000M Switch Controllers 29 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5. Pin Descriptions (RTL8382M-VB) 6.5.1. 1000M Ethernet PHY MDI Interface Pins Table 16. 1000M Ethernet PHY MDI Interface Pins Type Description Port 0 Media Dependent Interface A~D. AI/O For 1000Base-T operation, differential data from the media is transmitted and AI/O received on all four pairs. For 100Base-Tx and 10Base-T operation, only AI/O MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. AI/O Pin Name P0MDIAP Pin No. 194 P0MDIAN 195 P0MDIBP 196 P0MDIBN 197 P0MDICP 199 AI/O P0MDICN 200 AI/O P0MDIDP 201 AI/O P0MDIDN 202 AI/O P1MDIAP 204 AI/O P1MDIAN 205 AI/O P1MDIBP 206 AI/O P1MDIBN 207 AI/O P1MDICP 209 AI/O P1MDICN 210 AI/O P1MDIDP 211 AI/O P1MDIDN 212 AI/O P2MDIAP 215 AI/O P2MDIAN 216 AI/O P2MDIBP 1 AI/O P2MDIBN 2 AI/O P2MDICP 4 AI/O P2MDICN 5 AI/O P2MDIDP 6 AI/O P2MDIDN 7 AI/O P3MDIAP 9 AI/O P3MDIAN 10 AI/O P3MDIBP 11 AI/O P3MDIBN 12 AI/O P3MDICP 15 AI/O P3MDICN 16 AI/O P3MDIDP 17 AI/O P3MDIDN 18 AI/O 10/100/1000M Switch Controllers Each of the differential pairs has an internal 100 ohm termination resistor. Port 1 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 2 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 3 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 44 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name P4MDIAP Pin No. 37 Type AI/O P4MDIAN 38 AI/O P4MDIBP 39 AI/O P4MDIBN 40 AI/O P4MDICP 43 AI/O P4MDICN 44 AI/O P4MDIDP 45 AI/O P4MDIDN 46 AI/O P5MDIAP 48 AI/O P5MDIAN 49 AI/O P5MDIBP 50 AI/O P5MDIBN 51 AI/O P5MDICP 53 AI/O P5MDICN 54 AI/O P5MDIDP 55 AI/O P5MDIDN 56 AI/O P6MDIAP 59 AI/O P6MDIAN 60 AI/O P6MDIBP 61 AI/O P6MDIBN 62 AI/O P6MDICP 64 AI/O P6MDICN 65 AI/O P6MDIDP 66 AI/O P6MDIDN 67 AI/O P7MDIAP 69 AI/O P7MDIAN 70 AI/O P7MDIBP 71 AI/O P7MDIBN 72 AI/O P7MDICP 74 AI/O P7MDICN 75 AI/O P7MDIDP 76 AI/O P7MDIDN 77 AI/O 10/100/1000M Switch Controllers Description Port 4 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 5 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 6 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. Port 7 Media Dependent Interface A~D. For 1000Base-T operation, differential data from the media is transmitted and received on all four pairs. For 100Base-Tx and 10Base-T operation, only MDIAP/N and MDIBP/N are used. Auto MDIX can reverse the pairs MDIAP/N and MDIBP/N. Each of the differential pairs has an internal 100 ohm termination resistor. 45 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.2. SGMII Interface Pins Pin Name S4RXP Pin No. 96 Type AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 6.5.3. Table 17. SGMII Interface Pins Description SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. SGMII Interface Receive Data Differential Input Pair. SGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Pins Pin Name S0RXP Pin No. 184 Type AI S0RXN 185 AI S0TXP 182 AO S0TXN 183 AO S1RXP 190 AI S1RXN 189 AI S1TXP 188 AO S1TXN 187 AO S2RXP 84 AI S2RXN 85 AI S2TXP 82 AO S2TXN 83 AO S3RXP 90 AI S3RXN 89 AI S3TXP 88 AO S3TXN 87 AO S4RXP 96 AI S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO 10/100/1000M Switch Controllers Table 18. QSGMII Interface Pins Description QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. QSGMII Interface Receive Data Differential Input Pair. QSGMII Interface Transmit Data Differential Output Pair. 46 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.4. 1000Base-X/100Base-FX Interface Pins Table 19. 1000Base-X/100Base-FX Interface Pins Type Description 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. AI Pin Name S4RXP Pin No. 96 S4RXN 97 AI S4TXP 94 AO S4TXN 95 AO S5RXP 102 AI S5RXN 101 AI S5TXP 100 AO S5TXN 99 AO 6.5.5. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. 1000Base-X/100Base-FX Interface Receive Data Differential Input Pair. 1000Base-X/100Base-FX Interface Transmit Data Differential Output Pair. DDR1/2 SDRAM Interface Pins Table 20. DDR1/2 SDRAM Interface Pins Pin Name DDR12_D[7:0] Type I/O DDR2_BA[2] DDR12_BA[1:0] DDR12_WE# DDR12_CKE DDR12_RAS# DDR12_CAS# DDR12_CS#0 DDR2_ODT DDR12_DQS DDR12_CLK Pin No. 144, 136, 147, 133, 134, 146, 135, 145 156, 167, 157, 173, 169, 154, 170, 153, 171, 152, 172, 151, 166, 150 174 165, 175 161 164 159 158 149 148 142 141 DDR12_CLK# 140 DDR12_A[13:0] 10/100/1000M Switch Controllers Drive (mA) Description 8 DDR SDRAM Data Bus. I/O 8 DDR SDRAM Address Select. O O O O O O O O I/O O 8 8 8 8 8 8 8 8 8 8 O 8 DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Write Enable. DDR SDRAM Clock Enable. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Chip Select 0. DDR SDRAM On-Die Termination. DDR SDRAM Data Strobe. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. DDR SDRAM Clock. CLK and CLK# are differential clock outputs. 47 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.6. DDR3 SDRAM Interface Pins Table 21. DDR3 SDRAM Interface Pins Pin Name DDR3_D[7:0] DDR3_A[14] DDR3_A[13:10] DDR3_A[9] DDR3_A[8:0] DDR3_DQS# DDR3_DQS DDR3_CLK# DDR3_CLK DDR3_DM DDR3_CKE DDR3_BA[2:1] DDR3_BA[0] DDR3_RAS# DDR3_CAS# DDR3_WE# DDR3_RST# DDR3_CS# DDR3_ODT DDR3_ZQ# 6.5.7. Pin No. 146, 133, 147, 135, 144, 134, 145, 136 155 166, 150,156, 157 165 153, 169, 152, 170, 151, 172, 167, 154, 171 138 137 140 141 142 148 164, 149 173 158 159 161 168 174 175 176 Type I/O Drive (mA) Description 8 DDR SDRAM Data Bus. O I/O O I/O 8 8 8 8 DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. DDR SDRAM Address Select. I/O I/O O O I/O O O I/O O O O O O O - 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 DDR SDRAM Data Strobe. DDR SDRAM Data Strobe. DDR SDRAM Clock. DDR SDRAM Clock. DDR SDRAM Data Mask. DDR SDRAM Clock Enable. DDR SDRAM Bank Address Select. DDR SDRAM Bank Address Select. DDR SDRAM Row Address Strobe. DDR SDRAM Column Address Strobe. DDR SDRAM Write Enable. DDR SDRAM Reset. DDR SDRAM Chip Select. DDR SDRAM On-Die Termination. DDR SDRAM External Reference Ball for Output Drive Calibration. This ball is tied to an external 240 Ohm resistor, which is tied to GND. Master Mode SPI Flash Interface Pins Pin Name SPI_CLK SPI_SO/SIO1 Pin No. 130 129 SPI_SI/SIO0 128 SPI_CS#0 127 Table 22. Master Mode SPI Flash Interface Pins Type Drive (mA) Description OPD 12 Serial Clock Output Pin. I/OPD 12 In Serial Mode: This is a flash chip output pin In Dual Mode: This is a flash chip bi-directional pin Note: This is MSB first. I/OPD 12 In Serial Mode: This is a flash chip input pin In Dual Mode: This is a flash chip bi-directional pin Note: This is LSB first. O 12 Chip Select Output Pin. Slave Transmit Enable and active low. 10/100/1000M Switch Controllers 48 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.8. UART Interface Pins Pin Name UART0_RX UART0_TX UART1_RX UART1_TX 6.5.9. Pin No. 125 124 116 117 Type IPD I/OPD IPU I/OPD Table 23. UART Interface Pins Drive (mA) Description 4 UART0 Interface Receive Data. 4 UART0 Interface Transmit Data. 4 UART1 Interface Receive Data. 4 UART1 Interface Transmit Data. LED Interface Pins Pin Name LED_CLK Pin No. 122 Type OPU LED_DAT 123 I/OPU Table 24. LED Interface Pins Drive (mA) Description 12 (1) In Serial LED Mode Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. (2) In SMI-like LED Mode Reference output clock for I2C-like interface. 12 (1) In Serial LED Mode Serial bit stream of link status information. (2) In I2C-like LED Mode The data written to the LED IC. 6.5.10. GPIO Interface Pins Table 25. GPIO Interface Pins Type Drive (mA) Description This pin default set as system LED. I/OPD 4 Can be configured as General Purpose Input/Output Pin. Pin Name Pin No. GPIO0 113 GPIO[3:1] 110, 111, 112 I/OPD 4 General Purpose Input/Output Pins. GPO10 30 I/OPD 4 General Purpose Output Pins. GPIO11 31 I/OPD 4 General Purpose Input/Output Pins. GPIO[14:12] 32,28,29 I/OPU 4 General Purpose Input/Output Pins. 6.5.11. EJTAG Interface Pins Pin Name JTAG_TMS JTAG_TCK JTAG_TRST# JTAG_TDI JTAG_TDO Pin No. 29 28 32 31 30 Type I/OPU I/OPU I/OPU I/OPD I/OPD 10/100/1000M Switch Controllers Table 26. EJTAG Interface Pins Drive (mA) Description 4 JTAG Test Mode Select. 4 JTAG Test Clock Input. 4 JTAG Test Reset. 4 JTAG Test Data Input. 4 JTAG Test Data Output. 49 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 6.5.12. Configuration Strapping Pins Pin Name EEPROMTYPE Pin No. 30 DIS_PHYAUTO_UP 117 REG_IF_SEL 124 DIS_EEE 150 PWRBLINK[1:0] 152, 151 SEL_XTAL_CLK 153 SDS_PDOWN_EN 154 SPI_ADDR_SEL 155 LED_MODE[1:0] 156, 157 CPU_SLEEP 166 DRAM_INI_EN 167 MEM_TYPE[1:0] 169, 170 10/100/1000M Switch Controllers Table 27. Configuration Strapping Pins Default Description 0b0 Select EEPROM Address Byte Size. 0b0: 1-byte 0b1: 2-byte 0b0 Disable ASIC Auto Power Up PHY. 0b0: Enable ASIC auto power up PHY 0b1: Disable ASIC auto power up PHY 0b0 Select Switch Core Register Access Interface. 0b0: I2C 0b1: SPI slave 0b0 Disable 1000M EEE and 100M EEE Function. 0b0: Enable 0b1: Disable 0b00 Select LED Power On Blinking Timer. 0b00: Disable 0b01: 800ms 0b10: 1.6s 0b11: 3.2s 0b0 Select XTAL Input is 25M or 125M. 0b0: 25M 0b1:125M Note: This option is only for sync Ethernet. 0b0 Enable SerDes Power Down Mode. 0b0: SerDes4/5 operate in normal mode 0b1: SerDes4/5 operate in power down mode 0b0 Select Address Mode for SPI Flash. 0b0: 3-byte address 0b1: 4-byte address 0b0 Select LED Mode. 0b00: Serial LED mode 0b01: Scan Single mode 0b10: Scan Bicolor mode 0b11: Disable LED 0b0 Enable CPU Function. 0b0: CPU is always under reset state 0b1: CPU is enabled 0b0 Enable DRAM Initialization Procedure. 0b0: Enable DRAM Initialization procedure 0b1: Bypass DRAM Initialization procedure 0b00 Select Memory Type for SOC. 0b00: Select SPI flash + DDR-3 0b01: Select SPI flash + DDR-2 0b10: Select SPI flash + DDR-1 0b11: Select EEPROM 50 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name CLK_M_EE[1:0] EN_DECRYPT Pin No. 171, 172 173 Default Description 0b00 When MEM_TYPE Select is SPI Flash: This Strapping Pin Selects the Initial Clock for The Memory Controller. For DDR2: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 100MHz 0b11: Reserved for test; For DDR3: 0b00: Reserved for test; 0b01: Reserved for test; 0b10: 125MHz 0b11: Reserved for test; Note: The initial value for this strapping pin must be set as recommended in the reference design guide. 0b0 When MEM_TYPE Select is EEPROM: CLK_M_EE[0] is used to select SOC EEPROM address byte size. 0b0: 1-byte address 0b1: 2-byte address Enable or Disable Decrypt for Flash. 0b0: Disable decrypt 0b1: Enable decrypt 6.5.13. Miscellaneous Interface Pins Pin Name MDC MDIO SSPI_CLK/I2C_CLK Pin No. 120 121 119 SSPI_SI/I2C_DAT 118 SSPI_SO SSPI_CS# RESET# 117 116 114 XI XO MDIREF 106 105 21 RTT1 RTT2 VX CKOUT0 CKOUT2 23 24 179 180 80 10/100/1000M Switch Controllers Table 28. Miscellaneous Interface Pins Type Drive (mA) Description OPU 12 MII Management Interface Clock Pin. I/OPU 12 MII Management Interface Data Pin. I/OPU 4 SPI Serial Clock Input (Slave Mode). I2C Interface Clock Input (Slave Mode). I2C Interface Clock Output (Master Mode). I/OPU 4 SPI Serial Data Input (Slave Mode). I2C Interface Bi-Directional data (Slave Mode). I/OPD 4 SPI Serial Data Output (Slave Mode). IUP 4 SPI Serial Chip Select (Slave Mode). AI System Pin Reset Input (Low Active). To complete the reset function, this pin must be asserted for at least 10ms. It must be pulled up for normal operation. AI 25MHz Crystal Clock Input and Feedback Pin. AO 25MHz Crystal Clock Output Pin. AO MDI Bias Resistor. Adjust the reference current for all PHYs. This pin must connect to AGND via a 2.49k ohm resistor. AI/O Reserved for Internal Use (Must be Left Floating). AI/O Reserved for Internal Use (Must be Left Floating). A Low Voltage Power Control Resistor. AO 8 25MHz Clock Output. AO 8 25MHz Clock Output. 51 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Pin Name CKOUT4 ATESTCK[1:0] Pin No. 92 58, 214 Type AO AO Drive (mA) Description 8 25MHz Clock Output. Reserved for Internal Use (Must be Left Floating). 6.5.14. Power and Ground Pins Pin Name AVDDL PLLVDDL AVDDH DVDDL DVDDH SVDDL AVDDL_PLL SVDDH AVDDH_PLL MVDDH VREF AGND DGND 7. Table 29. Power and Ground Pins Pin No. Type Description 3, 13, 22, 42, 52, 63, AP Analog Low Voltage Power. 73, 198, 208 57, 213 AP Analog PLL Low Voltage Power. 8, 14, 19, 25, 36, 41, AP Analog High Voltage Power. 47, 68, 78, 193, 203 26, 33, 34, 79, 108, P Digital Low Voltage Power. 109, 126, 139, 160, 178, 192 27, 35, 115, 131 P Digital High Voltage Power. 81, 86, 93, 98, 103, AP SerDes Low Voltage Power. 181, 191 107 AP PLL Low Voltage Power. 91, 186 AP SerDes High Voltage Power. 104 AP PLL High Voltage Power. 132, 162, 163,177 P SDRAM High Voltage Power. 143 P SSTL Reference Voltage (MVDDH/2). 20 AG Analog Ground. E-PAD G Digital Ground. Switch Function Description 7.1. Hardware Reset and Software Reset 7.1.1. Hardware Reset A hardware reset forces the RTL8380M-VB/RTL8382M-VB to start the initial power-on sequence. First hardware will strap pins to give all default values when the ‘RESET’ signal terminates. Next the complete SRAM BIST (Built-In Self Test) process is run. Finally the packet buffer descriptors are initialized and internal registers and external CPU will access them. 7.1.2. Software Reset The RTL8380M-VB/RTL8382M-VB supports software queue resets, CPU&Memory reset, and Switch NIC reset. Reset sources are the signals that will trigger the reset command to the chip.   CPU&Memory Reset: Resets MIPS 4KEc + Memory Controller + Peripheral + NIC Switch NIC Reset: Resets the NIC interface between the CPU and Switch 10/100/1000M Switch Controllers 52 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.2. Crystal The RTL8380M-VB/RTL8382M-VB clock input frequency is 25MHz. When using a crystal, connect a loading capacitor from XI and XO to ground. The maximum Frequency Tolerance is +/-50ppm. Duty cycle should range from 40%~60%. 7.3. IEEE 802.3az Energy Efficient Ethernet (EEE) The RTL8380M-VB/RTL8382M-VB supports IEEE 802.3az Energy Efficient Ethernet (EEE) for 1000Base-T, 100Base-TX in full duplex operation. The Energy Efficient Ethernet (EEE) operational mode combines the IEEE 802.3 Media Access Control (MAC) Sub-layer with a family of Physical Layers defined to support operation in Low Power Idle (LPI) Mode. When Low Power Idle Mode is enabled, systems on both sides of the link can disable portions of the functionality and save power during periods of low link utilization. The RTL8380M-VB/RTL8382M-VB EEE operational mode supports IEEE 802.3 MAC operation at 1000Mbps/100Mbps. For 1000Mbps/100Mbps operation, the1000Base-T/ 100Base-TX PHY is supported. 7.4. Layer 2 Learning and Forwarding The RTL8380M-VB/RTL8382M-VB has a 4K-entry VLAN table and provides a 64-entry filtering database. The RTL8380M-VB/RTL8382M-VB supports IVL (Individual VLAN Learning) and SVL (Shared VLAN learning) mode. The mode used depends on the FID (Filtering Identifier) setting. 7.4.1. Forwarding IP multicast data packets involve multicast group table lookup and forwarding operations. If the table lookup returns a hit, the data packet is forwarded to all member ports and router ports. If the multicast address is not stored in the address table (i.e., lookup miss), the packet is broadcast to all ports of the broadcast domain. The VLAN Frame Forwarding Rules are defined as follows:   The received broadcast/multicast frame will flood to VLAN member ports only, except for the source port The received unicast frame will be forwarded to its destination port only if the destination port is in the same VLAN as the source port. If the destination port belongs to a different VLAN, the frame will be discarded 7.4.2. Learning The RTL8380M-VB/RTL8382M-VB features a Layer 2 table (8K entries) that uses a 4-way hash structure to store L2 entries. Each entry can be recorded in three formats, L2 Unicast, L2 Multicast, and IP Multicast. 10/100/1000M Switch Controllers 53 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet The L2 Unicast hash key is {MAC(48bits), FID/VID(12bits)}; the Multicast hash key is {MAC(48bits), FID/VID(12bits)}; the IP Multicast hash key is {MAC(48bits), FID/VID(12bits)}, {GIP(32bits), SIP(32bits)} or {0(16bits)+GIP(32bits), FID/VID(12bits)}. 7.4.3. DA/SA Block First bit transmitted: 0= Unicast Destination 1= Multicast Destination Destination Address Second bit transmitted: 0= Globally Administered 1= Locally Administered First byte Second byte Third byte Fourth byte Fifth byte Sixth byte First byte Second byte Third byte Fourth byte Fifth byte Sixth byte Second bit transmitted: 0= Globally Administered 1= Locally Administered Source Address First bit transmitted-Routing Information Indicator (RII) 0=Routing Information Not Present (Not Source Routed) 1=Routing Information Present (Source Routed) Figure 9. DA/SA Block While a frame may be sent to either a unicast or a multicast destination, frames are always sent from an individual station. The first bit of the Destination Address shows unicast or multicast. When used in its originally intended manner, the first bit of a Source Address should always be 0, indicating an individual sending station. The RTL8380M-VB/RTL8382M-VB features DA blocking, SA blocking, or DA and SA blocking function through the Address Hash Table setting. 7.5. Port Isolation The RTL8380M-VB/RTL8382M-VB supports the Port Isolation feature. We can control whether the hosts communicate with each other or not by controlling a register value. If we set the register to cut the connection between hosts, all packets from a host cannot be transmitted to another host directly. These packets can only be transmitted by passing through the router. This feature is called ‘Port Isolation’. In Figure 10, Host A and host B connect to the port0 and port3 of the switch, respectively, and port7 is a router. If we set the port isolation enable bit of port0 and port3 to 1, all packets between A and B need to pass through the router (in both directions, A to B and B to A). 10/100/1000M Switch Controllers 54 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet A B C D E F G H SELECTED ON-LINE 0 A 3 B 7 Uplink port: 7 Downlink port: 0, 3 Figure 10. Port Isolation Example Each port has its own port mask configuration (11 bits in total for the RTL8380M-VB, 29 bits for the RTL8382M-VB). These bits and the TX port list will be mixed to a list. We call this mixed list the final TX port list. Port isolation port mask settings will affect received packets; however, the Mirroring function is not affected by the port isolation port mask. 10/100/1000M Switch Controllers 55 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.6. IEEE 802.3x Flow Control The RTL8380M-VB/RTL8382M-VB supports IEEE 802.3x full duplex flow control. If one port’s received frame buffer is over the pause threshold, a pause-on frame is sent to indicate to the link partner to stop the transmission. When the port’s received frame buffer drops below the pause threshold, it sends a pause-off frame. The TX pause frame format is shown in Figure 11. Type =0x8808 MAC Control Opcode Pause on=0001 Start-of-Frame Delimiter 1 byte Preamble 7 bytes 1 byte Destination Address (DA) Source Address (SA) 6 bytes 6 bytes Pause On: 0xFFFF Pause Off: 0x0000 Reserved (Transmitted as Zero) 42 bytes 2 bytes 2 bytes 2 bytes Frame Check Sequence 4 bytes Figure 11. TX Pause Frame Format The flow control mechanism of the RTL8380M-VB/RTL8382M-VB is implemented on the RX side. It counts the received pages on the RX side in order to determine on which port it should send out Pause On/Off packets. Trigger Condition for Pause-Off Initial state; Flow Control Enabled Non-Congest State Congest State Trigger Condition for Pause-On Figure 12. Flow Control State Machine When RTL8380M-VB/RTL8382M-VB flow control is enabled, the initial state is ‘Non_Congest’. The state is monitored continuously. If a pause-on trigger condition occurs, it enters the ‘Congest’ state. When in the ‘congest’ state, it is also continuously monitored. When a pause-off trigger condition occurs it reenters the ‘Non_Congest’ state. Figure 12 shows the flow control state machine. 10/100/1000M Switch Controllers 56 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.7. Half Duplex Backpressure There are two mechanisms for half duplex backpressure (Backpressure is for input buffer overflow). 7.7.1. Collision-Based Backpressure (Jam Mode) If the input buffer is ready to overflow, this mechanism will force a collision. When the link partner detects this collision, the transmission is rescheduled. The Reschedule procedure is:     When the link partner detects the collision, it waits for a random backoff time. The RTL8380MVB/RTL8382M-VB will handle packets that are in the input packet buffer during this time RXDV and TXEN will be driven high. The RTL8380M-VB/RTL8382M-VB will send a 12-byte Jam signal (pattern is preamble (7bytes) + SFD (1byte) + 0xAA (4bytes)). The RTL8380MVB/RTL8382M-VB will then drive TXEN low When the link partner (which could be another RTL8380M-VB/RTL8382M-VB) receives the Jam signal, it will feedback a 4-byte signal (pattern is derived from the CRC of all transmitted bytes) After the RTL8380M-VB/RTL8382M-VB receives this jamming signal, it drives RXDV low. The link partner waits for a random backoff time then re-sends the packet. The timing is shown in Figure 13 Congestion State 0b’1: Congested 0b’0: Not Congested Jamming 4 bytes Backoff time XX RXD 96 bit times InterframeGap RXDV JAM TXEN 12 bytes TXD XX Figure 13. Signal Timing for Collision-Based Backpressure 7.7.2. Carrier-Based Backpressure (I.e., Defer Mode) If the input buffer is about to overflow, this mechanism will send a fix pattern to defer the other station’s transmission. The RTL8380M-VB/RTL8382M-VB will continuously send the defer signal until the input buffer overflow is resolved. 7.8. Layer 2 Multicast and IP Multicast There are two RTL8380M-VB/RTL8382M-VB IP multicast frame types: IPv4 multicast and IPv6 multicast. 10/100/1000M Switch Controllers 57 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet An IPv4 multicast frame must satisfy two conditions:   The type must be IPv4 DMAC should=01-00-5E-XX-XX-XX An IPv6 multicast frame must satisfy two conditions:   The type must be IPv6 DMAC should=0x33-33-XX-XX-XX-XX The RTL8380M-VB/RTL8382M-VB definition of a L2 multicast packet is that the packet is not an IP multicast packet, and the I/G bit of the MAC address is 1. The RTL8380M-VB/RTL8382M-VB supports IGMPv1/2/3. IGMP and MLDv1/2 packets can be trapped to the CPU to allow software to insert an IP multicast entry into the L2 table. 7.9. IEEE 802.1d/1w/1s (STP/RSTP/MSTP) There are 64 spanning tree instances for the RTL8380M-VB/RTL8382M-VB. The CPU will create a different Port State for different spanning tree instances at each port. The RTL8380M-VB/RTL8382M-VB will assign a VID for a received packet, and will look up the VLAN table to check for Multiple Spanning Tree Instances (MSTI). The RTL8380M-VB/RTL8382M-VB will follow the ports MSTI state to complete its corresponding ingress/egress check. The Spanning Tree and Rapid Spanning Tree port states are shown in Figure 14. Port State of Spanning Tree Port State of Rapid Spanning Tree Disable Learning Listening Blocking Discard Learning Forwarding Forwarding Figure 14. Spanning Tree and Rapid Spanning Tree Port States When using IEEE 802.1D, the RTL8380M-VB/RTL8382M-VB supports four status’ for each port: Disabled Except for software forwarding, the port will not transmit/receive packets, and will not perform learning. 10/100/1000M Switch Controllers 58 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Blocking/Listening Except for software forwarding, the port will only receive BPDU spanning tree protocol packets, but will not transmit any packets, and will not perform learning. Learning The port will receive any packet, including BPDU spanning tree protocol packets, and will perform learning, but will only transmit BPDU spanning tree protocol packets. Forwarding The port will transmit/receive all packets, and will perform learning. There are five Spanning Tree port states, and four Rapid Spanning Tree port states. Their mapping relations are DiscardingBlocking, LearningLearning, and ForwardingForwarding (see Table 30). Receive BPDUs Transmit BPDUs Learn Address Forward Frame Table 30. Spanning Tree and Rapid Spanning Tree Action Spanning Tree Rapid Spanning Tree Disable Blocking Listening Learning Forwarding Discard Learning Forwarding No Yes Yes Yes Yes Yes Yes Yes No No Yes Yes Yes No Yes Yes No No No Yes Yes No Yes Yes No No No No Yes No No Yes 7.10. IEEE 802.1p and IEEE 802.1Q (VLAN) The RTL8380M-VB/RTL8382M-VB supports IEEE 802.1Q tag-based, protocol-and-port-based, portbased, MAC-based, IP-subnet-based, and application-based VLANs. It supports a 4K-entry VLAN table, supporting C-VID (Customer VLAN ID) and FID (Filtering Identifier) entries. There are 6 fields in the VLAN table, and their definitions are as below.       MBR: Determines whether the packets belong to the same VLAN UNTAG: Determines whether Egress packets have a VLAN tag FID_MSTI: Gets different FIDs (Filtering Identifier) or determines the index of multiple spanning tree instances from different VLANs L2_HKEY_UBCAST: Determines the hash key (VID or FID) for L2 unicast and broadcast traffic L2_HKEY_MCAST: Determines the hash key (VID or FID) for L2 multicast and IP multicast traffic VLAN_PROFILE: Determines the index of the VLAN profile 10/100/1000M Switch Controllers 59 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet The RTL8380M-VB/RTL8382M-VB supports eight global VLAN profiles. Each VLAN profile has the following configurations:     L2_LRN_EN: Enable L2 SA learning L2_UNKN_MC_FLD_PMSK: Unknown L2 multicast flooding port mask IP4_UNKN_MC_FLD_PMSK: Unknown IPv4 multicast flooding port mask IP6_UNKN_MC_FLD_PMSK: Unknown IPv6 multicast flooding port mask For un-managed switches, there is a register setting to disable tag-based VLANs and force ‘no check’ for any VLAN settings. If a packet is tagged in, then it is tagged out. If untagged in, then it is untagged out.    The RTL8380M-VB/RTL8382M-VB supports ingress and egress VLAN filtering functions Ingress VLAN filtering: Packets from an input port that is not in the VLAN member set will be dropped, trapped, or forwarded depending on register configuration Egress VLAN filtering: Packets to an output port that is not in the VLAN member set will be dropped, trapped, or forwarded depending on register configuration 7.11. IEEE 802.1X (Network Access Control) The RTL8380M-VB/RTL8382M-VB provides a software solution for 802.1X. When a host connects to a switch, the switch will transfer the host information to an authentication server:   If authentication is successful, the switch will set the control bit of this port to ‘TRUE’ (i.e., the host will be allowed the service) If authentication is not successful, the switch will deny the host access to the network The CPU port can be regarded as a special port where transmit and receive packets are unrestricted for 802.1X. The RTL8380M-VB/RTL8382M-VB supports two types of 802.1X; Port-Based Network Access Control, and MAC-Based Network Access Control.   Port-Based Network Access Control: For each port, there is a bit to check whether this port has passed authentication or not. A direction control register decides whether this port needs pass-through authentication for both (IN/OUT) directions or only for receive (IN) MAC-Based Access Control: Provides authentication for multiple logical ports. Each logical port represents a source MAC address. There are multiple logical ports for a physical port. There is a register that enables/disables each logical port MAC-based network access control function. Another register controls transmit/receive direction authentication for each port (IN/OUT) or only receive direction (IN) 10/100/1000M Switch Controllers 60 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Table 31 illustrates the forwarding of host n. Authentication of Host n 0 (Unauthorized) 0 (Unauthorized) 1 (Authorized) 1 (Authorized) Table 31. Forwarding of Host n Direction of Whole Chip Fwd Frames to Host n 0 (BOTH) No 1 (IN) Yes 0 (BOTH) Yes 1 (IN) Yes Fwd Frames from Host n No No Yes Yes 7.12. Reserved Multicast Address Handling There are some Reserved Multicast Address (RMA) definitions in the IEEE 802.1 standard. The RTL8380M-VB/RTL8382M-VB includes 01-80-C2-00-00-00 to 01-80-C2-00-00-2F RMA support and provides user defined RMA settings. For each RMA, the actions include: Table lookup, Drop, Trap to CPU, and always Flood. The action priority is higher than the results of a L2 Table lookup. Default actions are shown in Table 32. Table 32. Reserved Multicast Address Default Actions Name Address Bridge Group Address 01-80-C2-00-00-00 IEEE Std 802.3, 1988 Edition, Full Duplex PAUSE Operation 01-80-C2-00-00-01 IEEE Std 802.3ad Slow Protocols-Multicast Address 01-80-C2-00-00-02 IEEE Std 802.1X PAE Address 01-80-C2-00-00-03 Reserved for future protocol standards 01-80-C2-00-00-04 to 01-80-C2-00-00-0D, 01-80-C2-00-00-0F LLDP IEEE Std 802.1AB Link Layer Discovery Protocol 01-80-C2-00-00-0E Multicast Address All LANs Bridge Management Group Address 01-80-C2-00-00-10 GMRP 01-80-C2-00-00-20 GVRP 01-80-C2-00-00-21 Reserved for use by Multiple Registration 01-80-C2-00-00-22 to 01-80-C2-00-00-2F Protocol (MRP) applications 10/100/1000M Switch Controllers 61 Default Forward Drop Drop Forward Drop Forward Drop Drop Forward Drop Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.13. Layer 2 Traffic Suppression (Storm Control) The per-port L2 storm filtering control mechanism suppresses the flow rate of some specific packets. The RTL8380M-VB/RTL8382M-VB supports five control types: Unknown Unicast Storm, Unicast Storm, Unknown Multicast Storm, Multicast Storm, and Broadcast Storm. Each port has control registers to enable or disable the storm filtering function. These five traffic type definitions are:      Unknown Unicast: If the I/G bit of the packet’s destination address is 0, it is a unicast packet and its DA look-up in the L2 unicast table failed. I.e., the packet’s destination address is unknown Unicast: The unicast storm filtering control includes unknown and known unicast for RTL8380MVB/RTL8382M-VB Unknown Multicast: If the I/G bit of the packet’s destination address is 1, it is a multicast packet and its DA look-up in the L2 unicast table failed, i.e., the packet’s destination address is unknown Multicast: The multicast storm filtering control includes unknown and known multicast for RTL8380M-VB/RTL8382M-VB Broadcast: DMAC = FF-FF-FF-FF-FF-FF indicates this is a broadcast packet Unknown Unicast and Unicast use the same traffic counter, and Unknown Multicast and Multicast use the same traffic counter. The user should set the Unicast and Multicast storm type as unknown or both known and unknown in the storm filter setting. The traffic rate for these five types can be set on a per-port basis. The priority sequence of L2 filtering control is: 1. Input bandwidth control 2. ACL policy 3. Storm-filtering control 7.14. PIE (Packet Inspection Engine) PIE is a 1.5K-entry search engine that is divided into 12 blocks (block numbers are 0~11). Each block size is 128-entries. Every entry has 216-bit data, and a 216-bit mask. There is an extra bit to indicate whether this entry is valid or not. Each block can be disabled for power saving when it is not used. All the entries are prepared for ingress ACL. 7.14.1. Ingress ACL The Ingress ACL (Access Control List) perform actions such as packet drop, forwarding, ingress I-VID Assignment, Ingress O-VID Assignment, filter, log, remarking, meter, mirror etc. When a packet hits one entry it will execute the corresponding action mapped to this entry. Each PIE memory entry corresponds to one action entry. The packet can match to multi-actions. When a multi-match occurs (i.e., there are several ACL entries that match) in one block, it will execute the lowest address entry corresponding action. 10/100/1000M Switch Controllers 62 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.15. Input Bandwidth Control and ACL Traffic Meter 7.15.1. Input Bandwidth Control The RTL8380M-VB/RTL8382M-VB has input bandwidth control for each port (excluding the CPU port). The bandwidth setting range is 16Kbps~1Gbps. The granularity is 16Kbps, and each port has a 16-bit register to control the bandwidth. If the speed of received packets is faster than the bandwidth setting, it will send a ‘Pause ON’ packet to slow the link partner transmissions when the flow control function is enabled, and drop packets when the flow control function is disabled. When normal transmissions become possible and the flow control function is enabled, the switch will send a ‘Pause OFF’ packet. 7.15.2. ACL Traffic Meter For Ingress ACL entry, there is an index to point to 256 ACL rate-limited entries. The rate limit is flow controlled via leaky bucket. The rate range is 16Kbps~1Gbps, the granularity is 16Kbps, and each ratelimited entry has a 16-bit register to control the rate value. 7.16. IEEE 802.3ad Link Aggregation Protocol To ensure correct frame ordering when changing the hash algorithm, the marker protocol mechanism must be started. Software will wait for the aggregation port queues to empty, and then send a marker message to all aggregation ports. After receiving a marker reply packet, software can change the hash algorithm. The RTL8380M-VB/RTL8382M-VB supports 802.3ad (Link Aggregation) for 8 groups of link aggregators with up to 8 ports per-group (based on DMAC/SMAC/SPA/SIP/DIP/SPORT/DPORT). The CPU port cannot be aggregated to an aggregation port. As the RTL8380M-VB/RTL8382M-VB does not check CPU port aggregation, software should check this to avoid frame transmit errors. Frame Distribution Link aggregation group frames are sent to an aggregation port of the link aggregation group according to a hash algorithm. There are seven parameters (DMAC, SMAC, SPA, SIP, DIP, SPORT, DPROT). To prevent assigning the same hash value when hash keys simultaneously change to another value, we stagger the least significant bit of all hash keys. Mapping a Physical Port to a Logical Port No matter how many physical aggregation port members are in a link aggregation group, it is regarded as one logical port. Each link aggregation has an ID (the lowest number of the physical aggregation port members is used as its ID). Once the ID is chosen, even if the logical port ID’s corresponding physical port is link down, the ID and setting of the link aggregation group will not change. However, it will change when this corresponding port is removed or a lower-numbered port is added. Hash Algorithm Change The algorithm will change when the following conditions occur:   The link aggregation group member port changes to link-down or link-up The user/LACP (i.e., Link Aggregation Control Protocol) changes the link aggregation group member 10/100/1000M Switch Controllers 63 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet port or register setting 7.17. IEEE 802.1ad VLAN Stacking The RTL8380M-VB/RTL8382M-VB supports multi-layered VLANs and can have Outer-VLAN and Inner-VLAN tagging. Standard 802.1ad takes the S-tag (Service VLAN tag) as the relay VID. The RTL8380M-VB/RTL8382M-VB uses the Outer-tag as S-tag, and the Inner-tag as C-tag to support 802.1ad applications. The IEEE 802.1ad frame format is shown in Figure 15. 6 bytes 1 byte Destination Address 6 bytes Source Address 2 bytes VLAN Protocol Info 0x 88a8 2 bytes 2 bytes 2 bytes 2 bytes S- Tag VLAN Protocol Info 0x8100 C- Tag Length / Type 4 bytes Frame Check Sequence Payload PCP DEI VLAN Identifier PCP CFI VLAN Identifier 3 bits 1bit 12 bits 3 bits 1 bit 12 bits Figure 15. IEEE 802.1ad Frame Format 10/100/1000M Switch Controllers 64 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.18. Quality of Service (QoS) There are 5 types of Priority Assignment for the RTL8380M-VB/RTL8382M-VB:      Port-based Inner-tag Priority Port-based Outer-tag Priority Inner-tag-based Priority Outer-tag-based Priority DSCP-based Priority These priority assignments will pass through the whole system priority selection table to decide the packets internal priority. Afterwards the internal priority will point to the adaptive output queue ID table. Priority Selection Tables A received packet may be assigned up to five different priorities. These priorities are coordinated into a final priority according to the priority selection table Figure 16. Each priority assignment has a control register. The corresponding bit set to 1, sets the priority from high bit to low bit. Inner-tag-based priority, Outer-tag-based priority, and DSCP-based priority may be NULL. The priority arbiter should check whether the item is NULL or not. The NULL item priority corresponds to the lowest priority arbitration value; the bigger the corresponding priority arbitration value, the higher the priority assignment. We can take an example to describe the priority order. The order is Inner-tag-based priority assignment > DSCP-based priority assignment > Outer-tag based priority assignment > Port-based Inner-tag Priority assignment = Port-based Outer-tag Priority assignment. Priority weight Port-based Inne-tag Priority Assignment 1 Port-based Inne-tag Priority Assignment 1 DSCP-based Priority Assignment 6 Inner-tag-based Priority Assignment 7 Outer-tag-based Priority Assignment 5 Figure 16. Priority Selection Table Weight Rules Example 10/100/1000M Switch Controllers 65 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Internal Priority to Queue ID Table Descriptor with Priority 7 Output Queue 7 Descriptor with Priority 6 Output Queue 6 Descriptor with Priority 5 Output Queue 5 Descriptor with Priority 4 Output Queue 4 Descriptor with Priority 3 Output Queue 3 Descriptor with Priority 2 Output Queue 2 Descriptor with Priority 1 Output Queue 1 Descriptor with Priority 0 Output Queue 0 Weighted Arbitor The RTL8380M-VB/RTL8382M-VB can transfer its internal priority setting (see Figure 17) to the output queue ID. The RTL8380M-VB/RTL8382M-VB can configure each port’s output queue level (including the CPU port). Each port has eight output queues. TX Figure 17. Per-Port Queue Management 7.19. Packet Scheduling (WRR and WFQ) The Packet Scheduler controls the various traffic classes (i.e., controls the packet sending sequence of the priority queue). The RTL8380M-VB/RTL8382M-VB scheduling algorithm is divided into Weighted Fair-Queuing (WFQ) and Weighted Round-Robin (WRR). Note that the Strict Priority queue is the highest priority of all queues, and overrides WFQ & WRR. A larger strict priority queue ID indicates the priority is higher. The Scheduler operates as follows:   Weighted Fair-Queuing (WFQ): Byte-count Weighted Round-Robin (WRR): Packet-count WFQ and WRR cannot exist at the same time. WFQ or WRR can co-exist with Strict Priority Schedule. Both WFQ and WRR are round robin, from large queue ID to small. 10/100/1000M Switch Controllers 66 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.20. Packet Drop Algorithm (TD) The RTL8380M-VB/RTL8382M-VB supports Tail Drop (TD).  Tail Drop (TD): For a drop threshold value, if a packet meets queue overflow conditions before entering the output queue, the switch will drop this packet 7.21. Egress Packet Remarking The RTL8380M-VB/RTL8382M-VB Remarking can be divided into Inner-tag remarking, Outer-tag remarking, and DSCP remarking.    For Inner-tag remarking, there is an internal priority to inner-tag priority remarking table that is used to configure the final user inner-tag priority value for per-port egress of a packet For Outer-tag remarking, there is an internal priority to outer-tag priority remarking table that is used to configure the final Outer-tag priority value for per-port egress of a packet DSCP remarking also has an internal priority to DSCP priority table for per-port egress of a packet 7.22. Ingress and Egress Port Mirror The RTL8380M-VB/RTL8382M-VB has four mirror sets (set0~3), and the Mirroring port can monitor several mirrored ports simultaneously. RX mirror and TX mirror function is supported by setting a source port mask, destination port mask. The mirror function can be configured across VLANs. The RTL8380M-VB/RTL8382M-VB supports a mirror filtering function to filter forwarded traffic. Only mirrored traffic can egress though a mirroring port. The RTL8380M-VB/RTL8382M-VB provide a flexible flow-based mirror function. In a flow-based mirror, only specified packets will be mirrored through a configured ACL action and fill a corresponding traffic mirror table entry. For flow control, the mirroring port will drop the mirrored packets and send PAUSE frames or backpressure signals to the mirrored port for normal packets. It will resume mirror function when flow control is back to normal status. The design limitations for mirroring settings are as below.    Each mirror entry can only set one mirroring port A mirroring port cannot be a member of a trunk group The mirroring port is not limited by port isolation for mirrored packets 10/100/1000M Switch Controllers 67 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.22.1. Remote Mirror (RSPAN) The RTL8380M-VB/RTL8382M-VB support Remote Switched Port Analyzer (RSPAN) to analyze a remote device’s traffic flow. The RTL8380M-VB/RTL8382M-VB defined RSPAN VLAN tag is illustrated in Figure 18. Users can configure the RSPAN tag’s TPID/VID/Priority/CFI at each port. The RTL8380M-VB/RTL8382M-VB can parse for the RSPAN tag in RX and add or remove RSPAN tags in TX. DMAC SMAC DMAC SMAC RSPAN TPID Layer2 Header PAYLOAD Layer 2 Header RSPAN Tag PRIO CFI FCS PAYLOAD FCS RSPAN VID Figure 18. RSPAN Encapsulation Figure 19 shows an example of an RSPAN application. In Source Switch A, Port0 is configured as a mirrored port, and Port2 as a mirroring port with setting ‘TX added RSPAN tag’. In Intermediate Switch B, Port3 and Port5 are added as RSPAN VLAN members. RSPAN mirrored packets will be forwarded without any modification. In Destination Switch C, Port7 and Port9 join as RSPAN VLAN members, with Port9 configured to ‘Remove RSPAN tag in TX’. This means packets are mirrored from Source Switch A Port0 to Destination Switch C Port9 without modification. 6 Intermediate Switch B Source Switch A 0 1 2 Port 0: Mirrored (TX or RX or both) port Port 2: RSPAN mirroring port; forwards mirrored traffic with RSPAN VLAN tag 3 4 Destination Switch C 5 Port 3 and Port 5 : Intermediate RSPAN port ; forwards RSPAN mirrored packets without any modification 7 8 9 Port 9 : RSPAN mirroring port; TX mirrored RSPAN packet without RSPAN VLAN tag Figure 19. RSPAN Illustration 10/100/1000M Switch Controllers 68 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.23. Management Information Base (MIB) The RTL8380M-VB/RTL8382M-VB MIB (Management Information Base) counters include:      Ethernet-like MIB (RFC 3635) Interface Group MIB (RFC 2863) RMON (Remote Network Monitoring) MIB (RFC 2819) Bridge MIB (RFC 1493) Bridge MIB Extension (RFC 2674) 7.24. NIC and CPU Tag Forwarding NIC interface: This is used for receiving packets from the CPU, or transmitting packets to the CPU. The architecture is shown in Figure 20. When a packet is sent from the switch core to the CPU port, the CPU tag can carry status information. The CPU tag can be divided into a transmit CPU tag, and a receive CPU tag.   Transmit CPU Tag: Forces TX port mask. Indicates which ports the packet will NOT be sent to. For example, if we set port1, port2, and port5 mask bits, then the packet will not be sent to these ports Receive CPU Tag: Indicates which RX port the packet came from If no CPU tag is attached, the normal process will be followed to perform a look-up in the L2 table. DMA NIC Driver SDRAM MAC Rx NIC CPU Port MAC Switch Core DMA MAC MAC Tx Figure 20. NIC Architecture 10/100/1000M Switch Controllers 69 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 7.25. Indirect Table Access The RTL8380M-VB/RTL8382M-VB employs an indirect method to set the control register and the data register to complete a VLAN/L2 Lookup/ Forwarding/SPT/ACL Table Access: 1. Sets the register to determine which table and which entry is to be accessed 2. Determines the read or write action 3. Hardware executes table access Read: After the control register setup has been completed by software, hardware access then puts this data into the data register. Software then reads this data from the data register. Write: The data is placed in the data register by software and the control register is set. Hardware writes this data to the table. 7.26. External PHY Register Access After the RTL8380M-VB/RTL8382M-VB powers on and initializes, it will set the PHY MII register via MDC/MDIO. The RTL8380M-VB/RTL8382M-VB supports three access control registers to indirectly access an external PHY via the MDC/MDIO interface. 7.27. Switch Interrupt Indication The RTL8380M-VB/RTL8382M-VB provides one global interrupt function: switch interrupt. Interrupt sources are listed below:    Port Link Change interrupt Port SA learning constraint interrupt SerDes interrupt 10/100/1000M Switch Controllers 70 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 8. CPU Function Description 8.1.     MIPS-4KEc MIPS 4KEc CPU Core (Targeted at 500MHz): 5-stage pipeline, MIPS32 instruction set, additional MIPS16e instruction set support, 2 GPR sets (one shadow set), and vectored/Non-Maskable Interrupts (NMI) support Cache Configuration: I-Cache is 16KB, 4-way set associative, and 16-byte line size. D-Cache is 16KB, 4-way set associative, 16-byte line size, and write-back policy. It also has virtually indexed, physically tagged, and Prefetch instructions MMU Configuration: 4-entry ITLB, 4-entry DTLB, and 32-entry JTLB Misc.: Power-down mode, EJTAG support, internal BIST, internal real-time timer interrupts (Count/Compare registers), and CPU breakpoints 8.2. SPI Flash The RTL8380M-VB/RTL8382M-VB support 32M-Byte (max) serial I/O, dual I/O SPI Flash. 8.3. SDRAM Interface Configuration The RTL8380M-VB/RTL8382M-VB support 8-bit data bus DDR1/DDR2/DDR3 SDRAM. 10/100/1000M Switch Controllers 71 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9. 9.1. Interface Descriptions QSGMII QSGMII-plus (Quad Serial Gigabit Media Independent Interface) reduces PCB complexity and IC pin count. This innovative 5Gbps serial interface provides an up to 10 inch MAC to PHY communication path. QSGMII can carry the full duplex gigabit Ethernet data streams of four ports simultaneously, using only 4 pins. Port0 MAC PHY TX+/- RX+/- TX Port0 RX Port1 Port1 25MHz QGMII TX+/- RX+/- Port2 QSGMII RX Port2 TX Port3 Port3 Figure 21. QSGMII Interconnection 9.2. SGMII SGMII (Serial Gigabit Media Independent Interface) conveys PHY and MAC data with significantly less pins than required for GMII. It operates in both half and full duplex, and at all port speeds. It includes 4 data signals and 2 CLK signals to convey frame data and link rate information between the PHY and MAC. The data signals operate at 1.25Gbaud, and the CLK operates at 625MHz. Each of these signals is carried as a differential pair, thus providing signal integrity while minimizing system noise. TX +/- MAC PHY RX +/- Figure 22. SGMII Signal 10/100/1000M Switch Controllers 72 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.3. DDR1 SDRAM The RTL8380M-VB/RTL8382M-VB support DDR1 SDRAM with the following features:      Bus width is 8 bits One chip selection Supports 4 banks Row count range is 4~16K, and column count range is 512~4K Supports maximum 128M Bytes DDR1 SDRAM CKE CLK CLK# WE# RAS# CAS# Controller DDR1 SDRAM DDR1_BA[1:0] CS# 1Gbit DM 128M*8bit DQS A[13:0] D[7:0] Figure 23. DDR1 SDRAM Configuration 10/100/1000M Switch Controllers 73 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.4. DDR2 SDRAM The RTL8380M-VB/RTL8382M-VB support DDR2 SDRAM with the following features:      Bus width is 8 bits One chip selection Supports 4 banks or 8 banks Row count range is 4~16K, and column count range is 512~4K Supports maximum 128M Bytes DDR2 SDRAM CKE CLK CLK# WE# RAS# CAS# DDR2 SDRAM DDR2_BA[2:0] Controller CS# 1Gbit DM 128M*8bit ODT DQS A[13:0] D[7:0] Figure 24. DDR2 SDRAM Configuration 10/100/1000M Switch Controllers 74 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.5. DDR3 SDRAM The RTL8380M-VB/RTL8382M-VB support DDR3 SDRAM with the following features:     Bus width is 8 bits One chip selection Supports 8 banks Supports maximum 256M Bytes DDR3 SDRAM CKE CLK CLK# WE# RAS# CAS# DDR3 SDRAM DDR3_BA[2:0] CS# Controller 2Gbit RST# 256M*8bit ODT DM DQS# DQS A[14:0] D[7:0] Figure 25. DDR3 SDRAM Configuration 9.6. SPI Flash Interface The RTL8380M-VB/RTL8382M-VB support SPI Flash with the following features:     Supports serial I/O, dual I/O SPI Flash (max) Supports both MMIO (Memory Mapped I/O) and PIO (Programmed I/O) mode One chip selection Supports maximum 32M Bytes SPI Flash in PIO mode and 16M Bytes in MMIO mode SPF_SCK SPI_SIO0/SPI_SI Controller SPI Flash SPI_SIO1/SPI_SO 256Mbit SPF_CS# Figure 26. SPI Flash Configuration 10/100/1000M Switch Controllers 75 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.7. UART The RTL8380M-VB/RTL8382M-VB provides two UARTs, and each contains a 16-byte FIFO buffer. The baud rate can be up to 1Mbps and a programmable baud rate generator allows division of any input reference clock by 1 to 65535, and generates an internal 16x clock. The RTL8380M-VB/RTL8382M-VB provides a fully programmable serial interface. In addition to the above functions, the RTL8380M-VB/RTL8382M-VB provides fully prioritized interrupt control and loopback functionality for diagnostic capabilities. The UART interface pins are shown in the following table. Table 33. UART Control Interface Pins Type Description Output Transmit Data. Input Receive Data. Signal Name TXD# RXD# 9.8. EJTAG EJTAG is inexpensive, and easy to implement. EJTAG utilizes the 5-pin IEEE 1149.1 JTAG (Joint Test Action Group) specification for off-chip communication. The interface pins are shown in Table 34. Table 34. EJTAG Interface Pins Type Description Input Test Data In. Output Test Data Out. Output Test Clock. Output Test Mode Select. Output (Optional) Test Reset. Signal Name TDI TDO TCK TMS TRST EJTAG Circuitry TRST TMS TAP Controller A+ D TCK CPU Addr . Direct Memory Access Data TDO TDI A+ D Debug Registers A+ D System Memory Addr. Instruction, Data, and Control Registers Processor Access Data Address / Data Busses Figure 27. EJTAG Using a 5-Pin JTAG Interface to Access Data Block 10/100/1000M Switch Controllers 76 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet EJTAG provides a path to access internal debug registers and circuitry that monitor and control the address and data busses of the processor. The DMA and Processor circuit blocks are used to setup and monitor the processor’s internal busses and to execute the code from the EJTAG interface. When an access is detected, the EJTAG circuitry makes the transaction address available in the EJTAG Address Register, and the appropriate data available in the EJTAG Data Register. It takes about 200 TCK periods to access 32-bit address and data registers in this fashion, so with a 40MHz TCK frequency, the access time is in the range of 5µs. 9.9. I2C Slave Interface The RTL8380M-VB/RTL8382M-VB supports an I2C slave interface (Slave mode) for an external CPU to access the internal register. The interface has two I/O pins (i.e., SDA and SCL). SDA is the access data signal, and SCL is the clock signal (typical clock is 1~2MHz). The read/write data sequence is shown below. 2 ADDRESS BYTES 1 CONTROL BYTE S T A R T A6 A5 A4 A3 A2 A1 A0 W R I T E A C K Addr [7:0] A C K MSB to LSB Addr [15:8] 4 DATA BYTES 1 CONTROL BYTE A C K S T A R T 1 0 1 0 A2 A1 A0 R E A D A C K Data [7:0] A C K Data [15:8] A A Data Data C C [23:16] [31:24] K K N O A C K S T O P MSB to LSB DUMMY WRITE 2 ADDRESS BYTES 1 CONTROL BYTE S T A R T A6 A5 A4 A3 A2 A1 A0 W R I T E A C K Addr [7:0] MSB to LSB A C K Addr [15:8] 4 DATA BYTES A C K Data [7:0] A C K Data [15:8] A A A Data Data C C C [23:16] [31:24] K K K S T O P MSB to LSB Figure 28. I2C Slave Interface Access Data Sequence 10/100/1000M Switch Controllers 77 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.10. SPI Slave Interface The RTL8380M-VB/RTL8382M-VB supports SPI slave interface (Slave mode) for an external CPU to access the internal register. The interface has four I/O pins (SI, SO, SCK, and CS#). The instruction sets are as shown in the following table. Instruction Name Table 35. SPI Slave Interface Byte 2 Byte 3 Byte 4 Byte 5 Write Data Byte 1 (Code) 02h A23~A16 A15~A8 A7~A0 Read Data 03h A23~A16 A15~A8 A7~A0 Byte 6 Byte 7 Byte 8 D31~D24 D23~D16 D15~D8 D7~D0 D31~D24 D23~D16 D15~D8 D7~D0 Note: A23~A8: Maps to the switch’s 16-bits register address. A7~A0 in Write Data Instruction: Dummy byte for switch and conforms to standard SPI 24-bits address format. A7~A0 in Read Data Instruction: Dummy byte waits for the switch to prepare the register data and conforms to standard SPI 24-bits address format. D31~D0: 32-bits Register Data. 10/100/1000M Switch Controllers 78 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 9.11. Serial LED The RTL8380M-VB/RTL8382M-VB supports a serial LED interface to display the link status. The serial LED interface, LED_CK and LED_DA provide clock and data to enable/disable the external shift registers. A 74HC164 8-Bit Serial-In, Parallel-Out Shift Register captures the per-port link status and diagnostic information. In serial shift LED mode, the RTL8380M-VB/RTL8382M-VB supports per-port one/two/three single-color LED to show the speed, link status, and other information. VCC LED_ DATA 3.3V LED_ CLK A B CLK QA QB QC 74 HC 164 P17_LED[0] P16_LED[2] QE P16_LED[1] QG QH A B CLK P17_LED[1] QD QF LED_ DATA 3.3V LED_ CLK P17_LED[2] P16_LED[0] P15_LED[2] P15_LED[1] QA QB QC 74 HC 164 QD QE QF QG QH LED_ DATA 3.3V LED_ CLK A B CLK QA QB QC 74 HC 164 P1_LED[2] P1_LED[1] P1_LED[0] QD P0_LED[2] QE P0_LED[1] QF P0_LED[0] QG QH Figure 29. Serial LED Connection 10/100/1000M Switch Controllers 79 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet The default LED status for the RTL8380M-VB/RTL8382M-VB is as follows: LED Number LED0 Definition LED1 Definition LED2 Definition 10/100/1000M Switch Controllers 3-LEDs 1000M Link 100M Link Link/Act 80 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10. Electrical AC/DC Characteristics 10.1. Absolute Maximum Ratings WARNING: Absolute maximum ratings are limits beyond which permanent damage may be caused to the device, or device reliability will be affected. All voltages are specified referenced to GND unless otherwise specified. Table 36. Absolute Maximum Ratings Parameter Junction Temperature (Tj) Storage Temperature DVDDH, AVDDH, SVDDH, AVDDH_PLL Supply Referenced to DGND and AGND DVDDL, AVDDL, SVDDL, AVDDL_PLL, PLLVDDL Supply Referenced to DGND and AGND MVDDH Supply Referenced to DGND (for DDR1) MVDDH Supply Referenced to DGND (for DDR2) MVDDH Supply Referenced to DGND (for DDR3) Min -45 Max +125 +125 Units C C 2.97 3.63 V 0.90 1.18 V 2.375 1.71 1.425 2.625 1.89 1.575 V V V 10.2. Operating Range Table 37. Recommended Operating Range Parameter Min Typical Ambient Operating Temperature (Ta) 0 DVDDH, AVDDH, SVDDH, AVDDH_PLL 3.135 3.3 Supply Voltage Range DVDDL, AVDDL, AVDDL_PLL, PLLVDDL 0.95 1.1 Supply Voltage Range SVDDL Supply Voltage Range 1.05 1.1 MVDDH Supply Voltage Range(for DDR1) 2.375 2.5 MVDDH Supply Voltage Range(for DDR2) 1.71 1.8 MVDDH Supply Voltage Range(for DDR3) 1.425 1.5 Max 55 Units C 3.465 V 1.15 V 1.15 2.625 1.89 1.575 V V V V 10.3. DC Characteristics Symbol VIH VIL VOH VOL Table 38. DC Characteristics (IO Power =3.3V) Parameter Min TTL Input High Voltage 2.0 TTL Input Low Voltage Output High Voltage 2.4 Output Low Voltage - 10/100/1000M Switch Controllers 81 Typical - Max 0.8 0.4 Units V V V V Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4. AC Characteristics 10.4.1. QSGMII Differential Transmitter Characteristics Symbol UI T_X1 T_X2 T_Y1 T_Y2 VTX-DIFFp-p TTX-EYE TTX-JITTER TTX-RISE TTX-FALL RTX CTX LTX Table 39. QSGMII Differential Transmitter Characteristics Parameter Min Typical Max Units Unit Interval 199.94 200 200.06 ps Eye Mask 0.2 UI Eye Mask 0.4 UI Eye Mask 150 mV Eye Mask 650 mV Output Differential Voltage 600 900 1300 mV Minimum TX Eye Width 0.6 UI Output Jitter 0.4 UI Output Rise Time 0.15 UI Output Fall Time 0.15 UI Differential Resistance 80 100 120 ohm AC Coupling capacitor 75 100 200 nF Transmit Length in PCB 10 inch Notes 200ps±300ppm - TTX-EYE-MIN T_Y2 T_Y1 Amplitude 0V VTX-DIFFp-p-MIN VTX-DIFFp-p-MAX -T_Y1 -T_Y2 0.0 T_X1 T_X2 1-T_X2 1-T_X1 1.0 Time UI Figure 30. QSGMII Differential Transmitter Eye Diagram 10.4.2. QSGMII Differential Receiver Characteristics Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE Table 40. QSGMII Differential Receiver Characteristics Parameter Min Typical Max Unit Interval 199.94 200 200.06 Eye Mask 0.3 Eye Mask 100 Eye Mask 650 Input Differential Voltage 200 1300 Minimum RX Eye Width 0.4 - 10/100/1000M Switch Controllers 82 Units ps UI mV mV mV UI Notes 200ps±300ppm Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet Symbol TRX-JITTER RRX Parameter Input Jitter Tolerance Differential Resistance Min 80 Typical 100 Max 0.6 120 Units UI ohm Notes - TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 31. QSGMII Differential Receiver Eye Diagram 10/100/1000M Switch Controllers 83 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.3. SGMII Differential Transmitter Characteristics Symbol UI T_X1 T_X2 T_Y1 T_Y2 VTX-DIFFp-p TTX-EYE TTX-JITTER RTX CTX LTX Table 41. SGMII Differential Transmitter Characteristics Parameter Min Typical Max Units Unit Interval 799.76 800 800.24 ps Eye Mask 0.1875 UI Eye Mask 0.4 UI Eye Mask 125 mV Eye Mask 500 mV Output Differential Voltage 400 700 900 mV Minimum TX Eye Width 0.625 UI Output Jitter 0.375 UI Differential Resistance 80 100 120 ohm AC Coupling capacitor 75 100 200 nF Transmit Length in PCB 10 inch Notes 800ps±300ppm - TTX-EYE-MIN T_Y2 T_Y1 Amplitude 0V VTX-DIFFp-p-MIN VTX-DIFFp-p-MAX -T_Y1 -T_Y2 0.0 T_X1 T_X2 1-T_X2 1-T_X1 1.0 Time UI Figure 32. SGMII Differential Transmitter Eye Diagram 10/100/1000M Switch Controllers 84 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.4. SGMII Differential Receiver Characteristics Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE TRX-JITTER RRX Table 42. SGMII Differential Receiver Characteristics Parameter Min Typical Max Unit Interval 799.76 800 800.24 Eye Mask 0.3125 Eye Mask 50 Eye Mask 600 Input Differential Voltage 100 1200 Minimum RX Eye Width 0.375 Input Jitter Tolerance 0.625 Differential Resistance 80 100 120 Units ps UI mV mV mV UI UI ohm Notes 800ps±300ppm - TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 33. SGMII Differential Receiver Eye Diagram 10/100/1000M Switch Controllers 85 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.5. 1000Base-X/100Base-FX Differential Transmitter Characteristics Table 43. 1000Base-X/100Base-FX Differential Transmitter Characteristics Parameter Min Typical Max Units Notes Unit Interval (1000Base-X) 799.76 800 800.24 ps 800ps±300ppm Unit Interval (100Base-FX) 7.9976 8.0 8.0024 ns 8ns±300ppm T_X1 Eye Mask 0.1875 UI T_X2 Eye Mask 0.4 UI T_Y1 Eye Mask 125 mV T_Y2 Eye Mask 650 mV VTX-DIFFp-p Output Differential Voltage 400 800 1300 mV TTX-EYE Minimum TX Eye Width 0.625 UI TTX-JITTER Output Jitter 0.375 UI RTX Differential Resistance 80 100 120 ohm CTX AC Coupling capacitor 75 100 200 nF LTX Transmit Length in PCB 10 inch Symbol UI TTX-EYE-MIN T_Y2 T_Y1 Amplitude 0V VTX-DIFFp-p-MIN VTX-DIFFp-p-MAX -T_Y1 -T_Y2 0.0 T_X1 T_X2 1-T_X2 1-T_X1 1.0 Time UI Figure 34. 1000Base-X/100Base-FX Differential Transmitter Eye Diagram 10/100/1000M Switch Controllers 86 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.6. 1000Base-X/100Base-FX Differential Receiver Characteristics Symbol UI R_X1 R_Y1 R_Y2 VRX-DIFFp-p TRX-EYE TRX-JITTER RRX Table 44. 1000Base-X/100Base-FX Differential Receiver Characteristics Parameter Min Typical Max Units Unit Interval (1000Base-X) 799.76 800 800.24 ps Unit Interval (100Base-FX) 7.9976 8.0 8.0024 ns Eye Mask 0.3125 UI Eye Mask 100 mV Eye Mask 1000 mV Input Differential Voltage 200 2000 mV Minimum RX Eye Width 0.375 UI Input Jitter Tolerance 0.625 UI Differential Resistance 80 100 120 ohm Notes 800ps±300ppm 8ns±300ppm - TRX-EYE-MIN R_Y2 R_Y1 Amplitude 0V VRX-DIFFp-p-MIN VRX-DIFFp-p-MAX -R_Y1 -R_Y2 0.0 R_X1 0.5 1-R_X1 1.0 Time UI Figure 35. 1000Base-X/100Base-FX Differential Receiver Eye Diagram 10/100/1000M Switch Controllers 87 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.7. DDR2 Characteristics Tcyc CK# CK# CK CK DQS Command DQ, DM tIS tDS tIH tDH tDQSQ tDQSQ DQS DQ(last data valid) DQ DQ(first data no longer valid) tQH Data valid window Figure 36. DDR2 Timing Characteristics Table 45. DDR2 SDRAM Timing Characteristics Symbol Description Min fCK, fCK# Clock Frequency of the CK and CK# Duty Duty Cycle of the CK and CK# 48 tJITper Clock period jitter -110 tJITcc Cycle-to-cycle jitter -220 tDS DQ and DM Output Setup Time 450 tDH DQ and DM Output Hold Time 450 tIS Address and Control Output Setup Time 600 tIH Address and Control Output Hold Time 600 tDQSQ Input DQS–DQ Skew, DQS to Last DQ Valid tQH Input DQ–DQS Hold, DQS to First DQ to Go Non-Valid 0.3 Note: Test Condition, fDDR_CK=300MHz. 10/100/1000M Switch Controllers 88 Typical 300 50 - Max 52 110 220 300 - Units MHz % ps ps ps ps ps ps ps CK Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.8. DDR3 Characteristics Tcyc CK# CK# CK CK DQS Command DQ, DM tIS tDS tIH tDH tDQSQ tDQSQ DQS DQ(last data valid) DQ DQ(first data no longer valid) tQH Data valid window Figure 37. DDR3 Timing Characteristics Table 46. DDR3 SDRAM Timing Characteristics Symbol Description Min fCK, fCK# Clock Frequency of the CK and CK# Duty Duty Cycle of the CK and CK# 47 tJITper Clock period jitter -90 tJITcc Cycle-to-cycle jitter -165 tDS DQ and DM Output Setup Time 450 tDH DQ and DM Output Hold Time 400 tIS Address and Control Output Setup Time 750 tIH Address and Control Output Hold Time 550 tDQSQ Input DQS–DQ Skew, DQS to Last DQ Valid tQH Input DQ–DQS Hold, DQS to First DQ to Go Non-Valid 0.3 Note: Test Condition, fDDR_CK=300MHz. 10/100/1000M Switch Controllers 89 Typical 300 50 - Max 53 90 165 300 - Units MHz % ps ps ps ps ps ps ps CK Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.9. SPI Interface Characteristics tSLCH tCHSH SPI_CS# SPI_SCK tsetup:O thold:O SPI_SI(output) tsetup:I thold:I MSB High-Z Data In SPI_SO(input) Figure 38. SPI Interface Timing Table 47. SPI Interface Timing Characteristics Symbol Description Min fSPI_SCK Clock Frequency of the SPI_SCK 49.5 Duty Duty Cycle of the SPI_SCK 45 tSLCH CS# Active Setup Time 7 tCHSH CS# Active Hold Time 8 tsetup:O Data Output Setup Time 4 thold:O Data Output Hold Time 6 tsetup:I Data Input Setup Time 4 thold:I Data Input Hold Time 0 Note: Test Condition, fSPI_SCK=50MHz. 10/100/1000M Switch Controllers 90 Typical 50 50 8.1 9.65 8.3 9.65 - Max 50.5 55 - Units MHz % ns ns ns ns ns ns Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10.4.10. SMI (MDC/MDIO) Interface Characteristics t1 t2 t3 MDC t4 t5 t6 Data Write MDIO t7 Data Read Figure 39. SMI (MDC/MDIO) Timing Symbol t1 t2 t3 t4 t5 t6 t7 Table 48. SMI (MDC/MDIO) Timing Characteristics Description Min Typ MDC Clock Period 380 MDC High Time 190 MDC Low Time 190 MDIO to MDC Rising Setup Time (Write Data) 190 MDIO to MDC Rising Hold Time (Write Data) 190 MDIO to MDC Rising Setup Time (Read Data) 40 MDIO to MDC rising hold time (Read Data) 2 - Max - Units ns ns ns ns ns ns ns 10.4.11. Serial Mode LED Tcyc LED_CK tsetup:O LED_DA thold:O V ih(max) V ih( min) Vih(max) Vih(min) Data Output Figure 40. Serial Mode LED AC Timing Parameters Table 49. Serial Mode LED AC Timing Mode and Description Symbol Input High Voltage Vih Input Low Voltage Vil Tcyc Serial LED_CK Clock Cycle LED Duty Cycle of the LED_CK Duty LED_DA to LED_CK Output Setup Time tsetup:O LED_DA to LED_CK Output Hold Time thold:O 10/100/1000M Switch Controllers 91 Min 2.0 45 - Typical 600 50 314 285 Max 0.8 55 - Units V V ns % ns ns Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 11. Package Information 11.1. LQFP216-E-PAD (24*24mm) 10/100/1000M Switch Controllers 92 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 10/100/1000M Switch Controllers 93 Track ID: Rev. 1.2 RTL8380M-VB/RTL8382M-VB Datasheet 12. Ordering Information Table 50. Ordering Information Part Number Package RTL8380M-VB-CG LQFP 216-Pin E-PAD (24*24mm) ‘Green’ Package (Managed) RTL8382M-VB-CG LQFP 216-Pin E-PAD (24*24mm) ‘Green’ Package (Managed) Note: See page 10 (RTL8380M-VB), page 25 (RTL8382M-VB)for package identification. Status MP MP Realtek Semiconductor Corp. Headquarters No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan, R.O.C. Tel: 886-3-5780211 Fax: 886-3-5776047 www.realtek.com 10/100/1000M Switch Controllers 94 Track ID: Rev. 1.2
RTL8382M-VB-CG
物料型号: - RTL8380M-VB-CG:1010/100/1000M端口的多层管理型交换机控制器。 - RTL8382M-VB-CG:2810/100/1000M端口的多层管理型交换机控制器。
器件简介: - RTL8380M-VB和RTL8382M-VB芯片是Realtek生产的交换机控制器,支持多种速率的以太网端口,具有管理功能,适用于构建网络交换设备。
引脚分配: - RTL8380M-VB和RTL8382M-VB芯片的引脚分配详细列出了每个引脚的功能,包括电源引脚、数据引脚、控制引脚等。例如,DDR3_A0/CLK_M_EE[1]、DDR3_A3/CLK_M_EE[0]等。
参数特性: - 芯片具有500MHz MIPS-4KEc CPU,支持最大32MByte SPI闪存和DDR1/DDR2/DDR3内存接口。 - 包含8K条目的4路哈希L2表,用于MAC地址学习和搜索。 - 支持802.1Q VLAN操作,具有4K条目VLAN表。 - 支持1.5K条目访问控制列表(ACL)。 - 支持每端口的入/出带宽控制和每队列的出带宽控制。
功能详解: - 支持硬件和软件重置。 - 支持IEEE 802.1X认证和端口隔离,增强安全性。 - 支持端口镜像功能,用于网络管理。 - 支持链路聚合,提高链路冗余和带宽。 - 采用高级技术如Realtek Cable Test (RTCT),自动环路检测和预防(RLPP/RLDP),攻击预防和MAC地址学习限制。
应用信息: - RTL8380M-VB适用于管理型81000M UTP+21000BASE-X交换机。 - RTL8382M-VB适用于管理型281000M交换机,通过RTL8218B PHY实现。
封装信息: - RTL8380M-VB和RTL8382M-VB芯片采用LQFP216-EPAD封装,具有2424mm的尺寸。
RTL8382M-VB-CG 价格&库存
很抱歉,暂时无法提供与“RTL8382M-VB-CG”相匹配的价格&库存,您可以联系我们找货
RTL8382M-VB-CG
    • 1+120.85200
    • 10+107.31960
    • 40+98.09640
    库存:24
    RTL8382M-VB-CG
    • 1+109.66200
    库存:1
    RTL8382M-VB-CG
    • 1+162.59670
    • 10+120.27650
    • 50+103.09420
    • 100+85.91180
    库存:2000
