ESD
Protection
Device
RL0603E Series
Circuit Protection
System
Revision:APR-17
Please refer to http://www.ruilon.com.cn for current information.
ESD Protection Device - RL0603E Series
Features
• Excellent ESD clamping & Small Insertion Loss
• High transient current capability, Fastest response time
• Capacitance is designed to ultra-low value, which can be
efficiently suitable to high speed data line.
• EU-RoHS Compliance
Features
• Transient voltage protection for IC and transistor
• ESD and I/O protection
• EFT and burst protection
• Portable equipment protection, such as mobile phone, PDA
Product Name
R
L
Brand Name
E
EIA
Type
0603
E:ESD
Max. Operating
Voltage VDC
M
Null
1
5
K
Capacitance
error
Capacitance
0.15PF
±20%
Package Dimensions
Varistor Ceramics
L1
W
Electrode
H
L2
EIA
L1
W
H
L2&L3
0603
1.60±0.15
0.80±0.15
1.0(Max)
0.35±0.15
L3
Circuit Protection
System
Revision:APR-17
Page:1
ElectrIcal CharacterlstIcs Per Lin (@ 25°C Unless Otherwise Specified)
Working
Voltage
VDC
Max.
Leakage
Curren
Capacitance
@1MHz
Trigger
Voltage
Clamping
Voltage
V
uA
pF
V
V
RL0603E005M005K
5
1
0.05
450
50
RL0603E005M015K
5
1
0.15
450
50
Type Number
RL0603E005M100K
5
1
1
250
50
RL0603E005M200K
5
1
2
50
25
RL0603E005M250K
5
1
2.5
50
25
RL0603E005M300K
5
1
3
50
25
RL0603E005M500K
5
1
5
15
25
RL0603E008M015K
8
1
0.15
250
50
RL0603E008M100K
8
1
1
200
50
RL0603E008M200K
8
1
2
50
25
RL0603E008M250K
8
1
2.5
50
25
RL0603E008M300K
8
1
3
50
25
RL0603E008M500K
8
1
5
50
25
RL0603E012M015K
12
1
0.15
200
50
RL0603E012M100K
12
1
1
200
50
RL0603E012M200K
12
1
2
200
50
RL0603E012M250K
12
1
2.5
200
50
RL0603E012M300K
12
1
3
200
50
RL0603E012M500K
12
1
5
200
50
RL0603E018M015K
18
1
0.15
250
50
RL0603E018M100K
18
1
1
200
50
RL0603E018M200K
18
1
2
125
50
RL0603E018M250K
18
1
2.5
125
50
RL0603E018M300K
18
10
3
500
50
RL0603E018M500K
18
10
5
500
50
RL0603E024M015K
24
10
0.15
500
50
RL0603E024M100K
24
10
1
500
50
RL0603E024M200K
24
10
2
500
50
RL0603E024M250K
24
10
2.5
500
50
RL0603E024M300K
24
10
3
500
50
RL0603E024M500K
24
10
5
500
50
Circuit Protection
System
Revision:APR-17
Please refer to http://www.ruilon.com.cn for current information. Page:2
Electrical Rating
No
ltem
1
Operation
Range
1. -55°C ~ 85°C
2
Leakage
current
Satisfaction to the specification, under 1uA
Applied voltage : specified working voltage
3
Capacitance
Satisfaction to the specification, under 1pF
Frquency & OSC level : 1MHz, 1.0Vrms
4
Solderability
More than 90% of the terminal electrode
shall be covered with new solder.
1. Type of solder : H63A
2. Soldering Temp & Time : 230+/-5°C, 5+/-1 sec
5
Reflow
soldering
1. No Serious mechanical damage
2. More than 50% of the terminal electrode
3. Leakage Currrent :≤ 10uA
2. Temp & Time : max 260+/-5°C, min 10sec
6
Humidity
Load Test
2. Leakage Currrent :≤ 10uA
Test Temp. & Relative Humidity & Time : 85+/- 5°C,
85 +/- 5% RH
7
Thermal
Shock
1. Step 1 : -40 +/- 5°C, Step 2 : 85 +/- 5°C
2. Cycle : 30min ± 3min, each 5 cycles
8
High Temp.
Test
Temp. & time : 85+/-5°C , 1000 +/- 24hrs
9
Adhesive
strength
10
ESD
Test Condition / Description
Requirement
under condition of
1005 : min 0.5kgf, 1608 : min 1.0kgf
1. No mechanical damage after test
2. Leakage Current :≤ 10uA
* ESD gun (IEC61000-4-2 standard)
* C=150pF R=330Ω
Circuit Protection
System
W [kgf] min.
1. Contact discharge
* Voltage :+/-8kV(Level 4)
* Number : 10 times in 10sec
2. Air discharge
* Voltage :+/-15kV(Level 4)
Revision:APR-17
Page:3
Recommended Soldering Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3°C/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
150°C
200°C
60-180 seconds
3°C/second max.
217°C
60-150 seconds
Peak Temperature (TP)
260°C
Time within 5°C of actual Peak Temperature (tP)
Ramp-down Rate
Time 25°C to Peak Temperature
Circuit Protection
System
20-40 seconds
6°C/second max.
8 minutes max.
Revision:APR-17
Please refer to http://www.ruilon.com.cn for current information. Page:4
Metal Oxide
Packing specifications
Circuit Protection
System
Circuit Protection
System
Varistors - RL0402A-0603A Series
Revision:APR-17
Please refer to http://www.ruilon.com.cn for current information. Page:5
Specifications are subject to change without notice.
很抱歉,暂时无法提供与“RL0603E005M100K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.25175
- 100+0.20043
- 300+0.17477
- 1000+0.15552
- 4000+0.13336
- 8000+0.12568
- 国内价格
- 1000+0.08204
- 4000+0.07955
- 国内价格
- 20+0.23077
- 400+0.16020
- 1600+0.14256
- 4000+0.12225
