Preliminary Datasheet
LPW5209
2.1A Power Switch with Programmable Current Limit
General Description
The LPW5209 is an integrated power switch for
Features
80mΩ Low RDS(ON), High-side N-MOSFET
(USB) applications. A built-in charge pump is used to
2100mA Programmable current limit
drive the N-Channel MOSFET that is free of parasitic
2.5V to 6V Input Voltage
body diode to eliminate any reversed current flow
Low Quiescent Current:30μA
across the switch when it is powered off. Its low
Soft Start Function
Built-In Short-Circuit Protection
Built-in Thermal Protection
RoHS Compliant and 100% Lead (Pb)-Free
self-powered and bus-powered Universal Series Bus
quiescent current (16μA) and small package (SOT23-5)
is particularly suitable in battery-powered portable
equipment.
Several protection functions include soft start to limit
inrush current during plug-in, current limiting at 2.1A to
meet USB power requirement, and thermal shutdown
Typical Application Circuit
to protect damage under over current conditions.
VIN
LPW5209B5F-Adj
5
Order Information
Ordering Number
Current
LPW5209AB5F
Adjustable
LPW5209B5F-21
2.1A
LPW5209B5F-11
1.1A
LPW5209B5F-06
600mA
Package
4
Cin
VIN
EN
VOUT
GND RSET
VOUT
1
Cout
3
2
Riset
6.8K
SOT23-5
Marking Information
Device
Applications
Power Switch
USB Device
Battery Charger Circuits
Marking
Shipping
LPS
LPW5209AB5F
C0YWX
LPW5209B5F-21
LPW5209B5F-11
LPW5209B5F-06
LPS
C1YWX
3K/REEL
LPS
C2YWX
LPS
C3YWX
Marking indication:
Y:Production year
LPW5209-00
Jul.-2017
Email: marketing@lowpowersemi.com
W:Production week
X:Production batch
www.lowpowersemi.com
Page 1 of 7
LPW5209
Functional Pin Description
Package Type
Pin Configurations
Top View
VOUT
1
GND
2
ISET/NC
3
5
VIN
4
EN
SOT23-5
Pin Description
Name
Pin
Description
LPW5209A
LPW5209-21/11/06
VOUT
1
1
Output to system pin.
GND
2
2
Ground.
ISET
3
NC
Connect a resistor to GND for setting current limit.
3
No connecter
EN
4
4
Device Enable (active High).
VIN
5
5
Input pin.
LPW5209-00
Jul.-2017
Page 2 of 7
LPW5209
Function Block Diagram
Absolute Maximum Ratings Note 1
Input Voltage to GND ----------------------------------------------------------------------------------------------------- 7V
Output Voltage to GND -------------------------------------------------------------------------------------------------- 7V
Other pin to GND ---------------------------------------------------------------------------------------------------------- 6V
Maximum Junction Temperature ---------------------------------------------------------------------------------- 150°C
Operating Ambient Temperature Range (TA) -------------------------------------------------------- -40℃ to 85°C
Maximum Soldering Temperature (at leads, 10 sec) ------------------------------------------------------
Note 1.
260°C
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
device reliability.
Thermal Information
Maximum Power Dissipation (SOT23-5, PD, TA=25°C) ----------------------------------------------------- 0.45W
Thermal Resistance (SOT23-5, θJA) ------------------------------------------------------------------------- 250℃/W
ESD Susceptibility
HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) --------------------------------------------------------------------------------------------------- 200V
LPW5209-00
Jul.-2017
Page 3 of 7
LPW5209
Electrical Characteristics
(Over recommended operating conditions unless specified otherwise, TA=25℃ )
Symbol
Parameter
VIN
Input Voltage
IOUT
Output Current Limit
Condition
Min
Typ
2.5
LPW5209B5F-Adj,RISET=10K
680
PW5209B5F-Adj,RISET=6.8K
1000
PW5209B5F-Adj,RISET=3.4K
2000
LPW5209B5F-21
2100
PW5209B5F-11
1100
PW5209B5F-06
600
Max
Units
6
V
mA
RDS(ON)
Output N-MOSFET RDS(ON)
Iout=1A
80
100
mΩ
IQ
Quiescent Current
VIN=3V
30
50
µA
ISHDN
Shutdown Current
VEN=GND
0.1
1
µA
VEN(L)
Enable Threshold Low
0.4
V
VEN(H)
Enable Threshold High
IEN
Input High Current
OTP
OTP-HYS
LPW5209-00
1.4
5
µA
Over temperature protection
150
Over temperature hysteresis
Jul.-2017
VIN=VEN=5.0V
V
Page 4 of 7
LPW5209
Typical Operating Characteristics
RISET VS. Current Limit
2500
Current Limit(mA)
2000
1500
1000
500
10
15
RISET(K)
LPW5209-00
Jul.-2017
Page 5 of 7
LPW5209
Chip Enable Input
Application Information
The LPW5209 are single N-Channel MOSFET
The switch will be disabled when the EN pin is in a
high-side power switches with active-high enable
logic low condition. During this condition, the
input, optimized for self-powered and bus-powered
internal circuit is turned off, reducing the supply
Universal Serial Bus (USB) applications. The
current to 0.1μA typical. The maximum guaranteed
LPW5209 equipped with a charge pump circuitry to
voltage for a logic low at the EN pin is 0.4V. A
drive the internal NMOS switch; the switch's low
minimum guaranteed voltage of 1.4V at the EN pin
RDS(ON),
will turn the LPW5209 back on. Floating the input
80mΩ,
meets
USB
voltage
drop
may cause unpredictable operation. EN should not
requirements.
be allowed to go negative with respect to GND. The
Input and Output
VIN (input) is the power source connection to the
internal circuitry and the drain of the MOSFET.
EN pin may be directly tied to VIN to keep the part
on.
VOUT (output) is the source of the MOSFET. In a
Soft Start for Hot Plug-In Applications
typical application, current flows through the switch
In order to eliminate the upstream voltage droop
from VIN to VOUT toward the load. If VOUT is
caused by the large inrush current during hot-plug
greater than VIN, current will flow from VOUT to VIN
events, the “soft-start” feature effectively isolates
since the MOSFET is bidirectional when on. Unlike
the power source from extremely large capacitive
a normal MOSFET, there is no a parasitic body
loads,
diode between drain and source of the MOSFET,
requirements.
the LPW5209 prevents reverse current flow if VOUT
Thermal Shutdown
being externally forced to a higher voltage than VIN
Thermal shutdown is employed to protect the device
when the output disabled (VEN < 0.4V).
from damage if the die temperature exceeds
satisfying
approximately
the
150°C.
USB
If
voltage
enabled,
the
droop
switch
automatically restarts when the die temperature falls
20°C. The output will continue to cycle on and off
until the device is disabled or the fault is removed.
LPW5209-00
Jul.-2017
Page 6 of 7
LPW5209
Packaging Information
SOT23-5
LPW5209-00
Jul.-2017
Page 7 of 7
很抱歉,暂时无法提供与“LPW5209AB5F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29810
- 3000+0.26400
- 国内价格
- 5+0.24640
- 20+0.24200
- 100+0.23320
- 国内价格
- 5+0.40911
- 50+0.36202
- 150+0.33848
- 500+0.32087
- 3000+0.29733
- 6000+0.29020
