SVF-01T-1.5A
SVF-01T-1.5A
    JST
    胶壳端子 可断开的压接式连接器 12-22AWG
SVF-01T-1.5A 数据手册
Crimp 5.0mm V CONNECTOR Disconnectable Crimp style connectors pitch Features –––––––––––––––––––––––– • Anti-misinsertion construction One position has a different pitch than the others. This provides the connector with polarization and prevents misinsertion. • Two-point contact Each contact has two wiping areas which ensure stable and reliable connection. The V connector can have from two to six circuits. A single contact position is provided 7.5mm away from the adjacent position, while the pitch of other positions is 5.0mm. This prevents reverse connection of the receptacle and header. 12 5 4 3 2 T JS 1 Specifications ––––––––––––––––––– • Current rating: 5A AC, DC (AWG #20) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #26 to #20 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 1 2 Recognized E60389 Certified LR20812 R75171 1 Downloaded from Arrow.com. V CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire Model No. mm SVF-01T-1.5A 2 0.13 to 0.5 AWG # Insulation O.D. (mm) Q'ty / reel 26 to 20 1.3 to 2.7 15,000 Material and Finish 13.1 5.6 3 1.2 Brass, tin-plated (reflow treatment) 1.4 RoHS compliance Note: Contact JST for details if you require shielded wires, thin wires or other special wires, or if two wires must be crimped in one contact. Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– (2 circuits) 18.5 8 Circuits Dimensions (mm) Model No. A B Q'ty / bag 2 2P-SVF 2P-SVF-V - - 1,000 3 3P-SVF 3P-SVF-V 5.0 17.5 1,000 4 4P-SVF 4P-SVF-V 10.0 22.5 500 5 5P-SVF 5P-SVF-V 15.0 27.5 500 6 6P-SVF 6P-SVF-V 20.0 32.5 500 Material PA 6, ( )P-SVF...UL94V-2, ( )P-SVF-V...UL94V-0, natural (white) 12.5 RoHS compliance 7 7.5 5 2.5 18.5 8 (3 to 6 circuits or more) B A 2.5 5 2 Downloaded from Arrow.com. 7 7.5 5 2.5 V CONNECTOR Header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– A 7.5 5 4.6 φ1.55 Model No. Dimension A (mm) Q'ty / box 2 RTB-1.5-2P 12.5 1,000 3 RTB-1.5-3P 17.5 1,000 4 RTB-1.5-4P 22.5 500 5 RTB-1.5-5P 27.5 500 6 RTB-1.5-6P 32.5 250 9.15 2.5 Circuits 15.5 Material and Finish 6.35 Pin: Brass, nickel-undercoated, tin/copper alloy-plated Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. PC board layout (viewed from soldering side) and Assembly layout ––––––––––––––––––– 5± 0.05 3 min 7 Approx.22 3 min 7.5 ±0.05 φ1.7 + 0.1 0 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Crimping machine, Applicator––––––––––––––––––––––––––––––––––––––––––––––– Contact Crimping machine SVF-01T-1.5A AP-K2N Crimp applicator Dies Crimp applicator with dies MK-L MK/SVF-01-15A APLMK SVF01-15A – – – 3 Downloaded from Arrow.com.
SVF-01T-1.5A 价格&库存
很抱歉,暂时无法提供与“SVF-01T-1.5A”相匹配的价格&库存,您可以联系我们找货
SVF-01T-1.5A
  • 15000+0.1636715000+0.02118
SVF-01T-1.5A
    库存:14891
    SVF-01T-1.5A
      库存:60000
      SVF-01T-1.5A
        • 1000+0.10080
        库存:10000
        SVF-01T-1.5A
          • 100+0.05500
          库存:2800
          SVF-01T-1.5A
            • 1+0.270761+0.03503
            • 10+0.2358310+0.03051
            • 50+0.1834250+0.02373
            • 100+0.15722100+0.02034
            • 500+0.14849500+0.01921
            • 1000+0.139751000+0.01808
            • 2000+0.139752000+0.01808
            库存:14900
            SVF-01T-1.5A
              • 5000+0.07010
              库存:33238
