KR FAMILY SERIES/KRW・KR・PHN・TR CONNECTOR
ラジアル
ラジアル
2.0 mm pitch/Disconnectable Insulation displacement and Crimp style connectors
PH connector:
Side entry type header
(for PHN and
KR receptacles)
TR connector:
Unit for wire-to-wire
connection
(for PHN and
KR receptacles)
KR connector:
IDC receptacle
● Multi-IDC-harnesses are possible
● Various types of connectors
● KR一般仕様
Cost reduction
● Two types of circuit layouts
PHN connector:
Crimp style receptacle
KRW connector:
Holder
PHN connector:
KRW connector:
■一般仕様
Specifications
Series
Item
KRW connector
Curren rating
TR・TRW connector
1.0 A AC/DC(AWG#26)
Voltage rating
100 V AC/DC
Temperaure rise
Contact rasistance
KRW connector:
Top entry type header
KR connector:
IDC receptacle
PH connector:
(for PHN and
KR receptacles)
Based upon JST's field proven KR series
KRファミリー姿図
connectors, the KR series family of
connectors have been expanded to meet the
requirements of high density packaging.
The KRW connector allows double-row wireto-board connection using either the KR or
PHN connectors. Whilst the TR connector
allows wire-to-wire connection, also using
either the KR or PHN connectors.
-25℃ to +85℃(including temperature rise)
initial/10 mΩ max. After environmental tests/20 mΩ max.
Insulation resistance
1,000 MΩ min.
Withstanding voltage
800 VAC/minute
Applicable connector
KR connector, CR connector, PHN connector
Applicable PC board thickness
1.6 mm
Applicable panel thickness
0.5 mm to 2 mm
* In using the products, refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Recognized E60389
Certified LR20812
R75087: PH, PHN connectors
Top entry type
Top entry type
(2)
1
Reverse type:
Circuit No.1
7.5 min.
6.9
1.5±0.05
2 ±0.05
3 ±0.1
+0.1
φ0.7 0
5
Normal type:
Circuit No.1
2 max.
1.5±0.05
Reverse type:
Circuit No.1
4.8
6
+0.1
φ0.8 0
7.5
Single-row shrouded header
6.6
PC board layout and Assembly layout
Normal type:
Circuit No.1
1 min.
2 ±0.05
1.6±0.1 1.6±0.1
Edge of the shrouded header (mating side)
Side entry type
8.5
+0.1
φ0.7 0
Side entry type
Normal type:
Circuit No.1
7.6
2±0.05
Reverse type:
Circuit No.1
8.5
1.6±0.1
1
Note: 1. Tolerances are non-cumulative: ± 0.05 mm for all centers.
2. Hole dimensions differ according to the type of PC board and
piercing method. The dimensions above should serve as a guideline.
5.5
6.25
1 min.
2 ±0.05
0.2
Normal type:
Circuit No.1
3.4±0.1
9 min.
Reverse type:
Circuit No.1
5.5 max.
4.8
7.6
1.5±0.1
Note: 1 . Tolerances are non-cumulative: ± 0.05 mm for all centers.
2. The dimensions above should serve as a guideline.
(1)
Double-row shrouded header
(viewed from component side)
Top entry type
Reverse type:
Line A/Circuit No.1
A±0.1
2
±0.05
6.5±0.05
+0.1
Normal type:
Line A/Circuit No.1
A
φ0.8 0
Reverse type:
Line A/Circuit No.1
±0.1
2±0.05
6.5±0.05
+0.1
±0.05
SIDE TYPE
A±0.1
Circuit No.1
(With a compact boss)
2
5.8
±0.1
2±0.05
5.8±0.1
SIDE TYPE
Line B/
Circuit No.1
+0.1
Side entry type
Normal type:
Line B/Circuit No.1
Reverse type:
Line B Line B/Circuit No.1
φ0.8 0
(With a standard boss)
+0.1
φ0.8 0
11.5
Normal type:
Line B/Circuit No.1
Line A
Normal type:
Line B/Circuit No.1Line B/
Line B
2.65±0.05 Boss hole
φ1.2±0.1
2 ±0.05
0.4±0.05
+0.1
φ0.8 0
A±0.1
Line A/
LineNo.1
B
Circuit
6.5±0.05
Reverse type:
Line B/Circuit No.1
2.65±0.05 Boss hole
φ1.6 ±0.1
1.1±0.05
2 ±0.05
6.5±0.05
Line A
with PHN receptacles
Normal type:
Line B/Circuit No.1
Line A
φ0.8 0
A±0.1
Line A/
Circuit No.1
with KR receptacles
Line B
Reverse type:
Line B/Circuit No.1
With locks
8.4
Line A
TOP TYPE
8.6
Normal type:
Line A/Circuit No.1
Reverse type:
A±0.1
Line A/Circuit
No.1
+0.1
with KR receptacles
Reverse
type:
Normal
type:
LineLine
B/Circuit
No.1
A/Circuit
No.1
φ0.8
2±0.05
10.95
11.15
+0.1
2.8±0.05
φ1.6 0
Normal type:
Line A/Circuit No.1
Reverse type:
Line A/Circuit No.1
2±0.05
2.8
11.5
TOP TYPE
with KR receptacles
+0.1
±0.05
φ1.6 0
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
Insulation displacement connector (Receptacle)
(2 to 12 circuits)
2
No. of
circuits
5.15
B
A
0.9
3.5
4.2
2
H JST
Reverse type:
Circuit No.1
Normal type:
Circuit No.1
(13 to 16 circuits)
2
5.15
B
A
0.9
Model No.
Normal type
Reverse type
02KR-6H-PC
02KR-6H-P
03KR-6H-PC
03KR-6H-P
04KR-6H-PC
04KR-6H-P
05KR-6H-PC
05KR-6H-P
06KR-6H-PC
06KR-6H-P
07KR-6H-PC
07KR-6H-P
08KR-6H-PC
08KR-6H-P
09KR-6H-PC
09KR-6H-P
10KR-6H-PC
10KR-6H-P
11KR-6H-PC
11KR-6H-P
12KR-6H-PC
12KR-6H-P
13KR-6H-PC
13KR-6H-P
14KR-6H-PC
14KR-6H-P
15KR-6H-PC
15KR-6H-P
16KR-6H-PC
16KR-6H-P
Dimensions (mm)
A
B
組立レイアウト
2.0
4.0
6.0
8.0
10.0
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
6.0
8.0
10.0
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
32.0
34.0
Q'ty/
box
2,000
2,000
2,000
2,000
2,000
1,000
1,000
1,000
1,000
1,000
1,000
500
500
500
500
Material and Finish
2
Normal type:
Circuit No.1
3.5
4.2
Contact: Phosphor bronze, tin-plated (reflow treatment)
Housing: 2 to 12 circuits...PA 66, UL94V-0, gray
13 to 16 circuits...Glass-filled PA 66, UL94V-0, gray
H JST
Reverse type:
Circuit No.1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Applicable wire
UL1571, 1061(Contact JST for other UL styles.)
AWG#28, #26
Conductor / 7 strands, tin-plated annealed copper
Insulation O.D. / 0.9 to 1.0 mm
RoHS2 compliance
2
PHコネクタ表1
Crimp style connector (Contact)
Applicable wire
AWG #
mm2
Model No.
SPH-002T-P0.5L
0.08~0.22
28~24
Insulation O.D.
(mm)
Q'ty/
reel
0.8~1.5
8,000
Material and Finish
1.5
1
5.7
2.05
RoHS2 compliance
Note: SPH-002T-P0.5S is also available.
2.08
2.85
Contact
Crimping
machine Crimp applicator
SPH-002T-P0.5L AP-K2N
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SPH-002-05L APLMK SPH002-05L
Note: Contact JST for fully automatic crimping applicator.
Crimp style connector (Housing)
Normal type
(2 circuits)
No. of
circuits
B
A
4.2
3.5
6.25
H JST
2
No. of circuits
Circuit No.1
(3 to 16 circuits)
2
2
B
A
4.2
3.5
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Model
Normal type
PHNR-02-H
PHNR-03-H
PHNR-04-H
PHNR-05-H
PHNR-06-H
PHNR-07-H
PHNR-08-H
PHNR-09-H
PHNR-10-H
PHNR-11-H
PHNR-12-H
PHNR-13-H
PHNR-14-H
PHNR-15-H
PHNR-16-H
No.
Reverse type
PHNR-02C-H
PHNR-03C-H
PHNR-04C-H
PHNR-05C-H
PHNR-06C-H
PHNR-07C-H
PHNR-08C-H
PHNR-09C-H
PHNR-10C-H
PHNR-11C-H
PHNR-12C-H
PHNR-13C-H
PHNR-14C-H
PHNR-15C-H
PHNR-16C-H
Dimensions (mm)
A
B
Material and Finish
6.25
H JST
RoHS2 compliance
No. of circuits
Circuit No.1
Reverse type
(2 circuits)
4.2
B
3.5
2
Circuit No.1
No. of circuits
(3 to 16 circuits)
6.25
H JST
A
4.2
B
2
2
No. of circuits
3
3.5
6.25
H JST
A
Circuit No.1
2.0
4.0
6.0
8.0
10.0
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
6.0
8.0
10.0
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
32.0
34.0
Q'ty/
bag
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
KR(DIP)表
Single-row shrouded header (Through-hole type)
Top entry type
(2 circuits)
4.5
(1.7)
Normal type:
Circuit No.1
0.5
(3 to 16 circuits)
1.7
4.5
2
Reverse type:
Circuit No.1 1.95
A
0.5
0.5
Normal type:
Circuit No.1
Side entry type
4.8
6
Dimensions( mm)
A
B
1.6
6.25
(1.7)
B
Reverse type Model No.
No. of
circuits Top entry type (with boss) Side entry type
2
B2B-PH-KBLC-H
S2B-PH-KLC-H
3
B3B-PH-KBLC-H
S3B-PH-KLC-H
4
B4B-PH-KBLC-H
S4B-PH-KLC-H
5
B5B-PH-KBLC-H
S5B-PH-KLC-H
0.5
6
B6B-PH-KBLC-H
S6B-PH-KLC-H
7
B7B-PH-KBLC-H
S7B-PH-KLC-H
8
B8B-PH-KBLC-H
S8B-PH-KLC-H
9
B9B-PH-KBLC-H
S9B-PH-KLC-H
10
B10B-PH-KBLC-H
S10B-PH-KLC-H
11
B11B-PH-KBLC-H
S11B-PH-KLC-H
12
B12B-PH-KBLC-H
S12B-PH-KLC-H
13
B13B-PH-KBLC-H
S13B-PH-KLC-H
14
B14B-PH-KBLC-H
S14B-PH-KLC-H
15
B15B-PH-KBLC-H
S15B-PH-KLC-H
16
B16B-PH-KBLC-H
S16B-PH-KLC-H
3.4
(3.4)
6
B
Dimensions( mm)
A
B
6.0
Reverse type:
Circuit No.1 1.95 A
(3.4)
6
B
Normal type Model No.
No. of
2
S2B-PH-KL
B2B-PH-KBL-H
3
S3B-PH-KL
B3B-PH-KBL-H
4
S4B-PH-KL
B4B-PH-KBL-H
5
S5B-PH-KL
B5B-PH-KBL-H
6
S6B-PH-KL
B6B-PH-KBL-H
7
S7B-PH-KL
B7B-PH-KBL-H
8
S8B-PH-KL
B8B-PH-KBL-H
9
S9B-PH-KL
B9B-PH-KBL-H
10
S10B-PH-KL
B10B-PH-KBL-H
11
S11B-PH-KL
B11B-PH-KBL-H
12
S12B-PH-KL
B12B-PH-KBL-H
13
S13B-PH-KL
B13B-PH-KBL-H
14
S14B-PH-KL
B14B-PH-KBL-H
4.5
15
S15B-PH-KL
B15B-PH-KBL-H1.7
16
S16B-PH-KL
B16B-PH-KBL-H
Reverse type:
Circuit No.1 1.95
2
0.5
A
Normal type:
Circuit No.1
Q'ty/box
Top entry type
(with a boss)
Side entry
type
1,000
1,000
2.0
5.9
4.0
7.9
1,000
1,000
6.0
9.9
1,000
500
8.0
11.9
1,000
500
10.0
13.9
1,000
500
12.0
15.9
500
500
14.0
17.9
500
250
16.0
19.9
500
250
18.0
21.9
500
250
20.0
23.9
500
250
22.0
25.9
500
250
24.0
27.9
250
250
26.0
29.9
250
200
28.0
31.9
250
200
30.0
33.9
250
200
Q'ty/box
Top entry type
(with a boss)
Side entry
type
2.0
5.9
1,000
1,000
4.0
7.9
1,000
1,000
6.0
9.9
1,000
500
8.0
11.9
1,000
500
10.0
13.9
1,000
500
12.0
15.9
500
500
14.0
17.9
500
250
16.0
19.9
500
250
18.0
21.9
500
250
20.0
23.9
500
250
22.0
25.9
500
250
24.0
27.9
250
250
26.0
29.9
250
200
28.0
31.9
250
200
30.0
33.9
250
200
Material and Finish
(3.4)
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, gray
RoHS2 compliance This product displays (LF)(SN) on a label.
Note: 1. Top entry type headers without a bosses are also available.
2. PH connector header [B( )B-PH-K-S, S( )B-PH-K-S] can be also used.
( ) stands for circuits No.
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
B2B-PH-KBLC-HH...gray S...white Y...yellow R...red N...brown
K...black (blank)...gray (normal side entry type only)
4
KR(SMT)表
Single-row shrouded header (SMT type)
Top entry type
No. of
circuits
2
B
2.975
A
5
(2)
1.9
2
3
4
5
6
7
6.6
8
9
10
Reverse type:
Circuit No.1
Normal type:
Circuit No.1
11
1.4 2.2
12
13
14
15
16
Top entry type
B2B-PH-SM4-TB
B3B-PH-SM4-TB
B4B-PH-SM4-TB
B5B-PH-SM4-TB
B6B-PH-SM4-TB
B7B-PH-SM4-TB
B8B-PH-SM4-TB
B9B-PH-SM4-TB
B10B-PH-SM4-TB
B11B-PH-SM4-TB
B12B-PH-SM4-TB
B13B-PH-SM4-TB
B14B-PH-SM4-TB
B15B-PH-SM4-TB
B16B-PH-SM4-TB
Side entry type
S2B-PH-SM4-TB
S3B-PH-SM4-TB
S4B-PH-SM4-TB
S5B-PH-SM4-TB
S6B-PH-SM4-TB
S7B-PH-SM4-TB
S8B-PH-SM4-TB
S9B-PH-SM4-TB
S10B-PH-SM4-TB
S11B-PH-SM4-TB
S12B-PH-SM4-TB
S13B-PH-SM4-TB
S14B-PH-SM4-TB
S15B-PH-SM4-TB
Dimensions (mm)
B
A
Top entry type Side entry type
Q'ty/
reel
2.0
7.95
7.9
1,000
4.0
9.95
9.9
1,000
6.0
11.95
11.9
1,000
8.0
13.95
13.9
1,000
10.0
15.95
15.9
1,000
12.0
17.95
17.9
1,000
14.0
19.95
19.9
1,000
16.0
21.95
21.9
1,000
18.0
23.95
23.9
1,000
20.0
25.95
25.9
1,000
22.0
27.95
27.9
1,000
24.0
29.95
29.9
1,000
26.0
31.95
31.9
1,000
28.0
33.95
33.9
1,000
30.0
35.95
1,000
Material and Finish
Wafer: PA 6T, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
Note: Top entry type headers with suction tape are also available.
Side entry type
2
6
5.5
2.4
2.95
B
A
Normal type:
Circuit No.1
Reverse type:
Circuit No.1
(2.6)
1.6
No. of
circuits Top entry type Side entry type
2
B2B-PH-SM4C-TB
S2B-PH-SM4C-TB
3
B3B-PH-SM4C-TB
S3B-PH-SM4C-TB
4
B4B-PH-SM4C-TB
S4B-PH-SM4C-TB
5
B5B-PH-SM4C-TB
S5B-PH-SM4C-TB
6
B6B-PH-SM4C-TB
S6B-PH-SM4C-TB
7
B7B-PH-SM4C-TB
S7B-PH-SM4C-TB
8
B8B-PH-SM4C-TB
S8B-PH-SM4C-TB
9
B9B-PH-SM4C-TB
S9B-PH-SM4C-TB
10
B10B-PH-SM4C-TB
S10B-PH-SM4C-TB
11
B11B-PH-SM4C-TB
S11B-PH-SM4C-TB
12
B12B-PH-SM4C-TB
S12B-PH-SM4C-TB
13
B13B-PH-SM4C-TB
S13B-PH-SM4C-TB
14
B14B-PH-SM4C-TB
S14B-PH-SM4C-TB
15
B15B-PH-SM4C-TB
S15B-PH-SM4C-TB
16
B16B-PH-SM4C-TB
Dimensions (mm)
B
A
Q'ty/
reel
2.0
7.9
1,000
4.0
9.9
1,000
6.0
11.9
1,000
8.0
13.9
1,000
10.0
15.9
1,000
12.0
17.9
1,000
14.0
19.9
1,000
16.0
21.9
1,000
18.0
23.9
1,000
20.0
25.9
1,000
22.0
27.9
1,000
24.0
29.9
1,000
26.0
31.9
1,000
28.0
33.9
1,000
30.0
35.9
1,000
Material and Finish
5
KRWコネクタ表1
Double-row shrouded Header
Top entry type
No. of
circuits
B
A
Reverse type: Line A/Circuit No.1
16
18
Line A
22
HJST
Normal type: Line A/Circuit No.1
Line B
26
28
Normal type: Line B/Circuit No.1
Reverse type: Line B/Circuit No.1
30
32
Model No.
Normal type
Reverse type
Top entry type Side entry type Top entry type Side entry type
B16B-KRWHK S16B-KRWHS B16B-KRWHK-C S16B-KRWHS-C
B18B-KRWHK S18B-KRWHS B18B-KRWHK-C S18B-KRWHS-C
B20B-KRWHK S20B-KRWHS B20B-KRWHK-C S20B-KRWHS-C
B22B-KRWHK S22B-KRWHS B22B-KRWHK-C S22B-KRWHS-C
B24B-KRWHK-C
B24B-KRWHK
B26B-KRWHK S26B-KRWHS B26B-KRWHK-C S26B-KRWHS-C
B28B-KRWHK S28B-KRWHS B28B-KRWHK-C S28B-KRWHS-C
B30B-KRWHK S30B-KRWHS B30B-KRWHK-C S30B-KRWHS-C
B32B-KRWHK S32B-KRWHS B32B-KRWHK-C S32B-KRWHS-C
A
4.7
10.7
4.7
22.4
320
280
16.0
24.4
288
252
18.0
26.4
256
224
20.0
28.4
224
196
22.0
30.4
224
196
24.0
32.4
192
168
26.0
34.4
192
168
28.0
36.4
192
168
30.0
38.4
160
140
Note:1.Top entry type headers with bosses or without clinched tails are also available.
2.The products listed above are supplied packed in tray.
B10B-KRWHK-( )M...green H...gray N...brown
3.7
10.05
Reverse type:
Line B/Circuit No.1
KRWコネクタポストトップ型
Line B
10.85
H J S T
Normal type:
Line B/Circuit No.1
2
14.0
ex.
B
A
B
B
Side entry type
Q'ty/box
A
Material and Finish
7.5
3.4
3.7
2
Dimensions
(mm)
3.4
Line A
2.8
2
KRWコネクタ表1
5.8
Normal type:
Line A/Circuit No.1
Reverse type:
Line A/Circuit No.1
Double-row shrouded Header (with locks)
Top entry type
No. of
circuits
Line A/Circuit No.1
B
A
10
12
14
Line A
HJST
Line B/Circuit No.1
16
18
Line B
22
10.7
24
26
30
32
10.7
3.4
11.5
With a compact boss
Q'ty/
box
364
308
280
252
252
224
196
196
168
168
168
140
Material and Finish
3.4
11.5
28
Model No.
Dimensions (mm)
Top entry type
Without bosses With a standard boss With a compact boss
A
B
8.0
17.0
B10B-KRWHK-F1
B10B-KRWHK-F1-1D
B10B-KRWHK-F1-1
10.0
19.0
B12B-KRWHK-F1
B12B-KRWHK-F1-1D
B12B-KRWHK-F1-1
12.0
21.0
B14B-KRWHK-F1
B14B-KRWHK-F1-1D
B14B-KRWHK-F1-1
14.0
23.0
B16B-KRWHK-F1
B16B-KRWHK-F1-1D
B16B-KRWHK-F1-1
16.0
25.0
B18B-KRWHK-F1
B18B-KRWHK-F1-1D
B18B-KRWHK-F1-1
18.0
27.0
B20B-KRWHK-F1
B20B-KRWHK-F1-1D
B20B-KRWHK-F1-1
29.0
20.0
B22B-KRWHK-F1
B22B-KRWHK-F1-1D
B22B-KRWHK-F1-1
22.0
31.0
B24B-KRWHK-F1
B24B-KRWHK-F1-1D
B24B-KRWHK-F1-1
24.0
33.0
B26B-KRWHK-F1
B26B-KRWHK-F1-1D
B26B-KRWHK-F1-1
26.0
35.0
B28B-KRWHK-F1
B28B-KRWHK-F1-1D
B28B-KRWHK-F1-1
28.0
37.0
B30B-KRWHK-F1
B30B-KRWHK-F1-1D
B30B-KRWHK-F1-1
30.0
39.0
B32B-KRWHK-F1
B32B-KRWHK-F1-1D
B32B-KRWHK-F1-1
Note:1. The products listed above are supplied packed in tray.
2. Unlisted in UL/CSA/TÜV.
3. The applicable holder is "KRWH-( )( )-( )-1" only.
ex.
B10B-KRWHK-F1-( )-
H...gray Y...yellow R...red N...brown
M...green K...black
6
CONNECTOR
KRWコネクタ表2
KRW connector Holder
0.7
B
A
Normal type:
Line A/Circuit No.1
φ1
Indication for Line A
1
No. of
circuits
Reverse type:
Line A/Circuit No.1
10
12
14
16
18
24
26
28
30
32
Line A
5
3
5
9.7
A
H JST
B
Line B
Normal type:
Line B/Circuit No.1
9.7
Dimensions (imm)
A
B
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
32.0
34.0
13.4
15.4
17.4
19.4
21.4
23.4
25.4
27.4
29.4
31.4
33.4
35.4
6.65
0.8
No.
Reverse type
KRWH-10C-H
KRWH-12C-H
KRWH-14C-H
KRWH-16C-H
KRWH-18C-H
KRWH-20C-H
KRWH-22C-H
KRWH-24C-H
KRWH-26C-H
KRWH-28C-H
KRWH-30C-H
KRWH-32C-H
Material and Finish
KRWコネクタ表2
RoHS2 compliance
0.8
Indication for Line B
Reverse type:
Line B/Circuit No.1
Model
Normal type
KRWH-10-H
KRWH-12-H
KRWH-14-H
KRWH-16-H
KRWH-18-H
KRWH-20-H
KRWH-22-H
KRWH-24-H
KRWH-26-H
KRWH-28-H
KRWH-30-H
KRWH-32-H
KRW connector Holder (for header with locks)
0.7
1
B
A
φ1
Line A
3
3
5
9.7
A
H JST
B
Line B
No. of
circuits
Model No.
10
12
14
16
18
24
26
28
30
32
KRWH-10-H-1
KRWH-12-H-1
KRWH-14-H-1
KRWH-16-H-1
KRWH-18-H-1
KRWH-20-H-1
KRWH-22-H-1
KRWH-24-H-1
KRWH-26-H-1
KRWH-28-H-1
KRWH-30-H-1
KRWH-32-H-1
Q'ty/
box
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
13.4
15.4
17.4
19.4
21.4
23.4
25.4
27.4
29.4
31.4
33.4
35.4
12.0
14.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
30.0
32.0
34.0
Material and Finish
9.7
6.65
0.8
0.8
Dimensions (mm)
A
B
RoHS2 compliance
Note:1. Unlisted in UL/CSA/TÜV.
2. The applicable header is "B( )B-KRW( )K-F1-( )" only.
TR コネクタ表-1
ex.
KRWH-10-H-1H...gray Y...yellow R...red N...brown K...black S...natural
TR connector (Unit for wire-to-wire connection)
Reverse type:
Circuit No.1
No. of
circuits
Normal type:
Circuit No.1
2
3
4
7.4
5
6
7
1.3
2.8
8
2
9
A
10
2
10.5
Panel layout
H J T
C
±0.1
11
12
13
14
15
D
B
Secure locking
±0.1
3.2±0.1
6.4±0.1
16
TR connectors without secure locking device are also available.
7
Model No.
Normal type
Reverse type
BU02P-TR-PC-H
BU02P-TR-P-H
BU03P-TR-PC-H
BU03P-TR-P-H
BU04P-TR-PC-H
BU04P-TR-P-H
BU05P-TR-PC-H
BU05P-TR-P-H
BU06P-TR-PC-H
BU06P-TR-P-H
BU07P-TR-PC-H
BU07P-TR-P-H
BU08P-TR-PC-H
BU08P-TR-P-H
BU09P-TR-PC-H
BU09P-TR-P-H
BU10P-TR-PC-H
BU10P-TR-P-H
BU11P-TR-PC-H
BU11P-TR-P-H
BU12P-TR-PC-H
BU12P-TR-P-H
BU13P-TR-PC-H
BU13P-TR-P-H
BU14P-TR-PC-H
BU14P-TR-P-H
BU15P-TR-PC-H
BU15P-TR-P-H
BU16P-TR-PC-H
BU16P-TR-P-H
Dimensions (mm)
B
C
D
Q'ty/
box
2.0
7.6
7.9
11.6
500
4.0
9.6
9.9
13.6
500
6.0
11.6
11.9
15.6
500
8.0
13.6
13.9
17.6
250
10.0
15.6
15.9
19.6
250
12.0
17.6
18.0
21.6
200
14.0
19.6
20.0
23.6
250
16.0
21.6
22.0
25.6
250
18.0
23.6
24.0
27.6
200
20.0
25.6
26.0
29.6
200
22.0
27.6
28.0
31.6
200
24.0
29.6
30.0
33.6
150
26.0
31.6
32.0
35.6
150
28.0
33.6
34.0
37.6
150
30.0
35.6
36.0
39.6
150
A
Material and Finish
Housing: PA 66, UL94V-0, gray
TR コネクタ表-1
TRW connector (Unit for wire-to-wire connection)
No. of
circuits
Normal type:
Line B/Circuit No.1
A
2
16
18
Line B Mark
24
13.2
H JST
B
26
28
A
30
Line A Mark
Reverse type:
Line A/Circuit No.1
32
B
A
Dimensions (mm)
B
C
D
Q'ty/
box
14.0
23.5
23.9
27.5
100
16.0
25.5
25.9
29.5
100
18.0
27.5
27.9
31.5
50
20.0
29.5
29.9
33.5
50
22.0
31.5
31.9
35.5
50
24.0
33.5
33.9
37.5
50
26.0
35.5
35.9
39.5
50
28.0
37.5
37.9
41.5
50
30.0
39.5
39.9
43.5
50
+0.1
11.5 0
+0.1
4.2 0
1.5 0
+0.1
7.6 ±0.05
13.4
No.
Reverse type
BU16P-TRW-PC-H
BU18P-TRW-PC-H
BU20P-TRW-PC-H
BU22P-TRW-PC-H
BU24P-TRW-PC-H
BU26P-TRW-PC-H
BU28P-TRW-PC-H
BU30P-TRW-PC-H
BU32P-TRW-PC-H
Material and Finish
Panel layout
+0.1
C 0
D
Model
Normal type
BU16P-TRW-P-H
BU18P-TRW-P-H
BU20P-TRW-P-H
BU22P-TRW-P-H
BU24P-TRW-P-H
BU26P-TRW-P-H
BU28P-TRW-P-H
BU30P-TRW-P-H
BU32P-TRW-P-H
±0.05
ex.
BU16P-TRW-P-HH...gray Y...yellow R...red N...brown
S...natural (white) M...green
8
