SD103AX SD103BX SD103CX
Schottky Barrier Diode
FEATURES
z
z
Low Forward Voltage Drop.
Guard Ring Construction For Transient Protection.
z
Negligible Reverse Recovery Time.
z
Low Reverse Capacitance.
APPLICATIONS
z
SOD-5 23
Schotty barrier switching.
ORDERING INFORMATION
Type No.
Marking
Package Code
SD103AX
SD103BX
SD103CX
S4
S5
S6
SOD-523
SOD-523
SOD-523
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Parameter
Symbol
SD103AX
SD103BX
SD103CX
Unit
Peak Repetitive Peak reverse voltage
Working Peak
DC Reverse Voltage
VRR
40
30
V
RMS Reverse Voltage
VR(RMS)
28
21
14
V
Forward Continuous Current
IF
350
mA
Repetitive Peak Forward Current
@t≤1.0s
IFRM
1.5
A
Power Dissipation
Pd
400
mW
Thermal Resistance Junction to
Ambient
RθjA
300
℃/W
Storage temperature
Tstg
-65~+125
REV.08
VRWM
VR
1 of 3
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Reverse Breakdown Voltage
SD103AX
SD103BX
SD103CX
Forward voltage
Reverse current
Symbol
Min.
V(BR)R
40
30
Typ.
Unit
V
0.37
0.60
VF
SD103AX
SD103BX
SD103CX
Max.
IRM
5.0
Conditions
IR=10μA
IR=10μA
IR=10μA
V
IF=20mA
IF=200mA
μA
VR=30V
VR=20V
VR=10V
Capacitance between terminals
CT
50
pF
VR=0,f=1MHz
trr
10
ns
IR=IF=200mA
Irr=0.1*IR,RL=100Ω
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
REV.08
2 of 3
PACKAGE OUTLINE
Plastic surface mounted package
SOD-523
A
C
HE
V M A
D
A
0.5
1mm
scale
E b
p
DIMENSIONS(mmaretheoriginaldimensions)
UNIT
A
bp
c
D
E
HE
V
mm
0.7
0.5
0.35
0.25
0.2
0.1
1.3
1.1
0.9
0.7
1.7
1.5
0.15
Note 1.Themarkingbarindicatesthecathode.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
EUROPEAN
PROJECTION
EIAJ
SOD523
REV.08
ISSUEDATE
98-11-25
3 of 3
很抱歉,暂时无法提供与“SD103AX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05700
- 500+0.05130
- 5000+0.04750
- 10000+0.04560
- 30000+0.04370
- 50000+0.04256
