GBU8J
GBU8J
    SK(時科)
    DB-4P_22.05X3.43MM_TM
    玻璃钝化桥式整流器VR=1KV IR=5μA GBU
GBU8J 数据手册
GBU8A THRU GBU8M GLASS PASSIVATED BRIDGE RECTIFIERS REVERSE VOLTAGE - 50 to 1000 Volts FORWARD CURRENT - 8.0 Amperes FEATURES - Polarity:As marked on body Surge overload rating -200 amperes peak ~ ~ + GBU Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique Plastic material has U/L The flammability classification 94V-0 Mounting postition:Any Weight: 0.138 ounces , 3.9 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. CHARACTERISTICS GBU8A GBU8B GBU8D GBU8G GBU8J GBU8K GBU8M SYMBOL UNIT Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward (with heatsink Note 2) Rectified Current @ T C=100℃ (without heatsink) Peak Forward Surage Current 8.3ms Single Half Sine-Wave I(AV) 8.0 3.0 A IFSM 200 A 1.0 V Super Imposed on Rated Load (JEDEC Method) VF Maximum Forward Voltage at 4.0A DC Maximum DC Reverse Current J=25℃ at Rated DC Blocking B Voltage J=125℃ 5.0 IR 500 uA I2t Rating for Fusing (t
GBU8J 价格&库存
很抱歉,暂时无法提供与“GBU8J”相匹配的价格&库存,您可以联系我们找货
GBU8J
  • 1+0.99892
  • 10+0.92208
  • 30+0.90671
  • 100+0.86061
库存:250
