GBJ35M
GBJ35M
    SK(時科)
    DB-4P_30X4.6MM_TM
    玻璃钝化桥式整流器VR=1KV IR=5μA GBJ
GBJ35M 数据手册
GBJ35A THRU GBJ35M GLASS PASSIVATED BRIDGE RECTIFIERS REVERSE VOLTAGE - 50 to 1000 Volts FORWARD CURRENT - 35.0 Amperes FEATURES GBJ Polarity:As marked on body Rating to 1000V PRV Ideal for printed circuit board Reliable low cost construction utilizing molded plastic technique Plastic material has U/L The flammability classification 94V-0 Mounting postition:Any Weight: 0.24 ounces , 6.79 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. CHARACTERISTICS SYMBOL GBJ35A GBJ35B GBJ3 5D GBJ3 5G GBJ3 5J GBJ3 5 K GBJ35M UNIT Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current (with heatsink Note 2) Peak Forward Surage Current 8.3ms Single Half Sine-Wave I(AV) 35 A IFSM 300 A 1.0 V Super Imposed on Rated Load (JEDEC Method) Maximum Forward Voltage at 17.5 A DC Maximum DC Reverse Current J=25℃ at Rated DC Blocking B Voltage J=125℃ I2t Rating for Fusing (t
GBJ35M 价格&库存
很抱歉,暂时无法提供与“GBJ35M”相匹配的价格&库存,您可以联系我们找货
GBJ35M
  • 1+2.20350
  • 10+2.03400
  • 30+2.00010
  • 100+1.89840
库存:73
