78L05K
78L05K
    SK(時科)
    SOT89-3
    三端正电压调节器
78L05K 数据手册
78L05K THRU 78L15K 3-Terminal Terminal Positive Voltage Regulator FEATURES ·Maximum Output Current IO: 0.1 A ·Output Voltage VO: 5V/6V/8V/9V/10V/12V/ /6V/8V/9V/10V/12V/15V ·Continuous Total Dissipation PD: 0.5 W (Ta = 25 ℃) 1:OUT 2:GND 3:IN SOT-89 PLASTIC PACKAGE Absolute Maximum Ratings (Ta = 25 OC) Parameter Input Voltage Symbol 78L05K~78L08K VI 78L09K~78L15K Rating Unit 30 V 35 V Power Dissipation Ptot 500 1) mW Operating Temperature Topr - 20 to + 120 ℃ Storage Temperature Range Tstg - 55 to +150 ℃ 1) 15 mm X 25 mm X 0.7 mm alumina ceramic board, Ta ≤ 25℃ specified 0℃≤ TJ ≤ 125℃, VI = 10 V, IO = 40 mA, CI = 0.33 μF, C2 = 0.1 μF) Electrical Characteristics (Ta = 25℃) (Unless otherwise specified,0 Parameter Output Voltage Symbol VO Line Regulation Regline Load Regulation Regload Quiescent Current IQ Test Condition Min. Typ. Max. Unit Tj = 25℃ 4.8 5 5.2 V 7 V ≤ VI ≤ 20 V, 1 mA ≤ IO ≤ 40 mA 4.75 -- 5.25 V VI = 10 V, 1 mA ≤ IO ≤ 70 mA 4.75 -- 5.25 V 7 V ≤ VI ≤ 20 V, Tj = 25℃ -- -- 150 8 V ≤ VI ≤ 20 V, Tj = 25℃ -- -- 100 1 mA ≤ IO ≤ 100 mA, Tj = 25℃ -- -- 60 1 mA ≤ IO ≤ 40 mA, Tj = 25℃ -- -- 30 Tj = 25℃ -- -- 5.5 8 V ≤ VI ≤ 20 V -- -- 1.5 1 mA ≤ IO ≤ 40 mA -- -- 0.1 mV mV mA Quiescent Current Change ΔIQ Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25℃ -- 40 -- μV Ripple Rejection RR f = 120 Hz, 8 V ≤ VI ≤ 18 V, Tj = 25℃ 41 -- -- dB Dropout Voltage VDrop Tj = 25℃ -- 1.7 -- V REV.08 1 of 7 mA 78L05K THRU 78L15K Electrical Characteristics (Ta = 25℃) (Unless otherwise specified,0℃≤ TJ ≤ 125℃, VI = 11 V, IO = 40 mA, CI = 0.33 μF, C2 = 0.1 μF) Parameter Output Voltage Symbol VO Line Regulation Regline Load Regulation Regload Quiescent Current IQ Test Condition Min. Typ. Max. Unit Tj = 25℃ 5.76 6 6.24 V 8.5V ≤ VI ≤ 21V, 1 mA ≤ IO ≤ 40 mA 5.7 -- 6.3 V VI = 11 V, 1 mA ≤ IO ≤ 70 mA 5.7 -- 6.3 V 8.5V ≤ VI ≤ 21V, Tj = 25℃ -- -- 155 9 V ≤ VI ≤ 21 V, Tj = 25℃ -- -- 105 1 mA ≤ IO ≤ 100 mA, Tj = 25℃ -- -- 65 1 mA ≤ IO ≤ 40 mA, Tj = 25℃ -- -- 35 Tj = 25℃ -- -- 5.5 9 V ≤ VI ≤ 21 V,IO = 40 mA -- -- 1.5 VI = 11 V,1 mA ≤ IO ≤ 40 mA -- -- 0.1 mV mV mA Quiescent Current Change ΔIQ mA Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25℃ -- 49 -- μV Ripple Rejection RR f = 120 Hz, 9 V ≤ VI ≤ 19 V, Tj = 25℃ 40 -- -- dB Dropout Voltage VDrop Tj = 25℃ -- 1.7 -- V specified ℃≤ TJ ≤ 125℃, VI = 14 V, IO = 40 mA, CI = 0.33 μF, C2 = 0.1 μF) Electrical Characteristics (Ta = 25℃) (Unless otherwise specified,0 Parameter Output Voltage Symbol VO Line Regulation Regline Load Regulation Regload Quiescent Current IQ Test Condition Min. Typ. Max. Unit Tj = 25℃ 7.7 8 8.3 V 10.5V ≤ VI ≤ 23V, 1 mA ≤ IO ≤ 40 mA 7.6 -- 8.4 V VI = 14 V, 1 mA ≤ IO ≤ 70 mA 7.6 -- 8.4 V 10.5V ≤ VI ≤ 23V, Tj = 25℃ -- -- 175 11 V ≤ VI ≤ 23 V, Tj = 25℃ -- -- 125 1 mA ≤ IO ≤ 100 mA, Tj = 25℃ -- -- 80 1 mA ≤ IO ≤ 40 mA, Tj = 25℃ -- -- 40 Tj = 25℃ -- -- 5.5 12 V ≤ VI ≤ 23 V,IO = 40 mA -- -- 1.5 VI = 14 V,1 mA ≤ IO ≤ 40 mA -- -- 0.1 mV mV mA Quiescent Current Change ΔIQ Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25℃ -- 60 -- μV Ripple Rejection RR f = 120 Hz, 12 V ≤ VI ≤ 22 V, Tj = 25℃ 39 -- -- dB Dropout Voltage VDrop Tj = 25℃ -- 1.7 -- V REV.08 2 of 7 mA 78L05K THRU 78L15K Electrical Characteristics (Ta = 25℃) (Unless otherwise specified,0℃≤ TJ ≤ 125℃, VI = 15 V, IO = 40 mA, CI = 0.33 μF, C2 = 0.1 μF) Parameter Output Voltage Symbol VO Line Regulation Regline Load Regulation Regload Quiescent Current IQ Test Condition Min. Typ. Max. Unit Tj = 25℃ 8.64 9 9.36 V 11.4V ≤ VI ≤ 24V, 1 mA ≤ IO ≤ 40 mA 8.55 -- 9.45 V VI = 15 V, 1 mA ≤ IO ≤ 70 mA 8.55 -- 9.45 V 11.4V ≤ VI ≤ 24V, Tj = 25℃ -- -- 200 12 V ≤ VI ≤ 24 V, Tj = 25℃ -- -- 160 1 mA ≤ IO ≤ 100 mA, Tj = 25℃ -- -- 90 1 mA ≤ IO ≤ 40 mA, Tj = 25℃ -- -- 45 Tj = 25℃ -- -- 6 12 V ≤ VI ≤ 24 V,IO = 40 mA -- -- 1.5 VI = 15 V,1 mA ≤ IO ≤ 40 mA -- -- 0.1 mV mV mA Quiescent Current Change ΔIQ Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25℃ -- 70 -- μV Ripple Rejection RR f = 120 Hz, 12 V ≤ VI ≤ 24 V, Tj = 25℃ 38 -- -- dB Dropout Voltage VDrop Tj = 25℃ -- 1.7 -- V Electrical Characteristics (Ta = 25℃) at specified virtual junction temperature, VI= 17V, IO = 40mA (unless otherwise noted) REV.08 3 of 7 mA 78L05K THRU 78L15K specified ℃≤ TJ ≤ 125℃, VI = 19 V, IO = 40 mA, CI = 0.33 μF, C2 = 0.1 μF) Electrical Characteristics (Ta = 25℃) (Unless otherwise specified,0 Parameter Output Voltage Symbol VO Line Regulation Regline Load Regulation Regload Quiescent Current IQ Test Condition Min. Typ. Max. Unit Tj = 25℃ 11.5 12 12.5 V 14.5V ≤ VI ≤ 27V, 1 mA ≤ IO ≤ 40 mA 11.4 -- 12.6 V VI = 19 V, 1 mA ≤ IO ≤ 70 mA 11.4 -- 12.6 V 14.5V ≤ VI ≤ 27V, Tj = 25℃ -- -- 250 16 V ≤ VI ≤ 27 V, Tj = 25℃ -- -- 200 1 mA ≤ IO ≤ 100 mA, Tj = 25℃ -- -- 100 1 mA ≤ IO ≤ 40 mA, Tj = 25℃ -- -- 50 Tj = 25℃ -- -- 6 16 V ≤ VI ≤ 27 V -- -- 1.5 1 mA ≤ IO ≤ 40 mA -- -- 0.1 mV mV mA Quiescent Current Change ΔIQ Output Noise Voltage VN 10 Hz ≤ f ≤ 100 KHz, Tj = 25℃ -- 80 -- μV Ripple Rejection RR f = 120 Hz, 15 V ≤ VI ≤ 25 V, Tj = 25℃ 37 -- -- dB Dropout Voltage VDrop Tj = 25℃ -- 1.7 -- V Electrical Characteristics (Unless otherwise specified, VIN = 23 V, IOUT = 40 mA, CIN = 0.33 μF, COUT = 0.1 μF, Tj = 25 °C) REV.08 4 of 7 mA 78L05K THRU 78L15K 78L05K Typical Characteristics REV.08 5 of 7 78L05K THRU 78L15K 78L12K Typical Characteristics REV.08 6 of 7 78L05K THRU 78L15K SOT-89 PACKAGE OUTLINE REV.08 Unitt:mm 7 of 7
78L05K 价格&库存
很抱歉,暂时无法提供与“78L05K”相匹配的价格&库存,您可以联系我们找货
78L05K
    • 1+0.28928
    • 30+0.28024
    • 100+0.26216
    • 500+0.24408
    • 1000+0.23504
    库存:1000
    78L05K
      • 1000+0.14553
      库存:375000
