2SC3357
NPN Silicon RF Transistor
FEATURES
· Low Noise and High Gain
NF = 1.1 dB TYP., Ga = 8.0 dB TYP.
@VCE = 10 V, IC = 7 mA, f = 1.0 GHz
NF = 1.8 dB TYP., Ga = 9.0 dB TYP.
@VCE = 10 V, IC = 40 mA, f = 1.0 GHz
APPLICATIONS
SOT-89
· Designed for low noise amplifier at VHF, UHF and CATV band.
MECHANICAL DATA
Case: SOT-89
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.055 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Symbol
Rating
Unit
Collector-base voltage
VCBO
V
Collector-emitter voltage
VCEO
12
V
Emitter-base voltage
VEBO
3.0
V
IC
100
mA
W
Parameter
Collector current
Total power dissipation
PT*
1.2
Junction temperature
Tj
150
Storage temperature
Tstg
-65 to +150
Thermal Resistance
Rth(j-a)*
62.5
/W
* mounted on 16 cm X 0.7 mm(t) Ceramic Substrate
2
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
Collector cutoff current
ICBO
Emitter cutoff current
Test conditions
Min
Typ
VCB = 10V,IE=0
IEBO
VEB = 1.0V,IC=0
1.0
A
1.0
A
hFE *1
VCE =10V,Ic=20mA
Insertion Power Gain
|S21e |2
VCE = 10 V, IC = 20 mA, f = 1.0 GHz
9
dB
1.1
dB
1.8
3.0
dB
VCB = 10 V, IE = 0, f = 1.0 MHz
0.65
1.0
pF
VCE = 10V ,Ic=20mA
6.5
NF
Output Capacitance
Cob
Transition frequency
fT
*1 Pulse Measurement PW
350 ms, Duty Cycle
120
Unit
DC current gain
Noise Figure
50
Max
250
GHz
2%
*2 The emitter terminal and the case shall be connected to the guard terminal of the three-terminal capacitance bridge.
CLASSIFICATION OF hFE
Marking
RH
RF
RE
Rank
RH
RF
RE
hFE
20 100
80 160
125 250
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/ 6
2SC3357
Typical Characteristics
2/ 6
2SC3357
S-PARAMETER
VCE = 10 V, IC = 40 mA, ZO = 50Ω
f (MHz)
︱S11︱
∠S11
︱S21︱
∠S21
︱S12︱
∠S12
︱S22︱
∠S22
200
0.196
-94.4
13.023
102.4
0.043
74.5
0.444
-21.1
400
0.103
-118.3
6.852
89.2
0.081
77.4
0.398
-25.3
600
0.056
-131.1
4.632
78.3
0.118
77.5
0.399
-26.9
800
0.024
-43.7
3.527
75.9
0.152
78.0
0.414
-28.9
1000
0.008
-2.0
2.854
68.7
0.188
78.4
0.440
-33.5
1200
0.039
13.1
2.421
65.7
0.218
75.7
0.461
-33.3
1400
0.072
11.8
2.118
59.0
0.255
71.7
0.479
-36.3
1600
0.102
9.6
1.887
57.1
0.278
73.1
0.499
-35.5
1800
0.129
8.6
1.681
52.5
0.308
71.3
0.515
-38.8
2000
0.151
9.8
1.579
51.4
0.339
71.8
0.537
-35.9
3/ 6
2SC3357
VCE = 10 V, IC = 20 mA, ZO = 50Ω
f (MHz)
︱S11︱
∠S11
︱S21︱
∠S21
︱S12︱
∠S12
︱S22︱
∠S22
200
0.130
-109.2
13.430
98.1
0.042
79.0
0.403
-22.1
400
600
0.073
0.037
-134.1
-146.6
6.930
4.690
87.2
79.4
0.081
0.119
80.6
79.4
0.382
0.392
-24.7
-25.6
800
1000
1200
1400
1600
1800
2000
0.010
0.024
0.056
0.093
0.124
0.151
0.174
177.1
23.7
17.2
13.8
12.0
11.0
13.4
3.560
2.878
2.439
2.133
1.898
1.693
1.591
75.2
68.2
65.4
59.0
57.3
52.9
52.0
0.154
0.191
0.220
0.257
0.280
0.311
0.341
79.7
76.5
76.8
72.9
74.0
72.4
72.8
0.412
0.440
0.463
0.483
0.504
0.519
0.542
-27.1
-31.9
-32.3
-35.7
-35.3
-38.4
-36.3
S-P ARAMETER
S11e, S22e-FREQUENCY
S21e-FREQUENCY
CONDITION VCE = 10 V
S12e-FREQUENCY
IC = 20 mA
IC = 20 mA
4/ 6
2SC3357
SOT-89 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550REF
0.061REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500TYP
0.060TYP
e1
3.000TYP
0.118TYP
L
0.900
1.200
0.035
0.047
SOT-89 Suggested Pad Layout
Note:
1. Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
5/ 6
2SC3357
SOT-89 Tape and Reel
SOT-89 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-89
4.85
4.45
1.85
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-89 Tape Leader and Trailer
SOT-89 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
13.20
16.50
±2
±1
±1
±1
±1
±1
±1
±1
6/ 6
很抱歉,暂时无法提供与“2SC3357”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56203
- 20+0.51244
- 100+0.46285
- 500+0.41326
- 1000+0.39011
- 2000+0.37358
