S8205A
Dual N-Channel Enhancement Mode Field Effect Transistor
FEATURES
Low on-resistance:VDS=20V,ID=5A,RDS(ON)≤25mΩ@VGS=4.5V
Low gate charge
For synchronous rectifier applications
Surface Mount device
SOT-23-6
MECHANICAL DATA
Case: SOT-23-6
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.3 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Drain-source voltage
Gate-source voltage
Continuous drain current @TA = 25°C
Pulsed drain current
Power dissipation
Thermal resistance from Junction to ambient
Junction and Storage temperature Range
Symbol
VDS
VGS
ID
IDM
PD
RθJA
TJ,TSTG
Value
±12
5
25
1.25
100
-55 ~+150
Unit
V
V
A
A
W
°C/W
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
STATIC CHARACTERICTISCS
Drain-Source breakdown voltage
Zero gate voltage drain current
Gate-body leakage current
Gate-threshold voltage
Drain-source on-resistance
Symbol
Min
V(BR)DSS*
IDSS*
IGSS*
VGS(th)*
0.5
RDS(ON)*
gFS
Forward transconductance
DRAIN-SOURCE DIODE CHARACERISTICS
Diode forward voltage
VSD
DYNAMIC CHARACTERICTISCS
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
SWITCHING CHARACTERICTISCS
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Turn-on delay time
td(on)
Turn-on rise time
tr
Turn-off delay time
td(off)
Turn-off fall time
tf
Typ
Max
Unit
1
±100
1.0
25
40
V
μA
nA
V
mΩ
mΩ
S
1.28
V
IS=1.7A, VGS=0V
800
155
125
pF
pF
pF
VDS=8V, VGS=0V, f=1MHz
11
2.2
2.5
18.3
4.8
43.5
nC
nC
nC
nS
nS
nS
nS
0.8
22
38
13
0.42
Conditions
VGS=0V, ID=250μA
VDS=16V, VGS=0V
VDS=0V, VGS=±12V
VDS=VGS, ID=250μA
VGS=4V, ID=5A
VGS=2.5V, ID=4A
VDS=5V, ID=5A
VGS=4V,VDS=10V,ID=4A
VDD=10V,
ID=1.0A,VGEN=4V,
RGEN=10Ω,RL=10Ω
*Pulse test ; Pulse width
很抱歉,暂时无法提供与“S8205A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15120
- 10+0.14580
- 30+0.13940
- 100+0.13500
- 500+0.12960
- 1000+0.11880
- 国内价格
- 1+0.29282
- 10+0.23455
- 30+0.20541
- 100+0.18355
- 500+0.16611
- 1000+0.15739
- 国内价格
- 1+0.55330
- 200+0.18370
- 1500+0.11550
- 3000+0.09141
- 国内价格
- 10+0.22631
- 100+0.17711
- 600+0.16028
- 1200+0.15868
- 3000+0.15551
