MMBD4148A/CA/CC/SE
SWITCHING DIODE
FEATURES
Fast Switching
High Conductance
Surface Mount device
For General Purpose Switching Applications
SOT-23
MECHANICAL DATA
Case: SOT-23
Case Material: Molded Plastic. UL
lammability
Classification Rating: 94V-0
Weight: 0.008 grams (approximate)
MMBD4148A:5H MMBD4148SE:D4 MMBD4148CC:D5 MMBD4148CA:D6
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Reverse Voltage
VR
100
V
Forward Current
IF
300
mA
Power Dissipation
350
mW
Thermal Resistance From Junction To Ambient
PD
RθJA
357
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
V(BR)
Reverse breakdown voltage
IR
Reverse voltage leakage current
Forward voltage
VF
CD
Diode capacitance
Trr
Reverse recovery time
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
Min
100
Max
5
1
4
4
Unit
V
uA
V
pF
nS
Conditions
IR=100uA
VR=75V
IF=10mA
VR=0V,f=1MHz
I F=IR=10mA Irr=0.1×IR RL=100Ω
E-mail:hkt@heketai.com
1/4
MMBD4148A/CA/CC/SE
SWITCHING DIODE
Typical Characteristics
Forward
Characteristics
Reverse
1000
300
Characteristics
100
(nA)
(mA)
300
REVERSE CURRENT IR
FORWARD CURRENT
10
T=
a 2
5℃
T=
a 1
00
IF
30
3
1
Ta=100℃
100
30
10
Ta=25℃
3
0.3
0.1
0.0
0.4
0.8
FORWARD VOLTAGE
1.2
VF
1
1.6
40
REVERSE VOLTAGE
Capacitance Characteristics
1.4
(V)
60
VR
80
(V)
Power Derating Curve
400
Ta=25℃
(mW)
300
PD
1.3
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
1.2
1.1
1.0
10
REVERSE VOLTAGE
15
VR
(V)
100
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
2/4
MMBD4148A/CA/CC/SE
SWITCHING DIODE
SOT-23 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 RE F
0.079
0.022 REF
L1
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
SOT-23 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for eference purposes only
3/4
MMBD4148A/CA/CC/SE
SWITCHING DIODE
SOT-23 Tape and Reel
SOT-23 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
SOT-23
3.15
2.77
1.22
Ø1.50
1.75
3.50
4.00
4.00
2.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-23 Tape Leader and Trailer
SOT-23 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“MMBD4148A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11182
- 600+0.09414
- 1200+0.09273
- 3000+0.08436
- 国内价格
- 50+0.12199
- 500+0.10270
- 3000+0.09203
- 6000+0.08557
- 24000+0.08003
- 51000+0.07695
- 国内价格
- 50+0.06380
- 500+0.05080
- 3000+0.04320
- 9000+0.03510
