MB4S
MB4S
    HOTTECH(合科泰)
    MBS
    整流桥 VRRM=400V If=800mA VF=1V CJ=13pF MBS
MB4S 数据手册
MB05S-MB10S SURFACE MOUNT BRIDGE RECTIFIER FEATURES ~ ~  UL Recognized Component  High surge current capability  Ideal for Printed Circuit Board .067(1.7) .057(1.3)  Plastic Package - UL Flammability Classification 94V-0 .014(0.35) .006(0.15) MBS .043(1.1) .027(0.7) .008(.20) .051(1.3) .035(0.9) .275(7)MAX .165(4.2) .150(3.8) MECHANICAL DATA .031(0.8) .019(0.5)  Case: Transfer Molded Epoxy .193(4.9) .177(4.5)  Mounting Position: Any .106(2.7) .090(2.3)  Terminals: Plated leads solderable per .106(2.7) .090(2.3) MTL-STD-750,Method 2026 Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% MB 05S MB 1S MB 2S MB 4S MB 6S MB 8S MB 10S Unit VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Characteristic Symbol Maximum Recurrent Peak Reverse Voltage Average Rectified Output Current @TA = 40°C IF(AV) 0.8 A IFSM 30 A It 5.0 As @IF = 0.5A VFM 1.0 V @TA=25°C @TA=100°C IRM 5.0 500 µA Typical Junction Capacitance per leg (Note1) Cj 13 pF Typical Thermal Resistance per leg (Note 2) RθJA RθJL 70 20 °C/W Operating and Storage Temperature Range Tj, TSTG -55 to +150 °C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) 2 2 I t Rating for Fusing (t < 8.3ms) Forward Voltage per element Maximum DC Reverse Current at Rated DC Blocking Voltage Notes: 2 1. Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts 2. On aluminum substrate P.C.B. with an area of 0.8" x 0.8" (20 x 20mm) mounted on 0.05 x 0.05" (1.3 x 1.3mm) solder pad ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 1/2 MB05S-MB10S SURFACE MOUNT BRIDGE RECTIFIER 0.8 IF, INSTANTANEOUS FORWARD CURRENT (A) I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A) Typical Characteristics 0.6 0.4 0.2 0 Resistive or Inductive Load 0 40 80 120 10 1.0 0.1 Tj = 25°C Pulse Width = 300µs 0.01 0.2 160 0.6 0.8 1.0 100 1.2 1.4 1.6 Tj = 25°C f = 1.0MHz 30 Cj, JUNCTION CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) 35 20 10 TA = 25°C Single Half Sine-Wave Pulse Width = 5.3ms (JEDEC Method) 0 10 1 1.0 1 10 NUMBER OF CYCLES AT 60 Hz Fig. 3 Maximum Peak Forward Surge Current (per leg) IR, INSTANTANEOUS REVERSE CURRENT (µA) 0.4 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics (per leg) TA, AMBIENT TEMPERATURE (°C) Fig. 1 Output Current Derating Curve 10 100 VR, REVERSE VOLTAGE (V) Fig. 4 Typical Junction Capacitance 100 Tj = 125°C 10 1.0 Tj = 25°C 0.1 0.01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig. 5 Typical Reverse Characteristics (per element) ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 2/2
很抱歉,暂时无法提供与“MB4S”相匹配的价格&库存,您可以联系我们找货
