MB1F
MB1F
    HOTTECH(合科泰)
    MBF
MB1F 数据手册
MB05F-MB10F SURFACE MOUNT BRIDGE RECTIFIER FEATURES ~  UL Recognized Component ~  High surge current capability  Ideal for Printed Circuit Board  Plastic Package - UL Flammability MBF Classification 94V-0 .193(4.9) .177(4.5) MECHANICAL DATA  Mounting Position: Any .008(0.2) .014(.35) .006(.15)  Terminals: Plated leads solderable per .031(0.8) .019(0.5) MTL-STD-750,Method 2026 .169(4.3) .153(3.9) .043(1.1) .023(0.6) .065(1.7) .059(1.5)  Case: Transfer Molded Epoxy .275(7.0)MAX .067(1.7) .057(1.3) .043(1.1) .027(0.7) .067(1.7) .057(1.3) .106(2.7) .09(2.3) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% MB 05F MB 1F MB 2F MB 4F MB 6F MB 8F MB 10F Unit VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Characteristic Symbol Maximum Recurrent Peak Reverse Voltage Maximum Average Forward Rectified Current @TA=40°C I(AV) 0.8 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I FSM Peak Forward Voltage at 0.8A DC VFM 1.0 V IRM 5.0 500 μA Typical Junction Capacitance CJ 15 pF Typical Thermal Resistance (Note 1) RθJA 75 °C/W Operating and Storage Temperature Range Tj, TSTG -55 to +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage @TA=25°C @TA=100°C 35 A Notes: 1. On aluminum substrate P.C.B. with an area of 0.8" x 0.8" (20 x 20mm) mounted on 0.05 x 0.05" (1.3 x 1.3mm) solder pad ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD E-mail:hkt@heketai.com 1/2 MB05F-MB10F SURFACE MOUNT BRIDGE RECTIFIER Fig. 2 Typical Forward Characteristics (per leg) Fig. 1 Output Current Derating Curve IF, INSTANTANEOUS FORWARD CURRENT (A) I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A) Typical Characteristics 1.0 0.8 Al. Substrate PC Board 0.6 0.4 Glass Epoxy PC Board 0.2 0 Resistive or Inductive Load 0 40 80 120 10 1.0 0.1 TA= 25°C Pulse Width = 300µs 0.01 0.2 160 0.6 0.8 1.0 1.2 1.4 1.6 VF, INSTANTANEOUS FORWARD VOLTAGE (V) TA, AMBIENT TEMPERATURE (°C) Fig. 3 Maximum Peak Forward Surge Current (per leg) 35 Fig. 4 Typical Junction Capacitance 100 TJ = 25°C f = 1.0MHz 30 Cj, JUNCTION CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) 0.4 20 10 0 TA = 25°C Single Half Sine-Wave Pulse Width =8.3ms (JEDEC Method) 1.0 10 1 10 NUMBER OF CYCLES AT 60 Hz ©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD 1 10 100 VR, REVERSE VOLTAGE (V) E-mail:hkt@heketai.com 2/2
很抱歉,暂时无法提供与“MB1F”相匹配的价格&库存,您可以联系我们找货
