RS3ABG THRU RS3MBG
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V Forward Current - 3 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Top View
Marking Code: R3A~R3M
Simplified outline SMB symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS3AB
G
RS3BB
G
RS3DB
G
RS3GB
G
RS3JB
G
RS3KB
G
RS3MB
G
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Forward Voltage at 3 A
VF
1.3
V
IR
5
100
μA
Cj
40
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
500
ns
RθJA
RθJC
48
16
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
250
150
1 of 3
RS3ABG THRU RS3MBG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
100
120
140
T J =25°C
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1.0
10
Reverse Voltage (V)
100
Number of Cycles
REV.08
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
1
60
1
0.5
Instaneous Forward Voltage (V)
00
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
2 of 3
100
RS3ABG THRU RS3MBG
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
Marking
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
REV.08
E1
3 of 3
Type number
Marking code
RS3ABG
RS3A
RS3BBG
RS3B
RS3DBG
RS3D
RS3GBG
RS3G
RS3JBG
RS3J
RS3KBG
RS3K
RS3MBG
RS3M
很抱歉,暂时无法提供与“RS3ABG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18119
- 30+0.17472
- 100+0.16824
- 500+0.15530
- 1000+0.14883
- 2000+0.14495
