BZT52C2V4 - 43
ZENER DIODES
FEATURES
Planar Die Construction
350mW Power Dissipation on Ceramic PCB
eneral Purpose, Medium Current
Ideally Suited for Automated Assembly Processes
SOD-123
MECHANICAL DATA
Case: SOD-123 Molded Plastic
Terminals: Solderable per MIL-STD-202,Method 208
Polarity: Cathode Band
Weight: 0.01 grams (approx.)
10
Cathode
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Characteristic
Symbol
Value
Unit
Forward Voltage (Note 2) @ IF = 10mA
VF
0.9
V
Power Dissipation(Note 1)
PD
350
mW
Thermal Resistance, Junction to Ambient Air
RθJ
357
°C /W
TJ
1 50
°C
Tj ,T S T
-65~ +150
Junction Temperature
Operating and Storage Temperature Range
°C
2
Notes: 1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm
2. Short duration test pulse used to minimize self-heating effect
3. f=1KHZ
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/5
BZT52C2V4 - 43
ZENER DIODES
ELECTRICAL CHARACTERISTICS @ Ta=25°C unless otherwise specified
Type
Zener Voltage Range (Note 2)
Maximum
Maximum
Zener Impedance
Reverse
(Note 3)
Current
Number
(Note 2)
VZ @I ZT
IZT
Nom(V) Min(V) Max(V)
mA
ZZT @IZT ZZK @IZK IZK
Ω
Typical
Test
Temperature Current
Coefficent IZTC
@IZTC
mV/°C
IR
VR
mA
uA
V
Min
Max
mA
BZT52C2V4
2.4
2.20
2.60
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
BZT52C15
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4 14.0
5
BZT52C18
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4 16.0
5
BZT52C20
21.2
5
55
225
1.0
0.1
14.0
14.4 18.0
5
BZT52C22
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4 20.0
5
BZT52C24
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4 22.0
5
BZT52C27
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4 25.3
2
BZT52C30
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4 29.4
2
BZT52C33
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4 33.4
2
BZT52C36
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4 37.4
2
BZT52C39
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4 41.2
2
BZT52C43
43
40.0
46.0
5
100
700
1.0
0.1
32
10.0 12.0
5
Notes: 1. Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2
3. f=1KHZ
2/5
BZT52C2V4 - 43
ZENER DIODES
Typical Characteristics
0.6
50
IZ, ZENER CURRENT (mA)
PD, POWER DISSIPATION (W)
C2V7
C3V9
C3V3
0.5
0.4
0.3
0.2
0.1
Tj = 25°C
40
C5V6
C4V7
C6V8
C6V2
C8V2
30
Test Current IZ
5.0mA
75
50
100
125
150
3
4
5
6
8
9
7
VZ, ZENER VOLTAGE (V)
Fig. 2 Zener Breakdown Characteristics
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Power Dissipation vs Ambient Temperature
30
Tj = 25°C
10
C10
2
10
C39
Tj = 25°C
C12
C15
C18
C22
10
Test current IZ
2mA
C27
Test current IZ
5mA
C33
C36
10
Fig. 3 Zener Breakdown Characteristics
8
6
4
Test Current IZ
2mA
2
40
30 40 50 60 70 80 90
Fig. 4 Zener Breakdown Characteristics
100
1000
Tj = 25 °C
f = 1MHz
CT, TOTAL CAPACITANCE (pF)
VR = 1V
VR = 2V
100
VR = 1V
VR = 2V
10
1
10
100
VZ, NOMINAL ZENER VOLTAGE (V)
Fig. 5 Total Capacitance vs Nominal Zener Voltage
3/5
BZT52C2V4 - 43
ZENER DIODES
SOD-123 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.450
0.650
0.018
0.026
c
0.080
0.150
0.003
0.006
D
1.500
1.700
0.059
0.067
E
2.600
2.800
0.102
0.110
E1
3.550
3.850
0.140
0.152
L
0.500 RE F
0.020 RE F
L1
0.250
0.450
0.010
0.018
θ
0°
8°
0°
8°
4/5
BZT52C2V4 - 43
ZENER DIODES
SOD-123 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOD-123
1.85
3.94
1.57
φ1.55
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.05
±0.05
±0.05
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
+0.3\-0.1
SOD-123 Tape Leader and Traller
SOD-123 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
φ178.00
54.40
13.00
R78.00
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
5/5
很抱歉,暂时无法提供与“BZT52C33”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11686
- 500+0.09532
- 3000+0.08322
- 6000+0.07603
- 24000+0.06977
- 51000+0.06638
