RS2BW
RS2BW
    SK(時科)
    SMF(SOD-123FL)
    二极管配置:独立式 直流反向耐压(Vr):100V 平均整流电流(Io):2A 正向压降(Vf):1.3V@2A 反向电流(Ir):5μA@100V 反向恢复时间(trr):150ns 工作温度:-5...
RS2BW 数据手册
RS2AW THRU RS2MW Surface Mount Fast Recovery Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 2 A PIN FEATURES ▪ For surface mounted applications ▪ Low profile package ▪ Glass Passivated Chip Junction ▪ Ideal for automated placement ▪ Fast reverse recovery time ▪ Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA ▪ Case: SOD-123FL ▪ Terminals: Solderable per MIL-STD-750, Method 2026 ▪ Approx. Weight:15mg 0.00053oz DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: RS2AW~RS2GW: 2F2 RS2JW: 2F5 RS2KW~RS2MW: 2F7 Simplified outline SOD-123FL and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols RS2AW RS2BW RS2DW RS2GW RS2JW Parameter RS2KW RS2MW Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at Ta = 65 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM 50 A Maximum Instantaneous Forward Voltage at 2 A VF 1.3 V IR 5 100 μA Maximum DC Reverse Current at Rated DC Blocking Voltage Ta = 25 °C Ta =125 °C Maximum Reverse Recovery Time 1) Typical Junction Capacitance at V R=4V, f=1MHz Typical Thermal Resistance 2) Operating and Storage Temperature Range 1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A. t rr 250 150 Cj 500 40 90 RθJA T j , T stg -55 ~ +150 2)P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. 1 of 3 ns pF °C/W °C RS2AW THRU RS2MW Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 2.5 100LFM 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 10 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 1.0 1.5 2.0 2.5 Peak Forward Surage Current (A) 80 100 120 140 T J =25°C 200 100 10 0.1 60 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 1.0 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 1 60 1 0.5 Instaneous Forward Voltage (V) 10 40 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 0.01 0.0 20 percent of Rated Peak Reverse Voltage (%) Ambient Temperature (°C) 100 Number of Cycles 2 of 3 100 RS2AW THRU RS2MW PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND VM D E A g Top View mil Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g pad e E A pad HE 7° The recommended mounting pad size Marking Type number 2.0 (79) Marking code RS2AW 1.2 (47) RS2BW 2F2 RS2DW 1.2 (47) 1.2 (47) ∠ RS2GW RS2JW 2F5 RS2KW Unit: mm (mil) 3 of 3 2F7 RS2MW
RS2BW 价格&库存
很抱歉,暂时无法提供与“RS2BW”相匹配的价格&库存,您可以联系我们找货
RS2BW
    • 3000+0.05643
