CQ0402BRNPO9BNR50
CQ0402BRNPO9BNR50
    YAGEO(国巨)
    贴片电容(MLCC) 0402 0.5pF ±0.1pF 50V C0G(NP0)
CQ0402BRNPO9BNR50 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS Hi Q Series Class 1, NP0 16V TO 500V 0.1 pF to 100 pF Product Specification – May 4, 2022 V.17 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ NPO 16V to 500V 4SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP This specification describes NP0 series chip capacitors with leadfree terminations. CTC & 12NC APPLICATIONS GLOBAL PART NUMBER (PREFERRED ) ⚫ ⚫ ⚫ Consumer electronics for example - Tuners - Television receivers - All types of cameras Telecommunications Data processing FEATURES ⚫ ⚫ ⚫ ⚫ Supplied in tape on reel Nickel-barrier end termination RoHS compliant Halogen Free compliant 2 13 All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. YAGEO/ PHYCOMP BRAND ordering code CQ XXXX X X (1) NPO (2) (3) X BN XXX (4) (5) (1) SIZE – INCH BASED (METRIC) 0100 (0402) 0201 (0603) 0402 (1005) 0603 (1608) 0805 (2012) (2) TOLERANCE 0.1pF B = ± 0.1 pF 0.2pF to 2.0 pF A = ± 0.05 pF B = ± 0.1 pF C = ± 0.25 pF 2.1pF to 5.0pF A = ± 0.05 pF B = ± 0.1 pF C = ± 0.25 pF D = ± 0.5 pF 5.1pF to 9.9pF B = ± 0.1 pF C = ± 0.25 pF D = ± 0.5 pF 10pF and over F = ± 1% G = ± 2% J = ± 5% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch (4) RATED VOLTAGE 7 = 16V 8 = 25V 9 = 50V 0=100V A=200V Y=250V B=500V (5) CAPACITANCE VALUE 2 significant digits + number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ 16V to 500V NPO 3 13 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction OUTLINES DIMENSION For dimension see Table 1 Table 1 For outlines see fig. 2 TYPE L1 (mm) W (mm) T (MM) L2 / L3 (mm) min. max. 01005 0.4± 0.02 0.2± 0.02 0.2± 0.02 0.07 0.14 0.13 0201 0.6± 0.03 0.3± 0.03 0.10 0.20 0.20 0402 1.0± 0.05 0.5± 0.05 0603 1.6± 0.10 0.8± 0.10 0805 2.0± 0.20 1.25± 0.20 Refer to table 2 to 5 L4 (mm) min. 0.15 0.35 0.30 0.20 0.60 0.40 0.25 0.75 0.55 W T L2 L4 L1 L3 MBB211 Fig. 2 Surface mounted multilayer ceramic capacitor dimension www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ 16V to 500V NPO 4 13 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0201 to 0402 01005 0201 0402 01005 0201 16V/25V 25V/50V 100V 50V to 250V 16V/25V 25V/50V 100V 50V to 250V 0.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 3.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 1.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 4.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 2.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 CAP. Tape Width 8mm CAP. Tape Width 0402 8mm NOTE 1. Values in shaded cells indicate thickness class in mm www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ NPO 16V to 500V 5 13 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0201 to 0402 CAP. 01005 0201 0402 CAP. 01005 0201 0402 16V/25V 25V/50V 100V 50V to 250V 16V/ 25V 25V/50V 100V 50V to 250V 5.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 8.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 5.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 9.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 6.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 10 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 7.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 12 pF 0.2± 0.02 0.3± 0.03 0.5± 0.05 7.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 15 pF 0.2± 0.02 0.3± 0.03 0.5± 0.05 7.2 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 18 pF 0.3± 0.03 0.5± 0.05 7.3 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 22 pF 0.3± 0.03 0.5± 0.05 7.4 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 27 pF 0.3± 0.03 0.5± 0.05 7.5 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 33 pF 0.3± 0.03 0.5± 0.05 7.6 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 39 pF 0.3± 0.03 0.5± 0.05 7.7 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 47 pF 0.5± 0.05 7.8 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 56 pF 0.5± 0.05 7.9 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 68 pF 0.5± 0.05 8.0 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 82 pF 0.5± 0.05 8.1 pF 0.2± 0.02 0.3± 0.03 0.3± 0.03 0.5± 0.05 100 pF 0.5± 0.05 Tape Width 8mm Tape Width 8mm NOTE Values in shaded cells indicate thickness class in mm www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ 16V to 500V NPO 6 13 CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 0603 to 0805 CAP. 0603 0805 50V 100V/250V CAP. 50V 100V/250V 0.1 pF 0.8± 0.1 0.8± 0.1 0.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.3 pF 0.8± 0.1 0.8± 0.1 0.4 pF 0.8± 0.1 0.5 pF 500V 0603 0805 50V 100V/250V 50V 100V/250V 500V 2.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.6± 0.1 0.85± 0.1 2.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 3.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 1.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 4.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 2.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 Tape Width 8mm Tape Width 8mm NOTE 1. Values in shaded cells indicate thickness class in mm www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors CAPACITANCE RANGE & THICKNESS FOR NP0 Table 5 Sizes from 0603 to 0805 CAP. 0603 0805 50V 100V/250V 50V 100V/250V CAP. 500V HiQ NPO 0603 16V to 500V 7 13 0805 50V 100V/250V 50V 100V/250V 500V 5.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 5.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 9.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 6.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 10 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 12 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 15 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.2 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 18 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.3 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 22 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.4 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 24 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.5 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 27 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.6 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 33 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.7 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 39 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.8 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 47 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 7.9 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 56 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.0 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 68 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 8.1 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 82 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 100 pF 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 Tape Width 8mm Tape Width 8mm NOTE 1. Values in shaded cells indicate thickness class in mm www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ NPO 16V to 500V 8 13 THICKNESS CLASSES AND PACKING QUANTITY Table 6 Ø 180 MM / 7 INCH Paper/PE Blister Ø 330 MM / 13 INCH Paper/PE Blister SIZE CODE THICKNESS CLASSIFICATION TAPE WIDTH QUANTITY PER REEL 01005 0.2 ± 0.02 mm 8 mm 20,000 --- 80,000 --- --- 0201 0.3 ± 0.03 mm 8 mm 15,000 --- 50,000 --- --- 0402 0.5 ± 0.05 mm 8 mm 10,000 --- 50,000 --- --- 0603 0.8 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- 0805 0.6 ± 0.1 mm 8 mm 4,000 --- 20,000 --- --- 0805 0.85 ± 0.1 mm 8 mm 4,000 --- 15,000 --- --- QUANTITY PER BULK CASE ELECTRICAL CHARACTERISTICS NP0 DIELECTRIC CAPACITORS; NISN TERMINATIONS Unless otherwise stated all electrical values apply at an ambient temperature of 20± 1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. Table 7 VALUE DESCRIPTION Capacitance range 0.1 pF to 100 pF Capacitance tolerance C < 10 pF ± 0.05 pF, ± 0.1 pF, ± 0.25 pF, ± 0.5 pF C ≥ 10 pF ± 1%, ± 2%, ± 5% C < 30 pF Q ≥ ( 400 + 20C ) Q value C: pF C ≥ 30 pF Q ≥ 1000 Insulation resistance after 1 minute at Ur (DC) Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): ± 30 ppm/°C Operating temperature range: –55 °C to +125 °C SOLDERING RECOMMENDATION Table 8 SOLDERING METHOD SIZE 01005 0201 0402 0603 0805 Reflow O O O O O Wave --- --- --- O O www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ NPO 16V to 500V 9 13 TESTS AND REQUIREMENTS Table 9 Test procedures and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 6038421/22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual inspection and dimension check 4.4 Any applicable method using × 10 magnification In accordance with specification Capacitance 4.5.1 Class 1: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C Within specified tolerance f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Q value 4.5.2 Class 1: f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 Vrms at 20 °C In accordance with specification f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Insulation resistance 4.5.3 At Ur (DC) for 1 minute In accordance with specification www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Temperature coefficient TEST METHOD 4.6 HiQ NPO 16V to 500V PROCEDURE REQUIREMENTS Capacitance shall be measured by the steps shown in the following table. Class1: ∆ C/C: ± 30ppm 10 13 The capacitance change should be measured after 5 min at each specified temperature stage. Step Temperature(°C) a 25± 2 b Lower temperature± 3°C c 25± 2 d Upper Temperature± 2°C e 25± 2 (1) Class I Temperature Coefficient shall be calculated from the formula as below C2 - C1 10 6 [ppm/°C] Temp, Coefficient = C1xΔT C1: Capacitance at step c C2: Capacitance at 125°C ∆T: 100°C (=125°C -25°C) Adhesion 4.7 A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate Force size ≥ 0603: 5N size = 0402: 2.5N size = 01005 / 0201: 1N Bending Strength 4.8 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 5 mm ∆C/C Measuring frequency: 1 ± 0.2GHz at room temperature. 0.2pF ≤ C ≤ 1pF : 350mΩ / C max ESR (0201 to 0805) NP0: within ± 1% or 0.5 pF whichever is greater 1pF < C ≤ 5pF : 300mΩ max 5pF < C ≤ 10pF : 250mΩ max C : Nominal cap (pF) Measuring frequency: 500 ± 50MHz at room temperature. 10pF < C ≤ 100pF :400mΩ max ESR (01005) Measuring frequency: 1 ± 0.2 GHz at room temperature. 0.2pF to 1pF: 700 mΩ /C max 1.1pF to 5pF: 500 mΩ max 5.1pF to 15pF: 300 mΩ max C: Nominal Cap. (pF) www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST TEST METHOD Resistance to IEC 60384soldering heat 21/22 4.9 HiQ NPO 16V to 500V 11 13 PROCEDURE REQUIREMENTS Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Preheating: for size >1206: 100 °C to 120 °C for 1 minute and 170 °C to 200 °C for 1 minute Solder bath temperature: 260 ± 5 °C Dipping time: 10 ± 0.5 seconds ∆C/C NP0: within ± 0.5% or 0.5 pF whichever is greater Recovery time: 24 ± 2 hours Q value within initial specified value Rins within initial specified value Solderability 4.10 Preheated the temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. The solder should cover over 95% of the critical area of each termination Test conditions for lead containing solder alloy Temperature: 235 ± 5 °C Dipping time: 2 ± 0.2 seconds Depth of immersion: 10 mm Alloy Composition: 60/40 Sn/Pb Number of immersions: 1 Test conditions for lead-free containing solder alloy Temperature: 245 ± 5 °C Dipping time: 3 ± 0.3 seconds Depth of immersion: 10 mm Alloy Composition: SAC305 Number of immersions: 1 Rapid change of temperature 4.11 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature No visual damage 5 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature NP0: within ± 1% or 1 pF whichever is greater ∆C/C Recovery time 24 ± 2 hours Q value meet initial specified value Rins meet initial specified value www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors TEST Damp heat with Ur load HiQ NPO 16V to 500V TEST METHOD PROCEDURE REQUIREMENTS IEC 6038421/22 1. Preconditioning, class 2 only: No visual damage after recovery 4.13 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C 3. Damp heat test: 500 ± 12 hours at 40 ± 2 °C; 90 to 95% R.H. 1.0 Ur applied 4. Recovery: Class 1: 6 to 24 hours 5. Final measure: C 12 13 ∆C/C NP0: within ± 7.5% or 0.75pF whichever is greater Q value: ≥30pF: Q ≥ 200 ≤30pF: Q ≥ 100+10C/3 I.R.: NP0: ≥ 500 MΩ or Rins x Cr ≥ 25s whichever is less P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be preconditioned according to “IEC 60384 4.1” and then the requirement shall be met. Endurance 4.14 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C 3. Endurance test: Temperature: NP0: 125 °C Specified stress voltage applied for 1,000 hours: Applied 2.0 x Ur for 16V to 100V product. Applied 1.5 x Ur for 200V to 250V product. Applied 1.3 x Ur for 500V product. 4. Recovery time: 24 ± 2 hours 5. Final measure: C No visual damage ∆C/C NP0: within ± 3% or 0.3pF whichever is greater Q value: ≥30pF: Q ≥ 350 10pF to 30pF: Q ≥ 275+5C/2 ≤10pF: Q ≥ 200+10C NP0: ≥ 1,000 MΩ or Rins x Cr ≥ 50Ω.F whichever is less P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be preconditioned according to “IEC 60384 4.1” and then the requirement shall be met. Voltage proof IEC 60384-1 4.6 Specified stress voltage applied for 1 minute Ur ≤ 100 V: series applied 2.5 Ur 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) Ur > 500 V: 1.3 Ur I: 7.5 mA No breakdown or flashover www.yageo.com May. 4, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors HiQ NPO 16V to 500V 13 13 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 17 May 04, 2022 - - Add 01005 0.1pF to 15pF, 16V to 25V capacitance range. Version 16 May 14, 2021 - - Add 0201 to 0603 0.1pF, 0201, 100V and 0805, 500V capacitance range Version 15 Mar.30, 2018 - - Add 0603/100V, 250V capacitance range Version 14 Feb. 14, 2018 - - Revised ESR requirements (0.2pF to 1pF) Version 13 Jul. 5, 2016 - - Add 0201/50V and 0402/100V, 250V Capacitance range Version 12 Feb. 23, 2016 - - Size update Version 11 Mar 19, 2014 - - Size update Version 10 Mar 19, 2014 - - Tests and requirements Version 9 Feb. 27, 2014 - - Tolerance update Version 8 Oct. 28, 2013 - - Rated voltage update Version 7 Oct. 09, 2013 - - Rated voltage update Version 6 Jun. 24, 2013 - - Tolerance update Version 5 Apr. 15, 2013 - - Tolerance update Version 4 Mar. 28, 2013 - - Capacitance range & thickness update Version 3 Feb. 07, 2013 - - Capacitance range & thickness update Version 2 Dec. 25, 2012 - - Capacitance range & thickness update Version 1 Dec. 03, 2012 - - Capacitance range & thickness update Version 0 Nov. 23, 2012 - - New datasheet for HiQ NP0 series with RoHS compliant www.yageo.com May. 4, 2022 V.17
CQ0402BRNPO9BNR50
物料型号:YAGEO的Hi Q系列NPO(非极性)多层陶瓷贴片电容器,符合RoHS标准,无卤素。
器件简介:这些电容器采用无铅端接,具有高Q值、低损耗、高电容稳定性,适用于多种电压范围(16V至500V)。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电容器为两端子电容器。
参数特性: - 电容值范围:0.1 pF至100 pF。 - 容差:根据电容值不同,容差从±0.05 pF至±5%不等。 - Q值:对于小于30 pF的电容,Q值≥(400+20C);对于30 pF及以上的电容,Q值≥1000。 - 绝缘电阻:在1分钟内,根据电容值不同,有不同的绝缘电阻要求。 - 温度特性:电容变化率为±30 ppm/°C。 - 工作温度范围:-55°C至+125°C。
功能详解:这些电容器具有高稳定性和低损耗的特点,适用于高频应用,如射频通信、信号处理等。
应用信息:适用于消费电子、电视接收器、调谐器、各种类型的相机、电信、数据处理等领域。
封装信息:提供多种尺寸,包括01005、0201、0402、0603和0805等,每种尺寸都有对应的厚度规格和卷带宽度。
测试和要求:包括安装、视觉检查、电容值测试、绝缘电阻测试、温度系数测试、附着力测试、弯曲强度测试、ESR测试等。
焊接建议:提供了回流焊和波峰焊的建议。
CQ0402BRNPO9BNR50 价格&库存
很抱歉,暂时无法提供与“CQ0402BRNPO9BNR50”相匹配的价格&库存,您可以联系我们找货
CQ0402BRNPO9BNR50
    CQ0402BRNPO9BNR50
    • 50+0.03828
    • 500+0.03480
    • 5000+0.03016
    • 30000+0.02900
    • 90000+0.02784
    库存:8089
    CQ0402BRNPO9BNR50
    • 10000+0.1358510000+0.01758
    • 20000+0.1257720000+0.01627
    • 30000+0.1207330000+0.01562
    • 50000+0.1151450000+0.01490
    • 70000+0.1118770000+0.01447
    • 100000+0.10872100000+0.01407
    库存:19585
