SOT-523 Plastic-Encapsulate Transistors
MMBT5401T
TRANSISTOR ( PNP)
SOT–523
FEATURES
Complementary to MMBT5551W
Small Surface Mount Package
Ideal for Medium Power Amplificationand Switching
MARKING:K4M
1. BASE
2. EMITTER
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-160
V
VCEO
Collector-Emitter Voltage
-150
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-600
mA
PC
Collector Power Dissipation
200
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
3. COLLECTOR
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-100µA, IE=0
-160
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-1mA, IB=0
-150
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10µA, IC=0
-5
V
Collector cut-off current
ICBO
VCB=-120V, IE=0
-50
nA
Emitter cut-off current
IEBO
VEB=-3V, IC=0
-50
nA
DC current gain
hFE
Collector-emitter saturation voltage
VCE(sat)
Base-emitter saturation voltage
VBE(sat)
Transition frequency
Collector output capacitance
fT
Cob
VCE=-5V, IC=-1mA
50
VCE=-5V, IC=-10mA
60
VCE=-5V, IC=-50mA
50
300
IC=-50mA, IB=-5mA
-0.5
V
IC=-10mA, IB=-1mA
-0.2
V
IC=-50mA, IB=-5mA
-1
V
IC=-10mA, IB=-1mA
-1
V
VCE=-10V,IC=-10mA , f=100MHz
VCB=-10V, IE=0, f=1MHz
1
100
MHz
6
pF
Typical Characteristics
h
Static Characteristic
-20
COMMON EMITTER
Ta=25℃
-0.08mA
-12
-0.07mA
-10
-0.06mA
-8
-0.05mA
FE
-0.09mA
-14
h
-16
-0.04mA
-6
-0.02mA
-2
-0
-1
-2
-3
-4
-5
COLLECTOR-EMITTER VOLTAGE
VBEsat
-1000
-6
VCE
-7
Ta=25℃
-1
-10
COLLECTOR CURRENT
IC
VCEsat
-10
COLLECTOR-EMITTER SATURATION
VOLTAGE V CEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
150
(V)
β=10
Ta=25℃
-600
T a=100℃
-400
-1
Ta=100℃
200
-800
-200
250
50
IB=-0.01mA
-0
300
100
-0.03mA
-4
-10
-100
VBE
T
(mA)
C
I
TRANSITION FREQUENCY f
COLLECTOR CURRENT
Ta=25℃
-1
-400
-600
-800
-1
-10
fT
-1000
Cob/ibC
Ta=25℃
100
10
1
-1
-1200
IC
COMMON EMITTER
VCE
= -10V
-10
BASE-EMMITER VOLTAGE VBE(mV)
100
-200
Ta =25℃
1000
-10
-0.1
-200
-100
IC
COLLECTOR CURRENT I (mA)
C
COMMON EMITTER
VCE
=-5V
Ta=100℃
-200
Ta=100℃
-0.1
(MHz)
-100
IC
-100
(mA)
-1
-0.01
-200
IC
β=10
C
-200
IC
COMMON EMITTER
VCE
=-5V
350
-0.1mA
DC CURRENT GAIN
COLLECTOR CURRENT
IC(mA)
-18
FE
400
-70
COLLECTOR CURRENT
VCB
/V
EB
PC
250
—— T
IC
(mA)
a
f=1MHz
IE=0/I C=0
COLLECTOR POWER DISSIPATION
PC(mW)
Ta=25℃
CAPACITANCE
C
(pF)
Cib
10
1
-0.1
Cob
-1
-10
200
150
100
50
REVERSE VOLTAGE V (V)
50
75
100
AMBIENT TEMPERATURE T (℃)
a
2
125
150
3
很抱歉,暂时无法提供与“MMBT5401T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11535
- 500+0.09018
- 3000+0.07269
- 6000+0.06437
- 24000+0.05703
- 51000+0.05314
- 国内价格
- 1+0.26510
- 200+0.08822
- 1500+0.05522
- 3000+0.04378
- 国内价格
- 1+0.07950
- 100+0.07420
- 300+0.06890
- 500+0.06360
- 2000+0.06095
- 5000+0.05936
- 国内价格
- 20+0.19240
- 100+0.11800
- 800+0.08020
- 3000+0.05730
- 6000+0.05440
- 30000+0.05030
