MMDT3052DW
MMDT3052DW
    CBI(创基)
    SOT-363
    塑料封装晶体管,双NPN
MMDT3052DW 数据手册
MMDT3052DW ( NPN+NPN) Silicon Epitaxial Planar Transistor Features • Each transistor elements are independent Applications • For low frequency amplify application MARKING: 5G Parameter Symbol Value Unit Collector Base Voltage VCBO 50 V Collector Emitter Voltage VCEO 50 V Emitter Base Voltage VEBO 6 V Collector Current IC 200 mA Power Dissipation Ptot 150 mW Tj 125 ℃ Tstg - 55 to + 125 ℃ Junction Temperature Storage Temperature Range Absolute Maximum Ratings (Ta = 25℃) Characteristics at Ta = 25 OC Parameter Symbol Min. Typ. Max. Unit hFE hFE hFE hFE 90 120 200 350 - 240 400 700 - Collector Base Cutoff Current at VCB = 50 V ICBO - - 100 nA Emitter Base Cutoff Current at VEB = 6 V IEBO - - 100 nA V(BR)CEO 50 - - V VCE(sat) - - 0.3 V fT - 200 - MHz Cob - 2.5 - pF DC Current Gain at VCE = 6 V, IC = 0.1 mA at VCE = 6 V, IC = 1 mA E F G Collector Emitter Breakdown Voltage at IC = 100 µA Collector Emitter Saturation Voltage at IC = 100 mA, IB = 10 mA Transition Frequency at VCE = 6 V, -IE = 10 mA Collector Output Capacitance at VCB = 6 V, f = 1 MHz 1 Electrical Characteristics Curves 2 3
MMDT3052DW 价格&库存
很抱歉,暂时无法提供与“MMDT3052DW”相匹配的价格&库存,您可以联系我们找货
MMDT3052DW
    • 10+0.19200
    • 50+0.17760
    • 200+0.16560
    • 600+0.15360
    • 1500+0.14400
    • 3000+0.13800
    MMDT3052DW
    • 10+0.28545
    • 100+0.22324
    • 300+0.19214
    • 3000+0.16546
    • 6000+0.14678
    • 9000+0.13738
    库存:2600
