Plastic-Encapsulate Transistors
SOT-363
DUAL TRANSISTOR (PNP+PNP)
FEATURES
Complementary to MMDT5551DW
Small Surface Mount Package
Ideal for Medium Power Amplificationand Switching
MARKING:2L
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-160
V
VCEO
Collector-Emitter Voltage
-150
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current
-600
mA
PC
Collector Power Dissipation
300
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-100µA, IE=0
-160
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-1mA, IB=0
-150
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10µA, IC=0
-5
V
Collector cut-off current
ICBO
VCB=-120V, IE=0
-50
nA
Emitter cut-off current
IEBO
VEB=-3V, IC=0
-50
nA
DC current gain
hFE
Collector-emitter saturation voltage
VCE(sat)
Base-emitter saturation voltage
VBE(sat)
Transition frequency
Collector output capacitance
fT
Cob
VCE=-5V, IC=-1mA
50
VCE=-5V, IC=-10mA
60
VCE=-5V, IC=-50mA
50
300
IC=-50mA, IB=-5mA
-0.5
V
IC=-10mA, IB=-1mA
-0.2
V
IC=-50mA, IB=-5mA
-1
V
IC=-10mA, IB=-1mA
-1
V
VCE=-10V,IC=-10mA , f=100MHz
100
VCB=-10V, IE=0, f=1MHz
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
MHz
6
pF
Typical Characteristics
hFE ——
Static Characteristic
COMMON EMITTER
Ta=25℃
(mA)
-16
IC
-14
-0.08mA
-12
-0.07mA
-10
-0.06mA
-8
-0.05mA
DC CURRENT GAIN
hFE
-0.09mA
-0.04mA
-6
-0.02mA
-2
300
250
Ta=100℃
200
150
Ta=25℃
100
-0.03mA
-4
COMMON EMITTER
VCE=-5V
350
-0.1mA
COLLECTOR CURRENT
-18
50
IB=-0.01mA
-0
-1
-2
-3
-4
-5
-6
COLLECTOR-EMITTER VOLTAGE
VBEsat
-1000
VCE
-7
-1
-8
COLLECTOR CURRENT
VCEsat ——
IC
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
Ta=25℃
Ta=100℃
-400
-200
-1
-10
-100
COLLECTOR CURRENT
IC
-200
IC
(mA)
IC
(mA)
-200
-100
-200
Ta=100℃
-0.1
Ta=25℃
-0.01
-200
-1
VBE
fT
1000
COMMON EMITTER
VCE=-5V
TRANSITION FREQUENCY
Ta=25℃
-1
-400
-600
-800
-1000
100
10
1
-1
-1200
VCB/ VEB
PC —— Ta
300
COLLECTOR POWER DISSIPATION
PC (mW)
f=1MHz
IE=0/IC=0
Ta=25℃
C
(pF)
Cib
10
Cob
REVERSE VOLTAGE
-10
V
(V)
-35
2 of 3
-70
-10
COLLECTOR CURRENT
100
-1
IC
Ta=25℃
BASE-EMMITER VOLTAGE VBE (mV)
Cob/ Cib ——
COMMON EMITTER
VCE= -10V
(MHz)
fT
(mA)
Ta=100℃
-10
COLLECTOR CURRENT
IC
COLLECTOR CURRENT
IC
-100
-1
(mA)
-10
1
-0.1
(mA)
β=10
-600
-0.1
-200
IC
IC
-10
-800
-100
-10
(V)
β=10
CAPACITANCE
IC
400
-20
250
200
150
100
50
75
AMBIENT TEMPERATURE
100
Ta
125
a
150
SOT-363-Package Outline Dimensions
3 of 3
很抱歉,暂时无法提供与“MMDT5401DW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.13760
- 50+0.12728
- 200+0.11868
- 600+0.11008
- 1500+0.10320
- 3000+0.09890
- 国内价格
- 10+0.23566
- 100+0.18555
- 300+0.15768
- 3000+0.12518
- 6000+0.11070
- 9000+0.10293
