MMDT4403DW
MMDT4403DW
    CBI(创基)
    SOT-363
    塑料封装晶体管,双PNP
MMDT4403DW 数据手册
Plastic-Encapsulate Transistors DUAL TRANSISTOR (PNP+PNP) SOT-363 FEATURES z Epitaxial Planar Die Construction z Ideal for Low Power Amplification and Switching MRKING:K2T Maximum Ratings (Ta=25℃ unless otherwise specified) Symbol Parameter Value Units VCBO Collector-Base Voltage -40 V VCEO Collector-Emitter Voltage -40 V VEBO Emitter-Base Voltage -5 V IC Collector Current -Continuous -0.6 A PC Collector Power Dissipation 0.2 W RθJA Thermal Resistance from Junction to Ambient 625 TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55 to +150 ℃ ℃/W ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Collector-base breakdown voltage V(BR)CBO IC=-100μA , Collector-emitter breakdown voltage V(BR)CEO IC= -1mA , Emitter-base breakdown voltage V(BR)EBO IE=-100μA, IE=0 Min Typ Max Unit -40 V IB=0 -40 V IC=0 -5 V Collector cut-off current ICBO VCB=-50V, IE=0 -0.1 μA Collector cut-off current ICEO VCE=-35V, IB=0 -0.5 μA Emitter cut-off current IEBO VEB=-5V, -0.1 μA hFE(1) VCE=-1V, IC= -0.1mA 30 hFE(2) VCE=-1V, IC= -1mA 60 hFE(3) VCE=-1 V, IC= -10mA 100 hFE(4) VCE=-2 V, IC= -150mA 100 hFE(5) VCE=-2 V, IC= -500mA 20 DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage IC=0 300 VCE(sat)1 IC=-150 mA, IB=-15mA -0.4 V VCE(sat)2 IC=-500 mA, IB=-50mA -0.75 V VBE(sat)1 IC= -150 mA, IB=-15mA -0.95 V VBE(sat)2 IC= -500 mA, IB=-50mA -1.3 V -0.75 Transition frequency fT VCE= -10V, IC=-20mA,f = 100MHz Output capacitance Cob VCB=-10V, IE=0,f=1MHz 8.5 pF VCC=-30V, VBE=-2V,IC=-150mA , IB1=-15mA 15 nS Delay time td Rise time tr Storage time tS Fall time tf 200 VCC=-30V, IC=-150mA B1=- IB2= -15mA 1 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MHz 20 nS 225 nS 30 nS Typical Characteristics 1000 -1mA COMMON EMITTER Ta=25℃ -150 -900uA Ta=100℃ -800uA (mA) -120 -600uA -90 -500uA hFE -700uA -400uA -60 -300uA -30 100 DC CURRENT GAIN IC COLLECTOR CURRENT —— IC hFE Static Characteristic -180 Ta=25℃ 10 -200uA COMMON EMITTER VCE=-2V IB=-100uA -0 -0 -1 -2 -3 COLLECTOR-EMITTER VOLTAGE VCEsat —— VCE -1 (V) -10 -100 COLLECTOR CURRENT VBEsat IC IC —— -100 Ta=100℃ Ta=25℃ -10 IC -1 -10 -100 COLLECTOR CURRENT IC IC Ta=25℃ -1000 β=10 -1 -0.1 Ta=100℃ β=10 -100 -0.1 -600 -1 -10 -100 COLLECTOR CURRENT (mA) —— VBE Cob/ Cib 100 -600 IC —— VCB/ VEB f=1MHz IE=0/ IC=0 (pF) (mA) CAPACITANCE Ta=100℃ Ta=25℃ -1 -0.1 -0.0 -0.2 Cob C IC COLLECTOR CURRENT Ta=25℃ Cib -100 -10 -0.4 -0.6 -0.8 -1.0 10 1 -0.1 -1.2 -1 BASE-EMMITER VOLTAGE VBE (V) fT —— -10 REVERSE VOLTAGE IC Pc 250 fT COLLECTOR POWER DISSIPATION Pc (mW) (MHz) 1000 -600 (mA) COMMON EMITTER VCE=-2V TRANSITION FREQUENCY -600 (mA) -5000 BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) -1000 1 -0.1 100 COMMON EMITTER VCE=-10V —— V -20 (V) Ta 200 150 100 50 Ta=25℃ 0 10 -1 -10 COLLECTOR CURRENT j-elec.com www.c -100 IC 0 (mA) 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃ ) 2 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.  SOT-363-Package Outline Dimensions 3 of 3 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
MMDT4403DW
物料型号:文档中没有明确提到物料型号,但提到了“MRKING:K2T”,这可能是型号的一部分。
器件简介:文档描述了一种塑料封装的双三极管(PNP+PNP),采用外延平面芯片结构,适用于低功耗放大和开关。
引脚分配:文档中提到了SOT-363封装,引脚分配为5(基极)、2(发射极)、3(集电极)。
参数特性: - 集电极-基极电压(VcBO):-40V - 集电极-发射极电压(VCEO):-40V - 发射极-基极电压(VEBO):-5V - 集电极电流(Ic):-0.6A - 集电极功耗(Pc):0.2W - 从结到环境的热阻(ROJA):625°C/W - 结温(TJ):150°C - 存储温度(Tstg):-55至+150°C
功能详解: - 直流电流增益(hFE)在不同条件下的典型值分别为30、60、100、100、20。 - 集电极-发射极饱和电压(VCE(sat))在不同条件下的典型值分别为-0.4V和-0.75V。 - 基极-发射极饱和电压(VBE(sat))在不同条件下的典型值分别为-0.75V和-1.3V。 - 过渡频率(fr):200MHz - 输出电容(Cab):8.5pF - 延迟时间(td)、上升时间(t)、存储时间(ts)、下降时间(tr)的典型值分别为15ns、20ns、225ns、30ns。
应用信息:文档没有提供具体的应用信息,但提到该器件适用于低功耗放大和开关。
MMDT4403DW 价格&库存
很抱歉,暂时无法提供与“MMDT4403DW”相匹配的价格&库存,您可以联系我们找货
MMDT4403DW
    • 20+0.23490
    • 200+0.18479
    • 600+0.15693
    • 3000+0.12345
    • 9000+0.10898
    • 21000+0.10120
    库存:2010
    MMDT4403DW
      • 10+0.13760
      • 50+0.12728
      • 200+0.11868
      • 600+0.11008
      • 1500+0.10320
      • 3000+0.09890
