UM3352EESA
UM3352EESA
    UNION(英联)
    SOP-8
    ±15kV ESD保护、转换速率受限、故障安全、真正的RS-485收发器
UM3352EESA 数据手册
UM3352E ±15kV ESD-Protected, Slew-Rate-Limited, Fail-Safe, True RS-485 Transceivers UM3352E SOP8/DIP8 General Description The UM3352E series are ±15kV ESD-protected, high-speed, half-duplex transceivers for RS-485 communication that contain one driver and one receiver. The device features fail-safe circuitry, which guarantees a logic-high receiver output when the receiver inputs are open, shorted or idle. This means that the receiver output will be logic high if all transmitters on a terminated bus are disabled (high impedance). The UM3352E features reduced slew-rate driver that minimizes EMI and reduces reflections caused by improperly terminated cables, allowing error-free data transmission up to 500kbps. It also features enhanced ESD protection. All transmitter outputs and receiver inputs incorporate advanced structures allowing them to survive ESD events in excess of ±15kV Human Body Mode and IEC61000-4-2 Air Discharge Mode, ±8kV IEC61000-4-2 Contact Discharge Mode. New ESD structures protect the device whether or not it is powered up and without degrading the RS-485 common mode range of -7V to 12V. The UM3352E includes a hot swap circuit inside, which allows live cable insertion and removal. Proprietary protection circuit built on A and B ports, can dissipate high surge current up to 6A to ground. The transceivers typically draw 450μA of supply current when unloaded, or when fully loaded with the drivers disabled. The device has a 1/8-unit-load receiver input impedance that allows up to 256 transceivers on the bus and are intended for half-duplex communications. Applications Features        RS-485 Transceivers Intelligent Meters and Sensors Industrial Control Lighting Systems Security Systems HVAC Application         ESD Protection for RS-485 I/O Pins ±15kV—Human Body Mode ±15kV—IEC61000-4-2, Air Discharge Mode ±8kV—IEC61000-4-2, Contact Discharge Mode True Fail-Safe Receiver Enhanced Slew-Rate Limiting Facilitates Error-Free Data Transmission 2µA Low-Current Shutdown Mode -7V to +12V Common-Mode Input Voltage Range Allows up to 256 Transceivers on the Bus Thermal Shutdown Current-Limiting for Driver Overload Protection Hot Swap Capability Ordering Information Part Number Operating Temperature Mark Code Package Type UM3352EESA -40°C to +85°C UM3352EESA SOP8 UM3352EEPA -40°C to +85°C UM3352EEPA DIP8 Shipping Qty 3000pcs/13 Inch Tape & Reel 50pcs/Tube Device Electrical Characteristic Summary Part Number UM3352E Guaranteed Date Rate (Mbps) 0.5 Low-Power Shutdown Slew-Rate Limited Yes Yes Driver/ Receiver Enable Yes Shutdown Current (µA) 2 Transceivers On Bus 256 ±15kV ESD Protection Yes __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 1/14 UM3352E Pin Configurations Top View RO 1 8 VCC RE 2 7 B DE 3 6 A DI 4 5 GND XX: Week Code UM3352EESA SOP8 RO 1 8 VCC RE 2 7 B DE 3 6 A DI 4 5 GND XX: Week Code UM3352EEPA DIP8 Pin Description Pin Number Symbol 1 RO 2 ______ RE Function Receiver Output. If A>B by -50mV, RO will be high; if A<B by 200mV, RO will be low. ______ Receiver Output Enable. Drive RE low to______ enable Receiver, RO is ______ high impedance when RE is high. Drive RE high and DE low to enter low-power shutdown mode. Driver Enable. Drive DE high to enable ______drivers. The outputs are high impedance when DE is low. Drive RE high and DE low to enter low-power shutdown mode. Driver Input. A low on DI forces output A low and output B high. Similarly, a high on DI forces output A high and output B low. Ground. 3 DE 4 DI 5 GND 6 A Non-Inverting Receiver Input and Non-Inverting Driver Output. 7 B Inverting Receiver Input and Inverting Driver Output. 8 VCC Power Supply for RS-485 Transceiver. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 2/14 UM3352E Absolute Maximum Ratings Symbol Parameter Value Unit VCC Supply Voltage +7 V Control Input Voltage (R E , DE) -0.3V to (VCC + 0.3V) V Driver Input Voltage (DI) -0.3V to (VCC + 0.3V) V Driver Output Voltage (A, B) -7.5 to +12.5 V Receiver Input Voltage (A, B) -7.5 to +12.5 V Receiver Output Voltage (RO) -0.3V to (VCC + 0.3V) V TA Ambient Temperature -40 to +85 °C TSTG Storage Temperature Range -65 to +160 °C TL Lead Temperature for Soldering 10 seconds +300 °C ______ DC Electrical Characteristics (VCC=+5V ± 5%, TA=-40°C to +85°C, unless otherwise noted. Typical values are at VCC=+5V and TA =+25°C.) (Note 1) Parameter Symbol Test Conditions Min Typ Max Unit SUPPLY CURRENT Supply Current Supply Current in Shutdown Mode ICC ISHDN No Load, DI=GND or VCC DE=VCC, R E =0V or VCC 0.45 DE=0V, ______ R E =0V 0.45 ______ mA ______ DE = GND, R E = VCC µA 2 LOGIC Input High Voltage Input Low Voltage VIH VIL ______ DE, DI, R E V 2.0 ______ DE, DI, R E ______ Input Hysteresis VHYS DE, DI, R E Input Leakage Current ILEAK DE, DI, R E 0.8 V mV 100 ______ ±2 µA 5 V DRIVER Differential Driver Output VOD1 No Load, Figure 2 Differential Driver Output VOD2 Figure 2, RLOAD=50Ω Change-in-Magnitude of Differential Output Voltage ΔVOD Figure 2, RLOAD=50Ω (Note 2) 0.2 V Driver Common-Mode Output Voltage VOC Figure 2, RLOAD=50Ω 3.0 V Change-in-Magnitude of Common-Mode Voltage ΔVOC Figure 2, RLOAD=50Ω (Note 2) 0.2 V Driver Short-Circuit Output Current (Note 3) IOSD 1.5 V VOUT=-7V -250 VOUT=12V 250 mA __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 3/14 UM3352E DC Electrical Characteristics (Continued) (VCC=+5V ± 5%, TA=-40°C to +85°C, unless otherwise noted. Typical values are at VCC=+5V and TA=+25°C.) (Note 1) Parameter Symbol Test Conditions Min -200 Typ Max Unit -50 mV RECEIVER Receiver Differential Threshold Voltage VTH -7V≤VCM≤12V Receiver Input Hysteresis ΔVTH VCM=0V Receiver Input Resistance RIN -7V≤VCM≤12V Input Current (A and B) IIN2 DE=GND, VCC=GND or 5V 25 mV 96 kΩ VIN=12V 1.0 VIN=-7V -0.8 mA VCC -1.5 V Receiver Output High Voltage VOH IO=-1.5mA, VID=+200mV Receiver Output Low Voltage VOL IO=2.5mA, VID=-200mV 0.4 V Three-State Output Current at Receiver IOZR VCC=5V, 0V≤VO≤VCC ±1 µA Receiver Output Short Circuit Current IOSR 0V≤VRO≤VCC ±60 mA ±8 ESD Protection ESD Protection for A, B Human Body Mode IEC61000-4-2 Air Discharge Mode IEC61000-4-2 Contact Discharge Mode ±15 ±15 kV ±8 Note 1: All currents into the device are positive; all currents out of the device are negative. All voltages are referred to device ground unless otherwise noted. Note 2: ΔVOD and ΔVOC are the changes in VOD and VOC, respectively, when the DI input changes state. Note 3: Maximum current level applies to peak current just prior to fold back current limiting; minimum current level applies during current limiting. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 4/14 UM3352E Switching Characteristics (VCC=+5V ± 5%, TA=-40°C to +85°C, unless otherwise noted. Typical values are at VCC=+5V and TA=+25°C.) Parameter Maximum Data Rate Driver Input-to-Output Symbol fMAX tDPLH tDPHL Test Conditions Figures 3 and 7, RDIFF=54Ω, CL1=CL2=100pF Min Typ 500 50 Max 1000 50 1000 Unit kbps ns Driver Output Skew | tDPLH - tDPHL | tDSKEW Figures 3 and 7, RDIFF=54Ω, CL1=CL2=100pF 15 100 ns Driver Rise or Fall Time tDR, tDF Figures 3 and 7, RDIFF=54Ω, CL1=CL2=100pF 100 750 ns Driver Enable to Output High tDZH Figures 4 and 8, CL=100pF, S2 Closed 30 2500 ns Driver Enable to Output Low tDZL Figures 4 and 8, CL=100pF, S1 Closed 30 2500 ns Driver Disable Time from Low tDLZ Figures 4 and 8, CL=15pF, S1 Closed 60 200 ns Driver Disable Time from High tDHZ Figures 4 and 8, CL=15pF, S2 Closed 100 200 ns Receiver Input to Output tRPLH, tRPHL |VID| ≥2.0V, Rise and Fall Time of VID≤ 1 5ns 75 200 ns tRSKD Figures 6 and 9, |VID| ≥2.0V, Rise and Fall Time of VID≤ 1 5ns 0 30 ns tRZL Figures 5 and 10, CL=100pF, S1 Closed 20 50 ns Receiver Enable to Output High tRZH Figures 5 and 10, CL=100pF, S2 Closed 20 50 ns Receiver Disable Time from Low tRLZ Figures 5 and 10, CL=100pF, S1 Closed 20 50 ns Receiver Disable Time from High tRHZ Figures 5 and 10, CL=100pF, S2 Closed 20 50 ns Time to Shutdown tSHDN (Note 4) 200 600 ns Driver Enable from Shutdown to Output High tDZH(SHDN) Figures 4 and 8, CL=15pF, S2 Closed 700 4500 ns Driver Enable from Shutdown to Output Low tDZL(SHDN) Figures 4 and 8, CL=15pF, S1 Closed 700 4500 ns Receiver Enable from Shutdown to Output High tRZH(SHDN) 700 3500 ns Receiver Enable from Shutdown to Output Low tRZL(SHDN) 700 3500 ns Differential Receiver Skew | tRPLH - tRPHL | Receiver Enable to Output Low Figures 5 and 10, CL=100pF, S2 Closed Figures 5 and 10, CL=100pF, S1 Closed ______ Note 4: The device is put into shutdown by bringing RE high and DE low. If the enable inputs are in this state for less than 50ns, the device is guaranteed not to enter shutdown. If the enable inputs are in this state for at least 600ns, the device is guaranteed to have entered shutdown. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 5/14 UM3352E Typical Operating Characteristics (VCC=+5.0V, TA=+25ºC, unless otherwise noted.) DriverDifferential Differential Output Temperature Driver OutputVoltage Voltagevs. vs. Temperature DI=1, RLOAD =54Ω RLOAD =54Ω Supply vs. Temperature Temperature SupplyCurrent Current vs. 0.50 Driver Differential Output Voltage (V) Supply Current (mA) 0.55 DE=0, RE=0 DE=0, /RE=0 0.45 DE=1, RE=1 DE=1, /RE=1 0.40 0.35 0.30 -50 -25 0 25 50 Temperature (℃ ) 75 4.95 4.9 4.85 4.8 A B Short-Circuit Current (mA) 90 0 25 50 Temperature (℃ ) 75 2.45 2.4 2.35 2.3 2.25 2.2 2.15 2.1 -50 -25 0 25 50 Temperature (℃ ) 75 100 Receiver vs.Temperature Temperature ReceiverOutput OutputLow Low Voltage Voltage vs. Receiver Output Low Voltage (mV) Receiver Output High Voltage (V) 5 -25 2.5 100 Receiver vs.Temperature Temperature ReceiverOutput Output High High Voltage Voltage vs. -50 2.55 0.06 0.05 0.04 0.03 0.02 0.01 0 100 -50 Short-Circuit Current Current vs. AABBShort-Circuit vs.Temperature Temperature DI=1 -25 0 25 50 Temperature (℃ ) 75 100 A B Pin I-V Snap Back Characteristic 80 70 60 VCLAMP 10V/div VSB 50 40 30 ISURGE 20 5A/div ISB 5µs/div 10 0 -50 -25 0 25 50 Temperature (℃ ) 75 100 __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 6/14 UM3352E Typical Operating Characteristics (Continued) (VCC=+5.0V, TA=+25ºC, unless otherwise noted.) Receiver Propagation Delay RL=54Ω, CL=100pF Transmitter Propagation Delay RL=54Ω, CL=100pF A-B DI 2V/div 2V/div A-B 2V/div RO 400ns/div 2V/div 400ns/div RS-485 Communication Function Table Table1. Transmitting INPUTS RE DE X 1 X 1 0 0 1 0 X=Don’t care; High-Z=High impedance ______ OUTPUTS DI 1 0 X X B 0 1 High-Z A 1 0 High-Z Shutdown Table2. Receiving INPUTS RE DE 0 X 0 X 0 X 1 1 1 0 X=Don’t care; High-Z=High impedance ______ A-B ≥-50mV ≤-200mV Open/Shorted X X OUTPUTS RO 1 0 1 High-Z Shutdown __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 7/14 UM3352E Typical Operating Circuit 120ohm 120ohm B DI DE B B D D A DE A A B RO RE A B A R RO RE R Master Node D DI R DI Terminal Slave Node R D DE RO RE Slave Node1 DI DE RO RE Slave Node N Figure 1. Typical Half-Duplex RS-485 Network Test Circuit B 3V DE RLOAD/2 CL2 A DI VOD2 RDIFF B VOD CL1 RLOAD/2 VOC A Figure 2. Driver DC Test Load Driver Output Under Test CL 500ohm S1 Figure 3. Driver Timing Test Circuit VCC CRL 15pF + 1K Test Point Receive Output S1 + VCC 1K S2 S2 Figure 4. Driver Enable/Disable Timing Test Load Figure 5. Receiver Enable/Disable Timing Test Load Figure 6. Receiver Propagation Delay Test Circuit __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 8/14 UM3352E Figure 7. Driver Propagation Delays Figure 9. Receiver Propagation Delays Figure 8. Driver Enable and Disable Times Figure 10. Receiver Enable and Disable Times Detail Description The UM3352E high-speed transceivers for RS-485 communication contain one driver and one receiver. The device features fail-safe circuitry, which guarantees a logic-high receiver output when the receiver input is open or shorted, or when it is connected to a terminated transmission line with all drivers disabled. The UM3352E features reduced slew-rate driver that minimizes EMI and reduces reflections caused by improperly terminated cables, allowing error-free data transmission up to 500kbps. It operates from a single +5V supply. Drivers are output short-circuit current limited. Thermal shutdown circuitry protects drivers against excessive power dissipation. When activated, the thermal shutdown circuitry places the driver outputs into a high impedance state. Fail-Safe The UM3352E guarantees a logic-high receiver output when the receiver inputs are shorted or open, or when they are connected to a terminated transmission line with all drivers disabled. This is done by setting the receiver threshold between -50mV and -200mV. If the differential receiver input voltage (A-B) is greater than or equal to -50mV, RO is logic high. If A-B is less than or equal to -200mV, RO is logic low. In the case of a terminated bus with all transmitters disabled, the receiver’s differential input voltage is pulled to 0V by the termination. With the receiver thresholds of the UM3352E, this results in a logic high with a 50mV minimum noise margin. Unlike previous fail-safe devices, the -50mV to -200mV threshold complies with the ±200mV EIA/TIA-485 standard. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 9/14 UM3352E Applications Information 256 Transceivers on the Bus The standard RS-485 receiver input impedance is 12kΩ (one unit load), and the standard driver can drive up to 32 unit loads. The Union family of transceivers have a 1/8 unit load receiver input impedance (96kΩ), allowing up to 256 transceivers to be connected in parallel on one communication line. Any combination of these devices, as well as other RS-485 transceivers with a total of 32 unit loads or fewer, can be connected to the line. Reduced EMI and Reflections The UM3352E is slew-rate limited, minimizing EMI and reducing reflections caused by improperly terminated cables. In general, a transmitter’s rise time relates directly to the length of an unterminated stub, which can be driven with only minor waveform reflections. The following equation expresses this relationship conservatively: Length=tRISE/(10×1.5ns/ft) Where tRISE is the transmitter’s rise time. A system can work well with longer unterminated stubs, even with severe reflections, if the waveform settles out before the receiver’s UART samples them. Low-Power Shutdown Mode ______ Low-power shutdown mode is initiated by bringing______ both R E high and DE low. In shutdown, the device typically draws only 2µA of supply current. R E and DE may be driven simultaneously; the ______ parts are guaranteed not to enter shutdown if R E is high and DE is low for less than 50ns. If the inputs are in this state for at least 600ns, the parts are guaranteed to enter shutdown. Enable times tZH and tZL in the Switching Characteristics tables assume the part was not in a low-power shutdown state. Enable times tZH(SHDN) and tZL(SHDN) assume the parts were shut down. It takes drivers and receivers longer to become enabled from low-power shutdown mode (tZH(SHDN), tZL(SHDN)) than from driver/receiver-disable mode (tZH, tZL). Driver Output Protection Two mechanisms prevent excessive output current and power dissipation caused by faults or by bus contention. The first, a foldback current limit on the output stage, provides immediate protection against short circuits over the whole common-mode voltage range. The second, a thermal shutdown circuit, forces the driver outputs into a high-impedance state if the die temperature becomes excessive. Line Length vs. Data Rate The RS-485/RS-422 standard covers line lengths up to 4000 feet. For line lengths greater than 4000 feet, repeater is required. ESD Protection All pins on these devices include class 2 (>2kV) Human Body Model (HBM) ESD protection structures, but the RS-485 pins (driver outputs and receiver inputs) incorporate advanced structures allowing them to survive ESD events in excess of ±15kV HBM, ±15kV IEC61000-4-2 Air Discharge Mode and ±8kV IEC61000-4-2 Contact Discharge Mode. The RS-485 pins are particularly vulnerable to ESD strikes because they typically connect to an exposed port on the exterior of the finished product. Simply touching the port pins, or connecting a cable, can cause an ESD event that might destroy unprotected ICs. These new ESD structures protect the device whether or not it is powered up, and without degrading the RS-485 common mode range of -7V to +12V. This built-in ESD protection cuts the need for board level protection structures (e.g., transient suppression diodes), and the associated, undesirable capacitive load they present. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 10/14 UM3352E IEC61000-4-2 Testing The IEC61000 test method applies to finished equipments, rather than to an individual IC. Therefore, the pins most likely to suffer an ESD event are those that are exposed to the outside world (the RS-485 pins in this case), and the IC is tested in its typical application configuration (power applied) rather than testing each pin-to-pin combination. The IEC61000 standard’s lower current limiting resistor coupled with the larger charge storage capacitor yields a test that is much more severe than the HBM test. Air-Gap Discharge Test Method For this test method, a charged probe tip moves toward the IC pin until the voltage arcs to it. The current waveform delivered to the IC pin depends on approach speed, humidity, temperature, etc., so it is difficult to obtain repeatable results. The UM3352E RS-485 pins withstand ±15kV air-gap discharges. Contact Discharge Test Method During the contact discharge test, the probe contacts the tested pin before the probe tip is energized, thereby eliminating the variables associated with the air-gap discharge. The result is a more repeatable and predictable test, but equipment limits prevent testing devices at voltages higher than ±8kV. The RS-485 pins of all the UM3352E versions survive ±8kV contact discharges. Typical Applications The UM3352E transceivers are designed for bidirectional data communications on multipoint bus transmission lines. To minimize reflections, the line should be terminated at both ends in its characteristic impedance, and stub lengths of the main line should be kept as short as possible. __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 11/14 UM3352E Package Information UM3352EESA SOP8 Outline Drawing D c Symbol 1 2 θ e Top View End View b Side View A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.35 1.55 1.75 0.053 0.061 0.069 0.10 0.25 0.004 0.010 1.25 1.65 0.049 0.065 0.30 0.51 0.012 0.020 0.15 0.25 0.006 0.010 4.70 4.90 5.10 0.185 0.193 0.200 3.80 3.90 4.00 0.150 0.154 0.157 5.80 6.00 6.20 0.228 0.236 0.244 1.27BSC 0.050 BSC 0.40 1.27 0.016 0.050 0° 8° 0° 8° Land Pattern 1.27 0.60 NOTES: 1. Compound dimension: 4.90×3.90; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 12/14 UM3352E UM3352EEPA DIP8 Outline Drawing Symbol A A1 A2 b b1 c D E E1 E2 e L DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 3.71 4.80 0.146 0.189 0.38 0.015 3.20 3.40 3.60 0.126 0.134 0.142 0.38 0.57 0.015 0.022 1.52BSC 0.060BSC 0.20 0.28 0.36 0.008 0.011 0.014 9.00 9.20 9.50 0.354 0.362 0.374 6.20 6.40 6.60 0.244 0.252 0.260 7.32 7.92 0.288 0.312 8.40 9.05 0.331 0.356 2.54TYP 0.100TYP 3.00 3.30 3.60 0.118 0.130 0.142 __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 13/14 UM3352E GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No. 570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com __________________________________________________________________________ http://www.union-ic.com Rev.10 May.2020 14/14
UM3352EESA 价格&库存
很抱歉,暂时无法提供与“UM3352EESA”相匹配的价格&库存,您可以联系我们找货
