2N7002KT
N-Channel Enhancement Mode Field Effect Transistor
Product Summary
● VDS
60V
● ID
100mA
● RDS(ON)( at VGS=10V)
<8.0 Ω
● RDS(ON)( at VGS=4.5V)
<13.0 Ω
● ESD Protected Up to 2.0KV (HBM)
General Description
● Trench Power LV MOSFET technology
● High Power and current handing capability
Applications
SOT-523
● Load/Power Switching
● Interfacing Switching
● Logic Level Shift
■ Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Drain-source Voltage
VDS
60
V
Gate-source Voltage
VGS
±20
V
Drain Current
ID
100
mA
Pulsed Drain Current A
IDM
1.5
A
Total Power Dissipation @ TA=25℃
PD
0.15
W
RθJA
357
℃/ W
TJ ,TSTG
-55~+150
Thermal Resistance Junction-to-Ambient @ Steady State
Junction and Storage Temperature Range
www.slkormicro.com
1
Unit
2N7002KT
■ Electrical Characteristics (TJ=25℃ unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Units
Drain-Source Breakdown Voltage
BVDSS
VGS= 0V, ID=250μA
60
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
IGSS
VGS= ±20V, VDS=0V
±10
μA
Gate Threshold Voltage
VGS(th)
VDS= VGS, ID=250μA
1.5
2.2
V
VGS= 10V, ID=100mA
2.5
8.0
Static Drain-Source On-Resistance
RDS(ON)
VGS= 4.5V, ID=10mA
3.0
13.0
Static Parameter
Gate-Body Leakage Current
Diode Forward Voltage C
0.8
V
Ω
1.2
V
IS
100
mA
Input Capacitance
Ciss
18
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Maximum Body-Diode Continuous Current
VSD
IS=100mA,VGS=0V
Dynamic Parameters B
VDS=30V,VGS=0V,f=1MHZ
12
pF
7
Switching Parameters B
Total Gate Charge
Qg
1.7
Gate Source Charge
Qgs
Gate Drain Charge
Qgd
0.27
Turn-on Delay Time
tD(on)
5
VGS=10V,VDS=30V,ID=0.1A
0.19
VGS=10V,VDD=30V,RG=6Ω,ID=0.1A
Turn-off Delay Time
A. Repetitive Rating: Pulse width limited by maximum junction temperature.
B. These parameters have no way to verify.
C. Pulse Test: Pulse Width≤300us, Duty Cycle≤0.5%.
www.slkormicro.com
ns
17
tD(off)
2
nC
2N7002KT
■ Typical Performance Characteristics
Figure1. Output Characteristics
Figure2. Transfer Characteristics
Figure3. Capacitance Characteristics
Figure4. Gate Charge
Figure5. Drain-Source on Resistance
www.slkormicro.com
Figure6. Drain-Source on Resistance
3
2N7002KT
Figure7. Safe Operation Area
Figure8. Switching wave
■SOT-523 Package Outline Dimensions
www.slkormicro.com
4
很抱歉,暂时无法提供与“2N7002KT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20701
- 300+0.16850
- 1200+0.14711
- 3000+0.10860
