PMEG4020EP
2 A low VF MEGA Schottky barrier rectifier
SOD-123FL
Features
0.8±0.2
2.8±0.1
0.10-0.30
1.8± 0.1
Metal to silicon rectifier, majority
carrier conduction.
For use in low voltage, high
frequency inverters free
wheeling, and polarity
protection applications.
Low power loss, high efficiency.
High current capability, low VF.
High surge capacity.
Glass passivated
1.3± 0.15
Cathode Band
Top View
0.6±0.25
3.7±0.2
Dimensions in millimeters
Schottky Rectifiers
Absolute Maximum Ratings*
TA = 25°C unless otherwise noted
CHARACTERISTICS
SYMBOL
PMEG4020EP
UNIT
Maximum Recurrent Peak Reverse Voltage
VRRM
40
V
Maximum RMS Voltage
VRMS
28
V
VDC
40
V
Maximum DC Blocking Voltage
Maximum Average Forward
Rectified Current
Peak Forward Surage Current
@TL=100 ℃
8.3ms Single Half Sine-Wave
Super Imposed On Rated Load (JEDEC Method)
Maximum Forward Voltage at 2.0A DC
Maximum DC Reverse Current
@TJ=25℃
at Rated DC Blocking Voltage
@TJ=100℃
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Operating Temperature Range
Storage Temperature Range
www.slkormicro.com
I(AV)
2.0
A
IFSM
60
A
VF
0. 45
0.5
0.55
0.7
0.85
1.0
IR
0.95
V
mA
CJ
200
pF
RθJL
15
℃/W
TJ
-55 to +150
TSTG
-55 to + 150
1
PMEG4020EP
FIG.2 -- TYPICAL FORWARD CHARACTERISTICS
T L =100℃
(JED E C M ethod)
40
30
10
10 0
10
1
SS
25
A~
SS
SS
26
A
28
A~
SS
22
0A
50
100
SS
22A
~S
S2
4A
INSTANTANEOUS FORWARD
CURRENT,AMPERES
PEAK FORWARD SURGE
CURRENT,AMPERES
FIG.1-- PEAK FORWARD SURGE CURRENT
0.1
0.01
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
.2
.3
.4
.5
.6
.7
.8
.9
NUMBER OF CYCLES AT 60Hz
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
INSTANTANEOUS REVERSE
CURRENT,MICRO AMPERES
FIG.3 -- TYPICAL REVERSE CHARACTERISTICS
10
1.0
SS28-SS210
0.1
0.01
0.001
0.001
TJ=125℃
SS22-SS26
SS28-SS210
T J=25℃
SS22-SS26
60
80
1 00
PERCENT OF RATED PEAK REVERSE VOLTAGE,
www.slkormicro.com
2
很抱歉,暂时无法提供与“PMEG4020EP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07968
- 200+0.06412
- 600+0.05635
- 3000+0.05052
- 9000+0.04585
- 21000+0.04352
- 国内价格
- 20+0.23354
- 300+0.18602
- 1200+0.16226
- 3000+0.14444
