ENS160
Digital Metal Oxide Multi-Gas Sensor
ENS160 Datasheet
Revision:
0.95
Release Date:
December 2020
Document Status: Preliminary / Pre-Production
Digital Metal-Oxide Multi-Gas Sensor
The ENS160 is a digital multi-gas sensor solution, based on metal oxide (MOX) technology
with four MOX sensor elements. Each sensor element has independent hotplate control to
detect a wide range of gases e.g. volatile organic compounds (VOCs) including ethanol,
toluene, as well as hydrogen and nitrogen dioxide with superior selectivity and accuracy.
For indoor air quality applications, the ENS160 supports intelligent algorithms to digitally
process raw sensor measurements on-chip. These algorithms calculate CO2-equivalents,
TVOC, air quality indices (AQIs) and perform humidity and temperature compensation, as
well as baseline management – all on chip! Moreover, a development option is available
to digitally output raw sensor measurements from each sensor element for customization.
The LGA-packaged device includes an SPI or I²C slave interface with separate VDDIO to
communicate with a main host processor. The ENS160 is a proven and maintenance-free
technology, designed for high volume and reliability.
Key Features & Benefits
Applications
TrueVOC™ air quality detection with industry-leading purity and stability, providing multiple outputs e.g. eCO21, TVOC and
AQIs2 in compliance with worldwide IAQ3signal standards
Independent sensor heater control for
highest selectivity (e.g. to ethanol, toluene, acetone, NO2) and outstanding background discrimination
Building Automation / Smarthome /
HVAC6
o Indoor air quality detection
o Demand-controlled ventilation
o Smart thermostats
Home appliances
o Cooker hoods
o Air cleaners / purifiers
IoT devices
Immunity to siloxanes and humidity4
Properties
Hassle-free on-chip heater drive control
and data processing – no need for external
libraries – no mainboard-CPU performance
impacts
Interrupt on threshold for low-power applications
Small-3 x 3 x 0.9mm LGA package
Design-flexibility through standard,
fast and fast mode plus I2C- and SPIinterfaces with separate VDDIO up to
3.6V
T&R packaged, reflow-solderable7
Wide operating ranges: temperature: -40
to +85°C; humidity: 5 to 95%5; VDD: 1.71 to
1.98V; VDDIO 1.71 to 3.6V
1
eCO2 = equivalent CO2 values for compatibility with
HVAC ventilation standards
2
AQI = Air Quality Index
3
IAQ = Indoor Air Quality
2
4
T/RH compensation via external T/RH-input
Non-condensing
6
HVAC = Heat, Ventilation and Air Conditioning
7
See section “Soldering Information” for further details
5
ENS160 Datasheet v0.95 preliminary / December 2020
Content Guide
Key Features & Benefits .................... 2
14.2.2
SPI Timing Information ......... 21
Applications .................................. 2
14.2.3
SPI Read Operation.............. 22
Properties ..................................... 2
14.2.4
SPI Write Operation ............. 22
1
Block Diagram ............................ 4
15 Operation ............................... 23
2
Pin Assignment ........................... 5
16 Registers ................................ 24
3
Absolute Maximum Ratings ............. 6
16.1 Register Overview .................. 24
4
Electrical Characteristics ............... 7
16.2 Detailed Register Description ..... 25
5
Air Quality Signal Characteristics ..... 8
16.2.1
PART_ID (Address 0x00) ........ 25
5.1
TVOC – Total Volatile Organic
Compounds ............................ 8
16.2.2
OPMODE (Address 0x10) ........ 25
5.2
eCO2 – Equivalent CO2 ................ 8
16.2.3
CONFIG (Address 0x11) ......... 25
5.3
AQI-UBA – Air Quality Index of the
UBA ................................... 10
16.2.4
COMMAND (Address 0x12) ...... 26
16.2.5
TEMP_IN (Address 0x13) ........ 27
6
Single Gas Signal Characteristics .... 11
16.2.6
RH_IN (Address 0x15) ........... 27
7
Gas Sensor Raw Resistance Signals .. 12
16.2.7
DATA_STATUS (Address 0x20) . 28
8
Signal Conditioning .................... 14
16.2.8
DATA_AQI (Address 0x21) ...... 28
8.1
Baselining ............................ 14
16.2.9
DATA_TVOC (Address 0x22) .... 29
8.2
Humidity Behavior & Compensation
.................................... 14
16.2.10 DATA_ECO2 (Address 0x24) .... 29
Output Signal Accuracy ............... 15
16.2.12 DATA_T (Address 0x30) ......... 29
10 Initial Start-Up and Warm-Up ........ 15
16.2.13 DATA_RH (Address 0x32) ....... 30
10.1 Initial Start-Up ...................... 15
16.2.14 DATA_MISR (Address 0x38) ..... 30
10.2 Warm-Up ............................. 15
16.2.15 GPR_WRITE (Address 0x40) .... 31
11 Gas Sensor Status and Signal Rating 16
16.2.16 GPR_READ (Address 0x48) ...... 32
12 Recommended Sensor Operation .... 16
17 Application Information .............. 33
13 Recommended Sensor Storage ....... 16
17.1 I2C Operation Circuitry ............. 33
14 Host Communication .................. 17
17.2 SPI Operation Circuitry............. 34
9
2
14.1 I C Specification .................... 17
14.1.1
14.1.2
16.2.11 DATA_ETOH (Address 0x22) .... 29
18 Soldering Information ................. 35
2
19 Package Drawings & Markings ........ 36
2
I C Description ................... 17
I C I/O and Timing Information 17
14.1.3
I C Read Operation .............. 19
20 RoHS Compliance & ScioSense Green
Statement .............................. 38
14.1.4
I2C Write Operation ............. 20
21 Copyrights & Disclaimer .............. 38
14.2 SPI Specification .................... 21
22 Document Status ....................... 39
14.2.1
23 Revision Information .................. 39
2
SPI Description ................... 21
3
1
Block Diagram
The ENS160 digital multi-gas sensor consists of four independent heaters and gas sensor
elements, based on metal oxide (MOX) technology and a controller as shown in the functional
block diagram below.
Figure 1: Functional Blocks
ENS160
4 Independent Sensors
Heaters
VDD
Sensors
VDDIO
GND
Controller
Heater Driver
x4
Sensor Measurement
x4
INTn
CSn
SCL (SCLK)
SDA (MOSI)
I2C
(SPI)
System Control
Memory
Data Processing
ADDR (MISO)
The Heater Driver controls the sensor operating modes and provides power to the heaters
of each individual sensor element. During operation the heater driver regulates the heaters
to their individual set-points.
The Sensor Measurement block determines the value of the sensor resistance for each
The System Control block processes the resistance values internally to output calculated
TVOC, CO2-equivalents, AQIs and further signals on the digital interface.
The ENS160 includes a standard 2-wire digital I2C interface (SCL, SDA) or 4-wire digital SPI
interface (SCLK, MOSI, MISO, CSn) for communication to the main host processor.
On-chip memory is used to store calibration values.
4
2
Pin Assignment
Figure 2: Pin Diagram
Bottom View
Top View
Pin 1 Corner
Corner Area
1
8
7
3
4
5
2
9
6
2
9
6
3
4
5
1
8
7
Pin 1 Corner
Corner Area
Table 1: Pin Description
Pins
Pin Name
Pin Type
1
MOSI / SDA
Input / Output
2
SCLK / SCL
Input
3
MISO / ADDR
Input / Output
4
5
6
7
8, 9
VDD
VDDIO
INTn
CSn
VSS
Supply
Supply
Output
Input
Supply
Description
SPI Master Output Slave Input / I²C Bus Bi-Directional
Data
SPI Serial Clock / I²C Bus Serial Clock Input
SPI Master Input Slave Output / I²C Address Select:
I2C ADDR pin high -> 0x53 / ADDR pin low -> 0x52
Main Supply Voltage
Interface Supply Pins
Interrupt to Host
SPI Interface Select (CSn low -> SPI / CSn high -> I2C)
Ground Supply Voltage
Also see sections “I2C Operation Circuitry” and “SPI Operation Circuitry” for wiring.
5
3
Table 2: Absolute Maximum Ratings
Symbol
VDD
VDDIO
VIO1
VIO2
VSS
ISCR
ESDHBM
ESDCDM
MSL
TBODY
TSTRG
RHSTRG
TAMB1
RHAMB1
Parameter
Supply Voltage
I/O Interface Supply
MOSI/SDA, SCLK/SCL
MISO/ADDR, INTn, CSn
Input Ground
Input Current (latch-up
immunity)
Min
Max
Electrical Parameters
-0.3
1.98
-0.3
3.6
-0.3
3.6
-0.3
VDDIO+0.3
-0.3
0.3
Units
± 100
Electrostatic Discharge
Electrostatic Discharge HBM
± 2000
Electrostatic Discharge CDM
± 750
Operating and Storage Conditions
Moisture Sensitivity Level
1
Max. Package Body
260
Temperature
Storage Temperature
-40
125
Storage Relative Humidity
5
95
Operating Ambient
-40
85
Temperature
Operating Ambient Rel.
5
95
Humidity
Comments
V
V
V
V
V
mA
V
V
AEC-Q100-004
JS-001-2014
JS-002-2014
Unlimited floor lifetime
°C
IPC/JEDEC J-STD-020
°C
Non-condensing
°C
Non-condensing
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage
to the device. These are stress ratings only. Functional operation of the device at these or
any other conditions beyond those indicated under Electrical Characteristics is not implied.
Exposure to absolute maximum rating conditions for extended periods may affect device
reliability and lifetime.
Important Note: The ENS160 is not designed for use in safety-critical or life-protecting
applications.
1
The ENS160 is electrically operable in this range, however its gas sensing performance might vary. Please refer to “Recommended Sensor Operation” for further information.
6
4
The following figure details the electrical characteristics of the ENS160.
Table 3: Electrical Characteristics
Symbol
VDD
VDDIO
IDD
IDD_PK
VIH
VIL
VOH
VOL
Parameter
Positive supply
IO Supply
Voltage
Average1 Supply
Current2
Peak Supply
Current4
High-level input
voltage
Low-level input
voltage
High-level
output voltage
Low-level
output voltage
Conditions
Min
1.71
1.71
DEEPSLEEP
(OP_MODE 0x00)3
IDLE
(OP_MODE 0x01)3
STANDARD
(OP_MODE 0x02)
STANDARD
(OP_MODE 0x02)
Typ
1.8
Max
1.98
3.6
0.01
2
mA
2.5
mA
24
mA
65
很抱歉,暂时无法提供与“ENS160”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+38.50000
- 30+37.00000
- 100+35.00000
